path: root/drivers/pci
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08intel-iommu: Fix intel_iommu_unmap_range() with size 0Sheng Yang
After some API change, intel_iommu_unmap_range() introduced a assumption that parameter size != 0, otherwise the dma_pte_clean_range() would have a overflowed argument. But the user like KVM don't have this assumption before, then some BUG() triggered. Fix it by ignoring size = 0. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: Fix IRQ swizzling for ARI-enabled devices ia64/PCI: adjust section annotation for pcibios_setup() x86/PCI: get root CRS before scanning children x86/PCI: fix boundary checking when using root CRS PCI MSI: Fix restoration of MSI/MSI-X mask states in suspend/resume PCI MSI: Unmask MSI if setup failed PCI MSI: shorten PCI_MSIX_ENTRY_* symbol names PCI: make pci_name() take const argument PCI: More PATA quirks for not entering D3 PCI: fix kernel-doc warnings PCI: check if bus has a proper bridge device before triggering SBR PCI: remove pci_dac_dma_... APIs on mn10300 PCI ECRC: Remove unnecessary semicolons PCI MSI: Return if alloc_msi_entry for MSI-X failed
2009-07-04intel-iommu: Don't use identity mapping for PCI devices behind bridgesDavid Woodhouse
Our current strategy for pass-through mode is to put all devices into the 1:1 domain at startup (which is before we know what their dma_mask will be), and only _later_ take them out of that domain, if it turns out that they really can't address all of memory. However, when there are a bunch of PCI devices behind a bridge, they all end up with the same source-id on their DMA transactions, and hence in the same IOMMU domain. This means that we _can't_ easily move them from the 1:1 domain into their own domain at runtime, because there might be DMA in-flight from their siblings. So we have to adjust our pass-through strategy: For PCI devices not on the root bus, and for the bridges which will take responsibility for their transactions, we have to start up _out_ of the 1:1 domain, just in case. This fixes the BUG() we see when we have 32-bit-capable devices behind a PCI-PCI bridge, and use the software identity mapping. It does mean that we might end up using 'normal' mapping mode for some devices which could actually live with the faster 1:1 mapping -- but this is only for PCI devices behind bridges, which presumably aren't the devices for which people are most concerned about performance. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: Use iommu_should_identity_map() at startup time too.David Woodhouse
At boot time, the dma_mask won't have been set on any devices, so we assume that all devices will be 64-bit capable (and thus get a 1:1 map). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: No mapping for non-PCI devicesDavid Woodhouse
This should fix kernel.org bug #11821, where the dcdbas driver makes up a platform device and then uses dma_alloc_coherent() on it, in an attempt to get memory < 4GiB. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: Restore DMAR_BROKEN_GFX_WA option for broken graphics driversDavid Woodhouse
We need to give people a little more time to fix the broken drivers. Re-introduce this, but tied in properly with the 'iommu=pt' support this time. Change the config option name and make it default to 'no' too. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: Add iommu_should_identity_map() functionDavid Woodhouse
We do this twice, and it's about to get more complicated. This makes the code slightly clearer about what it's doing, too. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: Fix reattaching of devices to identity mapping domainDavid Woodhouse
When we reattach a device to the si_domain (because it's been removed from a VM), we weren't calling domain_context_mapping() to actually tell the hardware about that. We should really put the call to domain_context_mapping() into domain_add_dev_info() -- we never call the latter without also doing the former, and we can keep the error paths simple that way. But that's a cleanup which can wait for 2.6.32 now. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: Don't set identity mapping for bypassed graphics devicesDavid Woodhouse
We should check iommu_dummy() _first_, because that means it's attached to an iommu that we've just disabled completely. At the moment, we might try to put the device into the identity mapping domain. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-04intel-iommu: Fix dma vs. mm page confusion with aligned_nrpages()David Woodhouse
The aligned_nrpages() function rounds up to the next VM page, but returns its result as a number of DMA pages. Purely theoretical except on IA64, which doesn't boot with VT-d right now anyway. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-02Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: (38 commits) intel-iommu: Don't keep freeing page zero in dma_pte_free_pagetable() intel-iommu: Introduce first_pte_in_page() to simplify PTE-setting loops intel-iommu: Use cmpxchg64_local() for setting PTEs intel-iommu: Warn about unmatched unmap requests intel-iommu: Kill superfluous mapping_lock intel-iommu: Ensure that PTE writes are 64-bit atomic, even on i386 intel-iommu: Make iommu=pt work on i386 too intel-iommu: Performance improvement for dma_pte_free_pagetable() intel-iommu: Don't free too much in dma_pte_free_pagetable() intel-iommu: dump mappings but don't die on pte already set intel-iommu: Combine domain_pfn_mapping() and domain_sg_mapping() intel-iommu: Introduce domain_sg_mapping() to speed up intel_map_sg() intel-iommu: Simplify __intel_alloc_iova() intel-iommu: Performance improvement for domain_pfn_mapping() intel-iommu: Performance improvement for dma_pte_clear_range() intel-iommu: Clean up iommu_domain_identity_map() intel-iommu: Remove last use of PHYSICAL_PAGE_MASK, for reserving PCI BARs intel-iommu: Make iommu_flush_iotlb_psi() take pfn as argument intel-iommu: Change aligned_size() to aligned_nrpages() intel-iommu: Clean up intel_map_sg(), remove domain_page_mapping() ...
2009-07-02intel-iommu: Don't keep freeing page zero in dma_pte_free_pagetable()David Woodhouse
Check dma_pte_present() and only free the page if there _is_ one. Kind of surprising that there was no warning about this. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-02intel-iommu: Introduce first_pte_in_page() to simplify PTE-setting loopsDavid Woodhouse
On Wed, 2009-07-01 at 16:59 -0700, Linus Torvalds wrote: > I also _really_ hate how you do > > (unsigned long)pte >> VTD_PAGE_SHIFT == > (unsigned long)first_pte >> VTD_PAGE_SHIFT Kill this, in favour of just looking to see if the incremented pte pointer has 'wrapped' onto the next page. Which means we have to check it _after_ incrementing it, not before. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-01PCI: Fix IRQ swizzling for ARI-enabled devicesMatthew Wilcox
For many purposes, including interrupt-swizzling, devices with ARI enabled behave as if they have one device (number 0) and 256 functions. This probably hasn't bitten us in practice because all ARI devices I've seen are also IOV devices, and IOV devices are required to use MSI. This isn't guaranteed, and there are legitimate reasons to use ARI without IOV, and hence potentially use pin-based interrupts. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-07-01intel-iommu: Use cmpxchg64_local() for setting PTEsDavid Woodhouse
2009-07-01intel-iommu: Warn about unmatched unmap requestsDavid Woodhouse
This would have found the bug in i386 pci_unmap_addr() a long time ago. We shouldn't just silently return without doing anything. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-01intel-iommu: Kill superfluous mapping_lockDavid Woodhouse
Since we're using cmpxchg64() anyway (because that's the only way to do an atomic 64-bit store on i386), we might as well ditch the extra locking and just use cmpxchg64() to ensure that we don't add the page twice. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-01intel-iommu: Ensure that PTE writes are 64-bit atomic, even on i386David Woodhouse
2009-07-01Fix iommu address space allocationDavid Woodhouse
This fixes kernel.org bug #13584. The IOVA code attempted to optimise the insertion of new ranges into the rbtree, with the unfortunate result that some ranges just didn't get inserted into the tree at all. Then those ranges would be handed out more than once, and things kind of go downhill from there. Introduced after 2.6.25 by ddf02886cbe665d67ca750750196ea5bf524b10b ("PCI: iova RB tree setup tweak"). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: mark gross <mgross@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30intel-iommu: Performance improvement for dma_pte_free_pagetable()David Woodhouse
As with other functions, batch the CPU data cache flushes and don't keep recalculating PTE addresses. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-30intel-iommu: Don't free too much in dma_pte_free_pagetable()David Woodhouse
The loop condition was wrong -- we should free a PMD only if its _entire_ range is within the range we're intending to clear. The early-termination condition was right, but not the loop. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-30intel-iommu: dump mappings but don't die on pte already setDavid Woodhouse
2009-06-30intel-iommu: Combine domain_pfn_mapping() and domain_sg_mapping()David Woodhouse
2009-06-30intel-iommu: Introduce domain_sg_mapping() to speed up intel_map_sg()David Woodhouse
Instead of calling domain_pfn_mapping() repeatedly with single or small numbers of pages, just pass the sglist in. It can optimise the number of cache flushes like domain_pfn_mapping() does, and gives a huge speedup for large scatterlists. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29PCI MSI: Fix restoration of MSI/MSI-X mask states in suspend/resumeHidetoshi Seto
There are 2 problems on mask states in suspend/resume. [1]: It is better to restore the mask states of MSI/MSI-X to initial states (MSI is unmasked, MSI-X is masked) when we release the device. The pci_msi_shutdown() does the restoration of mask states for MSI, while the msi_free_irqs() does it for MSI-X. In other words, in the "disable" path both of MSI and MSI-X are handled, but in the "shutdown" path only MSI is handled. MSI: pci_disable_msi() => pci_msi_shutdown() [ mask states for MSI restored ] => msi_set_enable(dev, pos, 0); => msi_free_irqs() MSI-X: pci_disable_msix() => pci_msix_shutdown() => msix_set_enable(dev, 0); => msix_free_all_irqs => msi_free_irqs() [ mask states for MSI-X restored ] This patch moves the masking for MSI-X from msi_free_irqs() to pci_msix_shutdown(). This change has some positive side effects: - It prevents OS from touching mask states before reading preserved bits in the register, which can be happen if msi_free_irqs() is called from error path in msix_capability_init(). - It also prevents touching the register after turning off MSI-X in "disable" path, which can be a problem on some devices. [2]: We have cache of the mask state in msi_desc, which is automatically updated when msi/msix_mask_irq() is called. This cached states are used for the resume. But since what need to be restored in the resume is the states before the shutdown on the suspend, calling msi/msix_mask_irq() from pci_msi/msix_shutdown() is not appropriate. This patch introduces __msi/msix_mask_irq() that do mask as same as msi/msix_mask_irq() but does not update cached state, for use in pci_msi/msix_shutdown(). [updated: get rid of msi/msix_mask_irq_nocache() (proposed by Matthew Wilcox)] Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI MSI: Unmask MSI if setup failedHidetoshi Seto
The initial state of mask register of MSI is unmasked. We set it masked before calling arch_setup_msi_irqs(). If arch_setup_msi_irq() fails, it is better to restore the state of the mask register. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI MSI: shorten PCI_MSIX_ENTRY_* symbol namesHidetoshi Seto
These names are too long! Drop _OFFSET to save some bytes/lines. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI: More PATA quirks for not entering D3Alan Cox
The ALi loses some state if it goes into D3. Unfortunately even with the chipset documents I can't figure out how to restore some bits of it. The VIA one saves/restores apparently fine but the ACPI _GTM methods break on some platforms if we do this and this causes cable misdetections. These are both effectively regressions as historically nothing matched the devices and then decided not to bind to them. Nowdays something is binding to all sorts of devices and a result they get dumped into D3. Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI: fix kernel-doc warningsRandy Dunlap
Add documentation for missing parameters in PCI hotplug code. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI: check if bus has a proper bridge device before triggering SBRYu Zhao
For devices attached to the root bus, we can't trigger Secondary Bus Reset because there is no bridge device associated with the bus. So need to check bus->self again NULL first before using it. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI ECRC: Remove unnecessary semicolonsJoe Perches
Acked-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI MSI: Return if alloc_msi_entry for MSI-X failedHidetoshi Seto
In current code it continues setup even if alloc_msi_entry() for MSI-X is failed due to lack of memory. It means arch_setup_msi_irqs() might be called with msi_desc entries less than its argument nvec. At least x86's arch_setup_msi_irqs() uses list_for_each_entry() for dev->msi_list that suspected to have entries same numbers as nvec, and it doesn't check the number of allocated vectors and passed arg nvec. Therefore it will result in success of pci_enable_msix(), with less vectors allocated than requested. This patch fixes the error route to return -ENOMEM, instead of continuing the setup (proposed by Matthew Wilcox). Note that there is no iounmap in msi_free_irqs() if no msi_disc is allocated. Reviewed-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29intel-iommu: Simplify __intel_alloc_iova()David Woodhouse
There's no need for the separate iommu_alloc_iova() function, and certainly not for it to be global. Remove the underscores while we're at it. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Performance improvement for domain_pfn_mapping()David Woodhouse
As with dma_pte_clear_range(), don't keep flushing a single PTE at a time. And also micro-optimise the setting of PTE values rather than using the helper functions to do all the masking. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Performance improvement for dma_pte_clear_range()David Woodhouse
It's a bit silly to repeatedly call domain_flush_cache() for each PTE individually, as we clear it. Instead, batch them up and flush a whole range at a time. We might as well refrain from recalculating the PTE address from scratch each time round the loop too. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Clean up iommu_domain_identity_map()David Woodhouse
2009-06-29intel-iommu: Remove last use of PHYSICAL_PAGE_MASK, for reserving PCI BARsDavid Woodhouse
This is fairly broken anyway -- it doesn't take hotplug into account. We should probably be checking page_is_ram() instead. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Make iommu_flush_iotlb_psi() take pfn as argumentDavid Woodhouse
Most of its callers are having to shift for themselves anyway, so we might as well do it in iommu_flush_iotlb_psi(). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Change aligned_size() to aligned_nrpages()David Woodhouse
2009-06-29intel-iommu: Clean up intel_map_sg(), remove domain_page_mapping()David Woodhouse
2009-06-29intel-iommu: Use domain_pfn_mapping() in intel_iommu_map_range()David Woodhouse
2009-06-29intel-iommu: Use domain_pfn_mapping() in __intel_map_single()David Woodhouse
2009-06-29intel-iommu: Introduce domain_pfn_mapping()David Woodhouse
... and use it in the trivial cases; the other callers want individual (and bisectable) attention, since I screwed them up the first time... Make the BUG_ON() happen on too-large virtual address rather than physical address, too. That's the one we care about. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Clean up address handling in domain_page_mapping()David Woodhouse
No more masking and alignment; just use pfns. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Change addr_to_dma_pte() to pfn_to_dma_pte()David Woodhouse
2009-06-29intel-iommu: Clean up intel_iommu_unmap_range()David Woodhouse
Use unaligned address for domain->max_addr. That algorithm isn't ideal anyway -- we should probably just look at the last iova in the tree. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Make dma_pte_free_pagetable() take pfns as argumentDavid Woodhouse
With some cleanup of intel_unmap_page(), intel_unmap_sg() and vm_domain_exit() to no longer play with 64-bit addresses. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-29intel-iommu: Make dma_pte_free_pagetable() use pfnsDavid Woodhouse
2009-06-29intel-iommu: Make dma_pte_clear_range() take pfns as argumentDavid Woodhouse
Noting that this is now an _inclusive_ range. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
