path: root/drivers/regulator/ad5398.c
2010-09-30i2c: Remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata-pointer on exit. This is obsolete meanwhile, so fix it and hope the word will spread. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-01regulator: ad5398 - fix a memory leakAxel Lin
In current implementation, the address return from regulator_register() is different from the address for regulator_unregister(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-11regulator: make sure the regulator is available prior to the consumers.Sonic Zhang
Some systems are likely to want this to be subsys_initcall() to make sure the regulator is available prior to the consumers. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-11regulator: new drivers for AD5398 and AD5821Sonic Zhang
The AD5398 and AD5821 are single 10-bit DAC with 120 mA output current sink capability. They feature an internal reference and operates from a single 2.7 V to 5.5 V supply. This driver supports both the AD5398 and the AD5821. It adapts into the voltage and current framework. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
