The regmap_config struct may be const because it is not modified by the
driver and regmap_init() accepts pointer to const. Make const also
slew_rates array.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
The of_get_regulator_init_data() function is used to extract the regulator
init_data but information on how to extract certain data is defined in the
static regulator descriptor (e.g: how to map the hardware operating modes).
Add a const struct regulator_desc * parameter to the function signature so
the parsing logic could use the information in the struct regulator_desc.
of_get_regulator_init_data() relies on of_get_regulation_constraints() to
actually extract the init_data so it has to pass the struct regulator_desc
but that is modified on a later patch.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Set di->regulator before dereference it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
The vendor-id gathered from the dt match-data was cast to int but assigned
to an unsigned long, producing warnings on at least sparc, like
drivers/regulator/fan53555.c: In function 'fan53555_regulator_probe':
>> drivers/regulator/fan53555.c:373:16: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
di->vendor = (int) match->data;
Fix this by using an appropriate cast.
Reported-by: kbuild test robot
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Silergy SYR82x regulators share the exact same functionality and register layout
as the Fairchild FAN53555 regulators. Therefore extend the driver to add
support for them.
Both types use the same vendor id in their ID1 register, so it's not possible
to distinguish them automatically.
Similarly, the types also do not match. Type 8 used by the SYR827 and SYR828
start at 712.5mV and increment in 12.5mv steps, while the FAN53555 type 8
starts at 600mV and increments in 10mV steps.
Add the ability to parse regulator-data from the devicetree.
The regulator constraints already provide a field for the ramp_delay, so
there is no need to set this manually. Therefore implement the set_ramp_delay
callback and convert the pdata value to the constraint value if necessary.
The regulator can be supplied by a parent regulator through its vin pin,
so add the supply_name for it.
kzalloc prints its own OOM message upon failure.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Yunfan Zhang <yfzhang@marvell.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Propagate the error values returned by the function instead.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull PTR_RET() removal patches from Rusty Russell:
"PTR_RET() is a weird name, and led to some confusing usage. We ended
up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages.
This has been sitting in linux-next for a whole cycle"
[ There are still some PTR_RET users scattered about, with some of them
possibly being new, but most of them existing in Rusty's tree too. We
have that
#define PTR_RET(p) PTR_ERR_OR_ZERO(p)
thing in <linux/err.h>, so they continue to work for now - Linus ]
* tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO
Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO
drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO
sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO
dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO
drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO
mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR().
staging/zcache: don't use PTR_RET().
remoteproc: don't use PTR_RET().
pinctrl: don't use PTR_RET().
acpi: Replace weird use of PTR_RET.
s390: Replace weird use of PTR_RET.
PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Sweep of the simple cases.
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Julia Lawall <julia.lawall@lip6.fr>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Used PTR_RET function instead of IS_ERR and PTR_ERR.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
The max voltage will be bounded by min_uV, uV_step and n_voltages, so
remove it to avoid confusing.
Signed-off-by: Yunfan Zhang <yfzhang@marvell.com>
Reviewed-by: Axel Lin <axel.lin@gmail.com>
This driver supports Fairchild FAN53555 Digitally Programmable
TinyBuck Regulator. The FAN53555 is a step-down switching voltage
regulator that delivers a digitally programmable output from an
input voltage supply of 2.5V to 5.5V. The output voltage is
programmed through an I2C interface.
