git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next
Pull MFD update from Samuel Ortiz:
"For 3.10 we have a few new MFD drivers for:
- The ChromeOS embedded controller which provides keyboard, battery
and power management services. This controller is accessible
through i2c or SPI.
- Silicon Laboratories 476x controller, providing access to their FM
chipset and their audio codec.
- Realtek's RTS5249, a memory stick, MMC and SD/SDIO PCI based
reader.
- Nokia's Tahvo power button and watchdog device. This device is
very similar to Retu and is thus supported by the same code base.
- STMicroelectronics STMPE1801, a keyboard and GPIO controller
supported by the stmpe driver.
- ST-Ericsson AB8540 and AB8505 power management and voltage
converter controllers through the existing ab8500 code.
Some other drivers got cleaned up or improved. In particular:
- The Linaro/STE guys got the ab8500 driver in sync with their
internal code through a series of optimizations, fixes and
improvements.
- The AS3711 and OMAP USB drivers now have DT support.
- The arizona clock and interrupt handling code got improved.
- The wm5102 register patch and boot mechanism also got improved."
* tag 'mfd-3.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (104 commits)
mfd: si476x: Don't use 0bNNN
mfd: vexpress: Handle pending config transactions
mfd: ab8500: Export ab8500_gpadc_sw_hw_convert properly
mfd: si476x: Fix i2c warning
mfd: si476x: Add header files and Kbuild plumbing
mfd: si476x: Add chip properties handling code
mfd: si476x: Add the bulk of the core driver
mfd: si476x: Add commands abstraction layer
mfd: rtsx: Support RTS5249
mfd: retu: Add Tahvo support
mfd: ucb1400: Pass ucb1400-gpio data through ac97 bus
mfd: wm8994: Add some OF properties
mfd: wm8994: Add device ID data to WM8994 OF device IDs
input: Export matrix_keypad_parse_of_params()
mfd: tps65090: Add compatible string for charger subnode
mfd: db8500-prcmu: Support platform dependant device selection
mfd: syscon: Fix warnings when printing resource_size_t
of: Add stub of_get_parent for non-OF builds
mfd: omap-usb-tll: Convert to devm_ioremap_resource()
mfd: omap-usb-host: Convert to devm_ioremap_resource()
This patch fixing units (1/10 °C) in which is temperature reported.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Anton Vorontsov <anton@enomsg.org>
Tell twl4030_madc_conversion that this driver needs raw values.
Driver twl4030_madc has some hardcoded values and conversation
functions which are incorrect for Nokia RX-51 board. This driver
rx51_battery expects raw values which convert itself.
This patch fixing values reported by power supply interface.
Before this patch driver reported always incorrect values on
3.8 kernel (sometimes design capacity was negative).
Acked-by: Anton Vorontsov <anton@enomsg.org>
Use devm_kzalloc() to make cleanup paths more simple.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitconst,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Jamie Lentin <jm@lentin.co.uk>
Cc: Jason Cooper <jason@lakedaemon.net>
This driver exporting battery design capacity, temperature and voltage for
battery in Nokia RX-51. This driver is needed for open source battery
management on Nokia RX-51 (N900).
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
