path: root/drivers/pcmcia/pd6729.c
2009-11-09pcmcia: use dev_dbg and dev_print in pd6729.cDominik Brodowski
As suggested by Wolfram Sang <w.sang@pengutronix.de>, use dev_dbg(), and dev_{err,warn,info}() in pd6729.c, and add some "\n" suggested by Komuro <komurojun-mbn@nifty.com>. In the ISR, use pr_devel() and dev_vdbg() as they are only compiled if DEBUG (or, for dev_vdbg(), VERBOSE_DEBUG) are set explicitly. CC: Komuro <komurojun-mbn@nifty.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-10-24pcmcia: do not load the pd6729 driver if io_base is NULLKomuro
The CL-PD6729 chip in some docking station is not initialized properly under Linux. In that case, do not load the pd6729 driver. [Dominik Brodowski <linux@dominikbrodowski.net>: spelling fixes, check for NULL not 0] Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-09-29PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()Rafael J. Wysocki
pcmcia_socket_dev_suspend() doesn't use its second argument, so it may be dropped safely. This change is necessary for the subsequent yenta suspend/resume fix. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2008-05-01pcmcia: silence section mismatch warnings from pci_driver variablesSam Ravnborg
Silence following warnings: WARNING: drivers/pcmcia/built-in.o(.data+0x14e0): Section mismatch in reference from the variable pd6729_pci_drv to the function .devinit.text:pd6729_pci_probe() WARNING: drivers/pcmcia/built-in.o(.data+0x14e8): Section mismatch in reference from the variable pd6729_pci_drv to the function .devexit.text:pd6729_pci_remove() WARNING: drivers/pcmcia/built-in.o(.data+0x16c0): Section mismatch in reference from the variable i82092aa_pci_drv to the function .devinit.text:i82092aa_pci_probe() WARNING: drivers/pcmcia/built-in.o(.data+0x16c8): Section mismatch in reference from the variable i82092aa_pci_drv to the function .devexit.text:i82092aa_pci_remove() Rename the variables from *_drv to *_driver so modpost ignore the OK references to __devinit/__devexit functions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14signedness: module_param_array nump argumentAl Viro
... should be unsigned int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07Driver core: convert pcmcia code to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Cc: <linux-pcmcia@lists.infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-04[PATCH] pcmcia: allow shared IRQs on pd6729 socketsKomuro
Use IRQF_PROBE_SHARED flag for request_irq() to find an unused interrupt for PCMCIA cards. Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-10-25[PATCH] CONFIG_PM=n slim: drivers/pcmcia/*Alexey Dobriyan
Remove some code which is unneeded if CONFIG_PM=n. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in pcmcia driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-21[PATCH] pd6729 section fixAndrew Morton
WARNING: drivers/pcmcia/pd6729.o - Section mismatch: reference to .init.text: from .text between 'pd6729_pci_probe' (at offset 0x9a8) and 'pd6729_pci_remove' Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] pcmcia: remove include of config.hDominik Brodowski
Remove the inclusion of include/config.h as it isn't needed any longer. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: kzalloc conversionDominik Brodowski
Convert users of kmalloc and memset to kzalloc Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: remove get_socket callbackDominik Brodowski
The .get_socket callback is never used by the PCMCIA core, therefore remove it. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-05-05[PATCH] pcmcia: enable 32-bit memory windows on pd6729Dominik Brodowski
Enable 32-bit memory windows on pd6729 PCI-PCMCIA bridges. Signed-off-by: Jarkko Raja <jar@pcuf.fi> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
