[ Upstream commit 977509f7c5c6fb992ffcdf4291051af343b91645 ]
Previously we didn't check the type of device before trying to apply Type 1
(PCI-X) or Type 2 (PCIe) Setting Records from _HPX.
We don't support PCI-X Setting Records, so this was harmless, but the
warning was useless.
We do support PCIe Setting Records, and we didn't check whether a device
was PCIe before applying settings. I don't think anything bad happened on
non-PCIe devices because pcie_capability_clear_and_set_word(),
pcie_cap_has_lnkctl(), etc., would fail before doing any harm. But it's
ugly to depend on those internals.
Check the device type before attempting to apply Type 1 and Type 2 Setting
Records (Type 0 records are applicable to PCI, PCI-X, and PCIe devices).
A side benefit is that this prevents useless "not supported" warnings when
a BIOS supplies a Type 1 (PCI-X) Setting Record and we try to apply it to
every single device:
pci 0000:00:00.0: PCI-X settings not supported
After this patch, we'll get the warning only when a BIOS supplies a Type 1
record and we have a PCI-X device to which it should be applied.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=187731
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 7a6d312b50e63f598f5b5914c4fd21878ac2b595 ]
Remove the assumption that IORESOURCE_ROM_ENABLE == PCI_ROM_ADDRESS_ENABLE.
PCI_ROM_ADDRESS_ENABLE is the ROM enable bit defined by the PCI spec, so if
we're reading or writing a BAR register value, that's what we should use.
IORESOURCE_ROM_ENABLE is a corresponding bit in struct resource flags.
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 51ebfc92b72b4f7dac1ab45683bf56741e454b8c upstream.
A PCI-to-PCIe bridge (a "reverse bridge") has a PCI or PCI-X primary
interface and a PCI Express secondary interface. The PCIe interface is a
Downstream Port that originates a Link. See the "PCI Express to PCI/PCI-X
Bridge Specification", rev 1.0, sections 1.2 and A.6.
The bug report below involves a PCI-to-PCIe bridge and a PCIe switch below
the bridge:
00:1e.0 Intel 82801 PCI Bridge to [bus 01-0a]
01:00.0 Pericom PI7C9X111SL PCIe-to-PCI Reversible Bridge to [bus 02-0a]
02:00.0 Pericom Device 8608 [PCIe Upstream Port] to [bus 03-0a]
03:01.0 Pericom Device 8608 [PCIe Downstream Port] to [bus 0a]
01:00.0 is configured as a PCI-to-PCIe bridge (despite the name printed by
lspci). As we traverse a PCIe hierarchy, device connections alternate
between PCIe Links and internal Switch logic. Previously we did not
recognize that 01:00.0 had a secondary link, so we thought the 02:00.0
Upstream Port *did* have a secondary link. In fact, it's the other way
around: 01:00.0 has a secondary link, and 02:00.0 has internal Switch logic
on its secondary side.
When we thought 02:00.0 had a secondary link, the pci_scan_slot() ->
only_one_child() path assumed 02:00.0 could have only one child, so 03:00.0
was the only possible downstream device. But 03:00.0 doesn't exist, so we
didn't look for any other devices on bus 03.
Booting with "pci=pcie_scan_all" is a workaround, but we don't want users
to have to do that.
Recognize that PCI-to-PCIe bridges originate links on their secondary
interfaces.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=189361
Fixes: d0751b98dfa3 ("PCI: Add dev->has_secondary_link to track downstream PCIe links")
Tested-by: Blake Moore <blake.moore@men.de>
Per PCIe spec r3.0, sec 2.3.1.1, the Read Completion Boundary (RCB)
determines the naturally aligned address boundaries on which a Read Request
may be serviced with multiple Completions:
- For a Root Complex, RCB is 64 bytes or 128 bytes
This value is reported in the Link Control Register
Note: Bridges and Endpoints may implement a corresponding command bit
which may be set by system software to indicate the RCB value for the
Root Complex, allowing the Bridge/Endpoint to optimize its behavior
when the Root Complex’s RCB is 128 bytes.
- For all other system elements, RCB is 128 bytes
Per sec 7.8.7, if a Root Port only supports a 64-byte RCB, the RCB of all
downstream devices must be clear, indicating an RCB of 64 bytes. If the
Root Port supports a 128-byte RCB, we may optionally set the RCB of
downstream devices so they know they can generate larger Completions.
Some BIOSes supply an _HPX that tells us to set RCB, even though the Root
Port doesn't have RCB set, which may lead to Malformed TLP errors if the
Endpoint generates completions larger than the Root Port can handle.
The IBM x3850 X6 with BIOS version -[A8E120CUS-1.30]- 08/22/2016 supplies
such an _HPX and a Mellanox MT27500 ConnectX-3 device fails to initialize:
mlx4_core 0000:41:00.0: command 0xfff timed out (go bit not cleared)
mlx4_core 0000:41:00.0: device is going to be reset
mlx4_core 0000:41:00.0: Failed to obtain HW semaphore, aborting
mlx4_core 0000:41:00.0: Fail to reset HCA
kernel BUG at drivers/net/ethernet/mellanox/mlx4/catas.c:193!
After 6cd33649fa83 ("PCI: Add pci_configure_device() during enumeration")
and 7a1562d4f2d0 ("PCI: Apply _HPX Link Control settings to all devices
with a link"), we apply _HPX settings to *all* devices, not just those
hot-added after boot.
Before 7a1562d4f2d0, we didn't touch the Mellanox RCB, and the device
worked. After 7a1562d4f2d0, we set its RCB to 128, and it failed.
Set the RCB to 128 iff the Root Port supports a 128-byte RCB. Otherwise,
set RCB to 64 bytes. This effectively ignores what _HPX tells us about
RCB.
Note that this change only affects _HPX handling. If we have no _HPX, this
does nothing with RCB.
[bhelgaas: changelog, clear RCB if not set for Root Port]
Fixes: 6cd33649fa83 ("PCI: Add pci_configure_device() during enumeration")
Fixes: 7a1562d4f2d0 ("PCI: Apply _HPX Link Control settings to all devices with a link")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=187781
Tested-by: Frank Danapfel <fdanapfe@redhat.com>
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Myron Stowe <myron.stowe@redhat.com>
CC: stable@vger.kernel.org # v3.18+
* pci/aer:
PCI/AER: Fix aer_probe() kernel-doc comment
PCI/AER: Cache capability position
PCI/AER: Avoid memory allocation in interrupt handling path
ACPI / APEI: Send correct severity to calculate AER severity
PCI/AER: Remove duplicate AER severity translation
PCI/AER: Remove aerdriver.forceload kernel parameter
PCI/AER: Remove aerdriver.nosourceid kernel parameter
x86/PCI: VMD: Add quirk for AER to ignore source ID
PCI/AER: Add bus flag to skip source ID matching
drivers/pci/probe.c
Save the position of the error reporting capability so it doesn't need to
be rediscovered during error handling.
Signed-off-by: Keith Busch <keith.busch@intel.com>
CC: Lukas Wunner <lukas@wunner.de>
Add Precision Time Measurement (PTM) support (see PCIe r3.1, sec 6.22).
Enable PTM on PTM Root devices and switch ports. This does not enable PTM
on endpoints.
There currently are no PTM-capable devices on the market, but it is
expected to be supported by the Intel Apollo Lake platform.
[bhelgaas: complete rework]
Signed-off-by: Jonathan Yong <jonathan.yong@intel.com>
'pci/pm' and 'pci/virtualization' into next
* pci/aspm:
PCI/ASPM: Remove redundant check of pcie_set_clkpm
* pci/dpc:
PCI: Remove DPC tristate module option
PCI: Bind DPC to Root Ports as well as Downstream Ports
PCI: Fix whitespace in struct dpc_dev
PCI: Convert Downstream Port Containment driver to use devm_* functions
* pci/hotplug:
PCI: Allow additional bus numbers for hotplug bridges
* pci/misc:
PCI: Include <asm/dma.h> for isa_dma_bridge_buggy
PCI: Make bus_attr_resource_alignment static
MAINTAINERS: Add file patterns for PCI device tree bindings
PCI: Fix comment typo
* pci/msi:
PCI/MSI: irqchip: Fix PCI_MSI dependencies
* pci/pm:
PCI: pciehp: Ignore interrupts during D3cold
PCI: Document connection between pci_power_t and hardware PM capability
PCI: Add runtime PM support for PCIe ports
ACPI / hotplug / PCI: Runtime resume bridge before rescan
PCI: Power on bridges before scanning new devices
PCI: Put PCIe ports into D3 during suspend
PCI: Don't clear d3cold_allowed for PCIe ports
PCI / PM: Enforce type casting for pci_power_t
* pci/virtualization:
PCI: Add ACS quirk for Solarflare SFC9220
PCI: Add DMA alias quirk for Adaptec 3805
PCI: Mark Atheros AR9485 and QCA9882 to avoid bus reset
PCI: Add function 1 DMA alias quirk for Marvell 88SE9182
A user may hot add a switch requiring more than one bus to enumerate. This
previously required a system reboot if BIOS did not sufficiently pad the
bus resource, which they frequently don't do.
Add a kernel parameter so a user can specify the minimum number of bus
numbers to reserve for a hotplug bridge's subordinate buses so rebooting
won't be necessary.
The default is 1, which is equivalent to previous behavior.
When a PCI device is removed through sysfs interface, the upstream bridge
(PCIe port) can be runtime suspended if it was the last device on that bus.
Now, if the bridge is in D3 we cannot find devices below the bridge
anymore. For example following fails to find the removed device again:
# echo 1 > /sys/bus/pci/devices/0000:00:01.0/0000:01:00.0/remove
# echo 1 > /sys/bus/pci/devices/0000:00:01.0/rescan
Where 0000:00:01.0 is the bridge device.
In order to be able to rescan devices below the bridge add
pm_runtime_get_sync()/pm_runtime_put() calls to pci_scan_bridge(). This
should keep bridges powered on while their children devices are being
scanned.
Reported-by: Peter Wu <peter@lekensteyn.nl>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Instead of assigning bus->domain_nr inside pci_bus_assign_domain_nr(),
return the domain and let the caller do the assignment. Rename
pci_bus_assign_domain_nr() to pci_bus_find_domain_nr() to reflect this.
No functional change intended.
[bhelgaas: changelog]
Signed-off-by: Tomasz Nowicki <tn@semihalf.com>
Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
* pci/hotplug:
PCI: Use cached copy of PCI_EXP_SLTCAP_HPC bit
* pci/resource:
PCI: Disable all BAR sizing for devices with non-compliant BARs
x86/PCI: Mark Broadwell-EP Home Agent 1 as having non-compliant BARs
PCI: Identify Enhanced Allocation (EA) BAR Equivalent resources in sysfs
b84106b4e229 ("PCI: Disable IO/MEM decoding for devices with non-compliant
BARs") disabled BAR sizing for BARs 0-5 of devices that don't comply with
the PCI spec. But it didn't do anything for expansion ROM BARs, so we
still try to size them, resulting in warnings like this on Broadwell-EP:
pci 0000:ff:12.0: BAR 6: failed to assign [mem size 0x00000001 pref]
Move the non-compliant BAR check from __pci_read_base() up to
pci_read_bases() so it applies to the expansion ROM BAR as well as
to BARs 0-5.
Note that direct callers of __pci_read_base(), like sriov_init(), will now
bypass this check. We haven't had reports of devices with broken SR-IOV
BARs yet.
Fixes: b84106b4e229 ("PCI: Disable IO/MEM decoding for devices with non-compliant BARs")
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Ingo Molnar <mingo@redhat.com>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Andi Kleen <ak@linux.intel.com>
Solve IOMMU support issues with PCIe non-transparent bridges that use
Requester ID look-up tables (RID-LUT), e.g., the PEX8733.
The NTB connects devices in two independent PCI domains. Devices separated
by the NTB are not able to discover each other. A PCI packet being
forwared from one domain to another has to have its RID modified so it
appears on correct bus and completions are forwarded back to the original
domain through the NTB. The RID is translated using a preprogrammed table
(LUT) and the PCI packet propagates upstream away from the NTB. If the
destination system has IOMMU enabled, the packet will be discarded because
the new RID is unknown to the IOMMU. Adding a DMA alias for the new RID
allows IOMMU to properly recognize the packet.
Each device behind the NTB has a unique RID assigned in the RID-LUT. The
current DMA alias implementation supports only a single alias, so it's not
possible to support mutiple devices behind the NTB when IOMMU is enabled.
Enable all possible aliases on a given bus (256) that are stored in a
bitset. Alias devfn is directly translated to a bit number. The bitset is
not allocated for devices that have no need for DMA aliases.
More details can be found in the following article:
http://www.plxtech.com/files/pdf/technical/expresslane/RTC_Enabling%20MulitHostSystemDesigns.pdf
Signed-off-by: Jacek Lawrynowicz <jacek.lawrynowicz@intel.com>
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Acked-by: Joerg Roedel <jroedel@suse.de>
* pci/resource:
PCI: Simplify pci_create_attr() control flow
PCI: Don't leak memory if sysfs_create_bin_file() fails
PCI: Simplify sysfs ROM cleanup
PCI: Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY
MIPS: Loongson 3: Keep CPU physical (not virtual) addresses in shadow ROM resource
MIPS: Loongson 3: Use temporary struct resource * to avoid repetition
ia64/PCI: Keep CPU physical (not virtual) addresses in shadow ROM resource
ia64/PCI: Use ioremap() instead of open-coded equivalent
ia64/PCI: Use temporary struct resource * to avoid repetition
PCI: Clean up pci_map_rom() whitespace
PCI: Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs
PCI: Set ROM shadow location in arch code, not in PCI core
PCI: Don't enable/disable ROM BAR if we're using a RAM shadow copy
PCI: Don't assign or reassign immutable resources
PCI: Mark shadow copy of VGA ROM as IORESOURCE_PCI_FIXED
x86/PCI: Mark Broadwell-EP Home Agent & PCU as having non-compliant BARs
* pci/host-hv:
PCI: hv: Add paravirtual PCI front-end for Microsoft Hyper-V VMs
PCI: Look up IRQ domain by fwnode_handle
PCI: Add fwnode_handle to x86 pci_sysdata
'pci/host-rcar', 'pci/host-tegra', 'pci/host-thunder', 'pci/host-vmd', 'pci/host-xilinx' and 'pci/host-xilinx-nwl' into next
* pci/host-altera:
PCI: altera: Fix altera_pcie_link_is_up()
* pci/host-imx6:
PCI: imx6: Add DT bindings to configure PHY Tx driver settings
* pci/host-keystone:
PCI: keystone: Defer probing if devm_phy_get() returns -EPROBE_DEFER
* pci/host-rcar:
PCI: rcar: Depend on ARCH_RENESAS, not ARCH_SHMOBILE
* pci/host-tegra:
PCI: tegra: Remove misleading PHYS_OFFSET
PCI: tegra: Track bus -> CPU mapping
PCI: tegra: Remove unused struct tegra_pcie.num_ports field
PCI: tegra: Implement ->{add,remove}_bus() callbacks
PCI: Add pci_ops.{add,remove}_bus() callbacks
* pci/host-thunder:
PCI: thunder: Add driver for ThunderX-pass{1,2} on-chip devices
PCI: thunder: Add PCIe host driver for ThunderX processors
PCI: generic: Expose pci_host_common_probe() for use by other drivers
PCI: generic: Add pci_host_common_probe(), based on gen_pci_probe()
PCI: generic: Move structure definitions to separate header file
* pci/host-vmd:
x86/PCI: VMD: Attach VMD resources to parent domain's resource tree
x86/PCI: VMD: Set bus resource start to 0
x86/PCI: VMD: Document code for maintainability
* pci/host-xilinx:
microblaze/PCI: Support generic Xilinx AXI PCIe Host Bridge IP driver
PCI: xilinx: Update Zynq binding with Microblaze node
PCI: xilinx: Don't call pci_fixup_irqs() on Microblaze
PCI: xilinx: Remove dependency on ARM-specific struct hw_pci
PCI: xilinx: Use of_pci_get_host_bridge_resources() to parse DT
* pci/host-xilinx-nwl:
PCI: xilinx-nwl: Add support for Xilinx NWL PCIe Host Controller
'pci/virtualization' and 'pci/vpd' into next
* pci/aer:
PCI/AER: Log aer_inject error injections
PCI/AER: Log actual error causes in aer_inject
PCI/AER: Use dev_warn() in aer_inject
PCI/AER: Fix aer_inject error codes
* pci/enumeration:
PCI: Fix broken URL for Dell biosdevname
* pci/kconfig:
PCI: Cleanup pci/pcie/Kconfig whitespace
PCI: Include pci/hotplug Kconfig directly from pci/Kconfig
PCI: Include pci/pcie/Kconfig directly from pci/Kconfig
* pci/misc:
PCI: Add PCI_CLASS_SERIAL_USB_DEVICE definition
PCI: Add QEMU top-level IDs for (sub)vendor & device
unicore32: Remove unused HAVE_ARCH_PCI_SET_DMA_MASK definition
PCI: Consolidate PCI DMA constants and interfaces in linux/pci-dma-compat.h
PCI: Move pci_dma_* helpers to common code
frv/PCI: Remove stray pci_{alloc,free}_consistent() declaration
PCI: Wait for up to 1000ms after FLR reset
PCI: Support SR-IOV on any function type
* pci/vpd:
PCI: Prevent VPD access for buggy devices
PCI: Sleep rather than busy-wait for VPD access completion
PCI: Fold struct pci_vpd_pci22 into struct pci_vpd
PCI: Rename VPD symbols to remove unnecessary "pci22"
PCI: Remove struct pci_vpd_ops.release function pointer
PCI: Move pci_vpd_release() from header file to pci/access.c
PCI: Move pci_read_vpd() and pci_write_vpd() close to other VPD code
PCI: Determine actual VPD size on first access
PCI: Use bitfield instead of bool for struct pci_vpd_pci22.busy
PCI: Allow access to VPD attributes with size 0
PCI: Update VPD definitions
Add pci_ops.{add,remove}_bus() callbacks, which will be called on every
newly created bus and when a bus is being removed, respectively. This can
be used by drivers to implement driver-specific initialization and teardown
of the bus, in addition to the architecture-specifics implemented by the
pcibios_add_bus() and the pcibios_remove_bus() functions.
Signed-off-by: Thierry Reding <treding@nvidia.com>
There's only one kind of VPD, so we don't need to qualify it as "the
version described by PCI spec rev 2.2."
Rename the following symbols to remove unnecessary "pci22":
PCI_VPD_PCI22_SIZE -> PCI_VPD_MAX_SIZE
pci_vpd_pci22_size() -> pci_vpd_size()
pci_vpd_pci22_wait() -> pci_vpd_wait()
pci_vpd_pci22_read() -> pci_vpd_read()
pci_vpd_pci22_write() -> pci_vpd_write()
pci_vpd_pci22_ops -> pci_vpd_ops
pci_vpd_pci22_init() -> pci_vpd_init()
Tested-by: Shane Seymour <shane.seymour@hpe.com>
Tested-by: Babu Moger <babu.moger@oracle.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
The PCI config header (first 64 bytes of each device's config space) is
defined by the PCI spec so generic software can identify the device and
manage its usage of I/O, memory, and IRQ resources.
Some non-spec-compliant devices put registers other than BARs where the
BARs should be. When the PCI core sizes these "BARs", the reads and writes
it does may have unwanted side effects, and the "BAR" may appear to
describe non-sensical address space.
Add a flag bit to mark non-compliant devices so we don't touch their BARs.
Turn off IO/MEM decoding to prevent the devices from consuming address
space, since we can't read the BARs to find out what that address space
would be.
Tested-by: Andi Kleen <ak@linux.intel.com>
If pci_host_bridge_msi_domain() can't find an IRQ domain through the OF
tree, try to look it up directly through the fwnode_handle.
Signed-off-by: Jake Oshins <jakeo@microsoft.com>
include/asm-generic/pci-bridge.h is now empty, so remove every #include of
it.
Acked-by: Will Deacon <will.deacon@arm.com> (arm64)
The PCI flag management constants and functions were previously declared in
include/asm-generic/pci-bridge.h. But they are not specific to bridges,
and arches did not include pci-bridge.h consistently.
Move the following interfaces and related constants to include/linux/pci.h
and remove pci-bridge.h:
pci_set_flags()
pci_add_flags()
pci_clear_flags()
pci_has_flag()
This fixes these warnings when building for some arches:
drivers/pci/host/pcie-designware.c:562:20: error: 'PCI_PROBE_ONLY' undeclared (first use in this function)
drivers/pci/host/pcie-designware.c:562:7: error: implicit declaration of function 'pci_has_flag' [-Werror=implicit-function-declaration]
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.5 merge window:
Enumeration:
- Simplify config space size computation (Bjorn Helgaas)
- Avoid iterating through ROM outside the resource window (Edward O'Callaghan)
- Support PCIe devices with short cfg_size (Jason S. McMullan)
- Add Netronome vendor and device IDs (Jason S. McMullan)
- Limit config space size for Netronome NFP6000 family (Jason S. McMullan)
- Add Netronome NFP4000 PF device ID (Simon Horman)
- Limit config space size for Netronome NFP4000 (Simon Horman)
- Print warnings for all invalid expansion ROM headers (Vladis Dronov)
Resource management:
- Fix minimum allocation address overwrite (Christoph Biedl)
PCI device hotplug:
- acpiphp_ibm: Fix null dereferences on null ibm_slot (Colin Ian King)
- pciehp: Always protect pciehp_disable_slot() with hotplug mutex (Guenter Roeck)
- shpchp: Constify hpc_ops structure (Julia Lawall)
- ibmphp: Remove unneeded NULL test (Julia Lawall)
Power management:
- Make ASPM sysfs link_state_store() consistent with link_state_show() (Andy Lutomirski)
Virtualization
- Add function 1 DMA alias quirk for Lite-On/Plextor M6e/Marvell 88SS9183 (Tim Sander)
MSI:
- Remove empty pci_msi_init_pci_dev() (Bjorn Helgaas)
- Mark PCIe/PCI (MSI) IRQ cascade handlers as IRQF_NO_THREAD (Grygorii Strashko)
- Initialize MSI capability for all architectures (Guilherme G. Piccoli)
- Relax msi_domain_alloc() to support parentless MSI irqdomains (Liu Jiang)
ARM Versatile host bridge driver:
- Remove unused pci_sys_data structures (Lorenzo Pieralisi)
Broadcom iProc host bridge driver:
- Hide CONFIG_PCIE_IPROC (Arnd Bergmann)
- Do not use 0x in front of %pap (Dmitry V. Krivenok)
- Update iProc PCIe device tree binding (Ray Jui)
- Add PAXC interface support (Ray Jui)
- Add iProc PCIe MSI device tree binding (Ray Jui)
- Add iProc PCIe MSI support (Ray Jui)
Freescale i.MX6 host bridge driver:
- Use gpio_set_value_cansleep() (Fabio Estevam)
- Add support for active-low reset GPIO (Petr Štetiar)
HiSilicon host bridge driver:
- Add support for HiSilicon Hip06 PCIe host controllers (Gabriele Paoloni)
Intel VMD host bridge driver:
- Export irq_domain_set_info() for module use (Keith Busch)
- x86/PCI: Allow DMA ops specific to a PCI domain (Keith Busch)
- Use 32 bit PCI domain numbers (Keith Busch)
- Add driver for Intel Volume Management Device (VMD) (Keith Busch)
Qualcomm host bridge driver:
- Document PCIe devicetree bindings (Stanimir Varbanov)
- Add Qualcomm PCIe controller driver (Stanimir Varbanov)
- dts: apq8064: add PCIe devicetree node (Stanimir Varbanov)
- dts: ifc6410: enable PCIe DT node for this board (Stanimir Varbanov)
Renesas R-Car host bridge driver:
- Add support for R-Car H3 to pcie-rcar (Harunobu Kurokawa)
- Allow DT to override default window settings (Phil Edworthy)
- Convert to DT resource parsing API (Phil Edworthy)
- Revert "PCI: rcar: Build pcie-rcar.c only on ARM" (Phil Edworthy)
- Remove unused pci_sys_data struct from pcie-rcar (Phil Edworthy)
- Add runtime PM support to pcie-rcar (Phil Edworthy)
- Add Gen2 PHY setup to pcie-rcar (Phil Edworthy)
- Add gen2 fallback compatibility string for pci-rcar-gen2 (Simon Horman)
- Add gen2 fallback compatibility string for pcie-rcar (Simon Horman)
Synopsys DesignWare host bridge driver:
- Simplify control flow (Bjorn Helgaas)
- Make config accessor override checking symmetric (Bjorn Helgaas)
- Ensure ATU is enabled before IO/conf space accesses (Stanimir Varbanov)
Miscellaneous:
- Add of_pci_get_host_bridge_resources() stub (Arnd Bergmann)
- Check for PCI_HEADER_TYPE_BRIDGE equality, not bitmask (Bjorn Helgaas)
- Fix all whitespace issues (Bogicevic Sasa)
- x86/PCI: Simplify pci_bios_{read,write} (Geliang Tang)
- Use to_pci_dev() instead of open-coding it (Geliang Tang)
- Use kobj_to_dev() instead of open-coding it (Geliang Tang)
- Use list_for_each_entry() to simplify code (Geliang Tang)
- Fix typos in <linux/msi.h> (Thomas Petazzoni)
- x86/PCI: Clarify AMD Fam10h config access restrictions comment (Tomasz Nowicki)"
* tag 'pci-v4.5-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits)
PCI: Add function 1 DMA alias quirk for Lite-On/Plextor M6e/Marvell 88SS9183
PCI: Limit config space size for Netronome NFP4000
PCI: Add Netronome NFP4000 PF device ID
x86/PCI: Add driver for Intel Volume Management Device (VMD)
PCI/AER: Use 32 bit PCI domain numbers
irqdomain: Export irq_domain_set_info() for module use
PCI: host: Add of_pci_get_host_bridge_resources() stub
genirq/MSI: Relax msi_domain_alloc() to support parentless MSI irqdomains
PCI: rcar: Add Gen2 PHY setup to pcie-rcar
PCI: rcar: Add runtime PM support to pcie-rcar
PCI: designware: Make config accessor override checking symmetric
PCI: ibmphp: Remove unneeded NULL test
ARM: dts: ifc6410: enable PCIe DT node for this board
ARM: dts: apq8064: add PCIe devicetree node
PCI: hotplug: Use list_for_each_entry() to simplify code
PCI: rcar: Remove unused pci_sys_data struct from pcie-rcar
PCI: hisi: Add support for HiSilicon Hip06 PCIe host controllers
PCI: Avoid iterating through memory outside the resource window
PCI: acpiphp_ibm: Fix null dereferences on null ibm_slot
This patch introduces pci_msi_register_fwnode_provider() for irqchip
to register a callback, to provide a way to determine appropriate MSI
domain for a pci device.
It also introduces pci_host_bridge_acpi_msi_domain(), which returns
the MSI domain of the specified PCI host bridge with DOMAIN_BUS_PCI_MSI
bus token. Then, it is assigned to pci device.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rjw@rjwysocki.net>
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
* pci/aspm:
PCI/ASPM: Make sysfs link_state_store() consistent with link_state_show()
* pci/hotplug:
PCI: pciehp: Always protect pciehp_disable_slot() with hotplug mutex
* pci/misc:
PCI: Simplify config space size computation
PCI: Limit config space size for Netronome NFP6000 family
PCI: Add Netronome vendor and device IDs
PCI: Support PCIe devices with short cfg_size
PCI: Print warnings for all invalid expansion ROM headers
PCI: Check for PCI_HEADER_TYPE_BRIDGE equality, not bitmask
* pci/msi:
PCI/MSI: Remove empty pci_msi_init_pci_dev()
PCI/MSI: Initialize MSI capability for all architectures
Restructure the logic so we return the config space size as soon as we know
it. This reduces indentation, removes negations, and removes gotos.
No functional change.
4a7cc8316705 ("genirq/MSI: Move msi_list from struct pci_dev to struct
device") removed the contents of pci_msi_init_pci_dev(). All
implementation of it are now empty, so remove it completely.
1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel doesn't
support MSI") moved dev->msi_cap and dev->msix_cap initialization from the
pci_init_capabilities() path (used on all architectures) to the
pci_setup_device() path (not used on Open Firmware architectures).
This broke MSI or MSI-X on Open Firmware machines. 4d9aac397a5d
("powerpc/PCI: Disable MSI/MSI-X interrupts at PCI probe time in OF case")
fixed it for PowerPC but not for SPARC.
Set up MSI and MSI-X (initialize msi_cap and msix_cap and disable MSI and
MSI-X) in pci_init_capabilities() so all architectures do it the same way.
This reverts 4d9aac397a5d since this patch fixes the problem generically
for both PowerPC and SPARC.
[bhelgaas: changelog, make pci_msi_setup_pci_dev() static]
Fixes: 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel doesn't support MSI")
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
* acpi-smbus:
Revert "ACPI / SBS: Add 5 us delay to fix SBS hangs on MacBook"
ACPI / SMBus: Fix boot stalls / high CPU caused by reentrant code
* acpi-ec:
ACPI-EC: Drop unnecessary check made before calling acpi_ec_delete_query()
* acpi-pci:
PCI: Fix OF logic in pci_dma_configure()
This patch fixes a bug introduced by previous commit,
which incorrectly checkes the of_node of the end-point device.
Instead, it should check the of_node of the host bridge.
Fixes: 50230713b639 ("PCI: OF: Move of_pci_dma_configure() to pci_dma_configure()")
Reported-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Pull more power management and ACPI updates from Rafael Wysocki:
"The only new feature in this batch is support for the ACPI _CCA device
configuration object, which it a pre-requisite for future ACPI PCI
support on ARM64, but should not affect the other architectures.
The rest is fixes and cleanups, mostly in cpufreq (including
intel_pstate), the Operating Performace Points (OPP) framework and
tools (cpupower and turbostat).
Specifics:
- Support for the ACPI _CCA configuration object intended to tell the
OS whether or not a bus master device supports hardware managed
cache coherency and a new set of functions to allow drivers to
check the cache coherency support for devices in a platform
firmware interface agnostic way (Suravee Suthikulpanit, Jeremy
Linton).
- ACPI backlight quirks for ESPRIMO Mobile M9410 and Dell XPS L421X
(Aaron Lu, Hans de Goede).
- Fixes for the arm_big_little and s5pv210-cpufreq cpufreq drivers
(Jon Medhurst, Nicolas Pitre).
- kfree()-related fixup for the recently introduced CPPC cpufreq
frontend (Markus Elfring).
- intel_pstate fix reducing kernel log noise on systems where
P-states are managed by hardware (Prarit Bhargava).
- intel_pstate maintainers information update (Srinivas Pandruvada).
- cpufreq core optimization related to the handling of delayed work
items used by governors (Viresh Kumar).
- Locking fixes and cleanups of the Operating Performance Points
(OPP) framework (Viresh Kumar).
- Generic power domains framework cleanups (Lina Iyer).
- cpupower tool updates (Jacob Tanenbaum, Sriram Raghunathan, Thomas
Renninger).
- turbostat tool updates (Len Brown)"
* tag 'pm+acpi-4.4-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
PCI: ACPI: Add support for PCI device DMA coherency
of/pci: Fix pci_get_host_bridge_device leak
device property: ACPI: Remove unused DMA APIs
device property: ACPI: Make use of the new DMA Attribute APIs
device property: Adding DMA Attribute APIs for Generic Devices
ACPI: Adding DMA Attribute APIs for ACPI Device
device property: Introducing enum dev_dma_attr
ACPI: Honor ACPI _CCA attribute setting
cpufreq: CPPC: Delete an unnecessary check before the function call kfree()
PM / OPP: Add opp_rcu_lockdep_assert() to _find_device_opp()
PM / OPP: Hold dev_opp_list_lock for writers
PM / OPP: Protect updates to list_dev with mutex
PM / OPP: Propagate error properly from dev_pm_opp_set_sharing_cpus()
cpufreq: s5pv210-cpufreq: fix wrong do_div() usage
MAINTAINERS: update for intel P-state driver
Creating a common structure initialization pattern for struct option
cpupower: Enable disabled Cstates if they are below max latency
cpupower: Remove debug message when using cpupower idle-set -D switch
cpupower: cpupower monitor reports uninitialized values for offline cpus
* acpi-pci:
drivers/crypto/ccp/ccp-platform.c
This patch adds support for setting up PCI device DMA coherency from
ACPI _CCA object that should normally be specified in the DSDT node
of its PCI host bridge.
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
This patch move of_pci_dma_configure() to a more generic
pci_dma_configure(), which can be extended by non-OF code (e.g. ACPI).
This has no functional change.
Acked-by: Rob Herring <robh+dt@kernel.org>
"Resource management:
- Add support for Enhanced Allocation devices (Sean O. Stalley)
- Add Enhanced Allocation register entries (Sean O. Stalley)
- Handle IORESOURCE_PCI_FIXED when sizing resources (David Daney)
- Handle IORESOURCE_PCI_FIXED when assigning resources (David Daney)
- Handle Enhanced Allocation capability for SR-IOV devices (David Daney)
- Clear IORESOURCE_UNSET when reverting to firmware-assigned address (Bjorn Helgaas)
- Make Enhanced Allocation bitmasks more obvious (Bjorn Helgaas)
- Expand Enhanced Allocation BAR output (Bjorn Helgaas)
- Add of_pci_check_probe_only to parse "linux,pci-probe-only" (Marc Zyngier)
- Fix lookup of linux,pci-probe-only property (Marc Zyngier)
- Add sparc mem64 resource parsing for root bus (Yinghai Lu)
PCI device hotplug:
- pciehp: Queue power work requests in dedicated function (Guenter Roeck)
Driver binding:
- Add builtin_pci_driver() to avoid registration boilerplate (Paul Gortmaker)
Virtualization:
- Set SR-IOV NumVFs to zero after enumeration (Alexander Duyck)
- Remove redundant validation of SR-IOV offset/stride registers (Alexander Duyck)
- Remove VFs in reverse order if virtfn_add() fails (Alexander Duyck)
- Reorder pcibios_sriov_disable() (Alexander Duyck)
- Wait 1 second between disabling VFs and clearing NumVFs (Alexander Duyck)
- Fix sriov_enable() error path for pcibios_enable_sriov() failures (Alexander Duyck)
- Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs (Ben Shelton)
- Don't try to restore VF BARs (Wei Yang)
MSI:
- Don't alloc pcibios-irq when MSI is enabled (Joerg Roedel)
- Add msi_controller setup_irqs() method for special multivector setup (Lucas Stach)
- Export all remapped MSIs to sysfs attributes (Romain Bezut)
- Disable MSI on SiS 761 (Ondrej Zary)
AER:
- Clear error status registers during enumeration and restore (Taku Izumi)
Generic host bridge driver:
- Allow multiple hosts with different map_bus() methods (David Daney)
- Pass starting bus number to pci_scan_root_bus() (David Daney)
- Fix address window calculation for non-zero starting bus (David Daney)
Altera host bridge driver:
- Add msi.h to ARM Kbuild (Ley Foon Tan)
- Add Altera PCIe host controller driver (Ley Foon Tan)
- Add Altera PCIe MSI driver (Ley Foon Tan)
APM X-Gene host bridge driver:
- Remove msi_controller assignment (Duc Dang)
- Fix header comment "Corporation" misspelling (Florian Fainelli)
- Fix code comment to match code (Ray Jui)
- Remove unused struct iproc_pcie.irqs[] (Ray Jui)
- Call pci_fixup_irqs() for ARM64 as well as ARM (Ray Jui)
- Fix PCIe reset logic (Ray Jui)
- Improve link detection logic (Ray Jui)
- Update PCIe device tree bindings (Ray Jui)
- Add outbound mapping support (Ray Jui)
- Return real error code from imx6_add_pcie_port() (Fabio Estevam)
- Add PCIE_PHY_RX_ASIC_OUT_VALID definition (Fabio Estevam)
Freescale Layerscape host bridge driver:
- Remove ls_pcie_establish_link() (Minghuan Lian)
- Ignore PCIe controllers in Endpoint mode (Minghuan Lian)
- Factor out SCFG related function (Minghuan Lian)
- Update ls_add_pcie_port() (Minghuan Lian)
- Remove unused fields from struct ls_pcie (Minghuan Lian)
- Add support for LS1043a and LS2080a (Minghuan Lian)
- Add ls_pcie_msi_host_init() (Minghuan Lian)
- Add HiSilicon SoC Hip05 PCIe driver (Zhou Wang)
Marvell MVEBU host bridge driver:
- Return zero for reserved or unimplemented config space (Russell King)
- Use exact config access size; don't read/modify/write (Russell King)
- Use of_get_available_child_count() (Russell King)
- Use for_each_available_child_of_node() to walk child nodes (Russell King)
- Report full node name when reporting a DT error (Russell King)
- Use port->name rather than "PCIe%d.%d" (Russell King)
- Move port parsing and resource claiming to separate function (Russell King)
- Fix memory leaks and refcount leaks (Russell King)
- Split port parsing and resource claiming from port setup (Russell King)
- Use gpio_set_value_cansleep() (Russell King)
- Use devm_kcalloc() to allocate an array (Russell King)
- Use gpio_desc to carry around gpio (Russell King)
- Improve clock/reset handling (Russell King)
- Add PCI Express root complex capability block (Russell King)
- Remove code restricting accesses to slot 0 (Russell King)
NVIDIA Tegra host bridge driver:
- Wrap static pgprot_t initializer with __pgprot() (Ard Biesheuvel)
- Build pci-rcar-gen2.c only on ARM (Geert Uytterhoeven)
- Build pcie-rcar.c only on ARM (Geert Uytterhoeven)
- Make PCI aware of the I/O resources (Phil Edworthy)
- Remove dependency on ARM-specific struct hw_pci (Phil Edworthy)
- Set root bus nr to that provided in DT (Phil Edworthy)
- Fix I/O offset for multiple host bridges (Phil Edworthy)
ST Microelectronics SPEAr13xx host bridge driver:
- Fix dw_pcie_cfg_read/write() usage (Gabriele Paoloni)
- Make "clocks" and "clock-names" optional DT properties (Bhupesh Sharma)
- Use exact access size in dw_pcie_cfg_read() (Gabriele Paoloni)
- Simplify dw_pcie_cfg_read/write() interfaces (Gabriele Paoloni)
- Require config accesses to be naturally aligned (Gabriele Paoloni)
- Make "num-lanes" an optional DT property (Gabriele Paoloni)
- Move calculation of bus addresses to DRA7xx (Gabriele Paoloni)
- Replace ARM pci_sys_data->align_resource with global function pointer (Gabriele Paoloni)
- Factor out MSI msg setup (Lucas Stach)
- Implement multivector MSI IRQ setup (Lucas Stach)
- Make get_msi_addr() return phys_addr_t, not u32 (Lucas Stach)
- Set up high part of MSI target address (Lucas Stach)
- Fix PORT_LOGIC_LINK_WIDTH_MASK (Zhou Wang)
- Revert "PCI: designware: Program ATU with untranslated address" (Zhou Wang)
- Use of_pci_get_host_bridge_resources() to parse DT (Zhou Wang)
- Make driver arch-agnostic (Zhou Wang)
Miscellaneous:
- Make x86 pci_subsys_init() static (Alexander Kuleshov)
- Turn off Request Attributes to avoid Chelsio T5 Completion erratum (Hariprasad Shenai)"
* tag 'pci-v4.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits)
PCI: altera: Add Altera PCIe MSI driver
PCI: hisi: Add HiSilicon SoC Hip05 PCIe driver
PCI: layerscape: Add ls_pcie_msi_host_init()
PCI: layerscape: Add support for LS1043a and LS2080a
PCI: layerscape: Remove unused fields from struct ls_pcie
PCI: layerscape: Update ls_add_pcie_port()
PCI: layerscape: Factor out SCFG related function
PCI: layerscape: Ignore PCIe controllers in Endpoint mode
PCI: layerscape: Remove ls_pcie_establish_link()
PCI: designware: Make "clocks" and "clock-names" optional DT properties
PCI: designware: Make driver arch-agnostic
ARM/PCI: Replace pci_sys_data->align_resource with global function pointer
PCI: designware: Use of_pci_get_host_bridge_resources() to parse DT
PCI: designware: Move calculation of bus addresses to DRA7xx
PCI: designware: Make "num-lanes" an optional DT property
PCI: designware: Require config accesses to be naturally aligned
PCI: designware: Simplify dw_pcie_cfg_read/write() interfaces
PCI: designware: Use exact access size in dw_pcie_cfg_read()
PCI: spear: Fix dw_pcie_cfg_read/write() usage
'pci/resource' and 'pci/virtualization' into next
* pci/aer:
PCI/AER: Clear error status registers during enumeration and restore
* pci/hotplug:
PCI: pciehp: Queue power work requests in dedicated function
* pci/misc:
PCI: Turn off Request Attributes to avoid Chelsio T5 Completion erratum
x86/PCI: Make pci_subsys_init() static
PCI: Add builtin_pci_driver() to avoid registration boilerplate
PCI: Remove unnecessary "if" statement
* pci/msi:
x86/PCI: Don't alloc pcibios-irq when MSI is enabled
PCI/MSI: Export all remapped MSIs to sysfs attributes
PCI: Disable MSI on SiS 761
* pci/resource:
sparc/PCI: Add mem64 resource parsing for root bus
PCI: Expand Enhanced Allocation BAR output
PCI: Make Enhanced Allocation bitmasks more obvious
PCI: Handle Enhanced Allocation capability for SR-IOV devices
PCI: Add support for Enhanced Allocation devices
PCI: Add Enhanced Allocation register entries
PCI: Handle IORESOURCE_PCI_FIXED when assigning resources
PCI: Handle IORESOURCE_PCI_FIXED when sizing resources
PCI: Clear IORESOURCE_UNSET when reverting to firmware-assigned address
PCI: Fix sriov_enable() error path for pcibios_enable_sriov() failures
PCI: Wait 1 second between disabling VFs and clearing NumVFs
PCI: Reorder pcibios_sriov_disable()
PCI: Remove VFs in reverse order if virtfn_add() fails
PCI: Remove redundant validation of SR-IOV offset/stride registers
PCI: Set SR-IOV NumVFs to zero after enumeration
PCI: Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs
PCI: Don't try to restore VF BARs
Add support for devices using Enhanced Allocation entries instead of BARs.
This allows the kernel to parse the EA Extended Capability structure in PCI
config space and claim the BAR-equivalent resources.
See https://pcisig.com/sites/default/files/specification_documents/ECN_Enhanced_Allocation_23_Oct_2014_Final.pdf
[bhelgaas: add spec URL, s/pci_ea_set_flags/pci_ea_flags/, consolidate
declarations, print unknown property in hex to match spec]
Signed-off-by: Sean O. Stalley <sean.stalley@intel.com>
[david.daney@cavium.com: Add more support/checking for Entry Properties,
allow EA behind bridges, rewrite some error messages.]
Signed-off-by: David Daney <david.daney@cavium.com>
So far, we've always considered that for a given PCI device, its
MSI controller was either set by the architecture-specific
pcibios hook, or simply inherited from the host bridge.
This doesn't cover things like firmware-defined topologies like
msi-map (DT) or IORT (ACPI), which can provide information about
which MSI controller to use on a per-device basis.
This patch adds the necessary hook into the MSI code to allow this
feature, and provides the msi-map functionnality as a first
implementation.
Acked-by: Rob Herring <robh@kernel.org>
So far, we have considered that the MSI domain for a device was
either set via the architecture-dependent pcibios implementation
or inherited from the host bridge.
As we're about to break that assumption, add pci_dev_msi_domain
which is the equivalent of pci_host_bridge_msi_domain, but for
a single device.
Other than moving things around a bit, this patch on its own
has no effect.
SR-IOV creates a virtual bus where bus->self is NULL. When we add VFs and
scan for an MSI domain, pci_set_bus_msi_domain() dereferences bus->self,
which causes a kernel NULL pointer dereference oops.
Scan up to the parent bus until we find a real bridge where we can get the
MSI domain.
Fixes: 44aa0c657e3e ("PCI/MSI: Add hooks to populate the msi_domain field")
Tested-by: Joerg Roedel <joro@8bytes.org>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
AER errors might be recorded when powering-on devices. These errors can be
ignored, so firmware usually clears them before the OS enumerates devices.
However, firmware is not involved when devices are added via hotplug, so
the OS may discover power-up errors that should be ignored. The same may
happen when powering up devices when resuming after suspend.
Clear the AER error status registers during enumeration and resume.
[bhelgaas: changelog, remove repetitive comments]
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Revert dff22d2054b5 ("PCI: Call pci_read_bridge_bases() from core instead
of arch code").
Reading PCI bridge windows is not arch-specific in itself, but there is PCI
core code that doesn't work correctly if we read them too early. For
example, Hannes found this case on an ARM Freescale i.mx6 board:
pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff]
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
pci 0000:00:00.0: BAR 8: no space for [mem size 0x01000000] (mem window)
pci 0000:01:00.0: BAR 2: failed to assign [mem size 0x00200000]
pci 0000:01:00.0: BAR 1: failed to assign [mem size 0x00004000]
pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x00000100]
The 00:00.0 mem window needs to be at least 3MB: the 01:00.0 device needs
0x204100 of space, and mem windows are megabyte-aligned.
Bus sizing can increase a bridge window size, but never *decrease* it (see
d65245c3297a ("PCI: don't shrink bridge resources")). Prior to
dff22d2054b5, ARM didn't read bridge windows at all, so the "original size"
was zero, and we assigned a 3MB window.
After dff22d2054b5, we read the bridge windows before sizing the bus. The
firmware programmed a 16MB window (size 0x01000000) in 00:00.0, and since
we never decrease the size, we kept 16MB even though we only needed 3MB.
But 16MB doesn't fit in the host bridge aperture, so we failed to assign
space for the window and the downstream devices.
I think this is a defect in the PCI core: we shouldn't rely on the firmware
to assign sensible windows.
Ray reported a similar problem, also on ARM, with Broadcom iProc.
Issues like this are too hard to fix right now, so revert dff22d2054b5.
Reported-by: Hannes <oe5hpm@gmail.com>
Reported-by: Ray Jui <rjui@broadcom.com>
Link: http://lkml.kernel.org/r/CAAa04yFQEUJm7Jj1qMT57-LG7ZGtnhNDBe=PpSRa70Mj+XhW-A@mail.gmail.com
Link: http://lkml.kernel.org/r/55F75BB8.4070405@broadcom.com
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm updates from Dan Williams:
"This update has successfully completed a 0day-kbuild run and has
appeared in a linux-next release. The changes outside of the typical
drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the
removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and
the introduction of ZONE_DEVICE + devm_memremap_pages().
Summary:
- Introduce ZONE_DEVICE and devm_memremap_pages() as a generic
mechanism for adding device-driver-discovered memory regions to the
kernel's direct map.
This facility is used by the pmem driver to enable pfn_to_page()
operations on the page frames returned by DAX ('direct_access' in
'struct block_device_operations').
For now, the 'memmap' allocation for these "device" pages comes
from "System RAM". Support for allocating the memmap from device
memory will arrive in a later kernel.
- Introduce memremap() to replace usages of ioremap_cache() and
ioremap_wt(). memremap() drops the __iomem annotation for these
mappings to memory that do not have i/o side effects. The
replacement of ioremap_cache() with memremap() is limited to the
pmem driver to ease merging the api change in v4.3.
Completion of the conversion is targeted for v4.4.
- Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem
driver, update the VFS DAX implementation and PMEM api to provide
persistence guarantees for kernel operations on a DAX mapping.
- Convert the ACPI NFIT 'BLK' driver to map the block apertures as
cacheable to improve performance.
- Miscellaneous updates and fixes to libnvdimm including support for
issuing "address range scrub" commands, clarifying the optimal
'sector size' of pmem devices, a clarification of the usage of the
ACPI '_STA' (status) property for DIMM devices, and other minor
fixes"
* tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits)
libnvdimm, pmem: direct map legacy pmem by default
libnvdimm, pmem: 'struct page' for pmem
libnvdimm, pfn: 'struct page' provider infrastructure
x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB
add devm_memremap_pages
mm: ZONE_DEVICE for "device memory"
mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h
dax: drop size parameter to ->direct_access()
nd_blk: change aperture mapping from WC to WB
nvdimm: change to use generic kvfree()
pmem, dax: have direct_access use __pmem annotation
dax: update I/O path to do proper PMEM flushing
pmem: add copy_from_iter_pmem() and clear_pmem()
pmem, x86: clean up conditional pmem includes
pmem: remove layer when calling arch_has_wmb_pmem()
pmem, x86: move x86 PMEM API to new pmem.h header
libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option
pmem: switch to devm_ allocations
devres: add devm_memremap
libnvdimm, btt: write and validate parent_uuid
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
"PCI changes for the v4.3 merge window:
Enumeration:
- Allocate ATS struct during enumeration (Bjorn Helgaas)
- Embed ATS info directly into struct pci_dev (Bjorn Helgaas)
- Reduce size of ATS structure elements (Bjorn Helgaas)
- Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas)
- iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas)
- Move MPS configuration check to pci_configure_device() (Bjorn Helgaas)
- Set MPS to match upstream bridge (Keith Busch)
- ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri)
- Add pci_scan_root_bus_msi() (Lorenzo Pieralisi)
- ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi)
- Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi)
PCI device hotplug:
- pciehp: Remove unused interrupt events (Bjorn Helgaas)
- pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas)
- pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson)
- pciehp: Simplify pcie_poll_cmd() (Yijing Wang)
- Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang)
- Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang)
- Hold pci_slot_mutex while searching bus->slots list (Yijing Wang)
Power management:
- Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui)
Virtualization:
- Add ACS quirks for Intel I219-LM/V (Alex Williamson)
- Restore ACS configuration as part of pci_restore_state() (Alexander Duyck)
MSI:
- Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu)
- Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu)
- ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi)
- Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi)
- Remove dependency on ARM-specific struct hw_pci (Jayachandran C)
- Build setup-irq.o for arm64 (Jayachandran C)
- Add arm64 support (Jayachandran C)
- Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang)
- Add support for a 64-bit prefetchable memory window (Duc Dang)
- Drop owner assignment from platform_driver (Krzysztof Kozlowski)
- Allow BCMA bus driver to be built as module (Hauke Mehrtens)
- Delete unnecessary checks before phy calls (Markus Elfring)
- Add arm64 support (Ray Jui)
- Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri)
TI DRA7xx host bridge driver:
- Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I)
- Add PM support (Kishon Vijay Abraham I)
- Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I)
- Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I)
Xilinx AXI host bridge driver:
- Check for MSI interrupt flag before handling as INTx (Russell Joyce)
Miscellaneous:
- Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa)
- Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas)
- Fix generic NCR 53c810 class code quirk (Bjorn Helgaas)
- Fix TI816X class code quirk (Bjorn Helgaas)
- Remove unused "pci_probe" flags (Bjorn Helgaas)
- Host bridge driver code simplifications (Fabio Estevam)
- Add dev_flags bit to access VPD through function 0 (Mark Rustad)
- Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad)
- Kill off set_irq_flags() usage (Rob Herring)
- Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar)
- Clean up pci_find_capability() (Wei Yang)"
* tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits)
PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI
PCI: Set MPS to match upstream bridge
PCI: Move MPS configuration check to pci_configure_device()
PCI: Drop references acquired by of_parse_phandle()
PCI/MSI: Remove unused pcibios_msi_controller() hook
PCI: Add pci_scan_root_bus_msi()
ARM/PCI: Replace panic with WARN messages on failures
PCI: generic: Add arm64 support
PCI: Build setup-irq.o for arm64
PCI: generic: Remove dependency on ARM-specific struct hw_pci
PCI: imx6: Simplify a trivial if-return sequence
PCI: spear: Use BUG_ON() instead of condition followed by BUG()
PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE()
PCI: Remove pci_ats_enabled()
PCI: Stop caching ATS Invalidate Queue Depth
PCI: Move ATS declarations to linux/pci.h so they're all together
PCI: Clean up ATS error handling
PCI: Use pci_physfn() rather than looking up physfn by hand
* pci/enumeration:
* pci/misc:
Commit 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel
doesn't support MSI") changed the location of the code that initialises
dev->msi_cap/msix_cap and then disables MSI/MSI-X interrupts at PCI
probe time in devices that have this flag set. It moved the code from
pci_msi_init_pci_dev() to a new function named pci_msi_setup_pci_dev(),
called by pci_setup_device().
The pseries PCI probing code does not call pci_setup_device(), so since
the aforementioned commit the function pci_msi_setup_pci_dev() is not
called and MSI/MSI-X interrupts are left enabled. Additionally because
dev->msi_cap/msix_cap are not initialised no driver can ever enable
MSI/MSI-X.
To fix this, the pseries PCI probe should manually call
pci_msi_setup_pci_dev(), so this patch makes it non-static.
[mpe: Update change log to mention dev->msi_cap/msix_cap]
Firmware typically configures the PCIe fabric with a consistent Max Payload
Size setting based on the devices present at boot. A hot-added device
typically has the power-on default MPS setting (128 bytes), which may not
match the fabric.
The previous Linux default, in the absence of any "pci=pcie_bus_*" options,
was PCIE_BUS_TUNE_OFF, in which we never touch MPS, even for hot-added
devices.
Add a new default setting, PCIE_BUS_DEFAULT, in which we make sure every
device's MPS setting matches the upstream bridge. This makes it more
likely that a hot-added device will work in a system with optimized MPS
configuration.
Note that if we hot-add a device that only supports 128-byte MPS, it still
likely won't work because we don't reconfigure the rest of the fabric.
Booting with "pci=pcie_bus_peer2peer" is a workaround for this because it
sets MPS to 128 for everything.
[bhelgaas: changelog, new default, rework for pci_configure_device() path]
Tested-by: Keith Busch <keith.busch@intel.com>
Tested-by: Jordan Hargrave <jharg93@gmail.com>
