Dave Hinds pointed out to me that 37979e1546a7 will break b43 and
ray_cs, as IOCARD is not -- as the name would suggest -- only needed
for cards using IO ports. Instead, as it re-deines several pins, it
is also required for using interrupts.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
au100_generic and soc_common call flush_scheduled_work() spuriously.
Remove them.
This is to prepare for the deprecation and removal of
flush_scheduled_work().
Some cards need the speedups on, some need them off. As we can't detect
this reliably, at least give the users a hint how to tweak the system.
Reported-by: David Bluecame <david.bluecame@gmail.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
pcmcia_socket_dev_resume() is only referenced from macro
SET_SYSTEM_SLEEP_PM_OPS(NULL, pcmcia_socket_dev_resume)
which based on CONFIG_PM_SLEEP may or may not actually
use its second parameter.
Signed-off-by: Maciej Żenczykowski <zenczykowski@gmail.com>
pci_disable_device
- pci_release_regions called during return error path.
- pci_disable_device called for cases where earlier it was enabled.
- code duplication avoided/reduced by adding resource release at goto statements.
Signed-off-by: Rahul Ruikar <rahul.ruikar@gmail.com>
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Remove this unnecessary message -- this info is either available
in sysfs or by enabling dynamic debug from the PCMCIA core.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-scsi@vger.kernel.org
CC: linux-usb@vger.kernel.org
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding
fields in struct pcmcia_device *p_dev->resource[0,1,2] are set
accordinly. Drivers wishing to override certain settings may do so in
the callback function, but they no longer need to parse the CIS entries
stored in cistpl_cftable_entry_t themselves.
CC: linux-ide@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: linux-bluetooth@vger.kernel.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Jiri Kosina <jkosina@suse.cz>
Introduce an autoconfiguration feature to set certain values in
pcmcia_loop_config(), instead of copying the same code over and over
in each PCMCIA driver. At first, introduce the following options:
CONF_AUTO_CHECK_VCC check or matching Vcc entry
CONF_AUTO_SET_VPP set Vpp
CONF_AUTO_AUDIO enable the speaker line
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
Fill in missing descriptions and update some others for functions in
pcmcia_resource.c.
pcmcia_enable_device() now replaces pcmcia_request_configuration().
Instead of config_req_t, all necessary flags are either passed as
a parameter to pcmcia_enable_device(), or (in rare circumstances)
set in struct pcmcia_device -> flags.
With the last remaining user of include/pcmcia/cs.h gone, remove
all references.
Several drivers prefer to explicitly set config_{base,index,regs},
formerly known as ConfigBase, ConfigIndex and Present. Instead of
passing these values inside config_req_t, store it in struct
pcmcia_device.
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
The Status (CISREG_CCSR) and ExtStatus (CISREG_ESR) registers were
only accessed to enable audio output for some drivers and IRQ for
serial_cs.c. The former also required setting config_req_t.Attributes
to CONF_ENABLE_SPKR; the latter can be simplified to setting this
field to CONF_ENABLE_ESR.
The "Pin" and "Copy" configuration registers (CISREG_SCR, CISREG_PPR)
do not seem to be utilized anywhere. If a device would request a
write to these registers, "0" would be written. Continue to do so, but
warn of unexpected behavior -- and remove the "Pin" and "Copy" entries
from config_req_t.
Some drivers prefer to explicitly set Vpp. Instead of passing the
voltage inside config_req_t, store it in struct pcmcia_device.
pcmcia_modify_configuration() was only used by two drivers to fix up
one issue each: setting the Vpp to a different value, and reducing
the IO width to 8 bit. Introduce two explicitly named functions
handling these things, and remove one further typedef.
Instead of win_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[2,3,4,5] for up to four iomem
ranges. After a call to pcmcia_request_window(), the windows found there
are reserved and may be used until pcmcia_release_window() is called.
In error return path
call pci_disable_device() which was enabled earlier.
If pcmcia_request_io() only fails partly -- for the second of two
requested resources -- preserve the configuration settings for the
first one.
As the iomem / ioport setup differs per device, it is much better
to print out the device instead of the socket.
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
arch/arm/Kconfig
arch/arm/mm/Kconfig
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/palmt5.c
arch/arm/mach-pxa/palmtreo.c
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (150 commits)
MIPS: PowerTV: Separate PowerTV USB support from non-USB code
MIPS: strip the un-needed sections of vmlinuz
MIPS: Clean up the calculation of VMLINUZ_LOAD_ADDRESS
MIPS: Clean up arch/mips/boot/compressed/decompress.c
MIPS: Clean up arch/mips/boot/compressed/ld.script
MIPS: Unify the suffix of compressed vmlinux.bin
MIPS: PowerTV: Add Gaia platform definitions.
MIPS: BCM47xx: Fix nvram_getenv return value.
MIPS: Octeon: Allow more than 3.75GB of memory with PCIe
MIPS: Clean up notify_die() usage.
MIPS: Remove unused task_struct.trap_no field.
Documentation: Mention that KProbes is supported on MIPS
SAMPLES: kprobe_example: Make it print something on MIPS.
MIPS: kprobe: Add support.
MIPS: Add instrunction format for BREAK and SYSCALL
MIPS: kprobes: Define regs_return_value()
MIPS: Ritually kill stupid printk.
MIPS: Octeon: Disallow MSI-X interrupt and fall back to MSI interrupts.
MIPS: Octeon: Support 256 MSI on PCIe
MIPS: Decode core number for R2 CPUs.
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done
by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
To: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/1461/
This driver adds support for the on-board CF socket.
NR_IRQS may be as low as 16, causing a (harmless?) buffer overflow in
pcmcia_setup_isa_irq():
static u8 pcmcia_used_irq[NR_IRQS];
if ((try < 32) && pcmcia_used_irq[irq])
continue;
This is read-only, so if this address would be non-zero, it would just
mean we would not attempt an IRQ >= NR_IRQS -- which would fail anyway!
And as request_irq() fails for an irq >= NR_IRQS, the setting code path:
pcmcia_used_irq[irq]++;
is never reached as well.
Reported-by: Christoph Fritz <chf.fritz@googlemail.com>
CC: stable@kernel.org
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Insert PCMCIA device resources into the resource tree. However, this is
currently only implemented for sockets which do not statically map the
resources.
Use struct resource * also for iomem resources.
Page already had to be set to 0; Offset can easily be passed as
parameter to pcmcia_map_mem_page.
CC: Michael Buesch <mb@bu3sch.de>
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
Introduce a new field into struct pcmcia_device named "resource" and of
type struct resource *, which contains the IO port ranges allocated for
this device. Memory window ranges and registration with the resource
trees will follow at a later date.
Remove some obsolete definitions from cs.h
Use pcmcia_read_config_byte and pcmcia_write_config_byte instead
of pcmcia_access_configuration_register.
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
As we only provide one way to set up resources now, we can remove
the resource-setup-related bitfield (except resource_setup_done).
In addition, pcmcia_state only consisted of one entry, so remove
this bitfield as well.
Suggested-by: Komuro <komurojun-mbn@nifty.com>
Split up the central event handler for 16bit cards into three individual
functions.
The event callback for handling 16bit PCMCIA cards only needs to be
informed about a few events. Furthermore, send_event may already
only be called with skt->skt_mutex held, which also protects against
the module being removed behind the callback's back.
* master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6265/1: kirkwood: move qnap_tsx1x_register_flash() to .init.text
ARM: 6263/1: ns9xxx: fix FTBFS for zImage
ARM: 6262/1: arm/clps711x: fix debug macro compilation failure
ARM: 6261/1: arm/shark: fix debug macro compilation failure
ARM: 6260/1: arm/plat-spear: fix debug macro compilation failure
ARM: 6259/1: arm/ns9xxx: fix debug macro compilation failure
ARM: 6258/1: arm/h720x: fix debug macro compilation failure
ARM: 6233/1: Delete a wrong redundant right parenthesis
ARM: 6230/1: fix nuc900 touchscreen clk definition bug
[ARM] pxa: fix incorrect CONFIG_CPU_PXA27x to CONFIG_PXA27x
[ARM] pxa/colibri-pxa300: fix AC97 init
[ARM] pxa: fix incorrect order of AC97 reset pin configs
[ARM] pxa: fix frequency scaling for pcmcia/pxa2xx_base
[ARM] pxa: cpufreq-pxa2xx: fix DRI recomputation routine
[ARM] pxa/corgi: fix MMC/SD card detection failure
Up to 2.6.34 pcmcia_release_irq() reset p_dev->_irq to 0 after releasing
the irq. The IRQ is now released in pcmcia_disable_device(), however
p_dev->_irq is not reset, triggering a warning in pcmcia_device_remove().
The MCxx values must be based off memory clock, not CPU core clock.
This also fixes the bug where on some machines the LCD went crazy
while using PCMCIA.
Cc: Nicolas Pitre <nico@fluxnic.net>
Reviewed-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The "present" flag was initialized too late -- possibly, a card
was already registered at this time, so re-setting the flag to 0
caused pcmcia_dev_present() to fail.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
