path: root/drivers/nfc
2012-04-12NFC: pn533 Rx chaining supportSamuel Ortiz
When buffers on the receiption path exceed 262 bytes, the pn533 uses a chaining mechanism where the initiator has to send NULL data frames to fetch the remaining frames. We do that from a workqueue context while holding the cmd lock. Once the MI bit is gone, we aggregate the queued received skbs. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-12NFC: Convert pn533 from tasklet to workqueuesSamuel Ortiz
There is no need for soft IRQ contexts, and workqueues are more flexible. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06NFC: Remove the rf mode parameter from the DEP link up routineSamuel Ortiz
When calling nfc_dep_link_up, we implicitely are in initiator mode. Which means we also can provide the general bytes as a function argument, as all drivers will eventually request them. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06NFC: Export NFCID when detecting a p2p target with pn533Samuel Ortiz
2012-03-06NFC: Export Jewel/Topaz ID from pn533Samuel Ortiz
The jewel ID is the NFCID1 for Topaz NFC tags. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06NFC: Export sensf from pn533Samuel Ortiz
sensf is the detection response for Felica NFC tags. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06NFC: Clear pn533 target structureSamuel Ortiz
The polled target structure should be memset to 0 in order to avoid sel_res and sens_res garbage. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06NFC: Export NFCID1 from pn533Samuel Ortiz
2012-01-24NFC: Free sk_buff if nfcwilink_send failsIlan Elias
Free sk_buff if nfcwilink_send fails. Signed-off-by: Ilan Elias <ilane@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24NFC: Download TI NFC init scriptIlan Elias
Download TI NFC init script during nfcwilink open operation, after the NFC channel is registered with TI shared transport. TI NFC init script is written in BTS format. First, read the chip version via a special vendor specific command. Second, we request the relevant BTS file from the user space, and then send the BTS commands to the chip. Signed-off-by: Ilan Elias <ilane@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24NFC: Add endian annotations to nfcwilink driverIlan Elias
Add endian annotations to TI nfcwilink driver. Signed-off-by: Ilan Elias <ilane@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2011-12-14NFC: DEP link hook implementation for pn533Samuel Ortiz
2011-12-14NFC: Set and get DEP general bytesSamuel Ortiz
Without an API for setting and getting the local and remote general bytes, drivers won't be able to properly establish a DEP link. This API also allows them to propagate the remote general bytes they get from the DEP link establishment up to the LLCP layer. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-14NFC: Add tx skb allocation routineSamuel Ortiz
This is a factorization of the current rawsock tx skb allocation routine, as it will be used by the LLCP code. We also rename nfc_alloc_skb to nfc_alloc_recv_skb for consistency sake. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-30NFC: pn533: Staticise pn533_data_exchange()Axel Lin
It is not used outside this driver so no need to make the symbol global. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-18USB: convert some miscellanies drivers to use module_usb_driver()Greg Kroah-Hartman
This converts the remaining USB drivers in the kernel to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Till Harbaum <till@harbaum.org> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-31drivers/nfc: add module.h to nfcwilink.cPaul Gortmaker
This is a full module, with module_init() and module_exit() and so it needs module.h called out for inclusion. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-21nfc: NFC_WILINK depends on NFC_NCIRandy Dunlap
nwcwilink.c uses nci_*() interfaces, so it should depend on NFC_NCI. Fixes these build errors: ERROR: "nci_register_device" [drivers/nfc/nfcwilink.ko] undefined! ERROR: "nci_allocate_device" [drivers/nfc/nfcwilink.ko] undefined! ERROR: "nci_recv_frame" [drivers/nfc/nfcwilink.ko] undefined! ERROR: "nci_free_device" [drivers/nfc/nfcwilink.ko] undefined! ERROR: "nci_unregister_device" [drivers/nfc/nfcwilink.ko] undefined! Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-20NFC: driver for TI shared transportIlan Elias
Signed-off-by: Ilan Elias <ilane@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-20NFC: move nfc.h from include/net to include/net/nfcIlan Elias
The file nfc.h was moved from include/net to include/net/nfc, since new NFC header files will be added to include/net/nfc. Signed-off-by: Ilan Elias <ilane@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-20NFC: Add dev_up and dev_down control operationsIlan Elias
Add 2 new nfc control operations: dev_up to turn on the nfc device dev_down to turn off the nfc device Signed-off-by: Ilan Elias <ilane@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24NFC: Reserve tx head and tail roomSamuel Ortiz
We can have the NFC core layer allocating the tx head and tail room for the drivers and avoid 1 or more SKBs copy on write on the Tx path. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-26NFC: pn533: use after free in pn533_disconnect()Dan Carpenter
We freed "dev" on the line before. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05NFC: pn533: add NXP pn533 nfc device driverAloisio Almeida Jr
Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05NFC: add nfc subsystem coreLauro Ramos Venancio
The NFC subsystem core is responsible for providing the device driver interface. It is also responsible for providing an interface to the control operations and data exchange. Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-25drivers/nfc/pn544.c: add missing regulatorMatti J. Aaltonen
The regulator framework is used for power management. The regulators are only named in the driver code, the actual control stuff is in the board file for each architecture or use case. The PN544 chip has three regulators that can be controlled or not - depending on the architecture where the chip is being used. So some of the regulators may not be controllable. In our current case the third regulator, which was missing from the code, went unnoticed because we didn't need to control it. To be as general as possible - in this respect - the driver needs to list all regulators. Then the board file can be used to actually set the usage. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25drivers/nfc/Kconfig: use full form of the NFC acronymMatti J. Aaltonen
Spell out the NFC acronym when it's shown for the first time. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16drivers/nfc/pn544.c: fix min_t warningsAndrew Morton
Fix these: drivers/nfc/pn544.c: In function 'pn544_read': drivers/nfc/pn544.c:356: warning: comparison of distinct pointer types lacks a cast drivers/nfc/pn544.c:377: warning: comparison of distinct pointer types lacks a cast drivers/nfc/pn544.c: In function 'pn544_write': drivers/nfc/pn544.c:463: warning: comparison of distinct pointer types lacks a cast drivers/nfc/pn544.c:485: warning: comparison of distinct pointer types lacks a cast Cc: "Matti J. Aaltonen" <matti.j.aaltonen@nokia.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13NFC: Driver for NXP Semiconductors PN544 NFC chip.Matti J. Aaltonen
Creates a new "Near Field Communication" subsystem in drivers/nfc. http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;) This is a driver for the pn544 NFC device. The driver transfers ETSI messages between the device and the user space. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
