path: root/drivers/pci/setup-res.c
2014-07-08PCI: Tidy resource assignment messagesBjorn Helgaas
Print messages about failures in pci_assign_resource(). We can drop the "by-hand" message from _pci_assign_resource() because %pR now prints the size rather than the address if the resource hasn't been assigned. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-07-08PCI: Return conventional error values from pci_revert_fw_address()Bjorn Helgaas
Previously we returned zero for success or 1 for failure. This changes that so we return zero for success or a negative errno for failure. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-07-08PCI: Cleanup control flowBjorn Helgaas
Return errors immediately so the straightline path is the normal, no-error path. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-07-03PCI: Keep original resource if we fail to expand itGuo Chao
If we have space assigned to a resource, we try to expand the resource (e.g., to accommodate SR-IOV resources), and the expansion attempt fails, we should keep the original assignment. After bd064f0a231a ("PCI: Mark resources as IORESOURCE_UNSET if we can't assign them"), we left the resource marked IORESOURCE_UNSET when the expansion failed, even if it had originally been set. That caused errors like this: pci 0003:00:00.0: can't enable device: BAR 15 [mem size 0x0c000000 64bit pref] not assigned pci 0003:00:00.0: Error enabling bridge (-22), continuing Fix this by restoring the original flags when reassignment fails. [bhelgaas: reworked to simplify, changelog] Fixes: bd064f0a231a ("PCI: Mark resources as IORESOURCE_UNSET if we can't assign them") Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.15+
2014-06-10PCI: Merge multi-line quoted stringsRyan Desfosses
Merge quoted strings that are broken across lines into a single entity. The compiler merges them anyway, but checkpatch complains about it, and merging them makes it easier to grep for strings. No functional change. [bhelgaas: changelog, do the same for everything under drivers/pci] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-06-10PCI: Move EXPORT_SYMBOL so it immediately follows function/variableRyan Desfosses
Move EXPORT_SYMBOL so it immediately follows the function or variable. No functional change. [bhelgaas: squash similar changes, fix hotplug, probe, rom, search, too] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-26Merge branches 'dma-api', 'pci/virtualization', 'pci/msi', 'pci/misc' and ↵Bjorn Helgaas
'pci/resource' into next * dma-api: iommu/exynos: Remove unnecessary "&" from function pointers DMA-API: Update dma_pool_create ()and dma_pool_alloc() descriptions DMA-API: Fix duplicated word in DMA-API-HOWTO.txt DMA-API: Capitalize "CPU" consistently sh/PCI: Pass GAPSPCI_DMA_BASE CPU & bus address to dma_declare_coherent_memory() DMA-API: Change dma_declare_coherent_memory() CPU address to phys_addr_t DMA-API: Clarify physical/bus address distinction * pci/virtualization: PCI: Mark RTL8110SC INTx masking as broken * pci/msi: PCI/MSI: Remove pci_enable_msi_block() * pci/misc: PCI: Remove pcibios_add_platform_entries() s390/pci: use pdev->dev.groups for attribute creation PCI: Move Open Firmware devspec attribute to PCI common code * pci/resource: PCI: Add resource allocation comments PCI: Simplify __pci_assign_resource() coding style PCI: Change pbus_size_mem() return values to be more conventional PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources PCI: Support BAR sizes up to 8GB resources: Clarify sanity check message PCI: Don't add disabled subtractive decode bus resources PCI: Don't print anything while decoding is disabled PCI: Don't set BAR to zero if dma_addr_t is too small PCI: Don't convert BAR address to resource if dma_addr_t is too small PCI: Reject BAR above 4GB if dma_addr_t is too small PCI: Fail safely if we can't handle BARs larger than 4GB x86/gart: Tidy messages and add bridge device info x86/gart: Replace printk() with pr_info() x86/PCI: Move pcibios_assign_resources() annotation to definition x86/PCI: Mark ATI SBx00 HPET BAR as IORESOURCE_PCI_FIXED x86/PCI: Don't try to move IORESOURCE_PCI_FIXED resources x86/PCI: Fix Broadcom CNB20LE unintended sign extension
2014-05-23PCI: Add resource allocation commentsBjorn Helgaas
Add comments in the code to match the allocation strategy of 7c671426dfc3 ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources"). No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-23PCI: Simplify __pci_assign_resource() coding styleBjorn Helgaas
If an allocation succeeds, we can return success immediately. Then we don't have to test for success in the subsequent code. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-23PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resourcesYinghai Lu
This patch changes the way we handle 64-bit prefetchable bridge windows to make it more likely that we can assign space to all devices. Previously we put all prefetchable resources in the prefetchable bridge window. If any of those resources was 32-bit only, we restricted the window to be below 4GB. After this patch, we only put 64-bit prefetchable resources in a 64-bit prefetchable window. We put all 32-bit prefetchable resources in the non-prefetchable window, even if there are no 64-bit prefetchable resources. With the previous approach, if there was a 32-bit prefetchable resource behind a bridge, we forced the bridge's prefetchable window below 4GB, which meant that even if there was plenty of space above 4GB available, we couldn't use it, and assignment of large 64-bit resources could fail, as in the bugzilla below. The new strategy is: 1) If the prefetchable window is 64 bits wide, we put only 64-bit prefetchable resources in it. Any 32-bit prefetchable resources go in the non-prefetchable window. 2) If the prefetchable window is 32 bits wide, we put both 32- and 64-bit prefetchable resources in it. 3) If there is no prefetchable window, all MMIO resources go in the non-prefetchable window. This reduces performance for 32-bit prefetchable resources below a bridge with a 64-bit prefetchable window. We previously assigned prefetchable space, but now we'll assign non-prefetchable space. This is the case even if there are no 64-bit prefetchable resources, or if they would all fit below 4GB. In those cases, the old strategy would work and would have better performance. [bhelgaas: write changelog, add bugzilla link, fold in mem64_mask removal] Link: https://bugzilla.kernel.org/show_bug.cgi?id=74151 Tested-by: Guo Chao <yan@linux.vnet.ibm.com> Tested-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-04-14PCI: Remove unnecessary includes of <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-03-19PCI: Don't enable decoding if BAR hasn't been assigned an addressBjorn Helgaas
Don't enable memory or I/O decoding if we haven't assigned or claimed the BAR's resource. If we enable decoding for a BAR that hasn't been assigned an address, we'll likely cause bus conflicts. This declines to enable decoding for resources with IORESOURCE_UNSET. Note that drivers can use pci_enable_device_io() or pci_enable_device_mem() if they only care about specific types of BARs. In that case, we don't bother checking whether the corresponding resources are assigned or claimed. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-27PCI: Don't try to claim IORESOURCE_UNSET resourcesBjorn Helgaas
If the IORESOURCE_UNSET bit is set, it means we haven't assigned an address yet, so don't try to claim the region. Also, make the error messages more uniform and add info about which BAR is involved. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-27PCI: Check IORESOURCE_UNSET before updating BARBjorn Helgaas
Check to make sure we don't update a BAR with an address we haven't assigned. If we haven't assigned an address to a resource, we shouldn't write it to a BAR. This isn't a problem for the usual path via pci_assign_resource(), which clears IORESOURCE_UNSET before calling pci_update_resource(), but paths like pci_restore_bars() can call this for resources we haven't assigned. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-27PCI: Don't clear IORESOURCE_UNSET when updating BARBjorn Helgaas
Clear IORESOURCE_UNSET when we assign an address to a resource, not when we write the address to the BAR. Also, drop the "BAR %d: set to %pR" message; this is mostly redundant with the "BAR %d: assigned %pR" message from pci_assign_resource(). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-27PCI: Mark resources as IORESOURCE_UNSET if we can't assign themBjorn Helgaas
When assigning addresses to resources, mark them with IORESOURCE_UNSET before we start and clear IORESOURCE_UNSET if assignment is successful. That means that if we print the resource during assignment, we will show the size, not a meaningless address. Also, clear IORESOURCE_UNSET if we do assign an address, so we print the address when it is valid. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-21PCI: Convert pcibios_resource_to_bus() to take a pci_bus, not a pci_devYinghai Lu
These interfaces: pcibios_resource_to_bus(struct pci_dev *dev, *bus_region, *resource) pcibios_bus_to_resource(struct pci_dev *dev, *resource, *bus_region) took a pci_dev, but they really depend only on the pci_bus. And we want to use them in resource allocation paths where we have the bus but not a device, so this patch converts them to take the pci_bus instead of the pci_dev: pcibios_resource_to_bus(struct pci_bus *bus, *bus_region, *resource) pcibios_bus_to_resource(struct pci_bus *bus, *resource, *bus_region) In fact, with standard PCI-PCI bridges, they only depend on the host bridge, because that's the only place address translation occurs, but we aren't going that far yet. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-11-14PCI: Fix whitespace, capitalization, and spelling errorsBjorn Helgaas
Fix whitespace, capitalization, and spelling errors. No functional change. I know "busses" is not an error, but "buses" was more common, so I used it consistently. Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus()) Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-15PCI: Remove unused variablesBjorn Helgaas
This fixes "set but not used" warnings found via "make W=1". Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-18Merge branch 'pci/nikhil-big-bar-fixes' into nextBjorn Helgaas
* pci/nikhil-big-bar-fixes: PCI: reorder __pci_assign_resource() (no change) PCI: fix truncation of resource size to 32 bits
2012-07-11PCI: reorder __pci_assign_resource() (no change)Bjorn Helgaas
Reorder functions so __pci_assign_resource(), _pci_assign_resource(), and pci_assign_resource() are closer together. No code change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-11PCI: fix truncation of resource size to 32 bitsNikhil P Rao
_pci_assign_resource() took an int "size" argument, which meant that sizes larger than 4GB were truncated. Change type to resource_size_t. [bhelgaas: changelog] Signed-off-by: Nikhil P Rao <nikhil.rao@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-09PCI: disable MEM decoding while updating 64-bit MEM BARsBjorn Helgaas
When we update 64-bit BARs, we have to perform two config writes. Between the writes, the half-written BAR value could match a MEM access intended for another device. This could result in corruption of this device (for writes) or an unexpected response machine check (for reads). To prevent this, disable MEM decoding while updating such BARs. This uses the same safety test as 253d2e5498, which disables both MEM and IO while sizing BARs, namely, we don't disable decoding for host bridge devices. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-24PCI: Move "pci reassigndev resource alignment" out of quirks.cYinghai Lu
This isn't really a quirk; calling it directly from pci_add_device makes more sense. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-14PCI: Move pdev_sort_resources() to setup-bus.cYinghai Lu
This allows us to move the definition of struct resource_list to setup_bus.c and later convert resource_list to a regular list. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-14PCI : Calculate right add_sizeYinghai Lu
During debug of one SRIOV enabled hotplug device, we found found that add_size is not passed properly. The device has devices under two level bridges: +-[0000:80]-+-00.0-[81-8f]-- | +-01.0-[90-9f]-- | +-02.0-[a0-af]----00.0-[a1-a3]--+-02.0-[a2]--+-00.0 Oracle Corporation Device | | \-03.0-[a3]--+-00.0 Oracle Corporation Device Which means later the parent bridge will not try to add a big enough range: [ 557.455077] pci 0000:a0:00.0: BAR 14: assigned [mem 0xf9000000-0xf93fffff] [ 557.461974] pci 0000:a0:00.0: BAR 15: assigned [mem 0xf6000000-0xf61fffff pref] [ 557.469340] pci 0000:a1:02.0: BAR 14: assigned [mem 0xf9000000-0xf91fffff] [ 557.476231] pci 0000:a1:02.0: BAR 15: assigned [mem 0xf6000000-0xf60fffff pref] [ 557.483582] pci 0000:a1:03.0: BAR 14: assigned [mem 0xf9200000-0xf93fffff] [ 557.490468] pci 0000:a1:03.0: BAR 15: assigned [mem 0xf6100000-0xf61fffff pref] [ 557.497833] pci 0000:a1:03.0: BAR 14: can't assign mem (size 0x200000) [ 557.504378] pci 0000:a1:03.0: failed to add optional resources res=[mem 0xf9200000-0xf93fffff] [ 557.513026] pci 0000:a1:02.0: BAR 14: can't assign mem (size 0x200000) [ 557.519578] pci 0000:a1:02.0: failed to add optional resources res=[mem 0xf9000000-0xf91fffff] It turns out we did not calculate size1 properly. static resource_size_t calculate_memsize(resource_size_t size, resource_size_t min_size, resource_size_t size1, resource_size_t old_size, resource_size_t align) { if (size < min_size) size = min_size; if (old_size == 1 ) old_size = 0; if (size < old_size) size = old_size; size = ALIGN(size + size1, align); return size; } We should not pass add_size with min_size in calculate_memsize since that will make add_size not contribute final add_size. So just pass add_size with size1 to calculate_memsize(). With this change, we should have chance to remove extra addon in pci_reassign_resource. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-14PCI: Fix typo in setup-res.cMasanari Iida
Correct spelling "resouce" to "resource" in dricers/pci/setup-res.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-14x86/PCI: Convert maintaining FW-assigned BIOS BAR values to use a listMyron Stowe
This patch converts the underlying maintenance aspects of FW-assigned BIOS BAR values from a statically allocated array within struct pci_dev to a list of temporary, stand alone, entries. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-14PCI: Fix starting basis for resource requestsMyron Stowe
pci_revert_fw_address() is used to reinstate a PCI device's original FW-assigned BIOS BAR value(s) if normal resource assignment fails. When attempting to reinstate an address, the point within the resource tree from which to attempt the new resource request should be the parent resource corresponding to the device, not the base of the resource tree (ioport_resource or iomem_resource). For PCI devices this would typically be the resource corresponding to the upstream PCI host bridge or P2P bridge aperture. This patch sets the point within the resource tree to attempt a new resource assignment request to the PCI device's parent resource and only if that fails does it fall back to the base ioport_resource or iomem_resource. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI/PM/Runtime: make PCI traces quieterVincent Palatin
When the runtime PM is activated on PCI, if a device switches state frequently (e.g. an EHCI controller with autosuspending USB devices connected) the PCI configuration traces might be very verbose in the kernel log. Let's guard those traces with DEBUG condition. Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-10-31pci: Fix files needing export.h for EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
They were implicitly getting it from device.h --> module.h but we want to clean that up. So add the minimal header for these macros. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-01PCI : ability to relocate assigned pci-resourcesRam Pai
Currently pci-bridges are allocated enough resources to satisfy their immediate requirements. Any additional resource-requests fail if additional free space, contiguous to the one already allocated, is not available. This behavior is not reasonable since sufficient contiguous resources, that can satisfy the request, are available at a different location. This patch provides the ability to expand and relocate a allocated resource. v2: Changelog: Fixed size calculation in pci_reassign_resource() v3: Changelog : Split this patch. The resource.c changes are already upstream. All the pci driver changes are in here. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-22PCI: fold pci_calc_resource_flags() into decode_bar()Bjorn Helgaas
decode_bar() and pci_calc_resource_flags() both looked at the PCI BAR type information, and it's simpler to just do it all in one place. decode_bar() sets IORESOURCE_IO, IORESOURCE_MEM, and IORESOURCE_MEM_64 as appropriate, so res->flags contains all the information pci_bar_type does, so we don't need to test the pci_bar_type return value. decode_bar() used to return pci_bar_type, which we no longer need. We can simplify it a bit by returning the struct resource flags rather than updating them internally. In pci_update_resource(), there's no need to decode the BAR type bits again; we can just test for IORESOURCE_MEM_64 directly. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-10-17PCI: fix message typoBjorn Helgaas
I missed the closing parenthesis on "(PCI address ...)". Acked-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Peter Maydell <peter.maydell@linaro.org> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-07-16PCI: fall back to original BIOS BAR addressesBjorn Helgaas
If we fail to assign resources to a PCI BAR, this patch makes us try the original address from BIOS rather than leaving it disabled. Linux tries to make sure all PCI device BARs are inside the upstream PCI host bridge or P2P bridge apertures, reassigning BARs if necessary. Windows does similar reassignment. Before this patch, if we could not move a BAR into an aperture, we left the resource unassigned, i.e., at address zero. Windows leaves such BARs at the original BIOS addresses, and this patch makes Linux do the same. This is a bit ugly because we disable the resource long before we try to reassign it, so we have to keep track of the BIOS BAR address somewhere. For lack of a better place, I put it in the struct pci_dev. I think it would be cleaner to attempt the assignment immediately when the claim fails, so we could easily remember the original address. But we currently claim motherboard resources in the middle, after attempting to claim PCI resources and before assigning new PCI resources, and changing that is a fairly big job. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16263 Reported-by: Andrew <nitr0@seti.kr.ua> Tested-by: Andrew <nitr0@seti.kr.ua> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-06-11PCI: change resource collision messages from KERN_ERR to KERN_INFOBjorn Helgaas
We can often deal with PCI resource issues by moving devices around. In that case, there's no point in alarming the user with messages like these. There are many bug reports where the message itself is the only problem, e.g., https://bugs.launchpad.net/ubuntu/+source/linux/+bug/413419 . Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-03-24PCI: for address space collisions, show conflicting resourceBjorn Helgaas
With request_resource_conflict(), we can learn what the actual conflict is, so print that info for debugging purposes. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: improve discovery/configuration messagesBjorn Helgaas
This makes PCI resource management messages more consistent and adds a few new messages to aid debugging. Whenever we assign resources to a device, update a BAR, or change a bridge aperture, it's worth noting it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: print resources consistently with %pRtBjorn Helgaas
This uses %pRt to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-10-06PCI: remove pci_assign_resource_fixed()Bjorn Helgaas
Adrian commented out this function in 2baad5f96b49, but I don't think it's even worth cluttering the file with the unused code. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: export pci_claim_resource for driver useJesse Barnes
yenta needs this for example. Acked-by: Matthew Wilcox <willy@linux.intel.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-08-30PCI SR-IOV: correct broken resource alignment calculationsChris Wright
An SR-IOV capable device includes an SR-IOV PCIe capability which describes the Virtual Function (VF) BAR requirements. A typical SR-IOV device can support multiple VFs whose BARs must be in a contiguous region, effectively an array of VF BARs. The BAR reports the size requirement for a single VF. We calculate the full range needed by simply multiplying the VF BAR size with the number of possible VFs and create a resource spanning the full range. This all seems sane enough except it artificially inflates the alignment requirement for the VF BAR. The VF BAR need only be aligned to the size of a single BAR not the contiguous range of VF BARs. This can cause us to fail to allocate resources for the BAR despite the fact that we actually have enough space. This patch adds a thin PCI specific layer over the generic resource_alignment() function which is aware of the special nature of VF BARs and does sorting and allocation based on the smaller alignment requirement. I recognize that while resource_alignment is generic, it's basically a PCI helper. An alternative to this patch is to add PCI VF BAR specific information to struct resource. I opted for the extra layer rather than adding such PCI specific information to struct resource. This does have the slight downside that we don't cache the BAR size and re-read for each alignment query (happens a small handful of times during boot for each VF BAR). Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Yu Zhao <yu.zhao@intel.com> Cc: stable@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-08-02Make pci_claim_resource() use request_resource() rather than insert_resource()Linus Torvalds
This function has traditionally used "insert_resource()", because before commit cebd78a8c5 ("Fix pci_claim_resource") it used to just insert the resource into whatever root resource tree that was indicated by "pcibios_select_root()". So there Matthew fixed it to actually look up the proper parent resource, which means that now it's actively wrong to then traverse the resource tree any more: we already know exactly where the new resource should go. And when we then did commit a76117dfd6 ("x86: Use pci_claim_resource"), which changed the x86 PCI code from the open-coded pr = pci_find_parent_resource(dev, r); if (!pr || request_resource(pr, r) < 0) { to using if (pci_claim_resource(dev, idx) < 0) { that "insert_resource()" now suddenly became a problem, and causes a regression covered by http://bugzilla.kernel.org/show_bug.cgi?id=13891 which this fixes. Reported-and-tested-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Andrew Patterson <andrew.patterson@hp.com> Cc: Linux PCI <linux-pci@vger.kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (74 commits) PCI: make msi_free_irqs() to use msix_mask_irq() instead of open coded write PCI: Fix the NIU MSI-X problem in a better way PCI ASPM: remove get_root_port_link PCI ASPM: cleanup pcie_aspm_sanity_check PCI ASPM: remove has_switch field PCI ASPM: cleanup calc_Lx_latency PCI ASPM: cleanup pcie_aspm_get_cap_device PCI ASPM: cleanup clkpm checks PCI ASPM: cleanup __pcie_aspm_check_state_one PCI ASPM: cleanup initialization PCI ASPM: cleanup change input argument of aspm functions PCI ASPM: cleanup misc in struct pcie_link_state PCI ASPM: cleanup clkpm state in struct pcie_link_state PCI ASPM: cleanup latency field in struct pcie_link_state PCI ASPM: cleanup aspm state field in struct pcie_link_state PCI ASPM: fix typo in struct pcie_link_state PCI: drivers/pci/slot.c should depend on CONFIG_SYSFS PCI: remove redundant __msi_set_enable() PCI PM: consistently use type bool for wake enable variable x86/ACPI: Correct maximum allowed _CRS returned resources and warn if exceeded ...
2009-06-17Fix pci_claim_resourceMatthew Wilcox
Instead of starting from the iomem or ioport roots, start from the parent bus' resources. This fixes a bug where child resources would appear above their parents resources if they had the same size. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Tested-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11PCI: improve resource allocation under transparent bridgesYinghai Lu
We could run out of space under under 4g, but devices under transparent bridges can use 64bit resources, so keep trying on the parent bus until we hit a non-transparent bridge. Impact: better support for assigning unassigned resources Reviewed-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: allow assignment of memory resources with a specified alignmentYuji Shimada
This patch allows memory resources to be assigned with a specified alignment at boot-time or run-time. The patch is useful when we use PCI pass-through, because page-aligned memory resources are required to securely share PCI resources with guest drivers. If you want to assign the resource at boot time, please set "pci=resource_alignment=" boot parameter. This is format of "pci=resource_alignment=" boot parameter: [<order of align>@][<domain>:]<bus>:<slot>.<func>[; ...] Specifies alignment and device to reassign aligned memory resources. If <order of align> is not specified, PAGE_SIZE is used as alignment. PCI-PCI bridge can be specified, if resource windows need to be expanded. This is example: pci=resource_alignment=20@07:00.0;18@0f:00.0;00:1d.7 If you want to assign the resource at run-time, please set "/sys/bus/pci/resource_alignment" file, and hot-remove the device and hot-add the device. For this purpose, fakephp or PCI hotplug interfaces can be used. The format of "/sys/bus/pci/resource_alignment" file is the same with boot parameter. You can use "," instead of ";". For example: # cd /sys/bus/pci # echo -n 20@12:00.0 > resource_alignment # echo 1 > devices/0000:12:00.0/remove # echo 1 > rescan Reviewed-by: Alex Chiang <achiang@hp.com> Reviewed-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Yuji Shimada <shimada-yxb@necst.nec.co.jp> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: add a new function to map BAR offsetsYu Zhao
Add a function to map a given resource number to a corresponding register so drivers can get the offset and type of device specific BARs. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: remove unnecessary arg of pci_update_resource()Yu Zhao
This cleanup removes unnecessary argument 'struct resource *res' in pci_update_resource(), so it takes same arguments as other companion functions (pci_assign_resource(), etc.). Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
