path: root/drivers/parisc
2007-04-25[NET]: Inline net_device_statsRusty Russell
Network drivers which keep stats allocate their own stats structure then write a get_stats() function to return them. It would be nice if this were done by default. 1) Add a new "stats" field to "struct net_device". 2) Add a new feature field to say "this driver uses the internal one" 3) Have a default "get_stats" which returns NULL if that feature not set. 4) Change callers to check result of get_stats call for NULL, not if ->get_stats is set. This should not break backwards compatibility with older drivers, yet allow modern drivers to shed some boilerplate code. Lightly tested: works for a modified lguest network driver. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits) [PARISC] Use symbolic last syscall in __NR_Linux_syscalls [PARISC] Add missing statfs64 and fstatfs64 syscalls Revert "[PARISC] Optimize TLB flush on SMP systems" [PARISC] Compat signal fixes for 64-bit parisc [PARISC] Reorder syscalls to match unistd.h Revert "[PATCH] make kernel/signal.c:kill_proc_info() static" [PARISC] fix sys_rt_sigqueueinfo [PARISC] fix section mismatch warnings in harmony sound driver [PARISC] do not export get_register/set_register [PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code [PARISC] convert to use CONFIG_64BIT instead of __LP64__ [PARISC] use CONFIG_64BIT instead of __LP64__ [PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro [PARISC] more ENTRY(), ENDPROC(), END() conversions [PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc [PARISC] Fixes /proc/cpuinfo cache output on B160L [PARISC] implement standard ENTRY(), END() and ENDPROC() [PARISC] kill ENTRY_SYS_CPUS [PARISC] clean up debugging printks in smp.c [PARISC] factor syscall_restart code out of do_signal ... Fix conflict in include/linux/sched.h due to kill_proc_info() being made publicly available to PARISC again.
2007-02-17[PARISC] Convert soft power switch driver to kthreadHelge Deller
And remove it's reference in time.c. Allow lcd_print() to take a const char *. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] lba_pci format warningsMatthew Wilcox
Fix resource_size_t warnings in a variety of ways Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17Merge branch 'parisc' from /home/kyle/repos/parisc-2.6.gitKyle McMartin
Conflicts: arch/parisc/hpux/sys_hpux.c arch/parisc/mm/ioremap.c
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[PATCH] parisc: fix module_param iommu permissionRandy Dunlap
Fix/change module_param permissions parameter from an init value to a permission value. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] WorkStruct: Fix up some PA-RISC work itemsDavid Howells
Fix up some PA-RISC work items broken by the workstruct reduction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-12-08[PARISC] Fix PCI bus numbering in the presence of Cardbus bridgesMatthew Wilcox
Firmware ignores Cardbus bridges, so when Linux assigns bus numbers, it must override firmware's notion of what the busses are numbered. This is not sufficient to support the Cardbus bridge as there is also no interrupt routing table entry for them. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-12-08[PARISC] sparse fixesMatthew Wilcox
0/NULL, missing __user, missing __iomem, non-ANSI prototype. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-12-08[PARISC] HPPB bus updates for E-Class systemsRyan Bradetich
This patch addresses the following issues: * Removes an incorrect comment. * Fixes a couple of compiler warnings. * Properly detects the HP-PB bus on E-Class systems. Signed-off-by: Ryan Bradetich <rbrad@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-06Build fixes for struct pt_regs removalMatthew Wilcox
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-05[PA-RISC] Fix sba_iommu compilationMatthew Wilcox
klist_iter_exit() only takes one parameter. Also fix warning by adding additional brackets. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-04[PARISC] Add support for Quicksilver AGPGARTKyle McMartin
2006-10-04[PARISC] Move LBA and SBA register defines to the common ropes.hKyle McMartin
header. This will allow the use of more constants in the agpgart driver. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Create shared <asm/ropes.h> headerKyle McMartin
Pull out struct sba_device and struct lba_device into a common ropes.h header. Also fold the parisc portion of iosapic.h into this file. (Then delete the useless portion of iosapic.h) Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Stash the lba_device in its struct device drvdataKyle McMartin
2006-10-04[PARISC] Generalize IS_ASTRO et al to take a parisc_device likeKyle McMartin
IS_ELROY. Also remove the useless caching of the parisc_device_id in struct sba_device. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Pretty print the name of the lba type on kernel bootKyle McMartin
(it's pretty useless telling a user they have a whole bunch of TR%d.%d LBAs) Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Remove some obsolete comments and I checked that Reo is similar to IkeMatthew Wilcox
2006-10-04[PARISC] Allow nested interruptsJames Bottomley
Our prior mode of operation didn't allow nested interrupts because it makes the interrupt code much simpler. However, nested interrupts are better for latency. This code uses the EIEM register to simulate level interrupts and thus achieve nesting. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Add asm-parisc/mckinley.h bus headerKyle McMartin
Add header for McKinley bus related code. Remove extern decl of proc_mckinley_root in drivers/parisc/sba_iommu.c Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[PATCH] replace cad_pid by a struct pidCedric Le Goater
There are a few places in the kernel where the init task is signaled. The ctrl+alt+del sequence is one them. It kills a task, usually init, using a cached pid (cad_pid). This patch replaces the pid_t by a struct pid to avoid pid wrap around problem. The struct pid is initialized at boot time in init() and can be modified through systctl with /proc/sys/kernel/cad_pid [ I haven't found any distro using it ? ] It also introduces a small helper routine kill_cad_pid() which is used where it seemed ok to use cad_pid instead of pid 1. [akpm@osdl.org: cleanups, build fix] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: PARISC: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30[PATCH] Light weight event countersChristoph Lameter
The remaining counters in page_state after the zoned VM counter patches have been applied are all just for show in /proc/vmstat. They have no essential function for the VM. We use a simple increment of per cpu variables. In order to avoid the most severe races we disable preempt. Preempt does not prevent the race between an increment and an interrupt handler incrementing the same statistics counter. However, that race is exceedingly rare, we may only loose one increment or so and there is no requirement (at least not in kernel) that the vm event counters have to be accurate. In the non preempt case this results in a simple increment for each counter. For many architectures this will be reduced by the compiler to a single instruction. This single instruction is atomic for i386 and x86_64. And therefore even the rare race condition in an interrupt is avoided for both architectures in most cases. The patchset also adds an off switch for embedded systems that allows a building of linux kernels without these counters. The implementation of these counters is through inline code that hopefully results in only a single instruction increment instruction being emitted (i386, x86_64) or in the increment being hidden though instruction concurrency (EPIC architectures such as ia64 can get that done). Benefits: - VM event counter operations usually reduce to a single inline instruction on i386 and x86_64. - No interrupt disable, only preempt disable for the preempt case. Preempt disable can also be avoided by moving the counter into a spinlock. - Handling is similar to zoned VM counters. - Simple and easily extendable. - Can be omitted to reduce memory use for embedded use. References: RFC http://marc.theaimsgroup.com/?l=linux-kernel&m=113512330605497&w=2 RFC http://marc.theaimsgroup.com/?l=linux-kernel&m=114988082814934&w=2 local_t http://marc.theaimsgroup.com/?l=linux-kernel&m=114991748606690&w=2 V2 http://marc.theaimsgroup.com/?t=115014808400007&r=1&w=2 V3 http://marc.theaimsgroup.com/?l=linux-kernel&m=115024767022346&w=2 V4 http://marc.theaimsgroup.com/?l=linux-kernel&m=115047968808926&w=2 Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (23 commits) [PARISC] Move os_id_to_string() inside #ifndef __ASSEMBLY__ [PARISC] Fix do_gettimeofday() hang [PARISC] Fix PCREL22F relocation problem for most modules [PARISC] Refactor show_regs in traps.c [PARISC] Add os_id_to_string helper [PARISC] OS_ID_LINUX == 0x0006 [PARISC] Ensure Space ID hashing is turned off [PARISC] Match show_cache_info with reality [PARISC] Remove unused macro fixup_branch in syscall.S [PARISC] Add is_compat_task() helper [PARISC] Update Thibaut Varene's CREDITS entry [PARISC] Reduce data footprint in pdc_stable.c [PARISC] pdc_stable version 0.30 [PARISC] Work around machines which do not support chassis warnings [PARISC] PDC_CHASSIS is implemented on all machines [PARISC] Remove unconditional #define PIC in syscall macros [PARISC] Use MFIA in current_text_addr on pa2.0 processors [PARISC] Remove dead function pc_in_user_space [PARISC] Test ioc_needs_fdc variable instead of open coding [PARISC] Fix gcc 4.1 warnings in sba_iommu.c ...
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PARISC] Add os_id_to_string helperKyle McMartin
Add a helper to asm/pdc.h to translate OS_ID values to strings and use it in the pdc_stable driver. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] OS_ID_LINUX == 0x0006Kyle McMartin
We were assigned an OS_ID of 0x0006. Consistently use OS_ID_LINUX instead of using the magic number. Also update the OS_ID_ defines in asm/pdc.h to reflect this. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] Reduce data footprint in pdc_stable.cThibaut Varene
No code change - reduce data footprint. Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] pdc_stable version 0.30Thibaut Varene
pdc_stable v0.30: This patch introduces 3 more files to the /sys/firmware/stable tree: - diagnostic, which contains a cryptic hex string - osdep1, a 16 bytes os-dependent storage area always available - osdep2, another os-dependent storage area which existence/size depends on hversion. This patch also adds code to setup the "Linux" signature in stable storage. That is to say that starting with this patch, the kernel will now sign its OSID (0x0006, thx LaMont) in Stable Storage upon boot, whether pdc_stable is enabled or not. Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] PDC_CHASSIS is implemented on all machinesThibaut Varene
This patch removes a limitation of the original code, so that CHASSIS codes can be sent to all machines. On machines with a LCD panel, this code displays "INI" during bootup, "RUN" when the system is booted and running, "FLT" when a panic occurs, etc. This part of the code can be enabled/disabled through CONFIG_PDC_CHASSIS This patch also adds minimalistic support for Chassis warnings, through a proc entry '/proc/chassis', which will reflect the warnings status (PSU or fans failure when they happen, NVRAM battery level and temperature thresholds overflows). This part of the code can be enabled/disabled through CONFIG_PDC_CHASSIS_WARN Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] Test ioc_needs_fdc variable instead of open codingKyle McMartin
Some debugging code in sba_iommu.c should be testing ioc_needs_fdc, not directly testing boot_cpu_data. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] Fix gcc 4.1 warnings in sba_iommu.cGrant Grundler
Clean up gcc 4.1 warnings noted by Joel Soete. Kyle McMartin gets kudos for pointing out the issues. Matthew Wilcox noticed sba_iommu was using open coded versions of (read|write)X. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-21[PARISC] Document that we tolerate "Relaxed Ordering"Grant Grundler
This means "DMA Read returns" can bypass "MMIO Writes". Violating the PCI specs in this case improves outbound DMA "flows" and is currently not required by any drivers. This is NOT a new behavior. Previous chipsets did this already and I believe ZX1 PDC was already setting this for hpux. I just want to further document the behavior. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-21[PARISC] Misc. janitorial workHelge Deller
Fix a spelling mistake, add a KERN_INFO flag, and fix some whitespace uglies. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Clarify pdc_stable license termsThibaut VARENE
pdc_stable.c is explicitly licensed under GPL version 2. Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24BUG_ON() Conversion in drivers/parisc/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-08[PARISC] Convert sba_iommu.c to use seq_fileKyle McMartin
Use seq_file interface for proc output in sba_iommu. Also clean up the bus root assignment, and give the proc files a more logical name. Tested on my J6000. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
