path: root/drivers/power/88pm860x_battery.c
2014-10-20power: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-06-0688pm860x_battery: Remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-01-0688pm860x_battery: Eliminate possible references to released resourcesJulia Lawall
devm_kzalloc should not be followed by kfree, as this results in a double free. The problem was found using the following semantic match (http://coccinelle.lip6.fr/): // <smpl> @@ expression x,e; @@ x = devm_kzalloc(...) ... when != x = e ?-kfree(x,...); // </smpl> Furthermore, in the remove function, the calls to free_irq are moved up to prevent a possible reference in the interrupt handler to resources freed by power_supply_unregister. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2012-11-28power: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28power: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28power: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-2088pm860x_battery and charger: Fix a few post-merge issuesAnton Vorontsov
Sparse complains: CHECK drivers/power/88pm860x_battery.c drivers/power/88pm860x_battery.c:128:5: warning: symbol 'array_soc' was not declared. Should it be static? CHECK drivers/power/88pm860x_charger.c drivers/power/88pm860x_charger.c:640:3: warning: symbol 'pm860x_irq_descs' was not declared. Should it be static? CHECK drivers/mfd/88pm860x-core.c drivers/mfd/88pm860x-core.c:803:53: warning: incorrect type in assignment (different base types) drivers/mfd/88pm860x-core.c:803:53: expected struct charger_regulator *charger_regulators drivers/mfd/88pm860x-core.c:803:53: got struct regulator_bulk_data static [toplevel] * The issues are minor, except for the last one. We seemed to use 'regulator_bulk_data' struct (just as charger manager documentation wrongly tells us), but in real it should have been 'struct charger_regulator'. The only reason that it worked is because both 'supply' and 'regulator_name' struct members are the first in these structs. :-) Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
2012-09-20power_supply: Enable battery-charger for 88pm860xJett.Zhou
There are charger and battery measurement feature for 88pm860x PMIC. For charger, it can support pre-charge with small current when battery is nearly exausted and then changed into fast-charge with CC&CV mode. For battery monitor, it can support battery measurement such as vbat,vsys,vchg and ibat etc,it can aslo accumulating the Coulomb value charged or discharged from battery based on Conlomb Counter, we use it to estimate battery capacity. Signed-off-by: Jett.Zhou <jtzhou@marvell.com> Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
