path: root/drivers/pci/bus.c
2012-02-23PCI: add struct pci_host_bridge_window with CPU/bus address offsetBjorn Helgaas
Some PCI host bridges apply an address offset, so bus addresses on PCI are different from CPU addresses. This patch adds a way for architectures to tell the PCI core about this offset. For example: LIST_HEAD(resources); pci_add_resource_offset(&resources, host->io_space, host->io_offset); pci_add_resource_offset(&resources, host->mem_space, host->mem_offset); pci_scan_root_bus(parent, bus, ops, sysdata, &resources); Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-06PCI: add helpers for building PCI bus resource listsBjorn Helgaas
We'd like to supply a list of resources when we create a new PCI bus, e.g., the root bus under a PCI host bridge. These are helpers for constructing that list. These are exported because the plan is to replace this exported interface: pci_scan_bus_parented() with this one: pci_add_resource(resources, ...) pci_scan_root_bus(..., resources) Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI/sysfs: move bus cpuaffinity to class dev_attrsYinghai Lu
Requested by Greg KH to fix a race condition in the creating of PCI bus cpuaffinity files. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-12-17Revert "PCI: allocate bus resources from the top down"Bjorn Helgaas
This reverts commit b126b4703afa4010b161784a43650337676dd03b. We're going back to the old behavior of allocating from bus resources in _CRS order. Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-12-17Revert "PCI: fix pci_bus_alloc_resource() hang, prefer positive decode"Bjorn Helgaas
This reverts commit 82e3e767c21fef2b1b38868e20eb4e470a1e38e3. We're going back to considering bus resources in the order we found them (in _CRS order, when we're using _CRS), so we don't need to define any ordering. Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-11-12PCI: fix pci_bus_alloc_resource() hang, prefer positive decodeBjorn Helgaas
When a PCI bus has two resources with the same start/end, e.g., pci_bus 0000:04: resource 2 [mem 0xd0000000-0xd7ffffff pref] pci_bus 0000:04: resource 7 [mem 0xd0000000-0xd7ffffff] the previous pci_bus_find_resource_prev() implementation would alternate between them forever: pci_bus_find_resource_prev(... [mem 0xd0000000-0xd7ffffff pref]) returns [mem 0xd0000000-0xd7ffffff] pci_bus_find_resource_prev(... [mem 0xd0000000-0xd7ffffff]) returns [mem 0xd0000000-0xd7ffffff pref] pci_bus_find_resource_prev(... [mem 0xd0000000-0xd7ffffff pref]) returns [mem 0xd0000000-0xd7ffffff] ... This happened because there was no ordering between two resources with the same start and end. A resource that had the same start and end as the cursor, but was not itself the cursor, was considered to be before the cursor. This patch fixes the hang by making a fixed ordering between any two resources. In addition, it tries to allocate from positively decoded regions before using any subtractively decoded resources. This means we will use a positive decode region before a subtractive decode one, even if it means using a smaller address. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=22062 Reported-by: Borislav Petkov <bp@amd64.org> Tested-by: Borislav Petkov <bp@amd64.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-10-28Merge branch 'stable/xen-pcifront-0.8.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm * 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: register xen pci notifier xen: initialize cpu masks for pv guests in xen_smp_init xen: add a missing #include to arch/x86/pci/xen.c xen: mask the MTRR feature from the cpuid xen: make hvc_xen console work for dom0. xen: add the direct mapping area for ISA bus access xen: Initialize xenbus for dom0. xen: use vcpu_ops to setup cpu masks xen: map a dummy page for local apic and ioapic in xen_set_fixmap xen: remap MSIs into pirqs when running as initial domain xen: remap GSIs as pirqs when running as initial domain xen: introduce XEN_DOM0 as a silent option xen: map MSIs into pirqs xen: support GSI -> pirq remapping in PV on HVM guests xen: add xen hvm acpi_register_gsi variant acpi: use indirect call to register gsi in different modes xen: implement xen_hvm_register_pirq xen: get the maximum number of pirqs from xen xen: support pirq != irq * 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits) X86/PCI: Remove the dependency on isapnp_disable. xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright. x86: xen: Sanitse irq handling (part two) swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it. MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer. xen/pci: Request ACS when Xen-SWIOTLB is activated. xen-pcifront: Xen PCI frontend driver. xenbus: prevent warnings on unhandled enumeration values xenbus: Xen paravirtualised PCI hotplug support. xen/x86/PCI: Add support for the Xen PCI subsystem x86: Introduce x86_msi_ops msi: Introduce default_[teardown|setup]_msi_irqs with fallback. x86/PCI: Export pci_walk_bus function. x86/PCI: make sure _PAGE_IOMAP it set on pci mappings x86/PCI: Clean up pci_cache_line_size xen: fix shared irq device passthrough xen: Provide a variant of xen_poll_irq with timeout. xen: Find an unbound irq number in reverse order (high to low). xen: statically initialize cpu_evtchn_mask_p ... Fix up trivial conflicts in drivers/pci/Makefile
2010-10-26PCI: allocate bus resources from the top downBjorn Helgaas
Allocate space from the highest-address PCI bus resource first, then work downward. Previously, we looked for space in PCI host bridge windows in the order we discovered the windows. For example, given the following windows (discovered via an ACPI _CRS method): pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff] pci_root PNP0A03:00: host bridge window [mem 0xbff00000-0xf7ffffff] pci_root PNP0A03:00: host bridge window [mem 0xff980000-0xff980fff] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff] we attempted to allocate from [mem 0x000a0000-0x000bffff] first, then [mem 0x000c0000-0x000effff], and so on. With this patch, we allocate from [mem 0xff980000-0xff980fff] first, then [mem 0xff97c000-0xff97ffff], [mem 0xfed20000-0xfed9ffff], etc. Allocating top-down follows Windows practice, so we're less likely to trip over BIOS defects in the _CRS description. On the machine above (a Dell T3500), the [mem 0xbff00000-0xbfffffff] region doesn't actually work and is likely a BIOS defect. The symptom is that we move the AHCI controller to 0xbff00000, which leads to "Boot has failed, sleeping forever," a BUG in ahci_stop_engine(), or some other boot failure. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=16228#c43 Reference: https://bugzilla.redhat.com/show_bug.cgi?id=620313 Reference: https://bugzilla.redhat.com/show_bug.cgi?id=629933 Reported-by: Brian Bloniarz <phunge0@hotmail.com> Reported-and-tested-by: Stefan Becker <chemobejk@gmail.com> Reported-by: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-10-18x86/PCI: Export pci_walk_bus function.Konrad Rzeszutek Wilk
In preperation of modularizing Xen-pcifront the pci_walk_bus needs to be exported so that the xen-pcifront module can walk call the pci subsystem to walk the PCI devices and claim them. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> [http://marc.info/?l=linux-pci&m=126149958010298&w=2]
2010-07-30PCI: check return value of pci_enable_device() when enabling bridgesJunchang Wang
pci_enable_device can fail. In that case, a printed warning would be more appropriate. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Junchang Wang <junchangwang@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-07-30PCI: sparse warning (trivial)Stephen Hemminger
Assigning zero where NULL should be used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07Driver core: create lock/unlock functions for struct deviceGreg Kroah-Hartman
In the future, we are going to be changing the lock type for struct device (once we get the lockdep infrastructure properly worked out) To make that changeover easier, and to possibly burry the lock in a different part of struct device, let's create some functions to lock and unlock a device so that no out-of-core code needs to be changed in the future. This patch creates the device_lock/unlock/trylock() functions, and converts all in-tree users to them. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <len.brown@intel.com> Cc: Magnus Damm <damm@igel.co.jp> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Alex Chiang <achiang@hp.com> Cc: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andrew Patterson <andrew.patterson@hp.com> Cc: Yu Zhao <yu.zhao@intel.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: CHENG Renquan <rqcheng@smu.edu.sg> Cc: Oliver Neukum <oliver@neukum.org> Cc: Frans Pop <elendil@planet.nl> Cc: David Vrabel <david.vrabel@csr.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-23PCI: augment bus resource table with a listBjorn Helgaas
Previously we used a table of size PCI_BUS_NUM_RESOURCES (16) for resources forwarded to a bus by its upstream bridge. We've increased this size several times when the table overflowed. But there's no good limit on the number of resources because host bridges and subtractive decode bridges can forward any number of ranges to their secondary buses. This patch reduces the table to only PCI_BRIDGE_RESOURCE_NUM (4) entries, which corresponds to the number of windows a PCI-to-PCI (3) or CardBus (4) bridge can positively decode. Any additional resources, e.g., PCI host bridge windows or subtractively-decoded regions, are kept in a list. I'd prefer a single list rather than this split table/list approach, but that requires simultaneous changes to every architecture. This approach only requires immediate changes where we set up (a) host bridges with more than four windows and (b) subtractive-decode P2P bridges, and we can incrementally change other architectures to use the list. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-23PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refsBjorn Helgaas
No functional change; this converts loops that iterate from 0 to PCI_BUS_NUM_RESOURCES through pci_bus resource[] table to use the pci_bus_for_each_resource() iterator instead. This doesn't change the way resources are stored; it merely removes dependencies on the fact that they're in a table. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: mark struct resource as constDominik Brodowski
Now that we return the new resource start position, there is no need to update "struct resource" inside the align function. Therefore, mark the struct resource as const. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: align functions now return start of resourceDominik Brodowski
As suggested by Linus, align functions should return the start of a resource, not void. An update of "res->start" is no longer necessary. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI AER: support Multiple Error Received and no error source idZhang, Yanmin
Based on PCI Express AER specs, a root port might receive multiple TLP errors while it could only save a correctable error source id and an uncorrectable error source id at the same time. In addition, some root port hardware might be unable to provide a correct source id, i.e., the source id, or the bus id part of the source id provided by root port might be equal to 0. The patchset implements the support in kernel by searching the device tree under the root port. Patch 1 changes parameter cb of function pci_walk_bus to return a value. When cb return non-zero, pci_walk_bus stops more searching on the device tree. Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-11PCI/x86: don't assume prefetchable ranges are 64bitYinghai Lu
We should not assign 64bit ranges to PCI devices that only take 32bit prefetchable addresses. Try to set IORESOURCE_MEM_64 in 64bit resource of pci_device/pci_bridge and make the bus resource only have that bit set when all devices under it support 64bit prefetchable memory. Use that flag to allocate resources from that range. Reported-by: Yannick <yannick.roehlly@free.fr> Reviewed-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-06PCI: Setup disabled bridges even if buses are addedYuji Shimada
This patch sets up disabled bridges even if buses have already been added. pci_assign_unassigned_resources is called after buses are added. pci_assign_unassigned_resources calls pci_bus_assign_resources. pci_bus_assign_resources calls pci_setup_bridge to configure BARs of bridges. Currently pci_setup_bridge returns immediately if the bus have already been added. So pci_assign_unassigned_resources can't configure BARs of bridges that were added in a disabled state; this patch fixes the issue. On logical hot-add, we need to prevent the kernel from re-initializing bridges that have already been initialized. To achieve this, pci_setup_bridge returns immediately if the bridge have already been enabled. We don't need to check whether the specified bus is a root bus or not. pci_setup_bridge is not called on a root bus, because a root bus does not have a bridge. The patch adds a new helper function, pci_is_enabled. I made the function name similar to pci_is_managed. The codes which use enable_cnt directly are changed to use pci_is_enabled. Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Yuji Shimada <shimada-yxb@necst.nec.co.jp> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: do not enable bridges more than onceAlex Chiang
In preparation for PCI core hotplug, we need to ensure that we do not attempt to re-enable bridges that have already been enabled. Reported-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI: constify pci_bus_add_devices()akpm@linux-foundation.org
drivers/pci/hotplug/fakephp.c:283: warning: passing argument 1 of 'pci_bus_add_devices' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: factor pci_bus_add_child() from pci_bus_add_devices()Yu Zhao
This patch splits a new function, pci_bus_add_child(), from pci_bus_add_devices(). The new function can be used to register PCI buses to the device core. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: cleanup pci_bus_add_devices()Yu Zhao
Cleanup pci_bus_add_devices() by negating the conditional and continuing, rather than having a single conditional take up the whole body. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: Add legacy_io/mem to all bussesBenjamin Herrenschmidt
Currently, only PHBs get the legacy_* files, which makes it tricky for userland to get access to the legacy space. This commit exposes them in every bus, since even child buses may forward legacy cycles if configured properly. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-20PCI: make CPU list affinity visibleMike Travis
Stephen Hemminger wrote: > Looks like Mike created cpulistaffinty in sysfs but never completed > the job. This patch hooks things up correctly, taking care to remove the new file when the bus is destroyed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: remove global list of PCI devicesGreg Kroah-Hartman
This patch finally removes the global list of PCI devices. We are relying entirely on the list held in the driver core now, and do not need a separate "shadow" list as no one uses it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: add is_added flag to struct pci_devGreg Kroah-Hartman
This lets us check if the device is really added to the driver core or not, which is what we need when walking some of the bus lists. The flag is there in anticipation of getting rid of the other PCI device list, which is what we used to check in this situation. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-13PCI: fix issue with busses registering multiple times in sysfsGreg Kroah-Hartman
PCI busses can be registered multiple times, so we need to detect if we have registered our bus structure in sysfs already. If so, don't do it again. Thanks to Guennadi Liakhovetski <g.liakhovetski@gmx.de> for reporting the problem, and to Linus for poking me to get me to believe that it was a real problem. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04PCI: fix up error messages for pci_bus registeringGreg Kroah-Hartman
Due to the class_device cleanup of pci_bus, the error messages when things go wrong are incorrect. So fix this up to properly report what is really happening, if things go wrong. Thanks to Kay for pointing out the issue. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: make pci_bus a struct deviceGreg Kroah-Hartman
This moves the pci_bus class device to be a real struct device and at the same time, place it in the device tree in the correct location. Note, the old "bridge" symlink is now gone, but this was a non-standard link and no userspace program used it. If you need to determine the device that the bus is on, follow the standard device symlink, or walk up the device tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: drivers/pci/: remove unused exportsAdrian Bunk
This patch removes the following unused exports: - remove the following unused EXPORT_SYMBOL's: - pci-acpi.c: pci_osc_support_set - proc.c: pci_proc_detach_bus - remove the following unused EXPORT_SYMBOL_GPL's: - bus.c: pci_walk_bus - probe.c: pci_create_bus - setup-res.c: pci_claim_resource Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02pci: do not mark exported functions as __devinitSam Ravnborg
Functions marked __devinit will be removed after kernel init. But being exported they are potentially called by a module much later. So the safer choice seems to be to keep the function even in the non CONFIG_HOTPLUG case. This silence the follwoing section mismatch warnings: WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_bus_add_device from __ksymtab_gpl between '__ksymtab_pci_bus_add_device' (at offset 0x20) and '__ksymtab_pci_walk_bus' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_create_bus from __ksymtab_gpl between '__ksymtab_pci_create_bus' (at offset 0x40) and '__ksymtab_pci_stop_bus_device' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_bus_max_busnr from __ksymtab_gpl between '__ksymtab_pci_bus_max_busnr' (at offset 0xc0) and '__ksymtab_pci_assign_resource_fixed' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_claim_resource from __ksymtab_gpl between '__ksymtab_pci_claim_resource' (at offset 0xe0) and '__ksymtab_pcie_port_bus_type' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_bus_add_devices from __ksymtab between '__ksymtab_pci_bus_add_devices' (at offset 0x70) and '__ksymtab_pci_bus_alloc_resource' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_scan_bus_parented from __ksymtab between '__ksymtab_pci_scan_bus_parented' (at offset 0x90) and '__ksymtab_pci_root_buses' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_bus_assign_resources from __ksymtab between '__ksymtab_pci_bus_assign_resources' (at offset 0x4d0) and '__ksymtab_pci_bus_size_bridges' WARNING: drivers/built-in.o - Section mismatch: reference to .init.text:pci_bus_size_bridges from __ksymtab between '__ksymtab_pci_bus_size_bridges' (at offset 0x4e0) and '__ksymtab_pci_setup_cardbus' Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: fix __must_check warningsGreg Kroah-Hartman
2006-06-27[PATCH] 64bit resource: change pci core and arch code to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] PCI: fix race with pci_walk_bus and pci_destroy_devZhang Yanmin
pci_walk_bus has a race with pci_destroy_dev. When cb is called in pci_walk_bus, pci_destroy_dev might unlink the dev pointed by next. Later on in the next loop, pointer next becomes NULL and cause kernel panic. Below patch against 2.6.17-rc4 fixes it by changing pci_bus_lock (spin_lock) to pci_bus_sem (rw_semaphore). Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI: Add pci_walk_bus function to PCI core (nonrecursive)Paul Mackerras
The PCI error recovery infrastructure needs to be able to contact all the drivers affected by a PCI error event, which may mean traversing all the devices under a given PCI-PCI bridge. This patch adds a function to the PCI core that traverses all the PCI devices on a PCI bus and under any PCI-PCI bridges on that bus (and so on), calling a given function for each device. This provides a way for the error recovery code to iterate through all devices that are affected by an error event. This version is not implemented as a recursive function. Instead, when we reach a PCI-PCI bridge, we set the pointers to start doing the devices on the bus under the bridge, and when we reach the end of a bus's devices, we use the bus->self pointer to go back up to the next higher bus and continue doing its devices. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI: start paying attention to a lot of pci function return valuesGreg Kroah-Hartman
2005-08-02pci: make bus resource start address override minimum IO addressLinus Torvalds
The reason we have PCIBIOS_MIN_IO and PCIBIOS_MIN_CARDBUS_IO is because we want to protect badly documented motherboard PCI resources and thus don't want to allocate new resources in low IO/MEM space. However, if we have already discovered a PCI bridge with a specified resource base, that should override that decision. This change will allow us to move the "careful" region upwards without resulting in problems allocating resources in low mappings. This was brought on by us having allocated a bus resource at 0x1000, conflicting with a undocumented VAIO Sony PI resources.
2005-06-27[PATCH] acpi bridge hotadd: Link newly created pci child bus to its parent ↵Rajesh Shah
on creation When a pci child bus is created, add it to the parent's children list immediately rather than waiting till pci_bus_add_devices(). For hot-plug bridges/devices, pci_bus_add_devices() may be called much later, after they have been properly configured. In the meantime, this allows us to use the normal pci bus search functions for the hot-plug bridges/buses. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
