path: root/drivers/regulator/max1586.c
2011-01-12regulator: Report actual configured voltage to set_voltage()Mark Brown
Change the interface used by set_voltage() to report the selected value to the regulator core in terms of a selector used by list_voltage(). This allows the regulator core to know the voltage that was chosen without having to do an explict get_voltage(), which would be much more expensive as it will generally access hardware. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-01regulator: max1586 - improve the logic of choosing selectorAxel Lin
A little bit improvement in the logic of choosing selector. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-11regulator: max1586 - fix a memory leak in max1586_pmic_remove()Axel Lin
In max1586_pmic_probe(), we allocate memory for max1586. In max1586_pmic_remove(), current implementation only free rdev which is a member of struct max1586_data. Thus, there is a small memory leak when we unload the module. This patch fixes the memory leak by passing max1586 to i2c clientdata, and properly kfree(max1586) in max1586_pmic_remove(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-22regulator: fix dangling pointersWolfram Sang
Fix I2C-drivers which missed setting clientdata to NULL before freeing the structure it points to. Also fix drivers which do this _after_ the structure was freed already. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03Regulators: max1586 - annotate probe and remove methodsDmitry Torokhov
Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15regulator/max1586: fix V3 gain calculation integer overflowPhilipp Zabel
On Thu, May 28, 2009 at 10:59 AM, Mark Brown <broonie@opensource.wolfsonmicro.com> wrote: > On Thu, May 28, 2009 at 07:15:16AM +0200, Philipp Zabel wrote: >> The V3 regulator can be configured with an external resistor >> connected to the feedback pin (R24 in the data sheet) to >> increase the voltage range. >> >> For example, hx4700 has R24 = 3.32 kOhm to achieve a maximum >> V3 voltage of 1.55 V which is needed for 624 MHz CPU frequency. >> >> Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> > > Looks good. > > Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Thanks, but it turns out I hit a 32 bit integer overflow in the gain calculation. I'd like to mend that with the following patch. Now max_uV could be increased up to 4.294 V, enough to charge LiPo cells. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15regulator/max1586: support increased V3 voltage rangePhilipp Zabel
The V3 regulator can be configured with an external resistor connected to the feedback pin (R24 in the data sheet) to increase the voltage range. For example, hx4700 has R24 = 3.32 kOhm to achieve a maximum V3 voltage of 1.55 V which is needed for 624 MHz CPU frequency. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15Maxim 1586 regulator driverRobert Jarzmik
The Maxim 1586 regulator is a voltage regulator with 2 voltage outputs, specially suitable for Marvell PXA chips. One output is in the range of required VCC_CORE by the PXA27x chips, the other in the VCC_USIM required as well by PXA27x chips. The chip is controlled through the I2C bus. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
