commit 8e2e03179923479ca0c0b6fdc7c93ecf89bce7a8 upstream.
Similar to the AR93xx and the AR94xx series, the AR95xx also have the same
quirk for the Bus Reset. It will lead to instant system reset if the
device is assigned via VFIO to a KVM VM. I've been able reproduce this
behavior with a MikroTik R11e-2HnD.
Fixes: c3e59ee4e766 ("PCI: Mark Atheros AR93xx to avoid bus reset")
Signed-off-by: Maik Broemme <mbroemme@libmpq.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit f3b0946d629c8bfbd3e5f038e30cb9c711a35f10 upstream.
Bharat Kumar Gogada reported issues with the generic MSI code, where the
end-point ended up with garbage in its MSI configuration (both for the vector
and the message).
It turns out that the two MSI paths in the kernel are doing slightly different
things:
generic MSI: disable MSI -> allocate MSI -> enable MSI -> setup EP
PCI MSI: disable MSI -> allocate MSI -> setup EP -> enable MSI
And it turns out that end-points are allowed to latch the content of the MSI
configuration registers as soon as MSIs are enabled. In Bharat's case, the
end-point ends up using whatever was there already, which is not what you
want.
In order to make things converge, we introduce a new MSI domain flag
(MSI_FLAG_ACTIVATE_EARLY) that is unconditionally set for PCI/MSI. When set,
this flag forces the programming of the end-point as soon as the MSIs are
allocated.
A consequence of this is that we have an extra activate in irq_startup, but
that should be without much consequence.
tglx:
- Several people reported a VMWare regression with PCI/MSI-X passthrough. It
turns out that the patch also cures that issue.
- We need to have a look at the MSI disable interrupt path, where we write
the msg to all zeros without disabling MSI in the PCI device. Is that
correct?
Fixes: 52f518a3a7c2 "x86/MSI: Use hierarchical irqdomains to manage MSI interrupts"
Reported-and-tested-by: Bharat Kumar Gogada <bharat.kumar.gogada@xilinx.com>
Reported-and-tested-by: Foster Snowhill <forst@forstwoof.ru>
Reported-by: Matthias Prager <linux@matthiasprager.de>
Reported-by: Jason Taylor <jason.taylor@simplivity.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: linux-pci@vger.kernel.org
Link: http://lkml.kernel.org/r/1468426713-31431-1-git-send-email-marc.zyngier@arm.com
commit c2e771b02792d222cbcd9617fe71482a64f52647 upstream.
Like the NFP6000, the NFP4000 as an erratum where reading/writing to PCI
config space addresses above 0x600 can cause the NFP to generate PCIe
completion timeouts.
Limit the NFP4000's PF's config space size to 0x600 bytes as is already
done for the NFP6000.
The NFP4000's VF is 0x6004 (PCI_DEVICE_ID_NETRONOME_NFP6000_VF), the same
device ID as the NFP6000's VF. Thus, its config space is already limited
by the existing use of quirk_nfp6000().
Signed-off-by: Simon Horman <simon.horman@netronome.com>
commit 9f33a2ae59f24452c1076749deb615bccd435ca9 upstream.
The NFP6000 has an erratum where reading/writing to PCI config space
addresses above 0x600 can cause the NFP to generate PCIe completion
timeouts.
Limit the NFP6000's config space size to 0x600 bytes.
Signed-off-by: Jason S. McMullan <jason.mcmullan@netronome.com>
[simon: edited changelog]
commit c20aecf6963d1273d8f6d61c042b4845441ca592 upstream.
If a device quirk modifies the pci_dev->cfg_size to be less than
PCI_CFG_SPACE_EXP_SIZE (4096), but greater than PCI_CFG_SPACE_SIZE (256),
the PCI sysfs interface truncates the readable size to PCI_CFG_SPACE_SIZE.
Allow sysfs access to config space up to cfg_size, even if the device
doesn't support the entire 4096-byte PCIe config space.
Note that pci_read_config() and pci_write_config() limit access to
dev->cfg_size even though pcie_config_attr contains 4096 (the maximum
size).
[bhelgaas: more changelog edits]
commit 9ac0108c2bac3f1d0255f64fb89fc27e71131b24 upstream.
Similar to the AR93xx series, the AR94xx and the Qualcomm QCA988x also have
the same quirk for the Bus Reset.
Signed-off-by: Chris Blake <chrisrblake93@gmail.com>
commit ad67b437f187ea818b2860524d10f878fadfdd99 upstream.
b84106b4e229 ("PCI: Disable IO/MEM decoding for devices with non-compliant
BARs") disabled BAR sizing for BARs 0-5 of devices that don't comply with
the PCI spec. But it didn't do anything for expansion ROM BARs, so we
still try to size them, resulting in warnings like this on Broadwell-EP:
pci 0000:ff:12.0: BAR 6: failed to assign [mem size 0x00000001 pref]
Move the non-compliant BAR check from __pci_read_base() up to
pci_read_bases() so it applies to the expansion ROM BAR as well as
to BARs 0-5.
Note that direct callers of __pci_read_base(), like sriov_init(), will now
bypass this check. We haven't had reports of devices with broken SR-IOV
BARs yet.
[bhelgaas: changelog]
Fixes: b84106b4e229 ("PCI: Disable IO/MEM decoding for devices with non-compliant BARs")
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Ingo Molnar <mingo@redhat.com>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Andi Kleen <ak@linux.intel.com>
commit b84106b4e2290c081cdab521fa832596cdfea246 upstream.
The PCI config header (first 64 bytes of each device's config space) is
defined by the PCI spec so generic software can identify the device and
manage its usage of I/O, memory, and IRQ resources.
Some non-spec-compliant devices put registers other than BARs where the
BARs should be. When the PCI core sizes these "BARs", the reads and writes
it does may have unwanted side effects, and the "BAR" may appear to
describe non-sensical address space.
Add a flag bit to mark non-compliant devices so we don't touch their BARs.
Turn off IO/MEM decoding to prevent the devices from consuming address
space, since we can't read the BARs to find out what that address space
would be.
Tested-by: Andi Kleen <ak@linux.intel.com>
commit 54c6e2dd00c313d0add58e5befe62fe6f286d03b upstream.
pci_create_root_bus() passes a "parent" pointer to
pci_bus_assign_domain_nr(). When CONFIG_PCI_DOMAINS_GENERIC is defined,
pci_bus_assign_domain_nr() dereferences that pointer. Many callers of
pci_create_root_bus() supply a NULL "parent" pointer, which leads to a NULL
pointer dereference error.
7c674700098c ("PCI: Move domain assignment from arm64 to generic code")
moved the "parent" dereference from arm64 to generic code. Only arm64 used
that code (because only arm64 defined CONFIG_PCI_DOMAINS_GENERIC), and it
always supplied a valid "parent" pointer. Other arches supplied NULL
"parent" pointers but didn't defined CONFIG_PCI_DOMAINS_GENERIC, so they
used a no-op version of pci_bus_assign_domain_nr().
8c7d14746abc ("ARM/PCI: Move to generic PCI domains") defined
CONFIG_PCI_DOMAINS_GENERIC on ARM, and many ARM platforms use
pci_common_init(), which supplies a NULL "parent" pointer.
These platforms (cns3xxx, dove, footbridge, iop13xx, etc.) crash
with a NULL pointer dereference like this while probing PCI:
Unable to handle kernel NULL pointer dereference at virtual address 000000a4
PC is at pci_bus_assign_domain_nr+0x10/0x84
LR is at pci_create_root_bus+0x48/0x2e4
Kernel panic - not syncing: Attempted to kill init!
[bhelgaas: changelog, add "Reported:" and "Fixes:" tags]
Reported: http://forum.doozan.com/read.php?2,17868,22070,quote=1
Fixes: 8c7d14746abc ("ARM/PCI: Move to generic PCI domains")
Fixes: 7c674700098c ("PCI: Move domain assignment from arm64 to generic code")
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit 79e3f4a853ed161cd4c06d84b50beebf961a47c6 upstream.
Commit cbce7900598c ("PCI: designware: Make driver arch-agnostic") changed
the host bridge sysdata pointer from the ARM pci_sys_data to the DesignWare
pcie_port structure, and changed pcie-designware.c to reflect that. But it
did not change the corresponding code in pci-keystone-dw.c, so it caused
crashes on Keystone:
Unable to handle kernel NULL pointer dereference at virtual address 00000030
pgd = c0003000
[00000030] *pgd=80000800004003, *pmd=00000000
Internal error: Oops: 206 [#1] PREEMPT SMP ARM
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.2-00139-gb74f926 #2
Hardware name: Keystone
PC is at ks_dw_pcie_msi_irq_unmask+0x24/0x58
Change pci-keystone-dw.c to expect sysdata to be the struct pcie_port
pointer.
Fixes: cbce7900598c ("PCI: designware: Make driver arch-agnostic")
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
CC: Zhou Wang <wangzhou1@hisilicon.com>
extracted.
commit 4d8c8bd6f2062c9988817183a91fe2e623c8aa5e upstream.
Occasionaly PV guests would crash with:
pciback 0000:00:00.1: Xen PCI mapped GSI0 to IRQ16
BUG: unable to handle kernel paging request at 0000000d1a8c0be0
.. snip..
<ffffffff8139ce1b>] find_next_bit+0xb/0x10
[<ffffffff81387f22>] cpumask_next_and+0x22/0x40
[<ffffffff813c1ef8>] pci_device_probe+0xb8/0x120
[<ffffffff81529097>] ? driver_sysfs_add+0x77/0xa0
[<ffffffff815293e4>] driver_probe_device+0x1a4/0x2d0
[<ffffffff813c1ddd>] ? pci_match_device+0xdd/0x110
[<ffffffff81529657>] __device_attach_driver+0xa7/0xb0
[<ffffffff815295b0>] ? __driver_attach+0xa0/0xa0
[<ffffffff81527622>] bus_for_each_drv+0x62/0x90
[<ffffffff8152978d>] __device_attach+0xbd/0x110
[<ffffffff815297fb>] device_attach+0xb/0x10
[<ffffffff813b75ac>] pci_bus_add_device+0x3c/0x70
[<ffffffff813b7618>] pci_bus_add_devices+0x38/0x80
[<ffffffff813dc34e>] pcifront_scan_root+0x13e/0x1a0
[<ffffffff817a0692>] pcifront_backend_changed+0x262/0x60b
[<ffffffff814644c6>] ? xenbus_gather+0xd6/0x160
[<ffffffff8120900f>] ? put_object+0x2f/0x50
[<ffffffff81465c1d>] xenbus_otherend_changed+0x9d/0xa0
[<ffffffff814678ee>] backend_changed+0xe/0x10
[<ffffffff81463a28>] xenwatch_thread+0xc8/0x190
[<ffffffff810f22f0>] ? woken_wake_function+0x10/0x10
which was the result of two things:
When we call pci_scan_root_bus we would pass in 'sd' (sysdata)
pointer which was an 'pcifront_sd' structure. However in the
pci_device_add it expects that the 'sd' is 'struct sysdata' and
sets the dev->node to what is in sd->node (offset 4):
set_dev_node(&dev->dev, pcibus_to_node(bus));
__pcibus_to_node(const struct pci_bus *bus)
const struct pci_sysdata *sd = bus->sysdata;
return sd->node;
However our structure was pcifront_sd which had nothing at that
offset:
struct pcifront_sd {
int domain; /* 0 4 */
/* XXX 4 bytes hole, try to pack */
struct pcifront_device * pdev; /* 8 8 */
That is an hole - filled with garbage as we used kmalloc instead of
kzalloc (the second problem).
This patch fixes the issue by:
1) Use kzalloc to initialize to a well known state.
2) Put 'struct pci_sysdata' at the start of 'pcifront_sd'. That
way access to the 'node' will access the right offset.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 4ae2182b1e3407de369f8c5d799543b7db74221b upstream.
A Root Port's AER structure (rpc) contains a queue of events. aer_irq()
enqueues AER status information and schedules aer_isr() to dequeue and
process it. When we remove a device, aer_remove() waits for the queue to
be empty, then frees the rpc struct.
But aer_isr() references the rpc struct after dequeueing and possibly
emptying the queue, which can cause a use-after-free error as in the
following scenario with two threads, aer_isr() on the left and a
concurrent aer_remove() on the right:
Thread A Thread B
aer_irq():
rpc->prod_idx++
aer_remove():
wait_event(rpc->prod_idx == rpc->cons_idx)
# now blocked until queue becomes empty
aer_isr(): # ...
rpc->cons_idx++ # unblocked because queue is now empty
... kfree(rpc)
mutex_unlock(&rpc->rpc_mutex)
To prevent this problem, use flush_work() to wait until the last scheduled
instance of aer_isr() has completed before freeing the rpc struct in
aer_remove().
I reproduced this use-after-free by flashing a device FPGA and
re-enumerating the bus to find the new device. With SLUB debug, this
crashes with 0x6b bytes (POISON_FREE, the use-after-free magic number) in
GPR25:
pcieport 0000:00:00.0: AER: Multiple Corrected error received: id=0000
Unable to handle kernel paging request for data at address 0x27ef9e3e
Workqueue: events aer_isr
GPR24: dd6aa000 6b6b6b6b 605f8378 605f8360 d99b12c0 604fc674 606b1704 d99b12c0
NIP [602f5328] pci_walk_bus+0xd4/0x104
[bhelgaas: changelog, stable tag]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 2c3033a0664dfae91e1dee7fabac10f24354b958 upstream.
In acpiphp_enable_slot(), there is a missing unlock path
when error occurred. It needs to be unlocked before returning
an error.
Signed-off-by: Insu Yun <wuninsu@gmail.com>
commit 3460baa620685c20f5ee19afb6d99d26150c382c upstream.
Commit 36e097a8a297 ("PCI: Split out bridge window override of minimum
allocation address") claimed to do no functional changes but unfortunately
did: The "min" variable is altered. At least the AVM A1 PCMCIA adapter was
no longer detected, breaking ISDN operation.
Use a local copy of "min" to restore the previous behaviour.
[bhelgaas: avoid gcc "?:" extension for portability and readability]
Fixes: 36e097a8a297 ("PCI: Split out bridge window override of minimum allocation address")
Signed-off-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
commit 8ff0ef996ca00028519c70e8d51d32bd37eb51dc upstream.
On -RT and if kernel is booting with "threadirqs" cmd line parameter,
PCIe/PCI (MSI) IRQ cascade handlers (like dra7xx_pcie_msi_irq_handler())
will be forced threaded and, as result, will generate warnings like this:
WARNING: CPU: 1 PID: 82 at kernel/irq/handle.c:150 handle_irq_event_percpu+0x14c/0x174()
irq 460 handler irq_default_primary_handler+0x0/0x14 enabled interrupts
Backtrace:
(warn_slowpath_common) from (warn_slowpath_fmt+0x38/0x40)
(warn_slowpath_fmt) from (handle_irq_event_percpu+0x14c/0x174)
(handle_irq_event_percpu) from (handle_irq_event+0x84/0xb8)
(handle_irq_event) from (handle_simple_irq+0x90/0x118)
(handle_simple_irq) from (generic_handle_irq+0x30/0x44)
(generic_handle_irq) from (dra7xx_pcie_msi_irq_handler+0x7c/0x8c)
(dra7xx_pcie_msi_irq_handler) from (irq_forced_thread_fn+0x28/0x5c)
(irq_forced_thread_fn) from (irq_thread+0x128/0x204)
This happens because all of them invoke generic_handle_irq() from the
requested handler. generic_handle_irq() grabs raw_locks and thus needs to
run in raw-IRQ context.
This issue was originally reproduced on TI dra7-evem, but, as was
identified during discussion [1], other hosts can also suffer from this
issue. Fix all them at once by marking PCIe/PCI (MSI) IRQ cascade handlers
IRQF_NO_THREAD explicitly.
[1] http://lkml.kernel.org/r/1448027966-21610-1-git-send-email-grygorii.strashko@ti.com
[bhelgaas: add stable tag, fix typos]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Acked-by: Lucas Stach <l.stach@pengutronix.de>
CC: Kishon Vijay Abraham I <kishon@ti.com>
CC: Jingoo Han <jingoohan1@gmail.com>
CC: Kukjin Kim <kgene@kernel.org>
CC: Krzysztof Kozlowski <k.kozlowski@samsung.com>
CC: Richard Zhu <Richard.Zhu@freescale.com>
CC: Thierry Reding <thierry.reding@gmail.com>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Alexandre Courbot <gnurou@gmail.com>
CC: Simon Horman <horms@verge.net.au>
CC: Pratyush Anand <pratyush.anand@gmail.com>
CC: Michal Simek <michal.simek@xilinx.com>
CC: "Sören Brinkmann" <soren.brinkmann@xilinx.com>
CC: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixlet from Bjorn Helgaas:
"This marks the TI DRA7xx host bridge driver as broken. Apparently it
has never worked without some additional out-of-tree code, so I'm
going to mark it broken now and remove it completely next cycle unless
it's fixed"
* tag 'pci-v4.4-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: dra7xx: Mark driver as broken
Mark the dra7xx PCI host driver as broken. This driver was first merged in
v3.17 and has never worked. Although the driver compiles just fine, it is
missing an essential device reset. If the driver is included, the kernel
locks up hard shortly after booting, before any console output appears.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Pull PCI bugfix from Bjorn Helgaas:
"Here's another fix for v4.4.
This fixes 32-bit config reads for the HiSilicon driver. Obviously
the driver is completely broken without this fix (apparently it
actually was tested internally, but got broken somehow in the process
of upstreaming it).
Summary:
HiSilicon host bridge driver
Fix 32-bit config reads (Dongdong Liu)"
* tag 'pci-v4.4-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: hisi: Fix hisi_pcie_cfg_read() 32-bit reads
Pull PCI fixes from Bjorn Helgaas:
"These are more fixes I'd like to have in v4.4. Several for the Altera
driver added for v4.4, and one for an MSI domain problem that affects
several arm64 platforms:
MSI:
- Only use the generic MSI layer when domain is hierarchical (Marc
Zyngier)
Altera host bridge driver:
- Fix loop in tlp_read_packet() (Dan Carpenter)
- Fix Requester ID for config accesses (Ley Foon Tan)
- Check TLP completion status (Ley Foon Tan)
- Fix error when INTx is 4 (Ley Foon Tan)"
* tag 'pci-v4.4-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: altera: Fix error when INTx is 4
PCI: altera: Check TLP completion status
PCI: altera: Fix Requester ID for config accesses
PCI: altera: Fix loop in tlp_read_packet()
PCI/MSI: Only use the generic MSI layer when domain is hierarchical
For 32-bit config reads (size == 4), hisi_pcie_cfg_read() returned success
but never filled in the data we read.
Return the register data for 32-bit config reads.
Without this fix, PCI doesn't work at all because enumeration depends on
32-bit config reads. The driver was tested internally, but got broken in
the process of upstreaming, so this fixes the breakage.
Fixes: 500a1d9a43e0 ("PCI: hisi: Add HiSilicon SoC Hip05 PCIe driver")
Signed-off-by: Dongdong Liu <liudongdong3@huawei.com>
Reviewed-by: Zhou Wang <wangzhou1@hisilicon.com>
PCI interrupt lines start at 1, not at 0. So, creates additional one
interrupt when register for irq domain.
Error when PCIe devices have 4 INTx:
WARNING: CPU: 1 PID: 1 at kernel/irq/irqdomain.c:280
irq_domain_associate+0x17c/0x1cc()
error: hwirq 0x4 is too large for dummy
Tested on Ethernet adapter card with multi-functions.
Signed-off-by: Ley Foon Tan <lftan@altera.com>
Check TLP packet successful completion status. This fix the issue when
accessing multi-function devices in enumeration process, TLP will return
error when accessing non-exist function number. Returns PCI error code
instead of generic errno.
[bhelgaas: simplify completion status checking code]
The Requester ID should use the Root Port devfn and it should be always 0.
Previously we constructed the Requester ID using the *Completer* devfn,
i.e., the devfn of the Function we expect to respond to the config access.
This causes issues when accessing configuration space for devices other
than the Root Port.
Build the Requester ID using the Root Port devfn.
TLP_LOOP is 500 and the "loop" variable was a u8 so "loop < TLP_LOOP" is
always true. We only need this condition to work if there is a problem so
it would have been easy to miss this in testing.
Make it a normal for loop with "int i" instead of over thinking things and
making it complicated.
Fixes: 6bb4dd154ae8 ("PCI: altera: Add Altera PCIe host controller driver")
Acked-by: Ley Foon Tan <lftan@altera.com>
Since d8a1cb757550 ("PCI/MSI: Let pci_msi_get_domain use struct
device::msi_domain"), we use the MSI domain associated with the PCI device.
But finding an MSI domain doesn't mean that the domain is implemented using
the generic MSI domain API, and a number of MSI controllers are still using
arch_setup_msi_irq() and arch_teardown_msi_irqs().
Check that the domain we just obtained is hierarchical. If it is, we can
use the new generic MSI stuff. Otherwise we have to fall back to the old
arch_setup_msi_irq() and arch_teardown_msi_irqs() interfaces.
This avoids an oops in msi_domain_alloc_irqs() on systems with R-Car,
Tegra, Armada 370, and probably other DesignWare-based host controllers.
Fixes: d8a1cb757550 ("PCI/MSI: Let pci_msi_get_domain use struct device::msi_domain")
Reported-by: Phil Edworthy <phil.edworthy@renesas.com>
Tested-by: Phil Edworthy <phil.edworthy@renesas.com>
CC: stable@vger.kernel.org # v4.3+
The runtime PM core doesn't treat EBUSY and EAGAIN retvals from the driver
suspend hooks as errors, but they still show up as errors in dmesg. Tune
them down. See rpm_suspend() for details of handling these return values.
Note that we use dev_dbg() for the retryable retvals, so after this
change you'll need either CONFIG_DYNAMIC_DEBUG or CONFIG_PCI_DEBUG
for them to show up in the log.
One problem caused by this was noticed by Daniel: the i915 driver
returns EAGAIN to signal a temporary failure to suspend and as a request
towards the RPM core for scheduling a suspend again. This is a normal
event, but the resulting error message flags a breakage during the
driver's automated testing which parses dmesg and picks up the error.
Reported-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://bugs.freedesktop.org/show_bug.cgi?id=92992
Signed-off-by: Imre Deak <imre.deak@intel.com>
Commit b3a72384fe29 ("ARM/PCI: Replace pci_sys_data->align_resource with
global function pointer") introduced an ARM-specific align_resource()
function pointer. This is not portable to other arches and doesn't work
for platforms with two different PCIe host bridge controllers.
Move the function pointer to the pci_host_bridge structure so each host
bridge driver can specify its own align_resource() function.
Signed-off-by: Gabriele Paoloni <gabriele.paoloni@huawei.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The hisi_pcie_probe() function is incorrectly marked as __init, as Kconfig
tells us:
WARNING: drivers/pci/host/built-in.o(.data+0x7780): Section mismatch in reference from the variable hisi_pcie_driver to the function .init.text:hisi_pcie_probe()
If the probe for this device gets deferred past the point where __init
functions are removed, or the device is unbound and then reattached to the
driver, we branch into uninitialized memory, which is bad.
Remove the __init annotation from hisi_pcie_probe() and
hisi_add_pcie_port().
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Zhou Wang <wangzhou1@hisilicon.com>
"pp->io" is an I/O resource, e.g., "[io 0x0000-0xffff]"; "pp->io_base" is
the CPU physical address of a region where the host bridge converts CPU
memory accesses into PCI I/O transactions.
Corrupting pp->io_base by assigning pp->io->start to it breaks access to
the PCI I/O space, as reported by Kishon.
Remove the invalid assignment.
Fixes: 0021d22b73d6 ("PCI: designware: Use of_pci_get_host_bridge_resources() to parse DT")
Reported-and-tested-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Stanimir Varbanov <stanimir.varbanov@linaro.org>
Commit 1266963170f5 ("PCI: Prevent out of bounds access in numa_node
override") missed that the user-provided node could also be negative.
Handle this case as well to avoid out-of-bounds accesses to the
node_states[] array. However, allow the special value -1, i.e.
NUMA_NO_NODE, to be able to set the 'no specific node' configuration.
Fixes: 1266963170f5 ("PCI: Prevent out of bounds access in numa_node override")
Fixes: 63692df103e9 ("PCI: Allow numa_node override via sysfs")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
CC: Sasha Levin <sasha.levin@oracle.com>
CC: Prarit Bhargava <prarit@redhat.com>
CC: stable@vger.kernel.org # v3.19+
* acpi-smbus:
Revert "ACPI / SBS: Add 5 us delay to fix SBS hangs on MacBook"
ACPI / SMBus: Fix boot stalls / high CPU caused by reentrant code
* acpi-ec:
ACPI-EC: Drop unnecessary check made before calling acpi_ec_delete_query()
* acpi-pci:
PCI: Fix OF logic in pci_dma_configure()
This patch fixes a bug introduced by previous commit,
which incorrectly checkes the of_node of the end-point device.
Instead, it should check the of_node of the host bridge.
Fixes: 50230713b639 ("PCI: OF: Move of_pci_dma_configure() to pci_dma_configure()")
Reported-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Pull more power management and ACPI updates from Rafael Wysocki:
"The only new feature in this batch is support for the ACPI _CCA device
configuration object, which it a pre-requisite for future ACPI PCI
support on ARM64, but should not affect the other architectures.
The rest is fixes and cleanups, mostly in cpufreq (including
intel_pstate), the Operating Performace Points (OPP) framework and
tools (cpupower and turbostat).
Specifics:
- Support for the ACPI _CCA configuration object intended to tell the
OS whether or not a bus master device supports hardware managed
cache coherency and a new set of functions to allow drivers to
check the cache coherency support for devices in a platform
firmware interface agnostic way (Suravee Suthikulpanit, Jeremy
Linton).
- ACPI backlight quirks for ESPRIMO Mobile M9410 and Dell XPS L421X
(Aaron Lu, Hans de Goede).
- Fixes for the arm_big_little and s5pv210-cpufreq cpufreq drivers
(Jon Medhurst, Nicolas Pitre).
- kfree()-related fixup for the recently introduced CPPC cpufreq
frontend (Markus Elfring).
- intel_pstate fix reducing kernel log noise on systems where
P-states are managed by hardware (Prarit Bhargava).
- intel_pstate maintainers information update (Srinivas Pandruvada).
- cpufreq core optimization related to the handling of delayed work
items used by governors (Viresh Kumar).
- Locking fixes and cleanups of the Operating Performance Points
(OPP) framework (Viresh Kumar).
- Generic power domains framework cleanups (Lina Iyer).
- cpupower tool updates (Jacob Tanenbaum, Sriram Raghunathan, Thomas
Renninger).
- turbostat tool updates (Len Brown)"
* tag 'pm+acpi-4.4-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
PCI: ACPI: Add support for PCI device DMA coherency
of/pci: Fix pci_get_host_bridge_device leak
device property: ACPI: Remove unused DMA APIs
device property: ACPI: Make use of the new DMA Attribute APIs
device property: Adding DMA Attribute APIs for Generic Devices
ACPI: Adding DMA Attribute APIs for ACPI Device
device property: Introducing enum dev_dma_attr
ACPI: Honor ACPI _CCA attribute setting
cpufreq: CPPC: Delete an unnecessary check before the function call kfree()
PM / OPP: Add opp_rcu_lockdep_assert() to _find_device_opp()
PM / OPP: Hold dev_opp_list_lock for writers
PM / OPP: Protect updates to list_dev with mutex
PM / OPP: Propagate error properly from dev_pm_opp_set_sharing_cpus()
cpufreq: s5pv210-cpufreq: fix wrong do_div() usage
MAINTAINERS: update for intel P-state driver
Creating a common structure initialization pattern for struct option
cpupower: Enable disabled Cstates if they are below max latency
cpupower: Remove debug message when using cpupower idle-set -D switch
cpupower: cpupower monitor reports uninitialized values for offline cpus
* acpi-pci:
drivers/crypto/ccp/ccp-platform.c
This patch adds support for setting up PCI device DMA coherency from
ACPI _CCA object that should normally be specified in the DSDT node
of its PCI host bridge.
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
This patch move of_pci_dma_configure() to a more generic
pci_dma_configure(), which can be extended by non-OF code (e.g. ACPI).
This has no functional change.
Acked-by: Rob Herring <robh+dt@kernel.org>
Pull PCI updates from Bjorn Helgaas:
"Resource management:
- Add support for Enhanced Allocation devices (Sean O. Stalley)
- Add Enhanced Allocation register entries (Sean O. Stalley)
- Handle IORESOURCE_PCI_FIXED when sizing resources (David Daney)
- Handle IORESOURCE_PCI_FIXED when assigning resources (David Daney)
- Handle Enhanced Allocation capability for SR-IOV devices (David Daney)
- Clear IORESOURCE_UNSET when reverting to firmware-assigned address (Bjorn Helgaas)
- Make Enhanced Allocation bitmasks more obvious (Bjorn Helgaas)
- Expand Enhanced Allocation BAR output (Bjorn Helgaas)
- Add of_pci_check_probe_only to parse "linux,pci-probe-only" (Marc Zyngier)
- Fix lookup of linux,pci-probe-only property (Marc Zyngier)
- Add sparc mem64 resource parsing for root bus (Yinghai Lu)
PCI device hotplug:
- pciehp: Queue power work requests in dedicated function (Guenter Roeck)
Driver binding:
- Add builtin_pci_driver() to avoid registration boilerplate (Paul Gortmaker)
Virtualization:
- Set SR-IOV NumVFs to zero after enumeration (Alexander Duyck)
- Remove redundant validation of SR-IOV offset/stride registers (Alexander Duyck)
- Remove VFs in reverse order if virtfn_add() fails (Alexander Duyck)
- Reorder pcibios_sriov_disable() (Alexander Duyck)
- Wait 1 second between disabling VFs and clearing NumVFs (Alexander Duyck)
- Fix sriov_enable() error path for pcibios_enable_sriov() failures (Alexander Duyck)
- Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs (Ben Shelton)
- Don't try to restore VF BARs (Wei Yang)
MSI:
- Don't alloc pcibios-irq when MSI is enabled (Joerg Roedel)
- Add msi_controller setup_irqs() method for special multivector setup (Lucas Stach)
- Export all remapped MSIs to sysfs attributes (Romain Bezut)
- Disable MSI on SiS 761 (Ondrej Zary)
AER:
- Clear error status registers during enumeration and restore (Taku Izumi)
Generic host bridge driver:
- Allow multiple hosts with different map_bus() methods (David Daney)
- Pass starting bus number to pci_scan_root_bus() (David Daney)
- Fix address window calculation for non-zero starting bus (David Daney)
- Add msi.h to ARM Kbuild (Ley Foon Tan)
- Add Altera PCIe host controller driver (Ley Foon Tan)
- Add Altera PCIe MSI driver (Ley Foon Tan)
APM X-Gene host bridge driver:
- Remove msi_controller assignment (Duc Dang)
Broadcom iProc host bridge driver:
- Fix header comment "Corporation" misspelling (Florian Fainelli)
- Fix code comment to match code (Ray Jui)
- Remove unused struct iproc_pcie.irqs[] (Ray Jui)
- Call pci_fixup_irqs() for ARM64 as well as ARM (Ray Jui)
- Fix PCIe reset logic (Ray Jui)
- Improve link detection logic (Ray Jui)
- Update PCIe device tree bindings (Ray Jui)
- Add outbound mapping support (Ray Jui)
Freescale i.MX6 host bridge driver:
- Return real error code from imx6_add_pcie_port() (Fabio Estevam)
- Add PCIE_PHY_RX_ASIC_OUT_VALID definition (Fabio Estevam)
Freescale Layerscape host bridge driver:
- Remove ls_pcie_establish_link() (Minghuan Lian)
- Ignore PCIe controllers in Endpoint mode (Minghuan Lian)
- Factor out SCFG related function (Minghuan Lian)
- Update ls_add_pcie_port() (Minghuan Lian)
- Remove unused fields from struct ls_pcie (Minghuan Lian)
- Add support for LS1043a and LS2080a (Minghuan Lian)
- Add ls_pcie_msi_host_init() (Minghuan Lian)
HiSilicon host bridge driver:
- Add HiSilicon SoC Hip05 PCIe driver (Zhou Wang)
Marvell MVEBU host bridge driver:
- Return zero for reserved or unimplemented config space (Russell King)
- Use exact config access size; don't read/modify/write (Russell King)
- Use of_get_available_child_count() (Russell King)
- Use for_each_available_child_of_node() to walk child nodes (Russell King)
- Report full node name when reporting a DT error (Russell King)
- Use port->name rather than "PCIe%d.%d" (Russell King)
- Move port parsing and resource claiming to separate function (Russell King)
- Fix memory leaks and refcount leaks (Russell King)
- Split port parsing and resource claiming from port setup (Russell King)
- Use gpio_set_value_cansleep() (Russell King)
- Use devm_kcalloc() to allocate an array (Russell King)
- Use gpio_desc to carry around gpio (Russell King)
- Improve clock/reset handling (Russell King)
- Add PCI Express root complex capability block (Russell King)
- Remove code restricting accesses to slot 0 (Russell King)
NVIDIA Tegra host bridge driver:
- Wrap static pgprot_t initializer with __pgprot() (Ard Biesheuvel)
Renesas R-Car host bridge driver:
- Build pci-rcar-gen2.c only on ARM (Geert Uytterhoeven)
- Build pcie-rcar.c only on ARM (Geert Uytterhoeven)
- Make PCI aware of the I/O resources (Phil Edworthy)
- Remove dependency on ARM-specific struct hw_pci (Phil Edworthy)
- Set root bus nr to that provided in DT (Phil Edworthy)
- Fix I/O offset for multiple host bridges (Phil Edworthy)
ST Microelectronics SPEAr13xx host bridge driver:
- Fix dw_pcie_cfg_read/write() usage (Gabriele Paoloni)
Synopsys DesignWare host bridge driver:
- Make "clocks" and "clock-names" optional DT properties (Bhupesh Sharma)
- Use exact access size in dw_pcie_cfg_read() (Gabriele Paoloni)
- Simplify dw_pcie_cfg_read/write() interfaces (Gabriele Paoloni)
- Require config accesses to be naturally aligned (Gabriele Paoloni)
- Make "num-lanes" an optional DT property (Gabriele Paoloni)
- Move calculation of bus addresses to DRA7xx (Gabriele Paoloni)
- Replace ARM pci_sys_data->align_resource with global function pointer (Gabriele Paoloni)
- Factor out MSI msg setup (Lucas Stach)
- Implement multivector MSI IRQ setup (Lucas Stach)
- Make get_msi_addr() return phys_addr_t, not u32 (Lucas Stach)
- Set up high part of MSI target address (Lucas Stach)
- Fix PORT_LOGIC_LINK_WIDTH_MASK (Zhou Wang)
- Revert "PCI: designware: Program ATU with untranslated address" (Zhou Wang)
- Use of_pci_get_host_bridge_resources() to parse DT (Zhou Wang)
- Make driver arch-agnostic (Zhou Wang)
Miscellaneous:
- Make x86 pci_subsys_init() static (Alexander Kuleshov)
- Turn off Request Attributes to avoid Chelsio T5 Completion erratum (Hariprasad Shenai)"
* tag 'pci-v4.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits)
PCI: altera: Add Altera PCIe MSI driver
PCI: layerscape: Add ls_pcie_msi_host_init()
PCI: layerscape: Add support for LS1043a and LS2080a
PCI: layerscape: Remove unused fields from struct ls_pcie
PCI: layerscape: Update ls_add_pcie_port()
PCI: layerscape: Factor out SCFG related function
PCI: layerscape: Ignore PCIe controllers in Endpoint mode
PCI: layerscape: Remove ls_pcie_establish_link()
PCI: designware: Make "clocks" and "clock-names" optional DT properties
ARM/PCI: Replace pci_sys_data->align_resource with global function pointer
PCI: designware: Move calculation of bus addresses to DRA7xx
PCI: designware: Make "num-lanes" an optional DT property
PCI: designware: Require config accesses to be naturally aligned
PCI: designware: Simplify dw_pcie_cfg_read/write() interfaces
PCI: designware: Use exact access size in dw_pcie_cfg_read()
PCI: spear: Fix dw_pcie_cfg_read/write() usage
Pull power management and ACPI updates from Rafael Wysocki:
"Quite a new features are included this time.
First off, the Collaborative Processor Performance Control interface
(version 2) defined by ACPI will now be supported on ARM64 along with
a cpufreq frontend for CPU performance scaling.
Second, ACPI gets a new infrastructure for the early probing of IRQ
chips and clock sources (along the lines of the existing similar
mechanism for DT).
Next, the ACPI core and the generic device properties API will now
support a recently introduced hierarchical properties extension of the
_DSD (Device Specific Data) ACPI device configuration object. If the
ACPI platform firmware uses that extension to organize device
properties in a hierarchical way, the kernel will automatically handle
it and make those properties available to device drivers via the
generic device properties API.
It also will be possible to build the ACPICA's AML interpreter
debugger into the kernel now and use that to diagnose AML-related
problems more efficiently. In the future, this should make it
possible to single-step AML execution and do similar things.
Interesting stuff, although somewhat experimental at this point.
Finally, the PM core gets a new mechanism that can be used by device
drivers to distinguish between suspend-to-RAM (based on platform
firmware support) and suspend-to-idle (or other variants of system
suspend the platform firmware is not involved in) and possibly
optimize their device suspend/resume handling accordingly.
In addition to that, some existing features are re-organized quite
substantially.
First, the ACPI-based handling of PCI host bridges on x86 and ia64 is
unified and the common code goes into the ACPI core (so as to reduce
code duplication and eliminate non-essential differences between the
two architectures in that area).
Second, the Operating Performance Points (OPP) framework is
reorganized to make the code easier to find and follow.
Next, the cpufreq core's sysfs interface is reorganized to get rid of
the "primary CPU" concept for configurations in which the same
performance scaling settings are shared between multiple CPUs.
Finally, some interfaces that aren't necessary any more are dropped
from the generic power domains framework.
On top of the above we have some minor extensions, cleanups and bug
fixes in multiple places, as usual.
Specifics:
- ACPICA update to upstream revision 20150930 (Bob Moore, Lv Zheng).
The most significant change is to allow the AML debugger to be
built into the kernel. On top of that there is an update related
to the NFIT table (the ACPI persistent memory interface) and a few
fixes and cleanups.
- ACPI CPPC2 (Collaborative Processor Performance Control v2) support
along with a cpufreq frontend (Ashwin Chaugule).
This can only be enabled on ARM64 at this point.
- New ACPI infrastructure for the early probing of IRQ chips and
clock sources (Marc Zyngier).
- Support for a new hierarchical properties extension of the ACPI
_DSD (Device Specific Data) device configuration object allowing
the kernel to handle hierarchical properties (provided by the
platform firmware this way) automatically and make them available
to device drivers via the generic device properties interface
(Rafael Wysocki).
- Generic device properties API extension to obtain an index of
certain string value in an array of strings, along the lines of
of_property_match_string(), but working for all of the supported
firmware node types, and support for the "dma-names" device
property based on it (Mika Westerberg).
- ACPI core fix to parse the MADT (Multiple APIC Description Table)
entries in the order expected by platform firmware (and mandated by
the specification) to avoid confusion on systems with more than 255
logical CPUs (Lukasz Anaczkowski).
- Consolidation of the ACPI-based handling of PCI host bridges on x86
and ia64 (Jiang Liu).
- ACPI core fixes to ensure that the correct IRQ number is used to
represent the SCI (System Control Interrupt) in the cases when it
has been re-mapped (Chen Yu).
- New ACPI backlight quirk for Lenovo IdeaPad S405 (Hans de Goede).
- ACPI EC driver fixes (Lv Zheng).
- Assorted ACPI fixes and cleanups (Dan Carpenter, Insu Yun, Jiri
Kosina, Rami Rosen, Rasmus Villemoes).
- New mechanism in the PM core allowing drivers to check if the
platform firmware is going to be involved in the upcoming system
suspend or if it has been involved in the suspend the system is
resuming from at the moment (Rafael Wysocki).
This should allow drivers to optimize their suspend/resume handling
in some cases and the changes include a couple of users of it (the
i8042 input driver, PCI PM).
- PCI PM fix to prevent runtime-suspended devices with PME enabled
from being resumed during system suspend even if they aren't
configured to wake up the system from sleep (Rafael Wysocki).
- New mechanism to report the number of a wakeup IRQ that woke up the
system from sleep last time (Alexandra Yates).
- Removal of unused interfaces from the generic power domains
framework and fixes related to latency measurements in that code
(Ulf Hansson, Daniel Lezcano).
- cpufreq core sysfs interface rework to make it handle CPUs that
share performance scaling settings (represented by a common cpufreq
policy object) more symmetrically (Viresh Kumar).
This should help to simplify the CPU offline/online handling among
other things.
- cpufreq core fixes and cleanups (Viresh Kumar).
- intel_pstate fixes related to the Turbo Activation Ratio (TAR)
mechanism on client platforms which causes the turbo P-states range
to vary depending on platform firmware settings (Srinivas
Pandruvada).
- intel_pstate sysfs interface fix (Prarit Bhargava).
- Assorted cpufreq driver (imx, tegra20, powernv, integrator) fixes
and cleanups (Bai Ping, Bartlomiej Zolnierkiewicz, Shilpasri G
Bhat, Luis de Bethencourt).
- cpuidle mvebu driver cleanups (Russell King).
- OPP (Operating Performance Points) framework code reorganization to
make it more maintainable (Viresh Kumar).
- Intel Broxton support for the RAPL (Running Average Power Limits)
power capping driver (Amy Wiles).
- Assorted power management code fixes and cleanups (Dan Carpenter,
Geert Uytterhoeven, Geliang Tang, Luis de Bethencourt, Rasmus
Villemoes)"
* tag 'pm+acpi-4.4-rc1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (108 commits)
cpufreq: postfix policy directory with the first CPU in related_cpus
cpufreq: create cpu/cpufreq/policyX directories
cpufreq: remove cpufreq_sysfs_{create|remove}_file()
cpufreq: create cpu/cpufreq at boot time
cpufreq: Use cpumask_copy instead of cpumask_or to copy a mask
cpufreq: ondemand: Drop unnecessary locks from update_sampling_rate()
PM / Domains: Merge measurements for PM QoS device latencies
PM / Domains: Don't measure ->start|stop() latency in system PM callbacks
PM / clk: Fix broken build due to non-matching code and header #ifdefs
ACPI / Documentation: add copy_dsdt to ACPI format options
ACPI / sysfs: correctly check failing memory allocation
ACPI / video: Add a quirk to force native backlight on Lenovo IdeaPad S405
ACPI / CPPC: Fix potential memory leak
ACPI / CPPC: signedness bug in register_pcc_channel()
ACPI / PAD: power_saving_thread() is not freezable
ACPI / PM: Fix incorrect wakeup IRQ setting during suspend-to-idle
ACPI: Using correct irq when waiting for events
ACPI: Use correct IRQ when uninstalling ACPI interrupt handler
cpuidle: mvebu: disable the bind/unbind attributes and use builtin_platform_driver
cpuidle: mvebu: clean up multiple platform drivers
Pull irq updates from Thomas Gleixner:
"The irq departement delivers:
- Rework the irqdomain core infrastructure to accomodate ACPI based
systems. This is required to support ARM64 without creating
artificial device tree nodes.
- Sanitize the ACPI based ARM GIC initialization by making use of the
new firmware independent irqdomain core
- Further improvements to the generic MSI management
- Generalize the irq migration on CPU hotplug
- Improvements to the threaded interrupt infrastructure
- Allow the migration of "chained" low level interrupt handlers
- Allow optional force masking of interrupts in disable_irq[_nosysnc]
- Support for two new interrupt chips - Sigh!
- A larger set of errata fixes for ARM gicv3
- The usual pile of fixes, updates, improvements and cleanups all
over the place"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
Document that IRQ_NONE should be returned when IRQ not actually handled
PCI/MSI: Allow the MSI domain to be device-specific
PCI: Add per-device MSI domain hook
of/irq: Use the msi-map property to provide device-specific MSI domain
of/irq: Split of_msi_map_rid to reuse msi-map lookup
irqchip/gic-v3-its: Parse new version of msi-parent property
PCI/MSI: Use of_msi_get_domain instead of open-coded "msi-parent" parsing
of/irq: Use of_msi_get_domain instead of open-coded "msi-parent" parsing
of/irq: Add support code for multi-parent version of "msi-parent"
irqchip/gic-v3-its: Add handling of PCI requester id.
PCI/MSI: Add helper function pci_msi_domain_get_msi_rid().
of/irq: Add new function of_msi_map_rid()
Docs: dt: Add PCI MSI map bindings
irqchip/gic-v2m: Add support for multiple MSI frames
irqchip/gic-v3: Fix translation of LPIs after conversion to irq_fwspec
irqchip/mxs: Add Alphascale ASM9260 support
irqchip/mxs: Prepare driver for hardware with different offsets
irqchip/mxs: Panic if ioremap or domain creation fails
irqdomain: Documentation updates
irqdomain/msi: Use fwnode instead of of_node
* pci/host-layerscape:
* pci/host-hisi:
'pci/host-imx6', 'pci/host-iproc', 'pci/host-mvebu', 'pci/host-rcar', 'pci/host-tegra' and 'pci/host-xgene' into next
* pci/host-altera:
ARM: Add msi.h to Kbuild
* pci/host-designware:
PCI: designware: Set up high part of MSI target address
PCI: designware: Make get_msi_addr() return phys_addr_t, not u32
PCI: designware: Implement multivector MSI IRQ setup
PCI: designware: Factor out MSI msg setup
PCI: Add msi_controller setup_irqs() method for special multivector setup
PCI: designware: Fix PORT_LOGIC_LINK_WIDTH_MASK
* pci/host-generic:
PCI: generic: Fix address window calculation for non-zero starting bus
PCI: generic: Pass starting bus number to pci_scan_root_bus()
PCI: generic: Allow multiple hosts with different map_bus() methods
arm64: dts: Drop linux,pci-probe-only from the Seattle DTS
powerpc/PCI: Fix lookup of linux,pci-probe-only property
PCI: generic: Fix lookup of linux,pci-probe-only property
of/pci: Add of_pci_check_probe_only to parse "linux,pci-probe-only"
* pci/host-imx6:
PCI: imx6: Add PCIE_PHY_RX_ASIC_OUT_VALID definition
PCI: imx6: Return real error code from imx6_add_pcie_port()
* pci/host-iproc:
PCI: iproc: Fix header comment "Corporation" misspelling
PCI: iproc: Add outbound mapping support
PCI: iproc: Update PCIe device tree bindings
PCI: iproc: Improve link detection logic
PCI: iproc: Fix PCIe reset logic
PCI: iproc: Call pci_fixup_irqs() for ARM64 as well as ARM
PCI: iproc: Remove unused struct iproc_pcie.irqs[]
PCI: iproc: Fix code comment to match code
* pci/host-mvebu:
PCI: mvebu: Remove code restricting accesses to slot 0
PCI: mvebu: Add PCI Express root complex capability block
PCI: mvebu: Improve clock/reset handling
PCI: mvebu: Use gpio_desc to carry around gpio
PCI: mvebu: Use devm_kcalloc() to allocate an array
PCI: mvebu: Use gpio_set_value_cansleep()
PCI: mvebu: Split port parsing and resource claiming from port setup
PCI: mvebu: Fix memory leaks and refcount leaks
PCI: mvebu: Move port parsing and resource claiming to separate function
PCI: mvebu: Use port->name rather than "PCIe%d.%d"
PCI: mvebu: Report full node name when reporting a DT error
PCI: mvebu: Use for_each_available_child_of_node() to walk child nodes
PCI: mvebu: Use of_get_available_child_count()
PCI: mvebu: Use exact config access size; don't read/modify/write
PCI: mvebu: Return zero for reserved or unimplemented config space
* pci/host-rcar:
PCI: rcar: Fix I/O offset for multiple host bridges
PCI: rcar: Set root bus nr to that provided in DT
PCI: rcar: Remove dependency on ARM-specific struct hw_pci
PCI: rcar: Make PCI aware of the I/O resources
PCI: rcar: Build pcie-rcar.c only on ARM
PCI: rcar: Build pci-rcar-gen2.c only on ARM
* pci/host-tegra:
PCI: tegra: Wrap static pgprot_t initializer with __pgprot()
* pci/host-xgene:
PCI/MSI: xgene: Remove msi_controller assignment
Add Altera PCIe MSI driver. This soft IP supports a configurable number of
vectors, which is a DTS parameter.
[bhelgaas: Kconfig depend on PCIE_ALTERA, typos, whitespace]
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Rob Herring <robh@kernel.org>
'pci/resource' and 'pci/virtualization' into next
* pci/aer:
PCI/AER: Clear error status registers during enumeration and restore
* pci/hotplug:
PCI: pciehp: Queue power work requests in dedicated function
* pci/misc:
PCI: Turn off Request Attributes to avoid Chelsio T5 Completion erratum
x86/PCI: Make pci_subsys_init() static
PCI: Add builtin_pci_driver() to avoid registration boilerplate
PCI: Remove unnecessary "if" statement
* pci/msi:
x86/PCI: Don't alloc pcibios-irq when MSI is enabled
PCI/MSI: Export all remapped MSIs to sysfs attributes
PCI: Disable MSI on SiS 761
* pci/resource:
sparc/PCI: Add mem64 resource parsing for root bus
PCI: Expand Enhanced Allocation BAR output
PCI: Make Enhanced Allocation bitmasks more obvious
PCI: Handle Enhanced Allocation capability for SR-IOV devices
PCI: Add support for Enhanced Allocation devices
PCI: Add Enhanced Allocation register entries
PCI: Handle IORESOURCE_PCI_FIXED when assigning resources
PCI: Handle IORESOURCE_PCI_FIXED when sizing resources
PCI: Clear IORESOURCE_UNSET when reverting to firmware-assigned address
* pci/virtualization:
PCI: Fix sriov_enable() error path for pcibios_enable_sriov() failures
PCI: Wait 1 second between disabling VFs and clearing NumVFs
PCI: Reorder pcibios_sriov_disable()
PCI: Remove VFs in reverse order if virtfn_add() fails
PCI: Remove redundant validation of SR-IOV offset/stride registers
PCI: Set SR-IOV NumVFs to zero after enumeration
PCI: Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs
PCI: Don't try to restore VF BARs
Add PCIe host support for HiSilicon SoC Hip05, related DT binding
documentation, and maintainer update.
[bhelgaas: changelog, 32-bit only config write warning text]
Signed-off-by: Zhou Wang <wangzhou1@hisilicon.com>
Signed-off-by: liudongdong <liudongdong3@huawei.com>
Acked-by: Rob Herring <robh@kernel.org> (DT binding)
Layerscape PCIe has its own MSI implementation.
Register ls_pcie_msi_host_init() to avoid using DesignWare's MSI.
[bhelgaas: add comment]
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
Both LS1043a and LS2080a are based on ARMv8 64-bit architecture and have
similar PCIe implementation. LUT is added to controller.
Add LS1043a and LS2080a support.
[bhelgaas: move unused field removal into separate patch, include DT update]
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> (DT update)
Acked-by: Arnd Bergmann <arnd@arndb.de> (DT update)
Removed unused node, dev, and bus fields from struct ls_pcie.
[bhelgaas: split into separate patch]
Update the ls_add_pcie_port() signature to keep it consistent with the
other DesignWare-based host drivers.
For the LS1021a PCIe controller, some status registers are located in SCFG,
unlike other Layerscape devices.
Move SCFG-related code to ls1021_pcie_host_init() and rename
ls_pcie_link_up() to ls1021_pcie_link_up() because LTSSM status is also in
SCFG.
