path: root/drivers/pinctrl/pinconf.c
2018-12-07pinctrl: Change to use DEFINE_SHOW_ATTRIBUTE macroYangtao Li
Use DEFINE_SHOW_ATTRIBUTE macro to simplify the code. Signed-off-by: Yangtao Li <tiny.windzz@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-08-14pinctrl: check ops->pin_config_set in pinconf_set_config()Masahiro Yamada
pinconf_set_config() is called by pinctrl_gpio_set_config(). If a GPIO driver is backed by a pinctrl driver and it does not support .pin_config_set() hook, it causes NULL pointer dereference. Fixes: 15381bc7c7f5 ("pinctrl: Allow configuration of pins from gpiolib based drivers") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-08-14pinctrl: move const qualifier before structMasahiro Yamada
Update subsystem wide for consistency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-05-22pinctrl: Add spaces for better code readabilityMarkus Elfring
The script "checkpatch.pl" pointed information out like the following. CHECK: spaces preferred around that '+' (ctx:VxV) Thus fix the affected source code places. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-05-22pinctrl: Combine substrings for a message in pin_config_group_get()Markus Elfring
The script "checkpatch.pl" pointed information out like the following. WARNING: quoted string split across lines Thus fix the affected source code place. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-05-22pinctrl: Adjust five checks for null pointersMarkus Elfring
MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit The script “checkpatch.pl” pointed information out like the following. Comparison to NULL could be written !… Thus fix the affected source code places. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-05-22pinctrl: Replace two seq_printf() calls by seq_puts() in pinconf_show_map()Markus Elfring
Strings which did not contain data format specifications should be put into a sequence. Thus use the corresponding function "seq_puts". This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-05-22pinctrl: Use seq_putc() in three functionsMarkus Elfring
A single character (line break) should be put into a sequence. Thus use the corresponding function "seq_putc". This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-03-14pinctrl: Fix spelling typosAndy Shevchenko
Just fix spelling typos in comments. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-01-26pinctrl: Allow configuration of pins from gpiolib based driversMika Westerberg
When a GPIO driver is backed by a pinctrl driver the GPIO driver sometimes needs to call the pinctrl driver to configure certain things, like whether the pin is used as input or output. In addition to this there are other configurations applicable to GPIOs such as setting debounce time of the GPIO. To support this we introduce a new function pinctrl_gpio_set_config() that can be used by gpiolib based driver to pass configuration requests to the backing pinctrl driver. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-31pinctrl: pinconf: separate config parameters with commas for debugfsMasahiro Yamada
To improve debugfs readability, use commas instead of whitespaces for separating configuration parameters. For example, the "pinconf-pins" dump on my board will change as follows: Without this commit: # head -5 pinconf-pins Pin config settings per pin Format: pin (name): configs pin 0 (ED0): input bias pull down output drive strength (8 mA) input enabled pin 1 (ED1): input bias pull down output drive strength (8 mA) input enabled pin 2 (ED2): input bias pull down output drive strength (8 mA) input enabled With this commit: # head -5 pinconf-pins Pin config settings per pin Format: pin (name): configs pin 0 (ED0): input bias pull down, output drive strength (8 mA), input enabled pin 1 (ED1): input bias pull down, output drive strength (8 mA), input enabled pin 2 (ED2): input bias pull down, output drive strength (8 mA), input enabled Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-31pinctrl: do not care about blank pin nameMasahiro Yamada
If a pin name is not specified in struct pinctrl_pin_desc, pinctrl_register_one_pin() dynamically assigns its name. So, desc->name is always a valid pointer here. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-10-31pinctrl: pinconf: remove needless loopLaurent Meunier
This removes a needless loop which was caught in pinconf.c. Suggested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Laurent Meunier <laurent.meunier@st.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-03pinctrl: join dev_dbg strings into a single lineMasahiro Yamada
These are user-visible strings, so can exceed 80 columns. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17pinctrl: pinconf: pinconf_show_config() can be statickbuild test robot
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17pinctrl: pinconf: Fix display of configsJon Hunter
The function pinconf_dbg_config_print() only prints the configuration of the 1st pin config in an array of pin configurations. Fix this so that all pin configurations in the array are displayed. There are a few places in the code where the pin configs are displayed and so add a helper function to display the pin configs to simplify the code. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17pinctrl: pinconf: Allow groups to be configured via debugfsJon Hunter
The function pinconf_dbg_config_write() currently only supports configuring a pin configuration mapping via the debugfs. Allow group mappings to also be configured via the debugfs. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-11pinctrl: pinconf-generic: Allow driver to specify DT paramsSoren Brinkmann
Additionally to the generic DT parameters, allow drivers to provide driver-specific DT parameters to be used with the generic parser infrastructure. To achieve this 'struct pinctrl_desc' is extended to pass custom pinconf option to the core. In order to pass this kind of information, the related data structures - 'struct pinconf_generic_dt_params', 'pin_config_item' - are moved from pinconf internals to the pinconf-generic header. Additionally pinconfg-generic is refactored to not only iterate over the generic pinconf parameters but also take the parameters into account that are provided through the driver's 'struct pinctrl_desc'. In particular 'pinconf_generic_parse_dt_config()' and 'pinconf_generic_dump' helpers are split into two parts each. In order to have a more generic helper that can be used to process the generic parameters as well as the driver-specific ones. v2: - fix typo - add missing documentation for @conf_items member in struct - rebase to pinctrl/devel: conflict in abx500 - rename _pinconf_generic_dump() to pinconf_generic_dump_one() - removed '_' from _parse_dt_cfg() - removed BUG_ONs, error condition is handled in if statements - removed pinconf_generic_dump_group() & pinconf_generic_dump_pin helpers - fixed up corresponding call sites - renamed pinconf_generic_dump() to pinconf_generic_dump_pins() - added kernel-doc to pinconf_generic_dump_pins() - add kernel-doc - more verbose commit message Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Tested-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-13pinctrl: pinconf: remove warning: unused variable 'ops'Alexandre Belloni
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-12pinctrl: pinconf: remove checks on ops->pin_config_getAlexandre Belloni
ops->pin_config_get() is only used in one specific path that will only be taken for generic pinconf drivers (ops->is_generic == true) when dumping the pinconf by using debugfs. By removing the check in pinconf_check_ops(), let's stop pressuring people to write a pin_config_get() function that will never be used and so will probably never be tested. Removing the check in pinconf_pins_show() allows driver to not implement pin_config_get() but still get a dump of the pinconf in debugfs by implementing pin_config_dbg_show(). Finally, not implementing pin_config_get() now results in returning -ENOTSUPP instead of -EINVAL. While this doesn't have any real impact for now, this feels more right. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-23pinctrl: remove an unnecessary castDan Carpenter
sizeof() is already size_t so there is no need to cast here. Generally, casting inside the min() macro instead of using min_t() is considered bad style. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-23pinctrl: fix pinconf_dbg_config_write return typeVincent Stehlé
Have pinconf_dbg_config_write() return a ssize_t. This fixes the following compilation warning: drivers/pinctrl/pinconf.c:617:2: warning: initialization from incompatible pointer type [enabled by default] drivers/pinctrl/pinconf.c:617:2: warning: (near initialization for ‘pinconf_dbg_pinconfig_fops.write’) [enabled by default] Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-28pinctrl: Pass all configs to driver on pin_config_set()Sherman Yin
When setting pin configuration in the pinctrl framework, pin_config_set() or pin_config_group_set() is called in a loop to set one configuration at a time for the specified pin or group. This patch 1) removes the loop and 2) changes the API to pass the whole pin config array to the driver. It is now up to the driver to loop through the configs. This allows the driver to potentially combine configs and reduce the number of writes to pin config registers. All c files changed have been build-tested to verify the change compiles and that the corresponding .o is successfully generated. Signed-off-by: Sherman Yin <syin@broadcom.com> Reviewed-by: Christian Daudt <csd@broadcom.com> Reviewed-by: Matt Porter <matt.porter@linaro.org> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-07pinctrl: pinconf: fix comparison of different typesJingoo Han
Fix the following sparse warning: drivers/pinctrl/pinconf.c:521:20: error: incompatible types in comparison expression (different type sizes) Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-07pinctrl: shut up a couple of pinctrl warningsRussell King - ARM Linux
So, I notice that we get a couple of warnings from the pinctrl code: drivers/pinctrl/pinconf.c: In function 'pinconf_dbg_config_print': drivers/pinctrl/pinconf.c:433:36: warning: 'configs' may be used uninitialized in this function drivers/pinctrl/pinconf.c: In function 'pinconf_dbg_config_write': drivers/pinctrl/pinconf.c:511:36: warning: 'configs' may be used uninitialized in this function While the compiler might not be able to work out that "configs" is safe, the code doesn't lend itself very well to identifying that fact when reading it either. This can be trivially solved by a slight restructuring of the code - which also reduces the LOC. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-25pinctrl: rip out the direct pinconf APILinus Walleij
From the inception ot the pin config API there has been the possibility to get a handle at a pin directly and configure its electrical characteristics. For this reason we had: int pin_config_get(const char *dev_name, const char *name, unsigned long *config); int pin_config_set(const char *dev_name, const char *name, unsigned long config); int pin_config_group_get(const char *dev_name, const char *pin_group, unsigned long *config); int pin_config_group_set(const char *dev_name, const char *pin_group, unsigned long config); After the introduction of the pin control states that will control pins associated with devices, and its subsequent introduction to the device core, as well as the introduction of pin control hogs that can set up states on boot and optionally also at sleep, this direct pin control API is a thing of the past. As could be expected, it has zero in-kernel users. Let's delete this API and make our world simpler. Reported-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-27pinctrl: pinconf: take the right mutexLinus Walleij
The pinconf_dgb_config_print() takes the per-pincontroller mutex, when what it wants to take is actually the pin maps mutex. Reported-by: James Hogan <james.hogan@imgtec.com> Cc: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-26pinctrl: move subsystem mutex to pinctrl_dev structPatrice Chotard
This mutex avoids deadlock in case of use of multiple pin controllers. Before this modification, by using a global mutex, deadlock appeared when, for example, a call to pinctrl_pins_show() locked the pinctrl_mutex, called the ops->pin_dbg_show of a particular pin controller. If this pin controller needs I2C access to retrieve configuration information and I2C driver is using pinctrl to drive its pins, a call to pinctrl_select_state() try to lock again pinctrl_mutex which leads to a deadlock. Notice that the mutex grab from the two direction functions was moved into pinctrl_gpio_direction(). For several cases, we can't replace pinctrl_mutex by pctldev->mutex, because at this stage, pctldev is not accessible : - pinctrl_get()/pinctrl_put() - pinctrl_register_maps() So add respectively pinctrl_list_mutex and pinctrl_maps_mutex in order to protect pinctrl_list and pinctrl_maps list instead. Reintroduce pinctrldev_list_mutex in find_pinctrl_by_of_node(), pinctrl_find_and_add_gpio_range() pinctrl_request_gpio(), pinctrl_free_gpio(), pinctrl_gpio_direction(), pinctrl_devices_show(), pinctrl_register() and pinctrl_unregister() to protect pinctrldev_list. Changes v2->v3: - Fix a missing EXPORT_SYMBOL_GPL() for pinctrl_select_state(). Changes v1->v2: - pinctrl_select_state_locked() is removed, all lock mechanism is located inside pinctrl_select_state(). When parsing the state->setting list, take the per-pin-controller driver lock. (Patrice). - Introduce pinctrldev_list_mutex to protect pinctrldev_list in all functions which parse or modify pictrldev_list. (Patrice). - move find_pinctrl_by_of_node() from pinctrl/devicetree.c to pinctrl/core.c in order to protect pinctrldev_list. (Patrice). - Sink mutex:es into some functions and remove some _locked variants down to where the lists are actually accessed to make things simpler. (Linus) - Drop *all* mutexes completely from pinctrl_lookup_state() and pinctrl_select_state() - no relevant mutex was taken and it was unclear what this was protecting against. (Linus) Reported by : Seraphin Bonnaffe <seraphin.bonnaffe@stericsson.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-26pinctrl/pinconfig: fix misplaced gotoLaurent Meunier
This update contains a basic fix that went unseen through test and review. Signed-off-by: Laurent Meunier <laurent.meunier@st.com> Reviewed-by: Patrice Chotard <patrice.chotard@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-19pinctrl/pinconfig: add debug interfaceLaurent Meunier
This update adds a debugfs interface to modify a pin configuration for a given state in the pinctrl map. This allows to modify the configuration for a non-active state, typically sleep state. This configuration is not applied right away, but only when the state will be entered. This solution is mandated for us by HW validation: in order to test and verify several pin configurations during sleep without recompiling the software. Change log in this patch set; Take into account latest feedback from Stephen Warren: - stale comments update - improved code efficiency and readibility - limit size of global variable pinconf_dbg_conf - remove req_type as it can easily be added later when add/delete requests support is implemented Signed-off-by: Laurent Meunier <laurent.meunier@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-03pinctrl/pinconf: partial revert of pin config debugfsLinus Walleij
I accidentally left this patch: commit 6f9e41f4e673bf9ae6a5c0831b1524a91ea1c440 "pinctrl/pinconfig: add debug interface" in the tree though the patch was not yet finished. Revert it partially (we need the infrastructural changes). Cc: Laurent Meunier <laurent.meunier@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-07pinctrl: Declare operation structures as constLaurent Pinchart
The pinconf, pinctrl and pinmux operation structures hold function pointers that are never modified. Declare them as const. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-10pinctrl/pinconfig: add debug interfaceLaurent Meunier
This update adds a debugfs interface to modify a pin configuration for a given state in the pinctrl map. This allows to modify the configuration for a non-active state, typically sleep state. This configuration is not applied right away, but only when the state will be entered. This solution is mandated for us by HW validation: in order to test and verify several pin configurations during sleep without recompiling the software. Signed-off-by: Laurent Meunier <laurent.meunier@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-10-18pinctrl: remove mutex lock in groups showHaojian Zhuang
Mutex is locked duplicatly by pinconf_groups_show() and pin_config_group_get(). It results dead lock. So avoid to lock mutex in pinconf_groups_show(). Cc: stable@kernel.org Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-05-15pinctrl: a minor error checking improvement for pinconfDong Aisheng
Also checking invalid num_configs when validate the pinconf map. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-26pinctrl: enhance reporting of errors when loading from DTJohn Crispin
There are a few places in the api where the code simply returns -EINVAL when it finds an error. An example is pinmux_map_to_setting() which now reports an error if we try to match a group with a function that it does not support. The reporting of errors in pinconf_check_ops and pinmux_check_ops now has the same style and is located inside the according functions and not the calling code. When the map is found in the DT but the default state can not be selected we get an error to know that the code at least tried. The patch also removes a stray word from one comment and a "->" from another for the sake of consistency. Finally we replace a few pr_err/debug() calls with dev_err/dbg(). Thanks go to Stephen Warren for reviewing the patch and enhancing the reporting inside pinmux_map_to_setting(). Signed-off-by: John Crispin <blogic@openwrt.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-18pinctrl: a minor fix of pin config debug informationDong Aisheng
2012-04-18pinctrl: allow pctldevs to decode pin config in debugfsStephen Warren
Add a pinconf op so that pin controller drivers can decode their pin config settings for debugfs. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-18pinctrl: add some error checking for user interfacesDong Aisheng
This patch can avoid kernel oops in case the mux or config function is not supported by driver. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-18pinctrl: replace list_*() with get_*_count()Viresh Kumar
Most of the SoC drivers implement list_groups() and list_functions() routines for pinctrl and pinmux. These routines continue returning zero until the selector argument is greater than total count of available groups or functions. This patch replaces these list_*() routines with get_*_count() routines, which returns the number of available selection for SoC driver. pinctrl layer will use this value to check the range it can choose. This patch fixes all user drivers for this change. There are other routines in user drivers, which have checks to check validity of selector passed to them. It is also no more required and hence removed. Documentation updated as well. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Viresh Kumar <viresh.kumar@st.com> [Folded in fix and fixed a minor merge artifact manually] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-12pinctrl: introduce generic pin configLinus Walleij
This is a split-off from the earlier patch set which adds generic pin configuration for the pin controllers that want it. Since we may have a system with mixed generic and custom pin controllers, we pass a boolean in the pin controller ops vtable to indicate if it is generic. ChangeLog v1->v5: - Follow parent patch versioning number system. - Document the semantic meaning of return values from pin config get functions, so we can iterate over pins and check their properties from debugfs as part of the generic config code. - Use proper cast functions in the generic debugfs pin config file. - Expand generic config to optionally cover groups too. ChangeLog v5->v6: - Update to match underlying changes. ChangeLog v6->v7: - Drop DRIVE_OFF parameter, use bias high impedance for this - Delete argument for drive modes push-pull, od and os. These are now just state transitions. - Delete slew rate rising/falling due to discussions on on proper semantics - Drop config wakeup, struct irq_chip does this for now, add back if need be. - Set PIN_CONFIG_END to 0x7fff making room for custom config parameters from 0x8000 and up. - Prefix accessor functions with pinconf_
2012-03-12pinctrl: fix error path in pinconf_map_to_setting()Linus Walleij
The code was using the union member setting->data.configs.group_or_pin to store a potential error code, but since that member is unsigned the < 0 comparison was not true, letting errors pass through, ending up as mapped to pin "-22". Fix this up and print the error. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: enhance mapping table to support pin config operationsStephen Warren
The pinctrl mapping table can now contain entries to: * Set the mux function of a pin group * Apply a set of pin config options to a pin or a group This allows pinctrl_select_state() to apply pin configs settings as well as mux settings. v3: Fix find_pinctrl() to iterate over the correct list. s/_MUX_CONFIGS_/_CONFIGS_/ in mapping table macros. Fix documentation to use correct mapping table macro. v2: Added numerous extra PIN_MAP_*() special-case macros. Fixed kerneldoc typo. Delete pinctrl_get_pin_id() and replace it with pin_get_from_name(). Various minor fixes. Updates due to rebase. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-05pinctrl: fix and simplify lockingStephen Warren
There are many problems with the current pinctrl locking: struct pinctrl_dev's gpio_ranges_lock isn't effective; pinctrl_match_gpio_range() only holds this lock while searching for a gpio range, but the found range is return and manipulated after releading the lock. This could allow pinctrl_remove_gpio_range() for that range while it is in use, and the caller may very well delete the range after removing it, causing pinctrl code to touch the now-free range object. Solving this requires the introduction of a higher-level lock, at least a lock per pin controller, which both gpio range registration and pinctrl_get()/put() will acquire. There is missing locking on HW programming; pin controllers may pack the configuration for different pins/groups/config options/... into one register, and hence have to read-modify-write the register. This needs to be protected, but currently isn't. Related, a future change will add a "complete" op to the pin controller drivers, the idea being that each state's programming will be programmed into the pinctrl driver followed by the "complete" call, which may e.g. flush a register cache to HW. For this to work, it must not be possible to interleave the pinctrl driver calls for different devices. As above, solving this requires the introduction of a higher-level lock, at least a lock per pin controller, which will be held for the duration of any pinctrl_enable()/disable() call. However, each pinctrl mapping table entry may affect a different pin controller if necessary. Hence, with a per-pin-controller lock, almost any pinctrl API may need to acquire multiple locks, one per controller. To avoid deadlock, these would need to be acquired in the same order in all cases. This is extremely difficult to implement in the case of pinctrl_get(), which doesn't know which pin controllers to lock until it has parsed the entire mapping table, since it contains somewhat arbitrary data. The simplest solution here is to introduce a single lock that covers all pin controllers at once. This will be acquired by all pinctrl APIs. This then makes struct pinctrl's mutex irrelevant, since that single lock will always be held whenever this mutex is currently held. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: fix pinconf_groups_show() to emit newlineStephen Warren
pinconf_groups_show() wrote all debug information on one line. Fix it to match pinconf_pins_show() and be legible. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-22pinctrl: Re-order pinconf.[ch] to match each-otherStephen Warren
Modify the two files so that the order of function prototypes in the header matches the order of implementations in the .c file. Don't prototype a couple of internal functions. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-01pinctrl: delete raw device pointers in pinmux mapsLinus Walleij
After discussion with Mark Brown in an unrelated thread about ADC lookups, it came to my knowledge that the ability to pass a struct device * in the regulator consumers is just a historical artifact, and not really recommended. Since there are no in-kernel users of these pointers, we just kill them right now, before someone starts to use them. Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-26pinctrl: add checks for empty function namesTony Lindgren
This is needed as otherwise we can get the following when dealing with buggy data in a pinmux driver for pinmux_search_function: Unable to handle kernel NULL pointer dereference at virtual address 00000000 ... PC is at strcmp+0xc/0x34 LR is at pinmux_get+0x350/0x8f4 ... As we need pctldev initialized to call ops->list_functions, let's initialize it before check_ops calls and pass the pctldev to the check_ops functions. Do this for both pinmux and pinconf check_ops functions. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-20pinctrl: fix pinconf_pins_show iterationStephen Warren
Commit 706e852 "pinctrl: correct a offset while enumerating pins" modified the variable used by pinconf_pin_show()'s for loop, but didn't update the for loop test expression. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-03pinctrl: correct a offset while enumerating pinsChanho Park
This patch modifies a offset while enumerating pins to support a partial pin space. If we use a pin number for enumerating pins, the pin space always starts with zero base. Indeed, we always check the pin is in the pin space. An extreme example, there is only two pins. One is 0. Another is 1000. We always enumerate whole offsets until 1000. For solving this problem, we use the offset of the pin array instead of the zero-based pin number. Signed-off-by: Chanho Park <chanho61.park@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [Restored sparse pin space comment] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
