This is unit testing code. It should use that name because it makes more
sense than 'selftest'. Rename the files to match and rename the config
variable.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
The of_platform_populate() test cases don't remove the test devices
after they are added. Fix this by adding tests for
of_platform_depopulate().
At the same time rework the selftest() macro to return the test result
value. This makes it easy to use the macro inside an if() condition.
The device tree structure is composed of two lists; the 'allnodes' list
which is a singly linked list containing every node in the tree, and the
child->parent structure where each parent node has a singly linked list
of children. All of the data in the allnodes list can be easily
reproduced with the parent-child lists, so of_allnodes is actually
unnecessary. Remove it entirely which saves a bit of memory and
simplifies the data structure quite a lot.
Cc: Rob Herring <robh@kernel.org>
Cc: Gaurav Minocha <gaurav.minocha.os@gmail.com>
Cc: Pantelis Antoniou <pantelis@pantelis.antoniou@konsulko.com>
The string property read helpers will run off the end of the buffer if
it is handed a malformed string property. Rework the parsers to make
sure that doesn't happen. At the same time add new test cases to make
sure the functions behave themselves.
The original implementations of of_property_read_string_index() and
of_property_count_strings() both open-coded the same block of parsing
code, each with it's own subtly different bugs. The fix here merges
functions into a single helper and makes the original functions static
inline wrappers around the helper.
One non-bugfix aspect of this patch is the addition of a new wrapper,
of_property_read_string_array(). The new wrapper is needed by the
device_properties feature that Rafael is working on and planning to
merge for v3.19. The implementation is identical both with and without
the new static inline wrapper, so it just got left in to reduce the
churn on the header file.
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Darren Hart <darren.hart@intel.com>
Cc: <stable@vger.kernel.org> # v3.3+: Drop selftest hunks that don't apply
The new testcase that checks phandle consistency was using a hash table
on the stack which made the frame size much large than it should be. Fix
the problem by moving the hash table into the file scope.
The selftest data ends up causing duplicate phandles in the live tree
for the time that the testcase data is inserted into the live tree. This
is obviously a bad situation because anything attempting to read the
tree while the selftests are running make resolve phandles to one of the
testcase data nodes. Fix the problem by using the of_resolve_phandles()
function to eliminate duplicates.
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
All phandles in the tree should be unique. Add a testcase to make sure
that this is so.
Note: this testcase fails on the current kernel because the selftest
code itself ends up adding duplicate phandles. Before this testcase is
merged the selftest code needs to be modified to resolve phandles before
adding them.
Add a testcase to verify that the device tree is properly constructed
and the lists are in a correct order. The new testcase gets run twice;
once after adding the testcase data, and once after removing it again.
It is run twice to make sure adding and removing the testcase data
doesn't corrupt the data structure.
The selftest code removes its testcase data from the live tree when
exiting, but if the testcases data tree contains an empty child of the
root, then it causes an oops due to a NULL dereference. The reason is
that the code tries to directly dereference the child pointer without
checking first if a child is actually there.
The solution is to pass the parent node into detach_node_and_children()
instead of trying to pass the child. This required removing the code
that attempts to remove all of the sibling nodes in
detach_node_and_children(), which was never sensible in the first place.
At the same time add a check to make sure the bounds of the nodes list
are not exceeded by the testdata tree. If they are then abort.
If there is no devicetree present, this patch adds the selftest
data as a live devicetree. It also removes the same after the
testcase execution is complete.
Tested with and without machine's devicetree.
Signed-off-by: Gaurav Minocha <gaurav.minocha.os@gmail.com>
drivers/of/testcase-data/testcases.dts
This patch attaches selftest's device tree data (required by /drivers/of/selftest.c)
dynamically into live device tree. First, it links selftest device tree data into the
kernel image and then iterates over all the nodes and attaches them into the live tree.
Once the testcases are complete, it removes the data attached.
This patch will remove the manual process of addition and removal of selftest device
tree data into the machine's dts file.
Tested successfully with current selftest's testcases.
[glikely: Removed ability to build as a module and fixed no-devicetree bug]
Introducing DT transactional support.
A DT transaction is a method which allows one to apply changes
in the live tree, in such a way that either the full set of changes
take effect, or the state of the tree can be rolled-back to the
state it was before it was attempted. An applied transaction
can be rolled-back at any time.
Documentation is in
Documentation/devicetree/changesets.txt
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
[glikely: Removed device notifiers and reworked to be more consistent]
Introduce helper functions for working with the live DT tree,
all of them related to dynamically adding/removing nodes and
properties.
__of_prop_dup() copies a property dynamically
__of_node_alloc() creates an empty node
Bug fix about prop->len == 0 by Ionut Nicu <ioan.nicu.ext@nsn.com>
[glikely: Added unittest for of_copy_property and dropped fine-grained allocations]
[glikely: removed name, type and phandle arguments from __of_node_alloc]
Add a testcase for the find_node_by_path() function to make sure it
handles all the valid scenarios.
Add a test case for nodes which have the same name and same
non-translatable unit address.
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Reviewed-by: Frank Rowand <frank.rowand@sonymobile.com>
Move the pass/fail checks into selftest() calls instead of a separate if
condition. Unconditionally calling pass was wrong.
Cc: Grant Likely <grant.likely@linaro.org>
[grant.likely: fixed failure when root node specifies the interrupt parent]
Adds a few simple test cases to ensure that addition, update and removal
of device tree node properties works correctly.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Adds a selftest function for the of_match_node function. of_match_node
is supposed to handle precedence for the compatible property as well as
the name and device_type values. This patch adds some test case data and
a function that makes sure each test node matches against the correct
entry of an of_device_id table.
This code was written to verify the new of_match_node() implementation
that is an earlier part of this series.
Cc: Kevin Hao <haokexin@gmail.com>
The standard interrupts property in device tree can only handle
interrupts coming from a single interrupt parent. If a device is wired
to multiple interrupt controllers, then it needs to be attached to a
node with an interrupt-map property to demux the interrupt specifiers
which is confusing. It would be a lot easier if there was a form of the
interrupts property that allows for a separate interrupt phandle for
each interrupt specifier.
This patch does exactly that by creating a new interrupts-extended
property which reuses the phandle+arguments pattern used by GPIOs and
other core bindings.
Acked-by: Kumar Gala <galak@codeaurora.org>
[grant.likely: removed versatile platform hunks into separate patch]
This patch extends the DT selftest code with some test cases for the
interrupt parsing functions.
This patch creates of_count_phandle_with_args(), a new function for
counting the number of phandle+argument tuples in a given property. This
is better than the existing method of parsing each phandle individually
until parsing fails which is a horribly slow way to do the count.
Tested on ARM using the selftest code.
v3: - Rebased on top of selftest code cleanup patch
v2: - fix bug where of_parse_phandle_with_args() could behave like _count_.
- made of_gpio_named_count() into a static inline regardless of CONFIG_OF_GPIO
Tested-by: Andreas Larsson <andreas@gaisler.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Some of the selftests are open-coded. Others use the selftest() macro
defined in drivers/of/selftest.c. The macro makes for cleaner selftest
code, so refactor the of_parse_phandle_with_args() tests to use it.
The of_gpio_named_count() self test doesn't hit the out-of-range
condition even though it is coded. Fix the bug by increasing the for
loop range by one.
Reported-by: Andreas Larsson <andreas@gaisler.com>
Add a helper function for finding the index of a string in a string
list property. This helper is useful for bindings that use a separate
*-name property for attaching names to tuples in another property such
as 'reg' or 'gpios'.
Add some runtime test cases for the library of device tree parsing functions.
v2: - Add testcase for phandle with 0 args
- Don't run testcases if testcase data isn't present in device tree
