path: root/drivers/pci
2009-02-17Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: iommu: fix Intel IOMMU write-buffer flushing futex: fix reference leak Trivial conflicts fixed manually in drivers/pci/intel-iommu.c
2009-02-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: Documentation: fix minor PCIe HOWTO thinko PCI: fix missing kernel-doc and typos PCI: fix struct pci_platform_pm_ops kernel-doc PCI: fix rom.c kernel-doc warning PCI/MSI: fix msi_mask() shift fix
2009-02-17Fix Intel IOMMU write-buffer flushingDavid Woodhouse
This is the cause of the DMA faults and disk corruption that people have been seeing. Some chipsets neglect to report the RWBF "capability" -- the flag which says that we need to flush the chipset write-buffer when changing the DMA page tables, to ensure that the change is visible to the IOMMU. Override that bit on the affected chipsets, and everything is happy again. Thanks to Chris and Bhavesh and others for helping to debug. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Tested-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-14iommu: fix Intel IOMMU write-buffer flushingDavid Woodhouse
This is the cause of the DMA faults and disk corruption that people have been seeing. Some chipsets neglect to report the RWBF "capability" -- the flag which says that we need to flush the chipset write-buffer when changing the DMA page tables, to ensure that the change is visible to the IOMMU. Override that bit on the affected chipsets, and everything is happy again. Thanks to Chris and Bhavesh and others for helping to debug. Should resolve: https://bugzilla.redhat.com/show_bug.cgi?id=479996 http://bugzilla.kernel.org/show_bug.cgi?id=12578 Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Tested-and-acked-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-13PCI: fix missing kernel-doc and typosRandy Dunlap
Fix pci kernel-doc parameter missing notation, correct function name, and fix typo: Warning(linux-2.6.28-git10//drivers/pci/pci.c:1511): No description found for parameter 'exclusive' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI: fix struct pci_platform_pm_ops kernel-docRandy Dunlap
Fix struct pci_platform_pm_ops kernel-doc notation. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI: fix rom.c kernel-doc warningRandy Dunlap
Fix PCI kernel-doc warning: Warning(linux-2.6.29-rc4-git1/drivers/pci/rom.c:67): No description found for parameter 'pdev' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI/MSI: fix msi_mask() shift fixMatthew Wilcox
Hidetoshi Seto points out that commit bffac3c593eba1f9da3efd0199e49ea6558a40ce has wrong values in the array. Rather than correct the array, we can just use a bounds check and perform the calculation specified in the comment. As a bonus, this will not run off the end of the array if the device specifies an illegal value in the MSI capability. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-11Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptrace, x86: fix the usage of ptrace_fork() i8327: fix outb() parameter order x86: fix math_emu register frame access x86: math_emu info cleanup x86: include correct %gs in a.out core dump x86, vmi: put a missing paravirt_release_pmd in pgd_dtor x86: find nr_irqs_gsi with mp_ioapic_routing x86: add clflush before monitor for Intel 7400 series x86: disable intel_iommu support by default x86: don't apply __supported_pte_mask to non-present ptes x86: fix grammar in user-visible BIOS warning x86/Kconfig.cpu: make Kconfig help readable in the console x86, 64-bit: print DMI info in the oops trace
2009-02-05x86: disable intel_iommu support by defaultKyle McMartin
Due to recurring issues with DMAR support on certain platforms. There's a number of filesystem corruption incidents reported: https://bugzilla.redhat.com/show_bug.cgi?id=479996 http://bugzilla.kernel.org/show_bug.cgi?id=12578 Provide a Kconfig option to change whether it is enabled by default. If disabled, it can still be reenabled by passing intel_iommu=on to the kernel. Keep the .config option off by default. Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-04PCI PM: make the PM core more careful with drivers using the new PM frameworkRafael J. Wysocki
Currently, the PM core always attempts to manage devices with drivers that use the new PM framework. In particular, it attempts to disable the devices (which is unnecessary), to save their state (which may be undesirable if the driver has done that already) and to put them into low power states (again, this may be undesirable if the driver has already put the device into a low power state). That need not be the right thing to do, so make the core be more careful in this respect. Generally, there are the following categories of devices to consider: * bridge devices without drivers * non-bridge devices without drivers * bridge devices with drivers * non-bridge devices with drivers and each of them should be handled differently. For bridge devices without drivers the PCI PM core will save their state on suspend and restore it (early) during resume, after putting them into D0 if necessary. It will not attempt to do anything else to these devices. For non-bridge devices without drivers the PCI PM core will disable them and save their state on suspend. During resume, it will put them into D0, if necessary, restore their state (early) and reenable them. For bridge devices with drivers the PCI PM core will only save their state on suspend if the driver hasn't done that already. Still, the core will restore their state (early) during resume, after putting them into D0, if necessary. For non-bridge devices with drivers the PCI PM core will only save their state on suspend if the driver hasn't done that already. Also, if the state of the device hasn't been saved by the driver, the core will attempt to put the device into a low power state. During resume the core will restore the state of the device (early), after putting it into D0, if necessary. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Read power state from device after trying to change it on resumeRafael J. Wysocki
pci_restore_standard_config() unconditionally changes current_state to PCI_D0 after attempting to change the device's power state, but it should rather read the actual current power state from the device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Do not disable and enable bridges during suspend-resumeRafael J. Wysocki
It is a mistake to disable and enable PCI bridges and PCI Express ports during suspend-resume, at least at the time when it is currently done. Disabling them may lead to problems with accessing devices behind them and they should be automatically enabled when their standard config spaces are restored. Fix this by not attempting to disable bridges during suspend and enable them during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: PCIe portdrv: Simplify suspend and resumeRafael J. Wysocki
Simplify suspend and resume of the PCI Express port driver. It no longer needs to save and restore the standard configuration space of the device; this is now done by the PCI PM core layer. This patch is reported to fix the regression tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12598 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Fix saving of device state in pci_legacy_suspendRafael J. Wysocki
Make pci_legacy_suspend() save the state of the device if it is in PCI_UNKNOWN after its suspend callback has run and warn only if the power state of the device has been changed by its suspend callback. Also, use WARN_ONCE(), which is more useful, in pci_legacy_suspend(), so that the name of the offending function is printed. Additionally, remove the unnecessary line of code setting pci_dev->state_saved. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Check if the state has been saved before trying to restore itRafael J. Wysocki
Check if the standard configuration registers of a PCI device have been saved during suspend before trying to restore them during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-By: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Fix handling of devices without driversRafael J. Wysocki
Suspend to RAM is reported to break on some machines as a result of attempting to put one of driverless PCI devices into a low power state. Avoid that by not attepmting to power manage driverless devices during suspend. Fix up pci_pm_poweroff() after a previous incomplete fix for the same thing during hibernation. This patch is reported to fix the regression from 2.6.28 tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12605 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: return error on failure to read PCI ROMsTimothy S. Nelson
This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: properly clean up ASPM link state on device removeAlex Chiang
We only want to disable ASPM when the last function is removed from the parent's device list. We determine this by checking to see if the parent's device list is completely empty. Unfortunately, we never hit that code because the parent is considered an upstream port, and never had an ASPM link_state associated with it. The early check for !link_state causes us to return early, we never discover that our device list is empty, and thus we never remove the downstream ports' link_state nodes. Instead of checking to see if the parent's device list is empty, we can check to see if we are the last device on the list, and if so, then we know that we can clean up properly. Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI hotplug: Change link order of pciehp & acpiphpMatthew Garrett
Some hardware exposes PCIE slots in such a way that they can be claimed by either the acpiphp or pciehp driver. pciehp is the preferred driver if the firmware allows the OS to claim control via the _OSC method so should be loaded first - if it fails to bind (either due to a missing _OSC method or the firmware refusing to hand off control) then we can fall back to acpiphp or a vendor-specific driver. This patch simply changes the link order to ensure that pciehp will be initialised before acpiphp if both are statically built into the kernel. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI hotplug: fakephp: Allocate PCI resources before adding the deviceDarrick J. Wong
For PCI devices, pci_bus_assign_resources() must be called to set up the pci_device->resource array before pci_bus_add_devices() can be called, else attempts to load drivers results in BAR collision errors where there are none. This is not done in fakephp, so devices can be "unplugged" but scanning the parent bus won't bring the devices back due to resource unallocation. Move the pci_bus_add_device-calling logic into pci_rescan_bus and preface it with a call to pci_bus_assign_resources so that we only have to (re)allocate resources once per bus where a new device is found. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI MSI: Fix undefined shift by 32Matthew Wilcox
Add an msi_mask() function which returns the correct bitmask for the number of MSI interrupts you have. This fixes an undefined bug in msi_capability_init(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Do not wait for buses in B2 or B3 during resumeRafael J. Wysocki
pci_restore_standard_config() adds extra delay for PCI buses in low power states (B2 or B3), but this is only correct for buses in B2, because the buses in B3 are reset when they are put back into B0. Thus we should wait for such buses to settle after the reset, but it's not a good idea to wait that long (1.1 s) with interrupts off. On the other hand, we have never waited for buses in B2 and B3 during resume and it seems reasonable to go back to this well tested behaviour. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Power up devices before restoring their stateRafael J. Wysocki
Devices that have MSI-X enabled before suspend to RAM or hibernation and that are in a low power state during resume will not be handled correctly by pci_restore_standard_config(). Namely, it first calls pci_restore_state() which calls pci_restore_msi_state(), which in turn executes __pci_restore_msix_state() that accesses the device's memory space to restore the contents of the MSI-X table. However, if the device is in a low power state at this point, it's memory space is not accessible. The easiest way to fix this potential problem is to make pci_restore_standard_config() call pci_restore_state() after it has put the device into the full power state, D0. Fortunately, all of this is done with interrupts off, so the change of ordering should not cause any trouble. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Fix hibernation breakage on EeePC 701Rafael J. Wysocki
Hibernation breaks on EeePC 701 as a result of attempting to put one of its (driverless) devices into a low power state. Avoid that by not attepmting to power manage driverless devices during hibernation. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Fix suspend error paths and testing facility breakageRafael J. Wysocki
If one of device drivers refuses to suspend by returning error code from its ->suspend() callback, the devices that have already been suspended are resumed by executing their drivers' ->resume() callbacks. Some of these callbacks expect the device's configuration space to be restored if the device has been put into D3 before they are called. Unfortunately, this mechanism has been broken by recent changes moving the restoration of config spaces of some devices (most importantly, USB controllers and HDA Intel) into the resume callbacks executed with interrupts off. Obviously, these callbacks are not invoked in the suspend error path and, as a result, the system cannot be successfully brought back into the working state in case of a suspend error. The same thing happens in the hibernation error path right before putting the system into S4. Similarly, the suspend testing facility associated with the /sys/power/pm_test file is broken, because it uses the very same mechanism that is used in the suspend and hibernation error paths. Fix the breakage by making the PCI core restore the configuration spaces of PCI devices that haven't been restored already before pci_pm_resume() is called for those devices by the PM core. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI hotplug: fix lock imbalance in pciehp PCI PM: Restore standard config registers of all devices early PCI/MSI: bugfix/utilize for msi_capability_init()
2009-01-19PCI hotplug: fix lock imbalance in pciehpJiri Slaby
set_lock_status omits mutex_unlock in fail path. Add the omitted unlock. As a result a lockup caused by this can be triggered from userspace by writing 1 to /sys/bus/pci/slots/.../lock often enough. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16PCI PM: Restore standard config registers of all devices earlyRafael J. Wysocki
There is a problem in our handling of suspend-resume of PCI devices that many of them have their standard config registers restored with interrupts enabled and they are put into the full power state with interrupts enabled as well. This may lead to the following scenario: * an interrupt vector is shared between two or more devices * one device is resumed earlier and generates an interrupt * the interrupt handler of another device tries to handle it and attempts to access the device the config space of which hasn't been restored yet and/or which still is in a low power state * the system crashes as a result To prevent this from happening we should restore the standard configuration registers of all devices with interrupts disabled and we should put them into the D0 power state right after that. Unfortunately, this cannot be done using the existing pci_set_power_state(), because it can sleep. Also, to do it we have to make sure that the config spaces of all devices were actually saved during suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16PCI/MSI: bugfix/utilize for msi_capability_init()Hidetoshi Seto
This patch fix a following bug and does a cleanup. bug: commit 5993760f7fc75b77e4701f1e56dc84c0d6cf18d5 had a wrong change (since is_64 is boolean[0|1]): - pci_write_config_dword(dev, - msi_mask_bits_reg(pos, is_64bit_address(control)), - maskbits); + pci_write_config_dword(dev, entry->msi_attrib.is_64, maskbits); utilize: Unify separated if (entry->msi_attrib.maskbit) statements. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: "Jike Song" <albcamus@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16ACPI PCI hotplug: harden against panic regressionJames Bottomley
ACPI hotplug panic with current git head http://lkml.org/lkml/2009/1/10/136 Rather than reverting the entire commit that causes the crash: e8c331e963c58b83db24b7d0e39e8c07f687dbc6 "PCI hotplug: introduce functions for ACPI slot detection" simply harden against it while the changes to the hotplug code on this particularl machine are understood. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16Revert "PCI PM: Register power state of devices during initialization"Linus Torvalds
This reverts commit 98e6e286d7b01deb7453b717aa38ebb69d6cefc0, as Yinghai Lu reports that it breaks kexec with at least the e1000 and e1000e drivers. The reason is that the shutdown sequence puts the hardware into D3 sleep, and the commit causes us to claim that it then is in D0 (running) state just because we don't understand the PM capabilities. Which then later makes "pci_set_power_state()" not do anything, and the device never wakes up properly and just returns 0xff to everything. Reported-by: Yinghai Lu <yinghai@kernel.org> Acked-by: From: Rafael J. Wysocki <rjw@sisk.pl> Cc: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-13Prevent oops at boot with VT-dDirk Hohndel
With some broken BIOSs when VT-d is enabled, the data structures are filled incorrectly. This can cause a NULL pointer dereference in very early boot. Signed-off-by: Dirk Hohndel <hohndel@linux.intel.com> Acked-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-10Merge branch 'cpus4096-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: [IA64] fix typo in cpumask_of_pcibus() x86: fix x86_32 builds for summit and es7000 arch's cpumask: use work_on_cpu in acpi-cpufreq.c for read_measured_perf_ctrs cpumask: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write cpumask: use cpumask_var_t in acpi-cpufreq.c cpumask: use work_on_cpu in acpi/cstate.c cpumask: convert struct cpufreq_policy to cpumask_var_t cpumask: replace CPUMASK_ALLOC etc with cpumask_var_t x86: cleanup remaining cpumask_t ops in smpboot code cpumask: update pci_bus_show_cpuaffinity to use new cpumask API cpumask: update local_cpus_show to use new cpumask API ia64: cpumask fix for is_affinity_mask_valid()
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-07PCI PM: Put PM callbacks in the order of executionRafael J. Wysocki
Put PM callbacks in drivers/pci/pci-driver.c in the order in which they are executed which makes it much easier to follow the code. No functional changes should result from this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Run default PM callbacks for all devices using new frameworkRafael J. Wysocki
It should be quite clear that it generally makes sense to execute the default PM callbacks (ie. the callbacks used for handling suspend, hibernation and resume of PCI devices without drivers) for all devices. Of course, the drivers that provide legacy PCI PM support (ie. the ->suspend, ->suspend_late, ->resume_early or ->resume hooks in the pci_driver structure), carry out these operations too, so we can't do it for devices with such drivers. Still, we can make the default PM callbacks run for devices with drivers using the new framework (ie. implement the pm object), since there are no such drivers at the moment. This also simplifies the code and makes it smaller. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Register power state of devices during initializationRafael J. Wysocki
Use the observation that the power state of a PCI device can be loaded into its pci_dev structure as soon as pci_pm_init() is run for it and make that happen. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Call pci_fixup_device from legacy routinesRafael J. Wysocki
The size of drivers/pci/pci-driver.c can be reduced quite a bit if pci_fixup_device() is called from the legacy PM callbacks, so make it happen. No functional changes should result from this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Rearrange code in pci-driver.cRafael J. Wysocki
Rename two functions and rearrange code in drivers/pci/pci-driver.c so that it's easier to follow. In particular, separate invocations of the legacy callbacks from the rest of the new callbacks' code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Avoid touching devices behind bridges in unknown stateRafael J. Wysocki
It generally is better to avoid accessing devices behind bridges that may not be in the D0 power state, because in that case the bridges' secondary buses may not be accessible. For this reason, during the early phase of resume (ie. with interrupts disabled), before restoring the standard config registers of a device, check the power state of the bridge the device is behind and postpone the restoration of the device's config space, as well as any other operations that would involve accessing the device, if that state is not D0. In such cases the restoration of the device's config space will be retried during the "normal" phase of resume (ie. with interrupts enabled), so that the bridge can be put into D0 before that happens. Also, save standard configuration registers of PCI devices during the "normal" phase of suspend (ie. with interrupts enabled), so that the bridges the devices are behind can be put into low power states (we don't put bridges into low power states at the moment, but we may want to do it in the future and it seems reasonable to design for that). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Move pci_has_legacy_pm_supportRafael J. Wysocki
Move pci_has_legacy_pm_support() closer to the functions that call it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Power-manage devices without drivers during suspend-resumeRafael J. Wysocki
PCI devices without drivers can be put into low power states during suspend with the help of pci_prepare_to_sleep() and prevented from generating wake-up events during resume with the help of pci_enable_wake(). However, it's better not to put bridges into low power states during suspend, because that might result in entire bus segments being powered off. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Add suspend counterpart of pci_reenable_deviceRafael J. Wysocki
PCI devices without drivers are not disabled during suspend and hibernation, but they are enabled during resume, with the help of pci_reenable_device(), so there is an unbalanced execution of pcibios_enable_device() in the resume code path. To correct this introduce function pci_disable_enabled_device() that will disable the argument device, if it is enabled when the function is being run, without updating the device's pci_dev structure and use it in the suspend code path to balance the pci_reenable_device() executed during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Fix poweroff and restore callbacksRafael J. Wysocki
pci_fixup_device() is called too early in pci_pm_poweroff() and too late in pci_pm_restore(). Moreover, pci_pm_restore_noirq() calls pci_fixup_device() twice and in a wrong way. Fix that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: Use msleep instead of cpu_relax during ASPM link retrainingAndrew Patterson
The cpu_relax() function can be a noop on certain architectures like IA-64 when CPU threads are disabled, so use msleep instead during link retraining busy/wait loop. Introduce define LINK_RETRAIN_TIMEOUT instead of hard-coding timeout in pcie_aspm_configure_common_clock. Use time_after() to avoid jiffy wraparound when checking for expired timeout. After timeout expires, recheck link status register link training bit instead of checking for expired timeout to avoid possible false positive. Note that Matthew Wilcox came up with the first rough version of this patch. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Add kerneldoc comments to remining core funtionsRafael J. Wysocki
Add kerneldoc comments to the reamining functions in drivers/pci/pcie/portdrv_core.c . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Rearrange code so that related things are togetherRafael J. Wysocki
Rearrange code in drivers/pci/pcie/portdrv_bus.c and drivers/pci/pcie/portdrv_core.c so that related functions and data structures are closer together. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Fix suspend and resume of PCI Express port servicesRafael J. Wysocki
There is a problem with the suspend and resume of PCI Express port service devices that the ->suspend() and ->resume() routines of each service device are called twice in each suspend-resume cycle, which is obviously wrong. The scenario is that first, the PCI Express port driver calls suspend and resume routines of each port service driver from its pcie_portdrv_suspend() and pcie_portdrv_resume() callbacks, respectively (which is correct), and second, the pcie_port_bus_type driver calls them from its ->suspend() and ->resume() callbacks (which is not correct, because it doesn't happen at the right time). The solution is to remove the ->suspend() and ->resume() callbacks from pcie_port_bus_type and the associated functions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
