Gobi devices are composite, needing both the qcserial and
qmi_wwan drivers to support all functions. Re-syncing the
list of supported devices with qcserial.
Cc: Aleksander Morgado <aleksander@lanedo.com>
Cc: Thomas Tuttle <ttuttle@chromium.org>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Signed-off-by: David S. Miller <davem@tempietto.lan>
The intent was to set 4 bytes of data so that's why the sp_len is set
to 4 on the next line. The cast to u_long pointer clears 8 bytes
on 64 bit arches.
davinci mdio device is not unregistered from mdiobus when removing
the module, which causes BUG_ON() when free the device from mdiobus.
Calling mdiobus_unregister() before mdiobus_free() fixes the issue.
Signed-off-by: Bin Liu <b-liu@ti.com>
Foxconn-branded Novatel E396, Gobi3k modem.
Cc: Dan Williams <dcbw@redhat.com>
Cc: Bjørn Mork <bjorn@mork.no>
Cc: Ben Chan <benchan@google.com>
Signed-off-by: Aleksander Morgado <aleksander@lanedo.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
A usbnet device can share a multifunction device
with a storage device. If the storage device is autoresumed
the usbnet devices also needs to be autoresumed. Allocating
memory with GFP_KERNEL can deadlock in this case.
This should go back into all kernels that have
commit 65841fd5132c3941cdf5df09e70df3ed28323212
That is 3.5
Signed-off-by: Oliver Neukum <oneukum@suse.de>
CC: stable@kernel.org
The RxCFG register of the CS89x0 could be configured incorrectly
(because of misplaced parentheses), resulting in the disabling
of packet reception.
Signed-off-by: Jaccon Bastiaansen <jaccon.bastiaansen@gmail.com>
This patch correct poll_bnx2x (ndo_poll_controller call) which was not
functioning well with MSI-X.
Signed-off-by: Merav Sicron <meravs@broadcom.com>
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Move netif_napi_add for all queues from the probe call to the open call, to
avoid the case that napi objects are added for queues that may eventually not
be initialized and activated. With the former behavior, the driver could crash
when netpoll was calling ndo_poll_controller.
With a low enough MSS on the link partner and TSO enabled locally, the
networking stack can periodically send a very large (e.g. 64KB) TCP
message for which the driver will attempt to use more Tx descriptors than
are available by default in the Tx ring. This is due to a workaround in
the code that imposes a limit of only 4 MSS-sized segments per descriptor
which appears to be a carry-over from the older e1000 driver and may be
applicable only to some older PCI or PCIx parts which are not supported in
e1000e. When the driver gets a message that is too large to fit across the
configured number of Tx descriptors, it stops the upper stack from queueing
any more and gets stuck in this state. After a timeout, the upper stack
assumes the adapter is hung and calls the driver to reset it.
Remove the unnecessary limitation of using up to only 4 MSS-sized segments
per Tx descriptor, and put in a hard failure test to catch when attempting
to check for message sizes larger than would fit in the whole Tx ring.
Refactor the remaining logic that limits the size of data per Tx descriptor
from a seemingly arbitrary 8KB to a limit based on the dynamic size of the
Tx packet buffer as described in the hardware specification.
Also, fix the logic in the check for space in the Tx ring for the next
largest possible packet after the current one has been successfully queued
for transmit, and use the appropriate defines for default ring sizes in
e1000_probe instead of magic values.
This issue goes back to the introduction of e1000e in 2.6.24 when it was
split off from e1000.
Reported-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Cc: Stable <stable@vger.kernel.org> [2.6.24+]
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Commit -
"b852b72 gianfar: fix bug caused by
87c288c6e9aa31720b72e2bc2d665e24e1653c3e"
disables by default (on mac init) the hw vlan tag insertion.
The "features" flags were not updated to reflect this, and
"ethtool -K" shows tx-vlan-offload to be "on" by default.
Cc: Sebastian Poehn <sebastian.poehn@belden.com>
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
I'm slightly concerned by the "only in exceptional circumstances"
comment on __pskb_pull_tail but the structure of an skb just created
by netfront shouldn't hit any of the especially slow cases.
This approach still does slightly more work than the old way, since if
we pull up the entire first frag we now have to shuffle everything
down where before we just received into the right place in the first
place.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: xen-devel@lists.xensource.com
Cc: netdev@vger.kernel.org
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Against -net.
In the patch "netpoll: re-enable irq in poll_napi()", I tried to
fix the following warning:
[100718.051041] ------------[ cut here ]------------
[100718.051048] WARNING: at kernel/softirq.c:159 local_bh_enable_ip+0x7d/0xb0()
(Not tainted)
[100718.051049] Hardware name: ProLiant BL460c G7
[100718.051068] Call Trace:
[100718.051073] [<ffffffff8106b747>] ? warn_slowpath_common+0x87/0xc0
[100718.051075] [<ffffffff8106b79a>] ? warn_slowpath_null+0x1a/0x20
[100718.051077] [<ffffffff810747ed>] ? local_bh_enable_ip+0x7d/0xb0
[100718.051080] [<ffffffff8150041b>] ? _spin_unlock_bh+0x1b/0x20
[100718.051085] [<ffffffffa00ee974>] ? be_process_mcc+0x74/0x230 [be2net]
[100718.051088] [<ffffffffa00ea68c>] ? be_poll_tx_mcc+0x16c/0x290 [be2net]
[100718.051090] [<ffffffff8144fe76>] ? netpoll_poll_dev+0xd6/0x490
[100718.051095] [<ffffffffa01d24a5>] ? bond_poll_controller+0x75/0x80 [bonding]
[100718.051097] [<ffffffff8144fde5>] ? netpoll_poll_dev+0x45/0x490
[100718.051100] [<ffffffff81161b19>] ? ksize+0x19/0x80
[100718.051102] [<ffffffff81450437>] ? netpoll_send_skb_on_dev+0x157/0x240
by reenabling IRQ before calling ->poll, but it seems more
problems are introduced after that patch:
http://ozlabs.org/~akpm/stuff/IMG_20120824_122054.jpg
http://marc.info/?l=linux-netdev&m=134563282530588&w=2
So it is safe to fix be2net driver code directly.
This patch reverts the offending commit and fixes be_poll() by
avoid disabling BH there, this is okay because be_poll()
can be called either by poll_napi() which already disables
IRQ, or by net_rx_action() which already disables BH.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Reported-by: Sylvain Munaut <s.munaut@whatever-company.com>
Cc: Sylvain Munaut <s.munaut@whatever-company.com>
Cc: Sathya Perla <sathya.perla@emulex.com>
Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com>
Cc: Ajit Khaparde <ajit.khaparde@emulex.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Tested-by: Sylvain Munaut <s.munaut@whatever-company.com>
Ben Hutchings says:
Simple fix for a braino. Please also queue this for the 3.4 and 3.5
stable series.
Marc Kleine-Budde says:
here are two fixes for the v3.6 release cycle. Alexey Khoroshilov submitted a
fix for a memory leak in the softing driver (in softing_load_fw()) in case a
krealloc() fails. Sven Schmitt fixed the misuse of the IRQF_SHARED flag in the
irq resouce of the sja1000 platform driver, now the correct flag is used. There
are no mainline users of this feature which need to be converted.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
This batch of fixes is intended for 3.6...
Johannes Berg gives us a pair of iwlwifi fixes. One corrects some
improperly defined ifdefs that lead to crashes and BUG_ONs. The other
prevents attempts to read SRAM for devices that aren't actually started.
Julia Lawall provides an ipw2100 fix to properly set the return code
from a function call before testing it! :-)
Thomas Huehn corrects the improper use of a constant related to a power
setting in ath5k.
Thomas Pedersen offers a mac80211 fix to properly handle destination
addresses of unicast frames passing though a mesh gate.
Vladimir Zapolskiy provides a brcmsmac fix to properly mark the
interface state when the device goes down.
This patch adds "#ifndef __<header>_H" for protecting header from double
inclusion.
Signed-off-by: Rayagond Kokatanur <rayagond@vayavyalabs.com>
Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
The sja1000 platform driver wrongly assumes that a shared IRQ is indicated
with the IRQF_SHARED flag in irq resource flags. This patch changes the
driver to handle the correct flag IORESOURCE_IRQ_SHAREABLE instead.
There are no mainline users of the platform driver which wrongly make use
of IRQF_SHARED.
Signed-off-by: Sven Schmitt <sven.schmitt@volkswagen.de>
Acked-by: Yegor Yefremov <yegorslists@googlemail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Do not leak memory by updating pointer with potentially NULL realloc return value.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
ETHTOOL_GRXCLSRULE returns filters for a TCP/IPv4 or UDP/IPv4 4-tuple
with source and destination swapped.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
This patch fixes the name of the macro used to mask the
mmc interrupt: erroneously it was used: MMC_DEFAUL_MASK.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Erroneously the DWMAC_CORE_3_40 was set to 34 instead of 0x34.
This can generate problems when run on old chips because
the driver assumes that there are the extra 16 regs available
for perfect filtering.
Cc: Gianni Antoniazzi <gianni.antoniazzi-ext@st.com>
This change marks interface as down on reset, otherwise the driver can't
reinitialize itself properly.
Without the change a transient problem turns out to be critical and leads
to inavailability to reset the driver without brcmsmac module unload/load
cycle:
ieee80211 phy0: wl0: PSM microcode watchdog fired at 5993 (seconds). Resetting.
brcms_c_dpc : PSM Watchdog, chipid 0xa8d9, chiprev 0x1
ieee80211 phy0: wl0: fatal error, reinitializing
ieee80211 phy0: Hardware restart was requested
ieee80211 phy0: brcms_ops_start: brcms_up() returned -19
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Arend van Spriel <arend@broadcom.com>
Pull networking update from David Miller:
"A couple weeks of bug fixing in there. The largest chunk is all the
broken crap Amerigo Wang found in the netpoll layer."
1) netpoll and it's users has several serious bugs:
a) uses GFP_KERNEL with locks held
b) interfaces requiring interrupts disabled are called with them
enabled
c) and vice versa
d) VLAN tag demuxing, as per all other RX packet input paths, is not
applied
All from Amerigo Wang.
2) Hopefully cure the ipv4 mapped ipv6 address TCP early demux bugs for
good, from Neal Cardwell.
3) Unlike AF_UNIX, AF_PACKET sockets don't set a default credentials
when the user doesn't specify one explicitly during sendmsg().
Instead we attach an empty (zero) SCM credential block which is
definitely not what we want. Fix from Eric Dumazet.
4) IPv6 illegally invokes netdevice notifiers with RCU lock held, fix
from Ben Hutchings.
5) inet_csk_route_child_sock() checks wrong inet options pointer, fix
from Christoph Paasch.
6) When AF_PACKET is used for transmit, packet loopback doesn't behave
properly when a socket fanout is enabled, from Eric Leblond.
7) On bluetooth l2cap channel create failure, we leak the socket, from
Jaganath Kanakkassery.
8) Fix all the netprio file handling bugs found by Al Viro, from John
Fastabend.
9) Several error return and NULL deref bug fixes in networking drivers
from Julia Lawall.
10) A large smattering of struct padding et al. kernel memory leaks to
userspace found of Mathias Krause.
11) Conntrack expections in netfilter can access an uninitialized timer,
fix from Pablo Neira Ayuso.
12) Several netfilter SIP tracker bug fixes from Patrick McHardy.
13) IPSEC ipv6 routes are not initialized correctly all the time,
resulting in an OOPS in inet_putpeer(). Also from Patrick McHardy.
14) Bridging does rcu_dereference() outside of RCU protected area, from
Stephen Hemminger.
15) Fix routing cache removal performance regression when looking up
output routes that have a local destination. From Zheng Yan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits)
af_netlink: force credentials passing [CVE-2012-3520]
ipv4: fix ip header ident selection in __ip_make_skb()
ipv4: Use newinet->inet_opt in inet_csk_route_child_sock()
tcp: fix possible socket refcount problem
net: tcp: move sk_rx_dst_set call after tcp_create_openreq_child()
net/core/dev.c: fix kernel-doc warning
netconsole: remove a redundant netconsole_target_put()
net: ipv6: fix oops in inet_putpeer()
net/stmmac: fix issue of clk_get for Loongson1B.
caif: Do not dereference NULL in chnl_recv_cb()
af_packet: don't emit packet on orig fanout group
drivers/net/irda: fix error return code
drivers/net/wan/dscc4.c: fix error return code
drivers/net/wimax/i2400m/fw.c: fix error return code
smsc75xx: add missing entry to MAINTAINERS
net: qmi_wwan: new devices: UML290 and K5006-Z
net: sh_eth: Add eth support for R8A7779 device
netdev/phy: skip disabled mdio-mux nodes
dt: introduce for_each_available_child_of_node, of_get_next_available_child
net: netprio: fix cgrp create and write priomap race
If the device is not started, we can't read its
SRAM and attempting to do so will cause issues.
Protect the debugfs read.
Cc: stable@vger.kernel.org
iwl_dbgfs_fh_reg_read() can cause crashes and/or
BUG_ON in slub because the ifdefs are wrong, the
code in iwl_dump_fh() should use DEBUGFS, not
DEBUG to protect the buffer writing code.
Also, while at it, clean up the arguments to the
function, some code and make it generally safer.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
The result of one call to a function is tested, and then at the second call
to the same function, the previous result, and not the current result, is
tested again.
Also changed &bssid to bssid, at the suggestion of Stanislav Yakovlev.
The semantic match that finds the first problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression ret;
identifier f;
statement S1,S2;
*ret = f(...);
if (\(ret != 0\|ret < 0\|ret == NULL\)) S1
... when any
*f(...);
if (\(ret != 0\|ret < 0\|ret == NULL\)) S2
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
This patch reduces the per rate target power eeprom reads for
AR5K_EEPROM_MODE_11A from 10 to 8, as there are only 8 valid
power curve entries on the eeprom. The former 10 reads lead to
equal max power limits per rate and this causes an increasing
distortion for all rates above 24 MBit and leads to a needless
poor performance in 802.11a mode.
Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull more USB patches from Greg Kroah-Hartman:
"Here are 10 more USB patches for 3.6-rc3. They all fix reported
problems (build problems for one of them, and easily repeatable oopses
for the others.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
gpu/mfd/usb: Fix USB randconfig problems
USB: CDC ACM: Fix NULL pointer dereference
USB: emi62: remove __devinit* from the struct usb_device_id table
USB: winbond: remove __devinit* from the struct usb_device_id table
USB: vt6656: remove __devinit* from the struct usb_device_id table
USB: rtl8187: remove __devinit* from the struct usb_device_id table
USB: p54usb: remove __devinit* from the struct usb_device_id table
USB: spca506: remove __devinit* from the struct usb_device_id table
USB: jl2005bcd: remove __devinit* from the struct usb_device_id table
USB: smsusb: remove __devinit* from the struct usb_device_id table
This netconsole_target_put() is obviously redundant, and it
causes a kernel segfault when removing a bridge device which has
netconsole running on it.
This is caused by:
commit 8d8fc29d02a33e4bd5f4fa47823c1fd386346093
Author: Amerigo Wang <amwang@redhat.com>
Date: Thu May 19 21:39:10 2011 +0000
netpoll: disable netpoll when enslave a device
(for all 3.x stable releases)
When getting clock, give a chance to the CPUs without DT support,
which use Common Clock Framework, such as Loongson1B.
Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret;
expression e1,e2;
if (ret < 0)
{ ... return ret; }
... when != ret = e1
when forall
*if(...)
... when != ret = e2
* return ret;
// </smpl>
Move up the initialization of rc so that failure of pci_alloc_consistent
returns -ENOMEM as well.
// <smpl>
identifier ret;
expression e1,e2;
if (ret < 0)
{ ... return ret; }
when forall
*if(...)
* return ret;
// </smpl>
// <smpl>
identifier ret;
expression e1,e2;
if (ret < 0)
{ ... return ret; }
when forall
*if(...)
* return ret;
// </smpl>
Newer firmware versions for the Pantech UML290 use a different
subclass ID. The Windows driver match on both IDs, so we do
that as well.
The ZTE (Vodafone) K5006-Z is a new device.
Cc: Thomas Schäfer <tschaefer@t-online.de>
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
The mdio-mux driver scans all child mdio nodes, without regard to whether
the node is actually used. Some device trees include all possible
mdio-mux nodes and rely on the boot loader to disable those that are not
present, based on some run-time configuration. Those nodes need to be
skipped.
This structure needs to always stick around, even if CONFIG_HOTPLUG
is disabled, otherwise we can oops when trying to probe a device that
was added after the structure is thrown away.
Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Bjørn Mork <bjorn@mork.no>
Cc: stable <stable@vger.kernel.org>
CC: Herton Ronaldo Krzesinski <herton@canonical.com>
CC: Hin-Tak Leung <htl10@users.sourceforge.net>
CC: Larry Finger <Larry.Finger@lwfinger.net>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Christian Lamparter <chunkeey@googlemail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma fixes from Roland Dreier:
"Grab bag of InfiniBand/RDMA fixes:
- IPoIB fixes for regressions introduced by path database conversion
- mlx4 fixes for bugs with large memory systems and regressions from
SR-IOV patches
- RDMA CM fix for passing bad event up to userspace
- Other minor fixes"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/mlx4: Check iboe netdev pointer before dereferencing it
mlx4_core: Clean up buddy bitmap allocation
mlx4_core: Fix integer overflow issues around MTT table
mlx4_core: Allow large mlx4_buddy bitmaps
IB/srp: Fix a race condition
IB/qib: Fix error return code in qib_init_7322_variables()
IB: Fix typos in infiniband drivers
IB/ipoib: Fix RCU pointer dereference of wrong object
IB/ipoib: Add missing locking when CM object is deleted
RDMA/ucma.c: Fix for events with wrong context on iWARP
RDMA/ocrdma: Don't call vlan_dev_real_dev() for non-VLAN netdevs
IB/mlx4: Fix possible deadlock on sm_lock spinlock
- Use kcalloc() / vzalloc() instead of an extra bitmap_zero().
- Add __GFP_NOWARN to kcalloc() since we'll try vzalloc() if it fails.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Fix some issues around int variables used in data structures related
to memory registration.
Handle int overflow in mlx4_init_icm_table by using a u64 intermediate
variable and changing struct mlx4_icm_table num_obj field to be u32.
Change some more fields/variables to use u32 instead of int to prevent
a case where the variable becomes negative when bit 31 is set.
Also subtract log_mtts_per_seg from the exponent when computing
num_mtt, since its added later on in that very same code area.
This and the previous commit fixes some issues which actually prevent
commit db5a7a65c058 ("mlx4_core: Scale size of MTT table with system
RAM") from working. Now, when the number of MTTs is scaled with the
size of the RAM we can map up to 8TB.
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
mlx4_buddy_init uses kmalloc() to allocate bitmaps, which fails when
the required size is beyond the max supported value (or when memory is
too fragmented to handle a huge allocation). Extend this to use use
vmalloc() if kmalloc() fails, and take that into account when freeing
the bitmaps as well.
This fixes a driver load failure when log num mtt is 26 or higher, and
is a step in the direction of allowing to register huge amounts of
memory on large memory systems.
dev_open() can complete before register_netdev() returns.
Fix vmxnet3_probe_device() to support this.
Signed-off-by: Steve Hodgson <steve@purestorage.com>
Alexey Khoroshilov provides a potential memory leak in rndis_wlan.
Bob Copeland gives us an ath5k fix for a lockdep problem.
Dan Carpenter fixes a signedness mismatch in at76c50x.
Felix Fietkau corrects a regression caused by an earlier commit that can
lead to an IRQ storm.
Lorenzo Bianconi offers a fix for a bad variable initialization in ath9k
that can cause it to improperly mark decrypted frames.
Rajkumar Manoharan fixes ath9k to prevent the btcoex time from running
when the hardware is asleep.
The remainder are Bluetooth fixes, about which Gustavo says:
"Here goes some fixes for 3.6-rc1, there are a few fix to
thte inquiry code by Ram Malovany, support for 2 new devices,
and few others fixes for NULL dereference, possible deadlock
and a memory leak."
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
// <smpl>
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
when != ret = e3
*if (x == NULL || ...)
... when != ret = e4
* return ret;
// </smpl>
function.
// <smpl>
identifier ret;
ret = 0
... when != x = e2
when != ret = e3
* return ret;
// </smpl>
If the NULL test is necessary, the initialization involving a dereference of
the tested value should be moved after the NULL test.
The sematic patch that fixes this problem is as follows:
// <smpl>
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
... when != E
when != i
if (E == NULL) S
+ i = E->fld;
// </smpl>
Take advantage of the matching macros to make the device id
list easier to read and maintain.
