path: root/drivers/pcmcia/soc_common.h
2010-12-16ARM: pxa: remove get_memclk_frequency_10khz()Eric Miao
Introduce 'struct clk' for memory and remove get_memclk_frequency_10khz(). Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: stop duplicating pci_irq in soc_pcmcia_socketRussell King - ARM Linux
skt->irq is a mere duplication of pcmcia_socket's pci_irq member. Get rid of it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socketRussell King - ARM Linux
The 'dev' member is now only ever written, so we can safely remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: constify soc_pcmcia_socket ops memberRussell King - ARM Linux
No one should modify the ops structure supplied to soc_pcmcia_socket so make it const. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: push socket probe down into SoC specific supportRussell King - ARM Linux
Move the individual socket probing and initialization down into the SoC specific support files, thereby allowing soc_common_drv_pcmcia_probe to be eliminated. soc_common.c now no longer deals with distinct groups of sockets. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: push socket removal down to SoC specific supportRussell King - ARM Linux
Mechanically transplant the removal code from soc_common into each SoC specific base support file, thereby allowing soc_common_drv_pcmcia_remove to be removed. No other changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: provide single socket add/remove functionalityRussell King - ARM Linux
Factor out the functionality for adding and removing a single socket, thereby allowing SoCs to individually register each socket. The advantage of this approach is that SoCs can then extend soc_pcmcia_socket as they wish. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-03-09[ARM] pxa: move PCMCIA definitions out of pxa-regs.h into pxa2xx_base.cEric Miao
Move the processor specific initialization (largely resources initialization) out of soc_common_drv_pcmcia_probe() into dedicated sa11xx_drv_pcmcia_probe() and __pxa2xx_drv_pcmcia_probe(). By doing this, we are now able to move the PCMCIA related definitions out of pxa-regs.h and back into pxa2xx_base.c. As a result, remove that reference of _PCMCIA1IO in arch/arm/mach-pxa/viper.c. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-08-25pcmcia: cs_internal.h is internalDominik Brodowski
cs_internal.h is meant for definitions internal to the PCMCIA core modules. It must not be included by PCMCIA socket drivers or by PCMCIA device drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: don't add extra DEBUG cflagDominik Brodowski
Use CONFIG_PCMCIA_DEBUG instead of DEBUG so that dev_dbg() and other tricks work properly. (includes bugfixes from and Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> ) Signed-off-by: Dominik Broodwski <linux@dominikbrodowski.net>
2008-06-24pcmcia: remove unused bulkmem.hMagnus Damm
The code in include/pcmcia/bulkmem.h was only kept for compatibility reasons. Therefore, move the remaining region_info_t definition to ds.h [linux@dominikbrodowski.net: do not modify the IOCTL, move definition to ds.h, and update changelog] Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-05-01drivers/pcmcia/soc_common.c: convert soc_pcmcia_sockets_lock into a mutex ↵Andrew Morton
and make it static Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-07-07[PATCH] pcmcia: remove references to pcmcia/version.hDominik Brodowski
As a follow-up, remove the inclusion of pcmcia/version.h in many files. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
