path: root/drivers/pwm/pwm-lpss-pci.c
2015-11-06pwm: lpss: Add support for runtime PMQipeng Zha
To be able to save some power when PWM is not in use, add support for runtime PM for this driver. This also allows the platform to transition to low power S0ix states when the system is idle. Signed-off-by: Huiquan Zhong <huiquan.zhong@intel.com> Signed-off-by: Qipeng Zha <qipeng.zha@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2015-11-06pwm: lpss: Add more Intel Broxton IDsMika Westerberg
Add more Intel Broxton ACPI and PCI IDs to the driver supported devices list. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2015-11-06pwm: lpss: Support all four PWMs on Intel BroxtonMika Westerberg
Intel Broxton has similar PWM than Intel Braswell but instead of one it has four PWMs included in one PCI/ACPI device. This patch adds support for all the four PWMs and changes the PCI part of the driver to use 'pwm_lpss_bxt_info' instead. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2015-06-12pwm: lpss: pci: Add support for Broxton platformQipeng Zha
Add PCI device IDs for Broxton platform. Signed-off-by: Qipeng Zha <qipeng.zha@intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-08-23pwm: lpss: pci: Move to use pcim_enable_device()Andy Shevchenko
Let's use managed functions for this driver. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-08-23pwm: lpss: Properly split driver to partsAndy Shevchenko
The driver consists of core, PCI, and platform parts. It would be better to split them into separate files. The platform driver is now called pwm-lpss-platform. Thus, previously set CONFIG_PWM_LPSS=m is not enough to build it. But we are on the safe side since it seems no one from outside Intel is using it for now. While here, move to use macros module_pci_driver() and module_platform_driver(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Alan Cox <alan@linux.intel.com> [thierry.reding: change select to depends on PWM_LPSS, cleanup] Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
