path: root/drivers/pinctrl/pinctrl-ab8540.c
2013-02-10pinctrl/abx500: use direct IRQ definesLinus Walleij
Make it harder to do mistakes by introducing the actual defined ABx500 IRQ number into the IRQ cluster definitions. Deduct cluster offset from the GPIO offset to make each cluster coherent. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-10pinctrl/abx500: replace IRQ offsets with table read-in valuesLee Jones
The ABx500 GPIO controller used to provide a set of virtual contiguous IRQs for use by sub-devices, but they have been removed after a request from Mainline Maintainers. Now the AB8500 core driver deals with almost all IRQ related issues instead. The ABx500 GPIO driver is now only used to convert between GPIO and IRQ numbers which is actually quite difficult, as the ABx500 GPIO's associated IRQs are clustered together throughout the interrupt number space at irregular intervals. To solve this quandary, we have placed the read-in values into the existing cluster information table to use during conversion. Signed-off-by: Lee Jones <lee.jones@linaro.org> [Moved irq_base removal into this patch] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-06pinctrl/abx500: align GPIO cluster boundariesLee Jones
Not quite sure how this ever worked. In ab8500_gpio_to_irq() the GPIO for conversion is passed through as the second argument. If GPIO13, which is a valid GPIO for IRQ functionality, was received; it would be rejected by the following guard: GPIO_IRQ_CLUSTER(5, 12, 0); /* GPIO numbers start from 1 */ if (offset >= cluster->start && offset <= cluster->end) /* Valid GPIO for IRQ use */ Signed-off-by: Lee Jones <lee.jones@linaro.org> [Augmented to account for off-by-one problem] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-05pinctrl/abx500: add AB8540 sub-driverPatrice Chotard
Add AB8540 sub driver to the ABx500 family, pins, pin groups and gpio range. As the pin controller (also the ABx500 controllers) is an inherent part of the SoC and will prevent boot if not available, select this from the Ux500 SoC Kconfig. Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Patrice Chotard <patrice.chotard@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
