path: root/drivers/ptp/ptp_chardev.c
2015-03-31ptp: remove 32 bit get/set methods.Richard Cochran
All of the PHC drivers have been converted to the new methods. This patch converts the three remaining callers within the core code and removes the older methods for good. As a result, the core PHC code is ready for the year 2038. However, some of the PHC drivers are not quite ready yet. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ptp: use the 64 bit gettime method for the SYS_OFFSET ioctl.Richard Cochran
This patch changes the code to use the new method whenever implemented by the PHC driver. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-01ptp: Allow reassigning calibration pin functionStefan Sørensen
The ptp pin function programming does not allow calibration pin to change function. This is problematic on hardware that uses the default calibration pin for other purposes. Removing this limitation does not impact calibration if userspace does not reprogram the calibration pin. Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-21ptp: introduce programmable pins.Richard Cochran
This patch adds a pair of new ioctls to the PTP Hardware Clock device interface. Using the ioctls, user space programs can query each pin to find out its current function and also reprogram a different function if desired. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-26ptp: reduce stack usage when measuring the system time offsetRichard Cochran
This patch removes the large buffer from the stack of the system offset ioctl and replaces it with a kmalloced buffer. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-26ptp: reduce stack usage when reading external time stampsRichard Cochran
This patch removes the large buffer from the stack of the read file operation and replaces it with a kmalloced buffer. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01ptp: add an ioctl to compare PHC time with system timeRichard Cochran
This patch adds an ioctl for PTP Hardware Clock (PHC) devices that allows user space to measure the time offset between the PHC and the system clock. Rather than hard coding any kind of estimation algorithm into the kernel, this patch takes the more flexible approach of just delivering an array of raw clock readings. In that way, the user space clock servo may be adapted to new and different hardware clocks. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Jacob Keller <jacob.e.keller@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01ptp: Fix some locking bugs in ptp_read()Dan Carpenter
In ptp_read there is an unlock missing on an error path, and a double unlock on another error path. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-01ptp: Return -EFAULT on copy_to_user() errorsDan Carpenter
copy_to_user() returns the number of bytes remaining, but we want a negative error code in ptp_ioctl. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23ptp: Added a brand new class driver for ptp clocks.Richard Cochran
This patch adds an infrastructure for hardware clocks that implement IEEE 1588, the Precision Time Protocol (PTP). A class driver offers a registration method to particular hardware clock drivers. Each clock is presented as a standard POSIX clock. The ancillary clock features are exposed in two different ways, via the sysfs and by a character device. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John Stultz <john.stultz@linaro.org>
