path: root/drivers/pinctrl/pinctrl-nomadik-db8540.c
2013-01-03Drivers: pinctrl: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Barry Song <baohua.song@csr.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15pinctrl/nomadik: db8540: split clkout groupPatrice Chotard
The clkout group is split into groups clkout1 and clkout2 which allows pins cklkout1 and clkout2 to be muxed separately. Signed-off-by: Patrice Chotard <patrice.chotard@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-09pinctrl/nomadik: db8540: fix moduartstmmux_oc4_1 pin group definition.Jean-Nicolas Graux
One group definition was missing, so add it. Signed-off-by: Jean-Nicolas Graux <jean-nicolas.graux@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-10-10pinctrl/nomadik: support other alternate-C functionsJean-Nicolas Graux
Upgrade nomadik pinctrl driver to enable selection of other alternate-C[1-4] functions on some specific ux500 SoC pins. Handling of those functions is done thanks to PRCM GPIOCR registers. This was previously managed in PRCMU driver and it was not really convenient. Idea is to provide a common way to control all alternate functions. Note that this improvement does not support the old-fashioned way used to control nomadik pins, namely the "nmk_config_pin()" function and its derivatives. Signed-off-by: Jean-Nicolas Graux <jean-nicolas.graux@stericsson.com> Reviewed-by: Philippe Langlais <philippe.langlais@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-03pinctrl/nomadik: add ASIC DB8450 pinctrl driverPatrice Chotard
This implements a subdriver for the DB8540 ASIC for the Nomadik pin controller. Signed-off-by: Patrice Chotard <patrice.chotard@stericsson.com> Reviewed-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
