path: root/drivers/pci
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-25Merge tag 'pci-v3.9-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug - Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu) - Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu) - Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu) - Stop caching _PRT and make independent of bus numbers (Yinghai Lu) PCI device hotplug - Clean up cpqphp dead code (Sasha Levin) - Disable ARI unless device and upstream bridge support it (Yijing Wang) - Initialize all hot-added devices (not functions 0-7) (Yijing Wang) Power management - Don't touch ASPM if disabled (Joe Lawrence) - Fix ASPM link state management (Myron Stowe) Miscellaneous - Fix PCI_EXP_FLAGS accessor (Alex Williamson) - Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov) - Document hotplug resource and MPS parameters (Yijing Wang) - Add accessor for PCIe capabilities (Myron Stowe) - Drop pciehp suspend/resume messages (Paul Bolle) - Make pci_slot built-in only (not a module) (Jiang Liu) - Remove unused PCI/ACPI bind ops (Jiang Liu) - Removed used pci_root_bus (Bjorn Helgaas)" * tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits) PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS ACPI / PCI: Make pci_slot built-in only, not a module PCI/PM: Clear state_saved during suspend PCI: Use atomic_inc_return() rather than atomic_add_return() PCI: Catch attempts to disable already-disabled devices PCI: Disable Bus Master unconditionally in pci_device_shutdown() PCI: acpiphp: Remove dead code for PCI host bridge hotplug PCI: acpiphp: Create companion ACPI devices before creating PCI devices PCI: Remove unused "rc" in virtfn_add_bus() PCI: pciehp: Drop suspend/resume ENTRY messages PCI/ASPM: Don't touch ASPM if forcibly disabled PCI/ASPM: Deallocate upstream link state even if device is not PCIe PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc PCI: Document hpiosize= and hpmemsize= resource reservation parameters PCI: Use PCI Express Capability accessor PCI: Introduce accessor to retrieve PCIe Capabilities Register PCI: Put pci_dev in device tree as early as possible PCI: Skip attaching driver in device_add() PCI: acpiphp: Keep driver loaded even if no slots found ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "The most prominent change in this patch set is the software dirty bit patch for s390. It removes __HAVE_ARCH_PAGE_TEST_AND_CLEAR_DIRTY and the page_test_and_clear_dirty primitive which makes the common memory management code a bit less obscure. Heiko fixed most of the PCI related fallout, more often than not missing GENERIC_HARDIRQS dependencies. Notable is one of the 3270 patches which adds an export to tty_io to be able to resize a tty. The rest is the usual bunch of cleanups and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/module: Add missing R_390_NONE relocation type drivers/gpio: add missing GENERIC_HARDIRQ dependency drivers/input: add couple of missing GENERIC_HARDIRQS dependencies s390/cleanup: rename SPP to LPP s390/mm: implement software dirty bits s390/mm: Fix crst upgrade of mmap with MAP_FIXED s390/linker skript: discard exit.data at runtime drivers/media: add missing GENERIC_HARDIRQS dependency s390/bpf,jit: add vlan tag support drivers/net,AT91RM9200: add missing GENERIC_HARDIRQS dependency iucv: fix kernel panic at reboot s390/Kconfig: sort list of arch selected config options phylib: remove !S390 dependeny from Kconfig uio: remove !S390 dependency from Kconfig dasd: fix sysfs cleanup in dasd_generic_remove s390/pci: fix hotplug module init s390/pci: cleanup clp page allocation s390/pci: cleanup clp inline assembly s390/perf: cpum_cf: fallback to software sampling events s390/mm: provide PAGE_SHARED define ...
2013-02-20Merge tag 'pm+acpi-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: - Rework of the ACPI namespace scanning code from Rafael J. Wysocki with contributions from Bjorn Helgaas, Jiang Liu, Mika Westerberg, Toshi Kani, and Yinghai Lu. - ACPI power resources handling and ACPI device PM update from Rafael J Wysocki. - ACPICA update to version 20130117 from Bob Moore and Lv Zheng with contributions from Aaron Lu, Chao Guan, Jesper Juhl, and Tim Gardner. - Support for Intel Lynxpoint LPSS from Mika Westerberg. - cpuidle update from Len Brown including Intel Haswell support, C1 state for intel_idle, removal of global pm_idle. - cpuidle fixes and cleanups from Daniel Lezcano. - cpufreq fixes and cleanups from Viresh Kumar and Fabio Baltieri with contributions from Stratos Karafotis and Rickard Andersson. - Intel P-states driver for Sandy Bridge processors from Dirk Brandewie. - cpufreq driver for Marvell Kirkwood SoCs from Andrew Lunn. - cpufreq fixes related to ordering issues between acpi-cpufreq and powernow-k8 from Borislav Petkov and Matthew Garrett. - cpufreq support for Calxeda Highbank processors from Mark Langsdorf and Rob Herring. - cpufreq driver for the Freescale i.MX6Q SoC and cpufreq-cpu0 update from Shawn Guo. - cpufreq Exynos fixes and cleanups from Jonghwan Choi, Sachin Kamat, and Inderpal Singh. - Support for "lightweight suspend" from Zhang Rui. - Removal of the deprecated power trace API from Paul Gortmaker. - Assorted updates from Andreas Fleig, Colin Ian King, Davidlohr Bueso, Joseph Salisbury, Kees Cook, Li Fei, Nishanth Menon, ShuoX Liu, Srinivas Pandruvada, Tejun Heo, Thomas Renninger, and Yasuaki Ishimatsu. * tag 'pm+acpi-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (267 commits) PM idle: remove global declaration of pm_idle unicore32 idle: delete stray pm_idle comment openrisc idle: delete pm_idle mn10300 idle: delete pm_idle microblaze idle: delete pm_idle m32r idle: delete pm_idle, and other dead idle code ia64 idle: delete pm_idle cris idle: delete idle and pm_idle ARM64 idle: delete pm_idle ARM idle: delete pm_idle blackfin idle: delete pm_idle sparc idle: rename pm_idle to sparc_idle sh idle: rename global pm_idle to static sh_idle x86 idle: rename global pm_idle to static x86_idle APM idle: register apm_cpu_idle via cpuidle cpufreq / intel_pstate: Add kernel command line option disable intel_pstate. cpufreq / intel_pstate: Change to disallow module build tools/power turbostat: display SMI count by default intel_idle: export both C1 and C1E ACPI / hotplug: Fix concurrency issues and memory leaks ...
2013-02-19Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/apic changes from Ingo Molnar: "Main changes: - Multiple MSI support added to the APIC, PCI and AHCI code - acked by all relevant maintainers, by Alexander Gordeev. The advantage is that multiple AHCI ports can have multiple MSI irqs assigned, and can thus spread to multiple CPUs. [ Drivers can make use of this new facility via the pci_enable_msi_block_auto() method ] - x86 IOAPIC code from interrupt remapping cleanups from Joerg Roedel: These patches move all interrupt remapping specific checks out of the x86 core code and replaces the respective call-sites with function pointers. As a result the interrupt remapping code is better abstraced from x86 core interrupt handling code. - Various smaller improvements, fixes and cleanups." * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) x86/intel/irq_remapping: Clean up x2apic opt-out security warning mess x86, kvm: Fix intialization warnings in kvm.c x86, irq: Move irq_remapped out of x86 core code x86, io_apic: Introduce eoi_ioapic_pin call-back x86, msi: Introduce x86_msi.compose_msi_msg call-back x86, irq: Introduce setup_remapped_irq() x86, irq: Move irq_remapped() check into free_remapped_irq x86, io-apic: Remove !irq_remapped() check from __target_IO_APIC_irq() x86, io-apic: Move CONFIG_IRQ_REMAP code out of x86 core x86, irq: Add data structure to keep AMD specific irq remapping information x86, irq: Move irq_remapping_enabled declaration to iommu code x86, io_apic: Remove irq_remapping_enabled check in setup_timer_IRQ0_pin x86, io_apic: Move irq_remapping_enabled checks out of check_timer() x86, io_apic: Convert setup_ioapic_entry to function pointer x86, io_apic: Introduce set_affinity function pointer x86, msi: Use IRQ remapping specific setup_msi_irqs routine x86, hpet: Introduce x86_msi_ops.setup_hpet_msi x86, io_apic: Introduce x86_io_apic_ops.print_entries for debugging x86, io_apic: Introduce x86_io_apic_ops.disable() x86, apic: Mask IO-APIC and PIC unconditionally on LAPIC resume ...
2013-02-19Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "There are lots of improvements, the biggest changes are: Main kernel side changes: - Improve uprobes performance by adding 'pre-filtering' support, by Oleg Nesterov. - Make some POWER7 events available in sysfs, equivalent to what was done on x86, from Sukadev Bhattiprolu. - tracing updates by Steve Rostedt - mostly misc fixes and smaller improvements. - Use perf/event tracing to report PCI Express advanced errors, by Tony Luck. - Enable northbridge performance counters on AMD family 15h, by Jacob Shin. - This tracing commit: tracing: Remove the extra 4 bytes of padding in events changes the ABI. All involved parties (PowerTop in particular) seem to agree that it's safe to do now with the introduction of libtraceevent, but the devil is in the details ... Main tooling side changes: - Add 'event group view', from Namyung Kim: To use it, 'perf record' should group events when recording. And then perf report parses the saved group relation from file header and prints them together if --group option is provided. You can use the 'perf evlist' command to see event group information: $ perf record -e '{ref-cycles,cycles}' noploop 1 [ perf record: Woken up 2 times to write data ] [ perf record: Captured and wrote 0.385 MB perf.data (~16807 samples) ] $ perf evlist --group {ref-cycles,cycles} With this example, default perf report will show you each event separately. You can use --group option to enable event group view: $ perf report --group ... # group: {ref-cycles,cycles} # ======== # Samples: 7K of event 'anon group { ref-cycles, cycles }' # Event count (approx.): 6876107743 # # Overhead Command Shared Object Symbol # ................ ....... ................. .......................... 99.84% 99.76% noploop noploop [.] main 0.07% 0.00% noploop ld-2.15.so [.] strcmp 0.03% 0.00% noploop [kernel.kallsyms] [k] timerqueue_del 0.03% 0.03% noploop [kernel.kallsyms] [k] sched_clock_cpu 0.02% 0.00% noploop [kernel.kallsyms] [k] account_user_time 0.01% 0.00% noploop [kernel.kallsyms] [k] __alloc_pages_nodemask 0.00% 0.00% noploop [kernel.kallsyms] [k] native_write_msr_safe 0.00% 0.11% noploop [kernel.kallsyms] [k] _raw_spin_lock 0.00% 0.06% noploop [kernel.kallsyms] [k] find_get_page 0.00% 0.02% noploop [kernel.kallsyms] [k] rcu_check_callbacks 0.00% 0.02% noploop [kernel.kallsyms] [k] __current_kernel_time As you can see the Overhead column now contains both of ref-cycles and cycles and header line shows group information also - 'anon group { ref-cycles, cycles }'. The output is sorted by period of group leader first. - Initial GTK+ annotate browser, from Namhyung Kim. - Add option for runtime switching perf data file in perf report, just press 's' and a menu with the valid files found in the current directory will be presented, from Feng Tang. - Add support to display whole group data for raw columns, from Jiri Olsa. - Add per processor socket count aggregation in perf stat, from Stephane Eranian. - Add interval printing in 'perf stat', from Stephane Eranian. - 'perf test' improvements - Add support for wildcards in tracepoint system name, from Jiri Olsa. - Add anonymous huge page recognition, from Joshua Zhu. - perf build-id cache now can show DSOs present in a perf.data file that are not in the cache, to integrate with build-id servers being put in place by organizations such as Fedora. - perf top now shares more of the evsel config/creation routines with 'record', paving the way for further integration like 'top' snapshots, etc. - perf top now supports DWARF callchains. - Fix mmap limitations on 32-bit, fix from David Miller. - 'perf bench numa mem' NUMA performance measurement suite - ... and lots of fixes, performance improvements, cleanups and other improvements I failed to list - see the shortlog and git log for details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (270 commits) perf/x86/amd: Enable northbridge performance counters on AMD family 15h perf/hwbp: Fix cleanup in case of kzalloc failure perf tools: Fix build with bison 2.3 and older. perf tools: Limit unwind support to x86 archs perf annotate: Make it to be able to skip unannotatable symbols perf gtk/annotate: Fail early if it can't annotate perf gtk/annotate: Show source lines with gray color perf gtk/annotate: Support multiple event annotation perf ui/gtk: Implement basic GTK2 annotation browser perf annotate: Fix warning message on a missing vmlinux perf buildid-cache: Add --update option uprobes/perf: Avoid uprobe_apply() whenever possible uprobes/perf: Teach trace_uprobe/perf code to use UPROBE_HANDLER_REMOVE uprobes/perf: Teach trace_uprobe/perf code to pre-filter uprobes/perf: Teach trace_uprobe/perf code to track the active perf_event's uprobes: Introduce uprobe_apply() perf: Introduce hw_perf_event->tp_target and ->tp_list uprobes/perf: Always increment trace_uprobe->nhit uprobes/tracing: Kill uprobe_trace_consumer, embed uprobe_consumer into trace_uprobe uprobes/tracing: Introduce is_trace_uprobe_enabled() ...
2013-02-19Merge branch 'pci/yinghai-root-bus-hotplug' into nextBjorn Helgaas
* pci/yinghai-root-bus-hotplug: PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers
2013-02-16PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbersYinghai Lu
Previously, we cached _PRT (PCI routing table, ACPI 5.0 sec 6.2.12) contents and associated each _PRT entry with a PCI bus number. The bus number association means dependencies on PCI device enumeration and bus number assignment, as well as on the PCI/ACPI binding process. After 4f535093cf ("PCI: Put pci_dev in device tree as early as possible"), these dependencies caused the IRQ issues reported by Peter: pci 0000:00:1e.0: PCI bridge to [bus 09] (subtractive decode) pci 0000:00:1e.0: can't derive routing for PCI INT A snd_ctxfi 0000:09:02.0: PCI INT A: no GSI - using ISA IRQ 5 irq 18: nobody cared (try booting with the "irqpoll" option) This patch removes _PRT caching. Instead, we evaluate _PRT as needed in the pci_enable_device() path. This also removes the dependency on PCI bus numbers: we can simply look at the _PRT associated with each bridge as we walk upstream toward the root. [bhelgaas: changelog] Reference: https://bugzilla.kernel.org/show_bug.cgi?id=53561 Reported-and-tested-by: Peter Hurley <peter@hurleysoftware.com> Suggested-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-15Merge branch 'pci/misc' into nextBjorn Helgaas
* pci/misc: PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS
2013-02-15Merge tag '3.8-pci-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fix from Bjorn Helgaas: "This is another fix for v3.8. It fixes an oops that happens when a Thunderbolt adapter is unplugged (remove device, poll for PME events on no-longer-existing device, oops)." * tag '3.8-pci-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI/PM: Clean up PME state when removing a device
2013-02-15PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGSAlex Williamson
PCI_EXP_FLAGS_TYPE is a mask, not an offset. Fix it. Previously, pcie_capability_read_word(..., PCI_EXP_FLAGS, ...) would fail. [bhelgaas: tweak changelog] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.7+
2013-02-14s390/pci: fix hotplug module initSebastian Ott
Loading the pci hotplug module when no devices are present will fail but unfortunately some hotplug callbacks stay registered to the pci bus level. Fix this by not letting module loading fail when no pci devices are present and provide proper {de}registration functions for these callbacks. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14s390/pci: rename pci_probe to s390_pci_probeHeiko Carstens
pci_probe is too generic and has a name clash with other common code parts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-13PCI/PM: Clean up PME state when removing a deviceRafael J. Wysocki
Devices are added to pci_pme_list when drivers use pci_enable_wake() or pci_wake_from_d3(), but they aren't removed from the list unless the driver explicitly disables wakeup. Many drivers never disable wakeup, so their devices remain on the list even after they are removed, e.g., via hotplug. A subsequent PME poll will oops when it tries to touch the device. This patch disables PME# on a device before removing it, which removes the device from pci_pme_list. This is safe even if the device never had PME# enabled. This oops can be triggered by unplugging a Thunderbolt ethernet adapter on a Macbook Pro, as reported by Daniel below. [bhelgaas: changelog] Reference: http://lkml.kernel.org/r/CAMVG2svG21yiM1wkH4_2pen2n+cr2-Zv7TbH3Gj+8MwevZjDbw@mail.gmail.com Reported-and-tested-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org
2013-02-13ACPI / hotplug: Fix concurrency issues and memory leaksRafael J. Wysocki
This changeset is aimed at fixing a few different but related problems in the ACPI hotplug infrastructure. First of all, since notify handlers may be run in parallel with acpi_bus_scan(), acpi_bus_trim() and acpi_bus_hot_remove_device() and some of them are installed for ACPI handles that have no struct acpi_device objects attached (i.e. before those objects are created), those notify handlers have to take acpi_scan_lock to prevent races from taking place (e.g. a struct acpi_device is found to be present for the given ACPI handle, but right after that it is removed by acpi_bus_trim() running in parallel to the given notify handler). Moreover, since some of them call acpi_bus_scan() and acpi_bus_trim(), this leads to the conclusion that acpi_scan_lock should be acquired by the callers of these two funtions rather by these functions themselves. For these reasons, make all notify handlers that can handle device addition and eject events take acpi_scan_lock and remove the acpi_scan_lock locking from acpi_bus_scan() and acpi_bus_trim(). Accordingly, update all of their users to make sure that they are always called under acpi_scan_lock. Furthermore, since eject operations are carried out asynchronously with respect to the notify events that trigger them, with the help of acpi_bus_hot_remove_device(), even if notify handlers take the ACPI scan lock, it still is possible that, for example, acpi_bus_trim() will run between acpi_bus_hot_remove_device() and the notify handler that scheduled its execution and that acpi_bus_trim() will remove the device node passed to acpi_bus_hot_remove_device() for ejection. In that case, the struct acpi_device object obtained by acpi_bus_hot_remove_device() will be invalid and not-so-funny things will ensue. To protect agaist that, make the users of acpi_bus_hot_remove_device() run get_device() on ACPI device node objects that are about to be passed to it and make acpi_bus_hot_remove_device() run put_device() on them and check if their ACPI handles are not NULL (make acpi_device_unregister() clear the device nodes' ACPI handles for that check to work). Finally, observe that acpi_os_hotplug_execute() actually can fail, in which case its caller ought to free memory allocated for the context object to prevent leaks from happening. It also needs to run put_device() on the device node that it ran get_device() on previously in that case. Modify the code accordingly. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org>
2013-02-12Merge branch 'pci/konstantin-runtime-pm' into nextBjorn Helgaas
* pci/konstantin-runtime-pm: PCI/PM: Clear state_saved during suspend PCI: Use atomic_inc_return() rather than atomic_add_return() PCI: Catch attempts to disable already-disabled devices PCI: Disable Bus Master unconditionally in pci_device_shutdown()
2013-02-11PCI/PM: Clear state_saved during suspendRafael J. Wysocki
This patch clears pci_dev->state_saved at the beginning of suspending. PCI config state may be saved long before that. Some drivers call pci_save_state() from the ->probe() callback to get snapshot of sane configuration space to use in the ->slot_reset() callback. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> # add comment Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-11PCI: Use atomic_inc_return() rather than atomic_add_return()Bjorn Helgaas
No functional change; just use atomic_inc_return() rather than the general-purpose atomic_add_return(). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-11PCI: Catch attempts to disable already-disabled devicesKonstantin Khlebnikov
Warn when disabling a device that has already been disabled. [bhelgaas: message wording] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-11PCI: Disable Bus Master unconditionally in pci_device_shutdown()Konstantin Khlebnikov
Commit b566a22c23 ("PCI: disable Bus Master on PCI device shutdown") used pci_disable_device(), but that doesn't disable Bus Mastering unconditionally; we allow nested enable/disable calls, and only the last disable call actually does anything. This uses pci_clear_master() to unconditionally clear the Bus Master bit. Matthew Garrett and Alan Cox said (see LKML link below) that clearing Bus Master for all PCI devices may lead to unpredictable consequences: some devices ignores this bit and continue DMA, some of them hang after that or crash the whole system. But we're already trying to clear Bus Master in general because of b566a22c23; this merely deals with the cases where drivers haven't shut down the device correctly. [bhelgaas: changelog] Link: https://lkml.org/lkml/2012/6/6/278 Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-02Merge branch 'pci/misc' into nextBjorn Helgaas
* pci/misc: PCI: pciehp: Drop suspend/resume ENTRY messages PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc PCI: Document hpiosize= and hpmemsize= resource reservation parameters PCI: Use PCI Express Capability accessor PCI: Introduce accessor to retrieve PCIe Capabilities Register PCI: Kill pci_is_reassigndev()
2013-02-02Merge branch 'pci/joe-aspm' into nextBjorn Helgaas
* pci/joe-aspm: PCI/ASPM: Don't touch ASPM if forcibly disabled PCI/ASPM: Deallocate upstream link state even if device is not PCIe
2013-02-02Merge branch 'pci/yinghai-root-bus-hotplug' into nextBjorn Helgaas
* pci/yinghai-root-bus-hotplug: PCI: acpiphp: Remove dead code for PCI host bridge hotplug PCI: acpiphp: Create companion ACPI devices before creating PCI devices PCI: Remove unused "rc" in virtfn_add_bus()
2013-02-02PCI: acpiphp: Remove dead code for PCI host bridge hotplugJiang Liu
Commit 668192b678201d2fff27c "PCI: acpiphp: Move host bridge hotplug to pci_root.c" has moved PCI host bridge hotplug logic from acpiphp to pci_root, but there is still PCI host bridge hotplug related dead code left in acpiphp. So remove those dead code. Now companion ACPI devices are always created before corresponding PCI devices. And the ACPI event handle_hotplug_event_bridge() will be installed only if it has associated PCI device. So remove dead code to handle bridge hot-adding in function handle_hotplug_event_bridge(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-01PCI: acpiphp: Create companion ACPI devices before creating PCI devicesJiang Liu
With commit 4f535093cf8f6da8c "PCI: Put pci_dev in device tree as early as possible", companion ACPI devices should be created before creating corresponding PCI devices, otherwise it will break the ACPI PCI binding logic. Without this patch, the /sys/bus/pci/devices/.../firmware_node symlink is missing after hot-removing and hot-adding a device with acpiphp. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-01PCI: Remove unused "rc" in virtfn_add_bus()Yijing Wang
Delete unused variable "rc" to fix build warning in drivers/pci/iov.c Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-01PCI: pciehp: Drop suspend/resume ENTRY messagesPaul Bolle
In each suspend and resume cycle my laptop prints these messages at KERN_INFO level: pciehp 0000:00:1c.1:pcie04: pciehp_suspend ENTRY pciehp 0000:00:1c.0:pcie04: pciehp_suspend ENTRY and pciehp 0000:00:1c.0:pcie04: pciehp_resume ENTRY pciehp 0000:00:1c.1:pcie04: pciehp_resume ENTRY Drop these messages, that were probably used to debug the suspend and resume code, but now serve no purpose. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-02-01PCI/ASPM: Don't touch ASPM if forcibly disabledJoe Lawrence
Don't allocate and track PCIe ASPM state when "pcie_aspm=off" is specified on the kernel command line. Based-on-patch-from: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: David Bulkow <david.bulkow@stratus.com> Acked-by: Myron Stowe <myron.stowe@redhat.com>
2013-02-01PCI/ASPM: Deallocate upstream link state even if device is not PCIeMyron Stowe
On PCI bus hotplug removal, pcie_aspm_exit_link_state() can potentially skip parent devices that have link_state allocated. Instead of exiting early if a given device is not PCIe, check whether or not the device's parent has link_state allocated. This enables pcie_aspm_exit_link_state() to properly clean up parent link_state when the last function in a slot might not be PCIe. Reported-by: Joe Lawrence <joe.lawrence@stratus.com> Tested-by: Joe Lawrence <joe.lawrence@stratus.com> Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-01-30PCI: Use PCI Express Capability accessorMyron Stowe
Use PCI Express Capability access functions to simplify device Capabilities Register usages. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-01-29Merge branch 'acpi-scan' into acpi-cleanupRafael J. Wysocki
The following commits depend on the 'acpi-scan' material.
2013-01-29Merge branch 'acpi-pm' into acpi-cleanupRafael J. Wysocki
The following commits depend on the 'acpi-pm' material.
2013-01-26Merge branch 'pci/yinghai-root-bus-hotplug' into nextBjorn Helgaas
* pci/yinghai-root-bus-hotplug: PCI: Put pci_dev in device tree as early as possible PCI: Skip attaching driver in device_add() PCI: acpiphp: Keep driver loaded even if no slots found PCI/ACPI: Print info if host bridge notify handler installation fails PCI: acpiphp: Move host bridge hotplug to pci_root.c PCI/ACPI: acpiphp: Rename alloc_acpiphp_hp_work() to alloc_acpi_hp_work() PCI: Make device create/destroy logic symmetric PCI: Fix reference count leak in pci_dev_present() PCI: Set pci_dev dev_node early so IOAPIC irq_descs are allocated locally PCI: Add root bus children dev's res to fail list PCI: acpiphp: Add is_hotplug_bridge detection Conflicts: drivers/pci/pci.h
2013-01-26Merge branch 'pci/acpi-scan2' into nextBjorn Helgaas
* pci/acpi-scan2: ACPI / scan: Drop acpi_bus_add() and use acpi_bus_scan() instead ACPI: update ej_event interface to take acpi_device ACPI / scan: Add second pass to acpi_bus_trim() ACPI / scan: Change the implementation of acpi_bus_trim() ACPI / scan: Drop the second argument of acpi_bus_trim() ACPI / scan: Drop the second argument of acpi_device_unregister() ACPI: Remove the ops field from struct acpi_device ACPI: remove unused acpi_op_bind and acpi_op_unbind ACPI / scan: Fix check of device_attach() return value.
2013-01-26Merge branch 'pci/yijing-ari' into nextBjorn Helgaas
* pci/yijing-ari: PCI: shpchp: Iterate over all devices in slot, not functions 0-7 PCI: sgihp: Iterate over all devices in slot, not functions 0-7 PCI: cpcihp: Iterate over all devices in slot, not functions 0-7 PCI: pciehp: Iterate over all devices in slot, not functions 0-7 PCI: Consolidate "next-function" functions PCI: Rename pci_enable_ari() to pci_configure_ari() PCI: Enable ARI if dev and upstream bridge support it; disable otherwise
2013-01-26Merge branch 'acpi-scan' into acpi-cleanupRafael J. Wysocki
2013-01-26ACPI / scan: Make it clear that acpi_bus_trim() cannot failRafael J. Wysocki
Since acpi_bus_trim() cannot fail, change its definition to a void function, so that its callers don't check the return value in vain and update the callers. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2013-01-25PCI: Put pci_dev in device tree as early as possibleYinghai Lu
We want to put pci_dev structs in the device tree as soon as possible so for_each_pci_dev() iteration will not miss them, but driver attachment needs to be delayed until after pci_assign_unassigned_resources() to make sure all devices have resources assigned first. This patch moves device registering from pci_bus_add_devices() to pci_device_add(), which happens earlier, leaving driver attachment in pci_bus_add_devices(). It also removes unattached child bus handling in pci_bus_add_devices(). That's not needed because child bus via pci_add_new_bus() is already in parent bus children list. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: Skip attaching driver in device_add()Yinghai Lu
We want to add PCI devices to the device tree as early as possible but delay attaching drivers. device_add() adds a device to the device hierarchy and (via device_attach()) attaches a matching driver and calls its .probe() method. We want to separate adding the device to the hierarchy from attaching the driver. This patch does that by adding "match_driver" in struct pci_dev. When false, we return failure from pci_bus_match(), which makes device_attach() believe there's no matching driver. Later, we set "match_driver = true" and call device_attach() again, which now attaches the driver and calls its .probe() method. [bhelgaas: changelog, explicitly init dev->match_driver, fold device_attach() call into pci_bus_add_device()] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: acpiphp: Keep driver loaded even if no slots foundYinghai Lu
Could have root bus hot-added later and there may be slots that need acpiphp. The result returned by acpiphp_get_num_slots() is meaningless, because the bridge the slots are under may be added after this function has been called, so drop acpiphp_get_num_slots() and the code using it. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: acpiphp: Move host bridge hotplug to pci_root.cYinghai Lu
The acpiphp driver is confusing because it contains partial support for PCI host bridge hotplug as well as support for hotplug of PCI devices. This patch moves the host bridge hot-add support to pci_root.c and adds hot-remove support in pci_root.c. How to test it: if sci_emu patch is applied, find out root bus number to ACPI root name mapping from dmesg or /sys. To remove root bus: echo "\_SB.PCIB 3" > /sys/kernel/debug/acpi/sci_notify To add back root bus: echo "\_SB.PCIB 1" > /sys/kernel/debug/acpi/sci_notify Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI/ACPI: acpiphp: Rename alloc_acpiphp_hp_work() to alloc_acpi_hp_work()Yinghai Lu
Will need to use it for PCI root bridge hotplug support, so rename *acpiphp* to *acpi* and move to osc.c. Also make kacpi_hotplug_wq static after that. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> CC: Len Brown <lenb@kernel.org> CC: linux-acpi@vger.kernel.org
2013-01-25PCI: Make device create/destroy logic symmetricJiang Liu
According to device model documentation, the way to create/destroy PCI devices should be symmetric. The rule is to either use 1) device_register()/device_unregister() or 2) device_initialize()/device_add()/device_del()/put_device(). So change PCI core logic to follow the rule and get rid of the redundant pci_dev_get()/pci_dev_put() pair. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: Fix reference count leak in pci_dev_present()Jiang Liu
Function pci_get_dev_by_id() takes a reference on the pci_dev returned, so pci_dev_present() should release the corresponding reference. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: Set pci_dev dev_node early so IOAPIC irq_descs are allocated locallyYinghai Lu
Otherwise irq_desc for PCI bridge with hot-added IOAPIC may not be allocated on the local node. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: Add root bus children dev's res to fail listYinghai Lu
We can stop trying according to try_number now and do not need to use root_bus checking as stop sign. In extreme case we could need to reallocate resource for device just under root bus. For PCI root bus hot-add, we need to retry to assign resources to PCI devices just under pci root bus. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25PCI: acpiphp: Add is_hotplug_bridge detectionYinghai Lu
When system support hotplug bridge with children hotplug slots, we need to make sure that parent bridge get preallocated resource so later when device is plugged into children slot, those children devices will get resource allocated. We do not meet this problem, because for PCIe hotplug card, when acpiphp is used, pci_scan_bridge will set that for us when detect hotplug bit in slot cap. Reported-and-tested-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Jason Baron <jbaron@redhat.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25Merge branch 'acpi-scan' of ↵Bjorn Helgaas
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm into pci/acpi-scan2 * 'acpi-scan' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / scan: Drop acpi_bus_add() and use acpi_bus_scan() instead ACPI: update ej_event interface to take acpi_device ACPI / scan: Add second pass to acpi_bus_trim() ACPI / scan: Change the implementation of acpi_bus_trim() ACPI / scan: Drop the second argument of acpi_bus_trim() ACPI / scan: Drop the second argument of acpi_device_unregister() ACPI: Remove the ops field from struct acpi_device ACPI: remove unused acpi_op_bind and acpi_op_unbind ACPI / scan: Fix check of device_attach() return value.
