path: root/drivers/pci/pcie/pme
2010-08-24PCI: PCIe: Move PCIe PME code to the pcie directoryRafael J. Wysocki
The PCIe PME code only consists of one file, so it doesn't need to occupy its own directory. Move it to drivers/pci/pcie/pme.c and remove the contents of drivers/pci/pcie/pme . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-24PCI: PCIe: Ask BIOS for control of all native services at onceRafael J. Wysocki
After commit 852972acff8f10f3a15679be2059bb94916cba5d (ACPI: Disable ASPM if the platform won't provide _OSC control for PCIe) control of the PCIe Capability Structure is unconditionally requested by acpi_pci_root_add(), which in principle may cause problems to happen in two ways. First, the BIOS may refuse to give control of the PCIe Capability Structure if it is not asked for any of the _OSC features depending on it at the same time. Second, the BIOS may assume that control of the _OSC features depending on the PCIe Capability Structure will be requested in the future and may behave incorrectly if that doesn't happen. For this reason, control of the PCIe Capability Structure should always be requested along with control of any other _OSC features that may depend on it (ie. PCIe native PME, PCIe native hot-plug, PCIe AER). Rework the PCIe port driver so that (1) it checks which native PCIe port services can be enabled, according to the BIOS, and (2) it requests control of all these services simultaneously. In particular, this causes pcie_portdrv_probe() to fail if the BIOS refuses to grant control of the PCIe Capability Structure, which means that no native PCIe port services can be enabled for the PCIe Root Complex the given port belongs to. If that happens, ASPM is disabled to avoid problems with mishandling it by the part of the PCIe hierarchy for which control of the PCIe Capability Structure has not been received. Make it possible to override this behavior using 'pcie_ports=native' (use the PCIe native services regardless of the BIOS response to the control request), or 'pcie_ports=compat' (do not use the PCIe native services at all). Accordingly, rework the existing PCIe port service drivers so that they don't request control of the services directly. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-24ACPI/PCI: Negotiate _OSC control bits before requesting them Rafael J. Wysocki
It is possible that the BIOS will not grant control of all _OSC features requested via acpi_pci_osc_control_set(), so it is recommended to negotiate the final set of _OSC features with the query flag set before calling _OSC to request control of these features. To implement it, rework acpi_pci_osc_control_set() so that the caller can specify the mask of _OSC control bits to negotiate and the mask of _OSC control bits that are absolutely necessary to it. Then, acpi_pci_osc_control_set() will run _OSC queries in a loop until the mask of _OSC control bits returned by the BIOS is equal to the mask passed to it. Also, before running the _OSC request acpi_pci_osc_control_set() will check if the caller's required control bits are present in the final mask. Using this mechanism we will be able to avoid situations in which the BIOS doesn't grant control of certain _OSC features, because they depend on some other _OSC features that have not been requested. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-07-19PM: Make it possible to avoid races between wakeup and system sleepRafael J. Wysocki
One of the arguments during the suspend blockers discussion was that the mainline kernel didn't contain any mechanisms making it possible to avoid races between wakeup and system suspend. Generally, there are two problems in that area. First, if a wakeup event occurs exactly when /sys/power/state is being written to, it may be delivered to user space right before the freezer kicks in, so the user space consumer of the event may not be able to process it before the system is suspended. Second, if a wakeup event occurs after user space has been frozen, it is not generally guaranteed that the ongoing transition of the system into a sleep state will be aborted. To address these issues introduce a new global sysfs attribute, /sys/power/wakeup_count, associated with a running counter of wakeup events and three helper functions, pm_stay_awake(), pm_relax(), and pm_wakeup_event(), that may be used by kernel subsystems to control the behavior of this attribute and to request the PM core to abort system transitions into a sleep state already in progress. The /sys/power/wakeup_count file may be read from or written to by user space. Reads will always succeed (unless interrupted by a signal) and return the current value of the wakeup events counter. Writes, however, will only succeed if the written number is equal to the current value of the wakeup events counter. If a write is successful, it will cause the kernel to save the current value of the wakeup events counter and to abort the subsequent system transition into a sleep state if any wakeup events are reported after the write has returned. [The assumption is that before writing to /sys/power/state user space will first read from /sys/power/wakeup_count. Next, user space consumers of wakeup events will have a chance to acknowledge or veto the upcoming system transition to a sleep state. Finally, if the transition is allowed to proceed, /sys/power/wakeup_count will be written to and if that succeeds, /sys/power/state will be written to as well. Still, if any wakeup events are reported to the PM core by kernel subsystems after that point, the transition will be aborted.] Additionally, put a wakeup events counter into struct dev_pm_info and make these per-device wakeup event counters available via sysfs, so that it's possible to check the activity of various wakeup event sources within the kernel. To illustrate how subsystems can use pm_wakeup_event(), make the low-level PCI runtime PM wakeup-handling code use it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: markgross <markgross@thegnar.org> Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
2010-06-18PCI/PM: Do not use native PCIe PME by defaultRafael J. Wysocki
Commit c7f486567c1d0acd2e4166c47069835b9f75e77b (PCI PM: PCIe PME root port service driver) causes the native PCIe PME signaling to be used by default, if the BIOS allows the kernel to control the standard configuration registers of PCIe root ports. However, the native PCIe PME is coupled to the native PCIe hotplug and calling pcie_pme_acpi_setup() makes some BIOSes expect that the native PCIe hotplug will be used as well. That, in turn, causes problems to appear on systems where the PCIe hotplug driver is not loaded. The usual symptom, as reported by Jaroslav Kameník and others, is that the ACPI GPE associated with PCIe hotplug keeps firing continuously causing kacpid to take substantial percentage of CPU time. To work around this issue, change the default so that the native PCIe PME signaling is only used if directly requested with the help of the pcie_pme= command line switch. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15924 , which is a listed regression from 2.6.33. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Jaroslav Kameník <jaroslav@kamenik.cz> Tested-by: Antoni Grzymala <antekgrzymala@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22PCIe PME: use pci_pcie_cap()Kenji Kaneshige
Use pci_pcie_cap() instead of pci_find_capability() to get PCIe capability offset. This reduces redundant search in PCI configuration space. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCIe PME: use pci_is_pcie()Kenji Kaneshige
Use pci_is_pcie() instead of looking at obsolete is_pcie field in struct pci_dev. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI PM: Make it possible to force using INTx for PCIe PME signalingRafael J. Wysocki
Apparently, some machines may have problems with PCI run-time power management if MSIs are used for the native PCIe PME signaling. In particular, on the MSI Wind U-100 PCIe PME interrupts are not generated by a PCIe root port after a resume from suspend to RAM, if the system wake-up was triggered by a PME from the device attached to this port. [It doesn't help to free the interrupt on suspend and request it back on resume, even if that is done along with disabling the MSI and re-enabling it, respectively.] However, if INTx interrupts are used for this purpose on the same machine, everything works just fine. For this reason, add a kernel command line switch allowing one to request that MSIs be not used for the native PCIe PME signaling, introduce a DMI table allowing us to blacklist machines that need this switch to be set by default and put the MSI Wind U-100 into this table. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI PM: PCIe PME root port service driverRafael J. Wysocki
PCIe native PME detection mechanism is based on interrupts generated by root ports or event collectors every time a PCIe device sends a PME message upstream. Once a PME message has been sent by an endpoint device and received by its root port (or event collector in the case of root complex integrated endpoints), the Requester ID from the message header is registered in the root port's Root Status register. At the same time, the PME Status bit of the Root Status register is set to indicate that there's a PME to handle. If PCIe PME interrupt is enabled for the root port, it generates an interrupt once the PME Status has been set. After receiving the interrupt, the kernel can identify the PCIe device that generated the PME using the Requester ID from the root port's Root Status register. [For details, see PCI Express Base Specification, Rev. 2.0.] Implement a driver for the PCIe PME root port service working in accordance with the above description. Based on a patch from Shaohua Li <shaohua.li@intel.com>. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
