path: root/drivers/nfc/st-nci
2016-05-04nfc: st-nci: Move loopback usage from HCI to NCIChristophe Ricard
NCI provides possible way to run loopback testing has done over HCI. For us it offers many advantages: - It simplifies the code: No more need for a vendor_cmds structure - Loopback over HCI may not be supported in future st-nci firmware Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: nci: Add an additional parameter to identify a connection idChristophe Ricard
According to NCI specification, destination type and destination specific parameters shall uniquely identify a single destination for the Logical Connection. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: st-nci: Remove redundant ST_NCI_HCI_HOST_ID_ESE from st-nci.hChristophe Ricard
ST_NCI_HCI_HOST_ID_ESE is already having an equivalent in se.c (ST_NCI_ESE_HOST_ID). Remove and replace where relevant. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04NFC: st-nci: spi: Drop two useless checks in ACPI probe pathChristophe Ricard
When st_nci_spi_acpi_request_resources() gets called we already know that the entries in ->acpi_match_table have matched ACPI ID of the device. In addition spi_device pointer cannot be NULL in any case (otherwise SPI core would not call ->probe() for the driver in the first place). Drop the two useless checks from the driver. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04NFC: st-nci: i2c: Drop two useless checks in ACPI probe pathChristophe Ricard
When st_nci_i2c_acpi_request_resources() gets called we already know that the entries in ->acpi_match_table have matched ACPI ID of the device. In addition I2C client pointer cannot be NULL in any case (otherwise I2C core would not call ->probe() for the driver in the first place). Drop the two useless checks from the driver. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: st-nci: A APDU_READER_GATE pipe is unexpected on a UICCChristophe Ricard
An APDU_READER_GATE pipe is not expected on a UICC. Be more explicit so that an other secure element form factor (SD card) does not prompt this message. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: st-nci: Simplify white list buildingChristophe Ricard
Simplify white list Building Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: st-nci: set is_ese_present and is_uicc_present properlyChristophe Ricard
When they're present, set is_ese_present and set is_uicc_present to the value describe in their package description. So far is_ese_present and is_uicc_present was set to true if their property was present. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: st-nci: spi: Change ST_NCI_GPIO_NAME_RESET to match DTChristophe Ricard
Since commit 10cf4899f8af ("gpiolib: tighten up ACPI legacy gpio lookups") If _DSD properties are available in an ACPI node, we are not allowed to fallback to _CRS data to retrieve gpio properties. This was causing us to fail if uicc-present and/or ese-present are defined. To be consistent with devicetree change ST_NCI_GPIO_NAME_RESET content to reset so that acpi_find_gpio in drivers/gpio/gpiolib.c will look for reset-gpios. In the mean time the ACPI table needs to be fixed as follow (Tested on Minnowboard Max): Device (NFC1) { Name (_ADR, Zero) // _ADR: Address Name (_HID, "SMO2101") // _HID: Hardware ID Name (_CID, "SMO2101") // _CID: Compatible ID Name (_DDN, "SMO NFC") // _DDN: DOS Device Name Name (_UID, One) // _UID: Unique ID Method (_CRS, 0, NotSerialized) // _CRS: Current Resource Settings { Name (SBUF, ResourceTemplate () { SpiSerialBus (0, PolarityLow, FourWireMode, 8, ControllerInitiated, 4000000, ClockPolarityLow, ClockPhaseFirst, "\\_SB.SPI1", 0x00, ResourceConsumer, ,) GpioInt (Edge, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0001 } GpioIo (Exclusive, PullDefault, 0x0000, 0x0000, IoRestrictionOutputOnly, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0002, } }) Name (_DSD, Package (0x02) { ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301") /* Device Properties for _DSD */, Package (0x03) { Package (0x02) { "uicc-present", 1 }, Package (0x02) { "ese-present", 1 }, Package (0x02) { "reset-gpios", Package(0x04) { ^NFC1, 1, 0, 0} }, } }) Return (SBUF) /* \_SB_.SPI1.NFC1._CRS.SBUF */ } Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x0F) } } Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-04nfc: st-nci: i2c: Change ST_NCI_GPIO_NAME_RESET to match DTChristophe Ricard
Since commit 10cf4899f8af ("gpiolib: tighten up ACPI legacy gpio lookups") If _DSD properties are available in an ACPI node, we are not allowed to fallback to _CRS data to retrieve gpio properties. This was causing us to fail if uicc-present and/or ese-present are defined. To be consistent with devicetree change ST_NCI_GPIO_NAME_RESET content to reset so that acpi_find_gpio in drivers/gpio/gpiolib.c will look for reset-gpios. In the mean time the ACPI table needs to be fixed as follow: Device (NFC1) { Name (_ADR, Zero) // _ADR: Address Name (_HID, "SMO2101") // _HID: Hardware ID Name (_CID, "SMO2101") // _CID: Compatible ID Name (_DDN, "SMO NFC") // _DDN: DOS Device Name Name (_UID, One) // _UID: Unique ID Method (_CRS, 0, NotSerialized) // _CRS: Current Resource Settings { Name (SBUF, ResourceTemplate () { I2cSerialBus (0x0008, ControllerInitiated, 400000, AddressingMode7Bit, "\\_SB.I2C7", 0x00, ResourceConsumer, ,) GpioInt (Edge, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0001 } GpioIo (Exclusive, PullDefault, 0x0000, 0x0000, IoRestrictionOutputOnly, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0002, } }) Name (_DSD, Package (0x02) { ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301") /* Device Properties for _DSD */, Package (0x03) { Package (0x02) { "uicc-present", 1 }, Package (0x02) { "ese-present", 1 }, Package (0x02) { "reset-gpios", Package(0x04) { ^NFC1, 1, 0, 0} }, } }) Return (SBUF) /* \_SB_.I2C7.NFC1._CRS.SBUF */ } Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x0F) } } Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2016-05-01nfc: Drop owner assignment from i2c_driverKrzysztof Kozlowski
i2c_driver does not need to set an owner because i2c_register_driver() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Add support for HCI event connectivityChristophe Ricard
Add support for connectivity event Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29NFC: st-nci: Auto-select core moduleChristophe Ricard
The core st-nci module is useless without either the I2C or the SPI access module. So hide NFC_ST_NCI and select it automatically if either NFC_ST_NCI_I2C or NFC_ST_NCI_SPI is selected. This avoids presenting NFC_ST_NCI when neither NFC_ST_NCI_I2C nor NFC_ST_NCI_SPI can be selected. Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Code cleanupChristophe Ricard
A few code cleanups, mostly empty lines removal. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Add support for acpi probing for spi device.Christophe Ricard
Add support for acpi probing. SMO2101 is used for st21nfcb It has been tested with the following acpi node on Minnowboard: Note: Remove uicc-present or ese-present Package if one of them is not supported. Device (NFC1) { Name (_ADR, Zero) // _ADR: Address Name (_HID, "SMO2101") // _HID: Hardware ID Name (_CID, "SMO2101") // _CID: Compatible ID Name (_DDN, "SMO NFC") // _DDN: DOS Device Name Name (_UID, One) // _UID: Unique ID Name (_DSD, Package (0x02) { /* Device Properties for _DSD */ ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), Package (0x02) { Package (0x02) { "uicc-present", 1 }, Package (0x02) { "ese-present", 1 } } }) Method (_CRS, 0, NotSerialized) // _CRS: Current Resource Settings { Name (SBUF, ResourceTemplate () { SpiSerialBus (0, PolarityLow, FourWireMode, 8, ControllerInitiated, 4000000, ClockPolarityLow, ClockPhaseFirst, "\\_SB.SPI1", 0x00, ResourceConsumer, ,) GpioInt (Edge, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0001 } GpioIo (Exclusive, PullDefault, 0x0000, 0x0000, IoRestrictionOutputOnly, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0002, } }) Return (SBUF) /* \_SB_.SPI1.NFC1._CRS.SBUF */ } Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x0F) } } Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Add support for acpi probing for i2c device.Christophe Ricard
Add support for acpi probing. SMO2101 is used for st21nfcb SMO2102 is used for st21nfcc It has been tested with the following acpi node on Minnowboard: Note: Remove uicc-present or ese-present Package if one them is not supported. Device (NFC1) { Name (_ADR, Zero) // _ADR: Address Name (_HID, "SMO2101") // _HID: Hardware ID Name (_CID, "SMO2101") // _CID: Compatible ID Name (_DDN, "SMO NFC") // _DDN: DOS Device Name Name (_UID, One) // _UID: Unique ID Name (_DSD, Package (0x02) { /* Device Properties for _DSD */ ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), Package (0x02) { Package (0x02) { "uicc-present", 1 }, Package (0x02) { "ese-present", 1 } } }) Method (_CRS, 0, NotSerialized) // _CRS: Current Resource Settings { Name (SBUF, ResourceTemplate () { I2cSerialBus (0x0008, ControllerInitiated, 400000, AddressingMode7Bit, "\\_SB.I2C7", 0x00, ResourceConsumer, ,) GpioInt (Edge, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0001 } GpioIo (Exclusive, PullDefault, 0x0000, 0x0000, IoRestrictionOutputOnly, "\\_SB.GPO2", 0x00, ResourceConsumer, ,) { // Pin list 0x0002, } }) Return (SBUF) /* \_SB_.I2C7.NFC1._CRS.SBUF */ } Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x0F) } } Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Add macro for gpio nameChristophe Ricard
Add macro definition for each gpio string for an easier code maintenance. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Group device table togetherChristophe Ricard
Group device table at the same place in order to make the code easier to read and parse. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Remove unneeded CONFIG_OF switchesChristophe Ricard
DT headers already define NOOP routines when CONFIG_OF is not defined. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-12-29nfc: st-nci: Remove useless #include "ndlc.h"Christophe Ricard
2015-11-05Merge tag 'spi-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "Quite a lot of activity in SPI this cycle, almost all of it in drivers with a few minor improvements and tweaks in the core. - Updates to pxa2xx to support Intel Broxton and multiple chip selects. - Support for big endian in the bcm63xx driver. - Multiple slave support for the mt8173 - New driver for the auxiliary SPI controller in bcm2835 SoCs. - Support for Layerscale SoCs in the Freescale DSPI driver" * tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits) spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI spi: pxa2xx: Add support for Intel Broxton spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals spi: pxa2xx: Add output control for multiple Intel LPSS chip selects spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific spi: Add DSPI support for layerscape family spi: ti-qspi: improve ->remove() callback spi/spi-xilinx: Fix race condition on last word read spi: Drop owner assignment from spi_drivers spi: Add THIS_MODULE to spi_driver in SPI core spi: Setup the master controller driver before setting the chipselect spi: dw: replace magic constant by DW_SPI_DR spi: mediatek: mt8173 spi multiple devices support spi: mediatek: handle controller_data in mtk_spi_setup spi: mediatek: remove mtk_spi_config spi: mediatek: Update document devicetree bindings to support multiple devices spi: fix kernel-doc warnings about missing return desc in spi.c spi: fix kernel-doc warnings about missing return desc in spi.h spi: pxa2xx: Align a few defines spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select ...
2015-10-28spi: Drop owner assignment from spi_driversAndrew F. Davis
An spi_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-27NFC: st-nci: Replace st21nfcb by st_nci in makefileChristophe Ricard
Replace 1 missing st21nfcb by st_nci Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: remove duplicated skb dumpChristophe Ricard
Remove SPI_DUMP_SKB and I2C_DUMP_SKB as skb is already dumped in ndlc layer. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Disable irq when powering the device upChristophe Ricard
Upon some conditions (timing, CLF errors, platform errors...), the irq might be already active when powering the device. Add irq_active variable as a guard to avoid kernel warning message Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Add few code style fixesChristophe Ricard
Add some few code style fixes. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Fix host_list verification after SE activationChristophe Ricard
A secure element can be activated in different order. The host_list is updated keeping a fixed order: <terminal_host_id><uicc_id><ese_id>. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Increase delay between 2 secure element activationsChristophe Ricard
After internal discussion, it appears this timing should be increased to 20 ms for interoperability reason. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Add ese-present/uicc-present dts propertiesChristophe Ricard
In order to align with st21nfca, dts configuration properties ese_present and uicc_present are made available in st-nci driver. So far, in early development firmware, because nci_nfcee_mode_set(DISABLE) was not supported we had to try to enable it during the secure element discovery phase. After several trials on commercial and qualified firmware it appears that nci_nfcee_mode_set(ENABLE) and nci_nfcee_mode_set(DISABLE) are properly supported. Such feature also help us to eventually save some time (~5ms) when only one secure element is connected. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Add error messages when an unexpected HCI event occursChristophe Ricard
Potentially an unexpected HCI event may occur because of a firmware bug. It could be transparent for the user but we need to at least log it. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: st-nci: Add support for proprietary commandsChristophe Ricard
Add support for proprietary commands useful mainly for factory testings. Here is a list: - FACTORY_MODE: Allow to set the driver into a mode where no secure element are activated. It does not consider any NFC_ATTR_VENDOR_DATA. - HCI_CLEAR_ALL_PIPES: Allow to execute a HCI clear all pipes command. It does not consider any NFC_ATTR_VENDOR_DATA. - HCI_DM_PUT_DATA: Allow to configure specific CLF registry like for example RF trimmings or low level drivers configurations (I2C, SPI, SWP). - HCI_DM_UPDATE_AID: Allow to configure an AID routing into the CLF routing table following RF technology, CLF mode or protocol. - HCI_DM_GET_INFO: Allow to retrieve CLF information. - HCI_DM_GET_DATA: Allow to retrieve CLF configurable data such as low level drivers configurations or RF trimmings. - HCI_DM_DIRECT_LOAD: Allow to load a firmware into the CLF. A complete packet can be more than 8KB. - HCI_DM_RESET: Allow to run a CLF reset in order to "commit" CLF configuration changes without CLF power off. - HCI_GET_PARAM: Allow to retrieve an HCI CLF parameter (for example the white list). - HCI_DM_FIELD_GENERATOR: Allow to generate different kind of RF technology. When using this command to anti-collision is done. - HCI_LOOPBACK: Allow to echo a command and test the Dh to CLF connectivity. - HCI_DM_VDC_MEASUREMENT_VALUE: Allow to measure the field applied on the CLF antenna. A value between 0 and 0x0f is returned. 0 is maximum. - HCI_DM_FWUPD_START: Allow to put CLF into firmware update mode. It is a specific CLF command as there is no GPIO for this. - HCI_DM_FWUPD_END: Allow to complete firmware update. - HCI_DM_VDC_VALUE_COMPARISON: Allow to compare the field applied on the CLF antenna to a reference value. - MANUFACTURER_SPECIFIC: Allow to retrieve manufacturer specific data received during a NCI_CORE_INIT_CMD. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Fix st_nci_gates offsetChristophe Ricard
It is useless to start from index 0 when looking for a gate because only dynamic pipes are retrieved with ST_NCI_DM_GETINFO(ST_NCI_DM_GETINFO_PIPE_LIST). The first dynamic pipe is present at index 3. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Add support for NCI_HCI_IDENTITY_MGMT_GATEChristophe Ricard
NCI_HCI_IDENTITY_MGMT_GATE might be useful to get information about hardware or firmware version. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: initialize gate_count in st_nci_hci_network_initChristophe Ricard
When initializing ndev->hci_dev->init_data, only gates field was set. gate_count needs to be initialized as well. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Keep st_nci_gates unchanged in load_sessionChristophe Ricard
We need to keep initial st_nci_gates values in order for nci_hci_dev_connect_gates to create and open pipe when necessary. For example after a firmware update CLF pipes are cleared. Changing pipe values in st_nci_gates was causing nci_hci_dev_connect_gates not using accurate pipes value. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Open NCI_HCI_LINK_MGMT_PIPEChristophe Ricard
NCI_HCI_LINK_MGMT_PIPE was never opened in st_nci_hci_load_session. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Remove HCI init_data.gates initialization in load_sessionChristophe Ricard
ndev->hci_dev->init_data.gates is already initialized in st_nci_hci_network. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Fix incorrect spi buffer sizeChristophe Ricard
When sending data over SPI, the maximum expected length is the maximum nci packet payload + data header size + the frame head room (1 for the ndlc header) + the frame trail room (0). Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: include st-nci.h instead of ndlc.hChristophe Ricard
st-nci.h already include ndlc.h. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-26NFC: st-nci: Align st-nci driver with other nfc driverChristophe Ricard
Align st-nci driver with other NFC drivers: - Remove st-nci_ prefix - Merge se.h in st-nci.h Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-25NFC: nci: rename nci_prop_ops to nci_driver_opsRobert Dolca
Initially it was used to create hooks in the driver for proprietary operations. Currently it is being used for hooks for both proprietary and generic operations. Signed-off-by: Robert Dolca <robert.dolca@intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-25NFC: st-nci: Rename st-nci_se.cSamuel Ortiz
Rename it to se.c to keep the driver files namespace consistent. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Remove pr_err in rcv_queue when ndlc header is unknownChristophe Ricard
spi phy needs to use ndlc_recv at every spi transaction causing "unknown packet control byte" error message each time the header is 00. Make this silent. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Add spi phy support for st21nfcbChristophe Ricard
st21nfcb does support another phy than i2c: spi. st21nfcc does not support spi as the spi ios are used by the AMS RF booster. st21nfcb is not following NCI NFC Forum recommendations for spi but rely on ST prioritary protocol ndlc as for i2c. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Free data with irrelevant NDLC PCB_SYNC valueChristophe Ricard
PCB_SYNC different than PCB_TYPE_SUPERVISOR or PCB_TYPE_DATAFRAME should be discarded. Irrelevant data may be forwarded up to the ndlc state machine by phys like spi to prevent missing potential data during "write" transactions. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Remove data from ack_pending_q when receiving a SYNC_ACKChristophe Ricard
When receiving a NDLC PCB_SYNC_ACK the pending data was never removed from ack_pending_q and cleared. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17NFC: st-nci: fix use of uninitialized variables in error pathChristophe Ricard
st_nci_hci_load_session() calls kfree_skb() on unitialized variables skb_pipe_info and skb_pipe_list if the call to nci_hci_connect_gate() failed. Reword the error path to not use these variables when they are not initialized. While at it, there seemed to be a memory leak because skb_pipe_info was only freed once, after the for-loop, even though several ones were created by nci_hci_send_cmd. Cc: stable@vger.kernel.org Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Fix non accurate comment for st_nci_i2c_readChristophe Ricard
Due to a copy and paste error st_nci_i2c_read still contains st21nfca header comment. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Fix typo when changing from st21nfcb to st-nciChristophe Ricard
Replace ST21NFCB with ST_NCI or st21nfcb with st_nci as it was forgotten in commit "nfc: st-nci: Rename st21nfcb to st-nci" ed06aeefdac348cfb91a3db5fe1067e3202afd70 Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: st-nci: Remove duplicate file platform_data/st_nci.hChristophe Ricard
commit "nfc: st-nci: Rename st21nfcb to st-nci" adds include/linux/platform_data/st_nci.h duplicated with include/linux/platform_data/st-nci.h. Only drivers/nfc/st-nci/i2c.c uses platform_data/st_nci.h. Cc: stable@vger.kernel.org Reported-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
