path: root/drivers/pcmcia/Kconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-20ARM: pxa: Colibri PXA320 PCMCIA driverMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-20ARM: pxa: Toradex Colibri PXA270 CF supportMarek Vasut
This driver also contains structures to eventually support PXA320. This is planned to be added in a later patch. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-08-06Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable Conflicts: arch/arm/mach-pxa/palmt5.c arch/arm/mach-pxa/palmtreo.c
2010-08-05MIPS: Alchemy: remove SOC_AU1X00 in favor of MIPS_ALCHEMYManuel Lauss
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1461/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05[ARM] pxa/balloon3: PCMCIA SupportMarek Vasut
This driver adds support for the on-board CF socket. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (29 commits) pcmcia: disable PCMCIA ioctl also for ARM drivers/staging/comedi: dev_node removal (quatech_daqp_cs) drivers/staging/comedi: dev_node removal (ni_mio_cs) drivers/staging/comedi: dev_node removal (ni_labpc_cs) drivers/staging/comedi: dev_node removal (ni_daq_dio24) drivers/staging/comedi: dev_node removal (ni_daq_700) drivers/staging/comedi: dev_node removal (das08_cs) drivers/staging/comedi: dev_node removal (cb_das16_cs) pata_pcmcia: get rid of extra indirection pcmcia: remove suspend-related comment from yenta_socket.c pcmcia: call pcmcia_{read,write}_cis_mem with ops_mutex held pcmcia: remove pcmcia_add_device_lock pcmcia: update gfp/slab.h includes pcmcia: remove unused mem_op.h pcmcia: do not autoadd root PCI bus resources pcmcia: clarify alloc_io_space, move it to resource handlers pcmcia: move all pcmcia_resource_ops providers into one module pcmcia: move high level CIS access code to separate file pcmcia: dev_node removal (core) pcmcia: dev_node removal (remaining drivers) ...
2010-05-17pcmcia: disable PCMCIA ioctl also for ARMDominik Brodowski
As per a3f916f2c84f2b9e1d32cc0dbfe326a9e380dbfb, disable the long obsolete PCMCIA ioctl also for ARM. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-11[ARM] pxa: add support for Voipac PXA270 PCMCIAMarek Vasut
PCMCIA support for Voipac PXA270 Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-10pcmcia: move all pcmcia_resource_ops providers into one moduleDominik Brodowski
2010-03-03pcmcia: disable pcmcia ioctl for !ARM, prepare for removalDominik Brodowski
The PCMCIA ioctl -- deprecated for years -- suffers from insufficient locking. As it already has been deprecated for years, with its removal long overdue, limit it to !SMP and !PREEMPT. Furthermore, the last legitimate use of the ioctl to be reported relates to the ARM architecture in 2008.[1] Attempts to resolve this issue turned out unsuccessful so far.[2] Other usages have only been reported as hear-say. If there are any legitiate and necessary use-cases remaining, please speak out before the end of the grace period until 2.6.3{5,6}(-rc1). [1] http://lists.infradead.org/pipermail/linux-pcmcia/2008-April/005440.html see also: http://lkml.org/lkml/2008/2/27/291 [2] http://lists.infradead.org/pipermail/linux-pcmcia/2008-April/005450.html http://lists.infradead.org/pipermail/linux-pcmcia/2010-January/006740.html see also: http://lists.infradead.org/pipermail/linux-pcmcia/2008-April/005453.html CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: Robert P. J. Day <rpjday@crashcourse.ca> CC: Jaswinder Singh Rajput <jaswinder@kernel.org> CC: linux-kernel@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-27Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (141 commits) MIPS: Alchemy: defconfig updates MIPS: Alchemy: Fix Au1100 ethernet build failure MIPS: Alchemy: Repair db1500/bosporus builds MIPS: ARC: Cleanup unused definitions from sgialib.h MIPS: Cobalt: convert legacy port addresses to GT-64111 bus addresses MIPS: Alchemy: use 36bit addresses for PCMCIA resources. MIPS: Cobalt: Fix theoretical port aliasing issue MIPS: Use ALIGN(x, bytes) instead of __ALIGN_MASK(x, bytes - 1) MIPS: Crazy spinlock speed test. MIPS: Optimize spinlocks. MIPS: Alchemy: devboard PM needs to save CPLD registers. MIPS: PowerTV: Eliminate duplicate opcode definition macros MIPS: Lemote 2F: Move printks out of port_access_lock. MIPS: PNX833x: Convert IRQ controller locks to raw spinlocks. MIPS: Octeon: Replace spinlock with raw_spinlocks in dma-octeon.c. MIPS: Octeon: Replace rwlocks in irq_chip handlers with raw_spinlocks. MIPS: Octeon: Convert octeon_irq_msi_lock to raw spinlock. MIPS: Loongson: Remove pointless sample_lock from oprofile code. MIPS: SNI: Convert sni_rm200_i8259A_lock to raw spinlock. MIPS: i8259: Convert IRQ controller lock to raw spinlock. ...
2010-02-27MIPS: Alchemy: XXS1500 PCMCIA driver rewriteManuel Lauss
Rewritten XXS1500 PCMCIA socket driver, standalone (doesn't depend on au1000_generic.c) and added carddetect IRQ support. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Florian Fainelli <florian@openwrt.org> Cc: Linux-PCMCIA <linux-pcmcia@lists.infradead.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: PCMCIA: new socket driver for Au1000 demoboards.Manuel Lauss
New PCMCIA socket driver for all Db/Pb1xxx boards (except Pb1000), which replaces au1000_db1x00.c and (most of) au1000_pb1x00.c. Notable improvements: - supports Db1000, DB/PB1100/1500/1550/1200. - support for carddetect and statuschange IRQs. - pcmcia socket mem/io/attr areas and irqs passed through platform resource information. - doesn't freeze system during card insertion/ejection like the one it replaces. - boardtype is automatically detected using BCSR ID register. Run-tested on the DB1200. Cc: Linux-PCMCIA <linux-pcmcia@lists.infradead.org> Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-17pcmcia: fix yenta dependency on PCCARD_NONSTATICMichal Marek
With CONFIG_PCMCIA=m and CONFIG_YENTA=y, we get drivers/built-in.o: In function `yenta_probe': yenta_socket.c:(.devinit.text+0x1e582): undefined reference to `pccard_nonstatic_ops' This is because select PCCARD_NONSTATIC if PCMCIA sets PCCARD_NONSTATIC = min(YENTA, PCMCIA). Change it to 'if PCMCIA!=n' to remove the upper limit. [linux@dominikbrodowski.net: propagate change to PCMICA_M8XX] Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: do not use resource manager on !PCMCIADominik Brodowski
If only CardBus cards are used, but not PCMCIA cards, we do not need the extensive resource management functions provided for by rsrc_nonstatic.c (~240K). Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: m8xx_pcmcia.c should use iodyn resource managerDominik Brodowski
The socket driver m8xx_pcmcia.c uses a static memory assignment, but io_offset is set to 0. Therefore, it seems proper to use the iodyn resource manager for this driver, as was previously the case (before commit 80128ff79d282cf71b1819dbca9b8dd47d8ed3e8). CC: Vitaly Bordug <vitb@kernel.crashing.org> CC: Arnd Bergmann <arnd@arndb.de> CC: Olof Johansson <olof@lixom.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-01-24pcmcia: m32r uses static socket resourcesDominik Brodowski
m32r_cfc sets the socket capabilities to SS_CAP_STATIC_MAP and also sets io_offset != 0. This means no calls to &pccard_nonstatic_ops went through. Therfore, replace it with &pccard_static_ops which is exactly for this case. CC: Mamoru Sakugawa <sakugawa@linux-m32r.org> CC: Hirokazu Takata <takata@linux-m32r.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: CodingStyle fixes pcmcia: remove unused IRQ_FIRST_SHARED
2009-12-13[ARM] pxa/zeus: make Viper pcmcia support more generic to support ZeusMarc Zyngier
The Arcom Zeus CF slot requires the same kind of support as the Viper. To avoid code duplication, introduce a platform device that abstracts the differences. This also allows for the removal of the ugly export of viper_cf_rst(). Signed-off-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-07pcmcia: CodingStyle fixesDominik Brodowski
Fix several CodingStyle issues in drivers/pcmcia/ . checkpatch.pl no longer reports errors in the PCMCIA core. The remaining warnings mostly relate to wrong indent -- PCMCIA historically used 4 spaces --, to lines over 80 characters and to hundreds of typedefs. The cleanup of those will follow in the future. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-06Fix soc_common PCMCIA configurationRussell King
Jonathan Cameron reports that building PCMCIA as modules doesn't work: As module get a load of undefined symbols: ERROR: "soc_pcmcia_request_irqs" [drivers/pcmcia/pxa2xx_stargate2.ko] undefined! ERROR: "soc_pcmcia_free_irqs" [drivers/pcmcia/pxa2xx_stargate2.ko] undefined! ERROR: "soc_pcmcia_enable_irqs" [drivers/pcmcia/pxa2xx_stargate2.ko] undefined! ERROR: "soc_pcmcia_disable_irqs" [drivers/pcmcia/pxa2xx_stargate2.ko] undefined! ERROR: "soc_pcmcia_add_one" [drivers/pcmcia/pxa2xx_base.ko] undefined! ERROR: "soc_common_pcmcia_get_timing" [drivers/pcmcia/pxa2xx_base.ko] undefined! ERROR: "soc_pcmcia_remove_one" [drivers/pcmcia/pxa2xx_base.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 This is because soc_common tries to be built-in, but it should be a module. Allow soc_common to be a module. Reported-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-09PCMCIA: soc_common: convert to a stand alone moduleRussell King - ARM Linux
Convert soc_common.c to be a stand alone module, rather than wrapping it up into the individual SoC specific base modules. In doing this, we need to add init/exit functions for soc_common to register/remove the cpufreq notifier. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-08pcmcia: use dynamic debug in PCMCIA socket driversDominik Brodowski
Make use of the dynamic debug infrastructure in various PCMCIA socket drivers. By doing so, only the drivers relying on soc_common make use of CONFIG_PCMCIA_DEBUG. Therefore, update the Kconfig entry accordingly. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-09-30MIPS: BCM63xx: Add PCMCIA & Cardbus support.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-05[ARM] pxa/stargate2: add support for Compact Flash/PCMCIAJonathan Cameron
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-15[PCMCIA] e740 PCMCIA socket driver.Ian Molton
This patch adds the platform specific support needed to control the PCMCIA hardware on the Toshiba e740. Signed-off-by: Ian Molton <spyro@f2s.com>
2008-10-28sh: Kill off long-dead HD64465 cchip support.Paul Mundt
This code has been dead for many years. The last update it received was in 2003 in order to update it for the driver model changes, though it had already been in disarray and unused before that point. The only boards that ever used this chip have not had users in many years either, so it is finally safe to just kill it off and move on with life. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-07Merge branch 'viper-for-rmk' of git://www.misterjones.org/linux-2.6-armRussell King
Merge branch 'pxa-viper' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile drivers/pcmcia/Kconfig drivers/pcmcia/Makefile
2008-10-07[ARM] 5294/1: Trizeps4 PCMCIA supportJürgen Schindele
Support for Trizeps4 SOM PCMCIA with ConXS or other baseboards. with double GPIO-free fixed (sorry!) replaces 5279/1 Signed-off-by: Jurgen Schindele <linux@schindele.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-09Add support for the Arcom/Eurotech Viper SBC CompactFlash card slotMarc Zyngier
The Arcom/Eurotech Viper needs some extra care to run. On this board, the PC104 connector is actually wired to the second PCMCIA slot. Therefore, this second socket needs to be enabled, despite not being managed by the PCMCIA code. I'd rather have the MECR setup in the platform support code so I could, for example, use the PC104 bus without having the PCMCIA module loaded. Signed-off-by: Marc Zyngier <marc.zyngier@altran.com>
2008-07-23Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (85 commits) [ARM] pxa: add base support for PXA930 Handheld Platform (aka SAAR) [ARM] pxa: add base support for PXA930 Evaluation Board (aka TavorEVB) [ARM] pxa: add base support for PXA930 (aka Tavor-P) [ARM] Update mach-types [ARM] pxa: make littleton to use the new smc91x platform data [ARM] pxa: make zylonite to use the new smc91x platform data [ARM] pxa: make mainstone to use the new smc91x platform data [ARM] pxa: make lubbock to use new smc91x platform data [NET] smc91x: prepare SMC_USE_PXA_DMA to be specified in platform data [NET] smc91x: prepare for SMC_IO_SHIFT to be a platform configurable variable [NET] smc91x: add SMC91X_NOWAIT flag to platform data [NET] smc91x: favor the use of SMC91X_USE_* instead of SMC_CAN_USE_* [NET] smc91x: remove "irq_flags" from "struct smc91x_platdata" [ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helper Support for LCD on e740 e750 e400 and e800 e-series PDAs E-series UDC support PXA UDC - allow use of inverted GPIO for pullup Add e350 support Fix broken e-series build E-series GPIO / IRQ definitions. ...
2008-07-10[ARM] 5154/1: PalmTX PCMCIAMarek Vašut
This patch adds PCMCIA support for PalmTX handheld computer. There is one chip hard-soldered to slot0, another slot is not in use and not accessible. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-24pcmcia: add support CompactFlash PCMCIA support for Blackfin.Michael Hennerich
A new host driver to add CompactFlash PCMCIA support for Blackfin. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-04-28ARM: always select HAVE_IDEAdrian Bunk
It's plain wrong for PCMCIA to select HAVE_IDE that implies e.g. the availability of an asm/ide.h It turns out this was done for ARM, and we can simply always select HAVE_IDE on ARM instead of manually tracking which platforms might possible have an IDE controller directly or indirectly. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-21[ARM] pxa: fix 0e623941bec7e80c97b076d346327b31ae17d84aRussell King
Place the dependency against the correct config symbol. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: restrict availability of pxa2xx PCMCIA driversRussell King
Not all PXA2xx platforms provide the necessary support files for PCMCIA to work, let alone build. Stop the build errors by making PXA2xx PCMCIA support only available on those platforms which have supplied the support files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-17pcmcia: CompactFlash driver for PA Semi Electra boardsOlof Johansson
Driver for the CompactFlash slot on the PA Semi Electra eval board. It's a simple device sitting on localbus, with interrupts and detect/voltage control over GPIO. The driver is implemented as an of_platform driver, and adds localbus as a bus being probed by the of_platform framework. [akpm@linux-foundation.org: cleanups] [olof@lixom.net: fix build] Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Christoph Hellwig <hch@infradead.org> Cc: Milton Miller <miltonm@bga.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Use menuconfig objects: PCMCIAJan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[POWERPC] 8xx: mpc885ads pcmcia supportVitaly Bordug
Adds support for PowerQuicc on-chip PCMCIA. The driver is implemented as of_device, so only arch/powerpc stuff is capable to use it, which now implies only mpc885ads reference board. To cope with the code that should be hooked inside driver, but is really board specific (like set_voltage), global structure mpc8xx_pcmcia_ops holds necessary function pointers that are filled in the BSP code. [akpm@linux-foundation.org: whitespace diddles] Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-07-10[PATCH] don't select CONFIG_HOTPLUGAndrew Morton
It's useful to be able to turn off CONFIG_HOTPLUG for compile-coverage testing and for section-checking coverage. But a few things go and select CONFIG_HOTPLUG, making it a royal PITA to turn the thing off. It's only turnable offable if CONFIG_EMBEDDED anyway. So let's make those things depend on HOTPLUG, not select it. Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] vrc4171: update configYoichi Yuasa
This patch updates "depends on" for PCMCIA_VRC4171. CONFIG_VRC4171 has been removed, so replace it with CPU_VR41XX && ISA. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: AT91RM9200 Compact Flash driverAndrew Victor
This patch adds support for the Compact Flash controller integrated in the Atmel AT91RM9200 processor. Signed-off-by: Andrew Victor <andrew@sanpeople.com Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: no probing of ioports on PARISCDominik Brodowski
Do not wildly probe the IO ports we're trying to use on PARISC. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: properly handle static mem, but dynamic io socketsDominik Brodowski
Some PCMCIA sockets have statically mapped memory windows, but dynamically mapped IO windows. Using the "nonstatic" socket library is inpractical for them, as they do neither need a resource database (as we can trust the kernel resource database on m68k and ppc) nor lots of other features of that library. Let them get a small "iodyn" socket library (105 lines of code) instead. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] yenta: make bridge specific init code configurableDaniel Ritz
Make the bridge specific initialization code config options depending on CONFIG_EMBEDDED. Config options for TI/EnE, Toshiba, Ricoh and O2Micro are available. Disabling all of the specific tweaks cuts off more than half of yenta_socket.ko. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-11-10[PCMCIA] MPC8xx PCMCIA updateMarcelo Tosatti
Kconfig entry: dependency on 8xx Makefile: fix whitespace breakage m8xx_pcmcia.c: - asm/segment.h is gone - use generic PCMCIA suspend/resume methods Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-10-29[PATCH] MPC8xx PCMCIA driverMarcelo Tosatti
Here is an uptodated version of the MPC8xx PCMCIA driver for v2.6, addressing comments by Jeff and Dominik: - use IO accessors instead of direct device memory referencing - avoid usage of non-standard "uint/uchar" data types - kill struct typedef's Will submit it for inclusion once v2.6.14 is out. Testing on 8xx platforms is more than welcome! Works like a charm on our custom hardware (CONFIG_PRxK). Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-26[PATCH] pcmcia: fix Kconfig dependencyKomuro
TCIC depends on ISA. It is used with ISA-bus system only. Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
