path: root/drivers/pnp
2008-07-16PNPACPI: add support for HP vendor-specific CCSR descriptorsBjorn Helgaas
The HP CCSR descriptor describes MMIO address space that should appear as a MEM resource. This patch adds support for parsing these descriptors in the _CRS data. The visible effect of this is that these MEM resources will appear in /sys/devices/pnp0/.../resources, which means that "lspnp -v" will report it, user applications can use this to locate device CSR space, and kernel drivers can use the normal PNP resource accessors to locate them. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: avoid legacy IDE IRQsBjorn Helgaas
If an IDE controller is in compatibility mode, it expects to use IRQs 14 and 15, so PNP should avoid them. This patch should resolve this problem report: parallel driver grabs IRQ14 preventing legacy SFF ATA controller from working https://bugzilla.novell.com/show_bug.cgi?id=375836 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: convert resource options to single linked listBjorn Helgaas
ISAPNP, PNPBIOS, and ACPI describe the "possible resource settings" of a device, i.e., the possibilities an OS bus driver has when it assigns I/O port, MMIO, and other resources to the device. PNP used to maintain this "possible resource setting" information in one independent option structure and a list of dependent option structures for each device. Each of these option structures had lists of I/O, memory, IRQ, and DMA resources, for example: dev independent options ind-io0 -> ind-io1 ... ind-mem0 -> ind-mem1 ... ... dependent option set 0 dep0-io0 -> dep0-io1 ... dep0-mem0 -> dep0-mem1 ... ... dependent option set 1 dep1-io0 -> dep1-io1 ... dep1-mem0 -> dep1-mem1 ... ... ... This data structure was designed for ISAPNP, where the OS configures device resource settings by writing directly to configuration registers. The OS can write the registers in arbitrary order much like it writes PCI BARs. However, for PNPBIOS and ACPI devices, the OS uses firmware interfaces that perform device configuration, and it is important to pass the desired settings to those interfaces in the correct order. The OS learns the correct order by using firmware interfaces that return the "current resource settings" and "possible resource settings," but the option structures above doesn't store the ordering information. This patch replaces the independent and dependent lists with a single list of options. For example, a device might have possible resource settings like this: dev options ind-io0 -> dep0-io0 -> dep1->io0 -> ind-io1 ... All the possible settings are in the same list, in the order they come from the firmware "possible resource settings" list. Each entry is tagged with an independent/dependent flag. Dependent entries also have a "set number" and an optional priority value. All dependent entries must be assigned from the same set. For example, the OS can use all the entries from dependent set 0, or all the entries from dependent set 1, but it cannot mix entries from set 0 with entries from set 1. Prior to this patch PNP didn't keep track of the order of this list, and it assigned all independent options first, then all dependent ones. Using the example above, that resulted in a "desired configuration" list like this: ind->io0 -> ind->io1 -> depN-io0 ... instead of the list the firmware expects, which looks like this: ind->io0 -> depN-io0 -> ind-io1 ... Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16ISAPNP: handle independent options following dependent onesBjorn Helgaas
The ISAPNP spec recommends that independent options precede dependent ones, but this is not actually required. The current ISAPNP code incorrectly puts such trailing independent options at the end of the last dependent option list. This patch fixes that bug by resetting the current option list to the independent list when we see an "End Dependent Functions" tag. PNPBIOS and PNPACPI handle this the same way. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: remove extra 0x100 bit from option priorityBjorn Helgaas
When building resource options, ISAPNP and PNPBIOS set the priority to something like "0x100 | PNP_RES_PRIORITY_ACCEPTABLE", but we immediately mask off the 0x100 again in pnp_build_option(), so that bit looks superfluous. Thanks to Rene Herman <rene.herman@gmail.com> for pointing this out. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: support optional IRQ resourcesBjorn Helgaas
This patch adds an IORESOURCE_IRQ_OPTIONAL flag for use when assigning resources to a device. If the flag is set and we are unable to assign an IRQ to the device, we can leave the IRQ disabled but allow the overall resource allocation to succeed. Some devices request an IRQ, but can run without an IRQ (possibly with degraded performance). This flag lets us run the device without the IRQ instead of just leaving the device disabled. This is a reimplementation of this previous change by Rene Herman <rene.herman@gmail.com>: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=3b73a223661ed137c5d3d2635f954382e94f5a43 I reimplemented this for two reasons: - to prepare for converting all resource options into a single linked list, as opposed to the per-resource-type lists we have now, and - to preserve the order and number of resource options. In PNPBIOS and ACPI, we configure a device by giving firmware a list of resource assignments. It is important that this list has exactly the same number of resources, in the same order, as the "template" list we got from the firmware in the first place. The problem of a sound card MPU401 being left disabled for want of an IRQ was reported by Uwe Bugla <uwe.bugla@gmx.de>. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: rename pnp_register_*_resource() local variablesBjorn Helgaas
No functional change; just rename "data" to something more descriptive. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNPACPI: ignore _PRS interrupt numbers larger than PNP_IRQ_NRBjorn Helgaas
ACPI Extended Interrupt Descriptors can encode 32-bit interrupt numbers, so an interrupt number may exceed the size of the bitmap we use to track possible IRQ settings. To avoid corrupting memory, complain and ignore too-large interrupt numbers. There's similar code in pnpacpi_parse_irq_option(), but I didn't change that because the small IRQ descriptor can only encode IRQs 0-15, which do not exceed bitmap size. In the future, we could handle IRQ numbers greater than PNP_IRQ_NR by replacing the bitmap with a table or list. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: centralize resource option allocationsBjorn Helgaas
This patch moves all the option allocations (pnp_mem, pnp_port, etc) into the pnp_register_{mem,port,irq,dma}_resource() functions. This will make it easier to rework the option data structures. The non-trivial part of this patch is the IRQ handling. The backends have to allocate a local pnp_irq_mask_t bitmap, populate it, and pass a pointer to pnp_register_irq_resource(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: remove redundant pnp_can_configure() checkBjorn Helgaas
pnp_assign_resources() is static and the only caller checks pnp_can_configure() before calling it, so no need to do it again. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: make resource assignment functions return 0 (success) or -EBUSY (failure)Bjorn Helgaas
This patch doesn't change any behavior; it just makes the return values more conventional. This changes pnp_assign_dma() from a void function to one that returns an int, just like the other assignment functions. For now, at least, pnp_assign_dma() always returns 0 (success), so it appears to never fail, just like before. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: in debug resource dump, make empty list obviousBjorn Helgaas
If the resource list is empty, say that explicitly. Previously, it was confusing because often the heading was followed by zero resource lines, then some "add resource" lines from auto-assignment, so the "add" lines looked like current resources. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: improve resource assignment debugBjorn Helgaas
When we fail to assign an I/O or MEM resource, include the min/max in the debug output to help match it with the options. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: increase I/O port & memory option address sizesBjorn Helgaas
ACPI Address Space Descriptors can be up to 64 bits wide. We should keep track of the whole thing when parsing resource options, so this patch changes PNP port and mem option fields from "unsigned short" and "unsigned int" to "resource_size_t". Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: introduce pnp_irq_mask_t typedefBjorn Helgaas
This adds a typedef for the IRQ bitmap, which should cause no functional change, but will make it easier to pass a pointer to a bitmap to pnp_register_irq_resource(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: make resource option structures private to PNP subsystemBjorn Helgaas
Nothing outside the PNP subsystem should need access to a device's resource options, so this patch moves the option structure declarations to a private header file. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: define PNP-specific IORESOURCE_IO_* flags alongside IRQ, DMA, MEMBjorn Helgaas
PNP previously defined PNP_PORT_FLAG_16BITADDR and PNP_PORT_FLAG_FIXED in a private header file, but put those flags in struct resource.flags fields. Better to make them IORESOURCE_IO_* flags like the existing IRQ, DMA, and MEM flags. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: whitespace/coding style fixesBjorn Helgaas
No functional change; just make a couple declarations consistent with the rest of the file. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: add pnp_possible_config() -- can a device could be configured this way?Bjorn Helgaas
As part of a heuristic to identify modem devices, 8250_pnp.c checks to see whether a device can be configured at any of the legacy COM port addresses. This patch moves the code that traverses the PNP "possible resource options" from 8250_pnp.c to the PNP subsystem. This encapsulation is important because a future patch will change the implementation of those resource options. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: dont sort by type in /sys/.../resourcesBjorn Helgaas
Rather than stepping through all IO resources, then stepping through all MMIO resources, etc., we can just iterate over the resource list once directly. This can change the order in /sys, e.g., # cat /sys/devices/pnp0/00:07/resources # OLD state = active io 0x3f8-0x3ff irq 4 # cat /sys/devices/pnp0/00:07/resources # NEW state = active irq 4 io 0x3f8-0x3ff The old code artificially sorted resources by type; the new code just lists them in the order we read them from the ISAPNP hardware or the BIOS. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: remove ratelimit on add resource failuresBjorn Helgaas
We used to have a fixed-size resource table. If a device had twenty resources when the table only had space for ten, we didn't need ten warnings, so we added the ratelimit. Now that we can dynamically allocate new resources, we should only get failures if the allocation fails. That should be rare enough that we don't need to ratelimit the messages. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNPACPI: keep disabled resources when parsing current configBjorn Helgaas
When we parse a device's _CRS data (the current resource settings), we should keep track of everything we find, even if it's currently disabled or invalid. This is what we already do for ISAPNP and PNPBIOS, and it helps keep things matched up when we subsequently re-encode resources. For example, consider a device with (mem, irq0, irq1, io), where irq0 is disabled. If we drop irq0 when parsing the _CRS, we will mistakenly put irq1 in the irq0 slot when we encode resources for an _SRS call. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: replace pnp_resource_table with dynamically allocated resourcesBjorn Helgaas
PNP used to have a fixed-size pnp_resource_table for tracking the resources used by a device. This table often overflowed, so we've had to increase the table size, which wastes memory because most devices have very few resources. This patch replaces the table with a linked list of resources where the entries are allocated on demand. This removes messages like these: pnpacpi: exceeded the max number of IO resources 00:01: too many I/O port resources References: http://bugzilla.kernel.org/show_bug.cgi?id=9535 http://bugzilla.kernel.org/show_bug.cgi?id=9740 http://lkml.org/lkml/2007/11/30/110 This patch also changes the way PNP uses the IORESOURCE_UNSET, IORESOURCE_AUTO, and IORESOURCE_DISABLED flags. Prior to this patch, the pnp_resource_table entries used the flags like this: IORESOURCE_UNSET This table entry is unused and available for use. When this flag is set, we shouldn't look at anything else in the resource structure. This flag is set when a resource table entry is initialized. IORESOURCE_AUTO This resource was assigned automatically by pnp_assign_{io,mem,etc}(). This flag is set when a resource table entry is initialized and cleared whenever we discover a resource setting by reading an ISAPNP config register, parsing a PNPBIOS resource data stream, parsing an ACPI _CRS list, or interpreting a sysfs "set" command. Resources marked IORESOURCE_AUTO are reinitialized and marked as IORESOURCE_UNSET by pnp_clean_resource_table() in these cases: - before we attempt to assign resources automatically, - if we fail to assign resources automatically, - after disabling a device IORESOURCE_DISABLED Set by pnp_assign_{io,mem,etc}() when automatic assignment fails. Also set by PNPBIOS and PNPACPI for: - invalid IRQs or GSI registration failures - invalid DMA channels - I/O ports above 0x10000 - mem ranges with negative length After this patch, there is no pnp_resource_table, and the resource list entries use the flags like this: IORESOURCE_UNSET This flag is no longer used in PNP. Instead of keeping IORESOURCE_UNSET entries in the resource list, we remove entries from the list and free them. IORESOURCE_AUTO No change in meaning: it still means the resource was assigned automatically by pnp_assign_{port,mem,etc}(), but these functions now set the bit explicitly. We still "clean" a device's resource list in the same places, but rather than reinitializing IORESOURCE_AUTO entries, we just remove them from the list. Note that IORESOURCE_AUTO entries are always at the end of the list, so removing them doesn't reorder other list entries. This is because non-IORESOURCE_AUTO entries are added by the ISAPNP, PNPBIOS, or PNPACPI "get resources" methods and by the sysfs "set" command. In each of these cases, we completely free the resource list first. IORESOURCE_DISABLED In addition to the cases where we used to set this flag, ISAPNP now adds an IORESOURCE_DISABLED resource when it reads a configuration register with a "disabled" value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: add pnp_resource_type_name() helper functionBjorn Helgaas
This patch adds a "pnp_resource_type_name(struct resource *)" that returns the string resource type. This will be used by the sysfs "show resources" function and the debug resource dump function. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: add pnp_resource_type() internal interfaceBjorn Helgaas
Given a struct resource, this returns the type (IO, MEM, IRQ, DMA). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: remove pnp_resource.indexBjorn Helgaas
We used pnp_resource.index to keep track of which ISAPNP configuration register a resource should be written to. We needed this only to handle the case where a register is disabled but a subsequent register in the same set is enabled. Rather than explicitly maintaining the pnp_resource.index, this patch adds a resource every time we read an ISAPNP configuration register and marks the resource as IORESOURCE_DISABLED when appropriate. This makes the position in the pnp_resource_table always correspond to the config register index. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: add detail to debug resource dumpBjorn Helgaas
In the debug resource dump, decode the flags and indicate when a resource is disabled or has been automatically assigned. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI PM: acpi_pm_device_sleep_state() cleanupDavid Brownell
Get rid of a superfluous acpi_pm_device_sleep_state() parameter. The only legitimate value of that parameter must be derived from the first parameter, which is what all the callers already do. (However, this does not address the fact that ACPI still doesn't set up those flags.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11PNPACPI: use _CRS IRQ descriptor length for _SRSBjorn Helgaas
When configuring the resources of an ACPI device, we first evaluate _CRS to get a template of resource descriptors, then fill in the specific resource values we want, and finally evaluate _SRS to actually configure the device. Some resources have optional fields, so the size of encoded descriptors varies depending on the specific values. For example, IRQ descriptors can be either two or three bytes long. The third byte contains triggering information and can be omitted if the IRQ is edge-triggered and active high. The BIOS often assumes that IRQ descriptors in the _SRS buffer use the same format as those in the _CRS buffer, so this patch enforces that constraint. The "Start Dependent Function" descriptor also has an optional byte, but we don't currently encode those descriptors, so I didn't do anything for those. I have tested this patch on a Toshiba Portege 4000. Without the patch, parport_pc claims the parallel port only if I use "pnpacpi=off". This patch makes it work with PNPACPI. This is an extension of a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c42 References: http://bugzilla.kernel.org/show_bug.cgi?id=5832 Enabling ACPI Plug and Play in kernels >2.6.9 kills Parallel support http://bugzilla.kernel.org/show_bug.cgi?id=9487 buggy firmware expects four-byte IRQ resource descriptor (was: Serial port disappears after Suspend on Toshiba R25) http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=1d5b285da1893b90507b081664ac27f1a8a3dc5b related ACPICA fix Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11pnpacpi: fix shareable IRQ encode/decodeBjorn Helgaas
When we encode IRQ resources, we should use the "shareable" flag we got from _PRS rather than guessing based on the IRQ trigger mode. This is based on a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11pnpacpi: fix IRQ flag decodingBjorn Helgaas
When decoding IRQ trigger mode and polarity, it is not enough to mask by IORESOURCE_BITS because there are now additional bits defined. For example, if IORESOURCE_IRQ_SHAREABLE was set, we failed to set *triggering and *polarity at all. I can't point to a failure that this patch fixes, but bugs in this area have caused problems when resuming after suspend, for example: http://bugzilla.kernel.org/show_bug.cgi?id=6316 http://bugzilla.kernel.org/show_bug.cgi?id=9487 https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/152187 This is based on a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32 [rene.herman@keyaccess.nl: fix comment] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-05PNP: skip UNSET MEM resources as well as DISABLED onesBjorn Helgaas
We don't need to reserve "unset" resources. Trying to reserve them results in messages like this, which are ugly but harmless: system 00:08: iomem range 0x0-0x0 could not be reserved Future PNP patches will remove use of IORESOURCE_UNSET, but we still need it for now. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-02PNP: mark resources that conflict with PCI devices "disabled"Bjorn Helgaas
Both the PNP/PCI conflict detection quirk and the PNP system driver must use the same mechanism to mark resources as disabled. I think it's best to keep the resource and to keep the type bit (IORESOURCE_MEM, etc), so that we match the list from firmware as closely as possible. Fixes this regression from 2.6.25: http://lkml.org/lkml/2008/6/1/82 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Tested-by: Avuton Olrich <avuton@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-15Clean up 'print_fn_descriptor_symbol()' typesLinus Torvalds
Everybody wants to pass it a function pointer, and in fact, that is what you _must_ pass it for it to make sense (since it knows that ia64 and ppc64 use descriptors for function pointers and fetches the actual address from there). So don't make the argument be a 'unsigned long' and force everybody to add a cast. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14lib: create common ascii hex arrayHarvey Harrison
Add a common hex array in hexdump.c so everyone can use it. Add a common hi/lo helper to avoid the shifting masking that is done to get the upper and lower nibbles of a byte value. Pull the pack_hex_byte helper from kgdb as it is opencoded many places in the tree that will be consolidated. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: add ISAPnP MPU option quirksRene Herman
The AD181x and AZT230 chips don't support an IRQ-less MPU401 option but work fine without one. This adds (priority functional) IRQ-less options for each port option to help systems with few available IRQs. The AD1815 quirk can't use pnp_register_irq_resource() due to doubly penalizing the IRQ. Also, while not a practical issue due to no IRQ option being present for the dependents, this needs to add in front, not back. Doesn't use pnp_register_port_resource() for symetry with above. This does not delete the AD1815 independent option even though it should be empty after the IRQ transfer due to AD1816 coming with an empty but still present independent option by default. Was tested on AD1815, AD1816 and AZT2320. The ALSA snd-ad1818a driver also support the AZT2002 ID for MPU401 but this doesn't as I was unable to test it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: add pnp_build_option() to the APIRene Herman
The subsequent AD181x quirk patch would like this as part of the API. pnp_register_dependent_option() adds to the same dependent chain the quirk is walking which is fairly unclean. This enables a private option chain build which it can then just add onto the end when done. Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: clean up pnp_fixup_device()Rene Herman
Make it look a bit more like pci_fixup_device/pci_do_fixups. Also print the PnP ID and delete the () from the "foo+0x0/0x1234()". Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13PNP: set IRQ index in sysfs "set irq" interfaceBjorn Helgaas
We have to set the ISAPNP register index when setting an IRQ via the sysfs interface. We already do it for IO, MEM, and DMA resources; I just missed the IRQ one. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01PNP: fix printk format warningsRandy Dunlap
next-20080430/drivers/pnp/pnpbios/rsparser.c:594: warning: format '%d' expects type 'int', but argument 4 has type 'resource_size_t' next-20080430/drivers/pnp/pnpbios/rsparser.c:605: warning: format '%d' expects type 'int', but argument 4 has type 'resource_size_t' [joe@perches.com: fix it] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge branch 'pnp' into releaseLen Brown
2008-04-30acpi: fix section mismatch warning in pnpacpiSam Ravnborg
Fix following section mismatch warning: WARNING: vmlinux.o(.text+0x153d69): Section mismatch in reference from the function is_exclusive_device() to the variable .init.data:excluded_id_list is_exclusive_device is only used from __init context so document this with the __init annotation and get rid of the warning. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29PNPBIOS: remove include/linux/pnpbios.hBjorn Helgaas
The contents of include/linux/pnpbios.h are used only inside the PNPBIOS backend, so this file doesn't need to be visible outside PNP. This patch moves the contents into an existing PNPBIOS-specific file, drivers/pnp/pnpbios/pnpbios.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29ISAPNP: remove unused pnp_dev->regs fieldBjorn Helgaas
The "regs" field in struct pnp_dev is set but never read, so remove it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: make interfaces private to the PNP coreBjorn Helgaas
The interfaces for registering protocols, devices, cards, and resource options should only be used inside the PNP core. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: move _CRS/_PRS warnings closer to the actionBjorn Helgaas
Move warnings about _CRS and _PRS problems to the place where we actually make the ACPI calls. Then we don't have to pass around acpi_status values any more than necessary. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29ISAPNP: fold isapnp_read_resources() back into isapnp_get_resources()Bjorn Helgaas
isapnp_get_resources() does very little besides call isapnp_read_resources(), so just fold them back together. Based on a patch by Rene Herman <rene.herman@gmail.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
