path: root/drivers/net
2008-02-26Update the i.MX31 Kernel to 2.6.232.6.23-mx31ads-2008022618072.6.23-mx31-200802261807Justin Waters
This is the result of a brute-force attempt to update the kernel to 2.6.23. Now that we have a git tree, our effort will be a little nicer in the future. Signed-off-by: Justin Waters <justin.waters@timesys.com>
2007-10-24CR ENGR00052918 fec 2.6.22 workqueue changesQuinn Jensen
Patch for CR ENGR00052918: This patch updates the FEC ethernet with workqueue changes for the linux 2.6.22 kernel. Applies to MX27 platform. http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00052918-fec-2.6.22-workqueue-chang.patch
2007-10-24Bugzilla 510: Update to code review fixes following L2618.2Quinn Jensen
Patch for Bugzilla 510: Update to code review fixes following L2618.2 Changes made to fix bugs and/or port to 2.6.19.2 after including GSO L2618-2 patches as discovered and discussed in the code review. http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-510-Update-to-code-review-fixes-f.patch
2007-10-24This patch adds network drivers (CS8900, FEC, IrDA) to the linux 2.6.22Quinn Jensen
kernel for MX platforms. http://www.bitshrine.org/gpp/linux-2.6.22-mx-drivers_net.patch
2007-08-30PPP: Fix PPP buffer sizing.Konstantin Sharlaimov
This patch addresses the issue with "osize too small" errors in mppe encryption. The patch fixes the issue with wrong output buffer size being passed to ppp decompression routine. -------------------- As pointed out by Suresh Mahalingam, the issue addressed by ppp-fix-osize-too-small-errors-when-decoding patch is not fully resolved yet. The size of allocated output buffer is correct, however it size passed to ppp->rcomp->decompress in ppp_generic.c if wrong. The patch fixes that. -------------------- Signed-off-by: Konstantin Sharlaimov <konstantin.sharlaimov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-30sky2: don't clear phy power bitsStephen Hemminger
There are special PHY settings available on Yukon EC-U chip that should not get cleared. This should solve mysterious errors on some motherboards (like Gigabyte DS-3). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-30NET: Share correct feature code between bridging and bondingHerbert Xu
[NET]: Share correct feature code between bridging and bonding http://bugzilla.kernel.org/show_bug.cgi?id=8797 shows that the bonding driver may produce bogus combinations of the checksum flags and SG/TSO. For example, if you bond devices with NETIF_F_HW_CSUM and NETIF_F_IP_CSUM you'll end up with a bonding device that has neither flag set. If both have TSO then this produces an illegal combination. The bridge device on the other hand has the correct code to deal with this. In fact, the same code can be used for both. So this patch moves that logic into net/core/dev.c and uses it for both bonding and bridging. In the process I've made small adjustments such as only setting GSO_ROBUST if at least one constituent device supports it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22forcedeth: fix random hang in forcedeth driver when using netconsoleTimo Jantunen
If the forcedeth driver receives too much work in an interrupt, it assumes it has a broken hardware with stuck IRQ. It works around the problem by disabling interrupts on the nic but makes a printk while holding device spinlog - which isn't smart thing to do if you have netconsole on the same nic. This patch moves the printk's out of the spinlock protected area. Without this patch the machine hangs hard. With this patch everything still works even when there is significant increase on CPU usage while using the nic. Signed-off-by: Timo Jantunen <jeti@iki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22r8169: avoid needless NAPI poll schedulingFrancois Romieu
Theory : though needless, it should not have hurt. Practice: it does not play nice with DEBUG_SHIRQ + LOCKDEP + UP (see https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=3D242572). The patch makes sense in itself but I should dig why it has an effect on #242572 (assuming that NAPI do not change in a near future). Patch in mainline as 313b0305b5a1e7e0fb39383befbf79558ce68a9c. Backported to 2.6.22-stable by Thomas M=FCller. Signed-off-by: Thomas M=FCller <thomas@mathtm.de> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22sky2: check drop truncated packetsStephen Hemminger
Backport of commit 71749531f2d1954137a1a77422ef4ff29eb102dd If packet larger than MTU is received, the driver uses hardware to truncate the packet. Use the status registers to catch/drop them. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22sky2: check for more work before leaving NAPIStephen Hemminger
Backport of commit 5c11ce700f77fada15b6264417d72462da4bbb1c This patch avoids generating another IRQ if more packets arrive while in the NAPI poll routine. Before marking device as finished, it rechecks that the status ring is empty. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22sky2: carrier managementStephen Hemminger
backport of commit 55d7b4e6ed6ad3ec5e5e30b3b4515a0a6a53e344 Make sky2 handle carrier similar to other drivers, eliminate some possible races in carrier state transistions. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22sky2: restore workarounds for lost interruptsStephen Hemminger
Backport of commit c59697e06058fc2361da8cefcfa3de85ac107582 This patch restores a couple of workarounds from 2.6.16: * restart transmit moderation timer in case it expires during IRQ routine * default to having 10 HZ watchdog timer. At this point it more important not to hang than to worry about the power cost. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09forcedeth bug fix: realtek phyAyaz Abdulla
This patch contains errata fixes for the realtek phy. It only renamed the defines to be phy specific. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09forcedeth bug fix: vitesse phyAyaz Abdulla
This patch contains errata fixes for the vitesse phy. It only renamed the defines to be phy specific. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09forcedeth bug fix: cicada phyAyaz Abdulla
This patch contains errata fixes for the cicada phy. It only renamed the defines to be phy specific. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-06potential compiler error, irqfunc caller sites updateYoann Padioleau
In 7d12e780e003f93433d49ce78cfedf4b4c52adc5 David Howells performed this evolution: "IRQ: Maintain regs pointer globally rather than passing to IRQ handlers" He correctly updated many of the function definitions that were using this extra regs pointer parameter but forgot to update some caller sites of those functions. The reason the modifications was not properly done on all drivers is that some drivers were rarely compiled because they are for AMIGA, or that some code sites were inside #ifdefs where the option is not set or inside #if 0. Here is the semantic patch that found the occurences and fixed the problem. @ rule1 @ identifier fn; identifier irq, dev_id; typedef irqreturn_t; @@ static irqreturn_t fn(int irq, void *dev_id) { ... } @@ identifier rule1.fn; expression E1, E2, E3; @@ fn(E1, E2 - ,E3 ) Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-05Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Update defconfigs [POWERPC] Uninline and export virq_to_hw() for the pasemi_mac driver [POWERPC] Fix PMI breakage in cbe_cbufreq driver [POWERPC] Disable old EMAC driver in arch/powerpc
2007-07-02Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IPoIB/cm: Partial error clean up unmaps wrong address mlx4_core: Add new Mellanox device IDs
2007-07-02mlx4_core: Add new Mellanox device IDsJack Morgenstein
Add new IDs for PCIe gen2 devices. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-023c589_cs: fix local_bh_enable warningPatrick McHardy
Russell King wrote: > Having upgraded from 2.6.16 to 2.6.22-rc6, I'm now seeing the following. > > Looks like netfilter is calling local_bh_enable() with IRQs disabled, > which would appear to be illegal. Thankfully, this is a warn-once > warning. > > WARNING: at /home/rmk/git/linux-2.6-rmk/kernel/softirq.c:138 local_bh_enable() > [...] > [<c01447fc>] (nf_conntrack_destroy+0x0/0x2c) from [<c012c05c>] (__kfree_skb+0xd0/0x100) > [<c012bf8c>] (__kfree_skb+0x0/0x100) from [<c012c0d8>] (kfree_skb+0x4c/0x50) > r5:c12a3800 r4:00000300 > [<c012c08c>] (kfree_skb+0x0/0x50) from [<bf03cbb0>] (el3_start_xmit+0xb8/0xd0 [3c589_cs]) > [<bf03caf8>] (el3_start_xmit+0x0/0xd0 [3c589_cs]) from [<c01324dc>] (dev_hard_start_xmit+0x1a8/0x244) > r7:c12a3800 r6:c1a9aa00 r5:c1a9aa00 r4:c12a3800 > [<c0132334>] (dev_hard_start_xmit+0x0/0x244) from [<c013fcc0>] (__qdisc_run+0xb0/0x198) Thats a bug in the 3c589_cs driver. Patch attached. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02RESEND [PATCH 3/3] NetXen: Graceful teardown of interface and hardware upon ↵Dhananjay Phadke
module unload Resending patch 3/3 only. These changes allow driver close routine to be called during module unload, to clean-up buffers and other software resources, flush queues etc. Also, hardware is reset to pristine state. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Milan Bag <mbag@netxen.com> Signed-off-by: Wen Xiong <wenxiong@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02drivers/net/ns83820.c: fix a check-after-useAdrian Bunk
This patch fixes a check-after-use spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02net/usb/cdc_ether minor sparse cleanupDavid Brownell
Remove an "sparse" warning about a shadowed variable name. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02RESEND [PATCH 2/3] NetXen: Support per PCI-function interrupt mask registersdhananjay.phadke@gmail.com
This patch updates the various access routines to access different control and status settings present in different register locations. This will fix problems related to working of different ports in multi Port card. Signed-off by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off by: Milan Bag <mbag@netxen.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02RESEND [PATCH 1/3] NetXen: Fix issue of MSI not working correctlydhananjay.phadke@gmail.com
NetXen driver uses PCI function 0 to provide the functionality of MSI. The patch makes driver check the bus master bit for function 0 and enable it after the card initialization. Signed-off-by: Dhananjay Phadke<dhananjay@netxen.com> Signed-off-by: Milan Bag <mbag@netxen.com> Signed-off-by: Wen Xiong <wenxiong@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02dm9601: Return 0 from bind() on successPeter Korsgaard
Fixup dm9601_bind() so it returns 0 on success rather than just a positive number, as otherwise usbnet doesn't init the status handler. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02usbnet: Zero padding byte if there is tail room in skbPeter Korsgaard
Usbnet adds a padding byte if a 0 byte USB packet would be sent. Zero padding byte if there is tail room in skb. Signed-of-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02dm9601: HW header size shouldn't be included in packet lengthPeter Korsgaard
The dm9601 driver was including the 2 byte hardware header in the packet length, causing the HW to send 2 extra bytes of garbage on tx. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02starfire list alpha as 64 bit archmaximilian attems
instead of: "This driver has not been ported to this 64-bit architecture yet." the driver is said to work on alpha, see http://bugs.debian.org/305330 Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02myri10ge: SET_NETDEV_DEV()Maik Hampel
SET_NETDEV_DEV() in myri10ge to create the "/sys/class/net/<if>/device" symlink. Signed-off-by: Maik Hampel <m.hampel@gmx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02Merge branch 'for_linus' of ↵Jeff Garzik
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into upstream-fixes
2007-07-02Merge branch 'libertas-fixes' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
2007-07-02[POWERPC] Disable old EMAC driver in arch/powerpcDavid Gibson
The EMAC driver, in drivers/net/ibm_emac, for the embedded Ethernet MAC found in PowerPC 4xx embedded chips is not suitable for arch/powerpc. It will not build because it relies on the old arch/ppc OCP mechanism. BenH has a new, device-tree aware version of the driver which will work in arch/powerpc, but until it's merged, this patch will disable the old, non-building version. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-01smsc-ircc2: bypass PNP detection until we get the quirks worked outBjorn Helgaas
Don't use PNP detection by default yet. We have some PNP and BIOS issues to work out first. Sample problem on a Toshiba Portege 4000: the SMCf010 device is handed off disabled. We assign I/O ports originally assigned to the SMCf010 to a PCMCIA device instead. We enable the SMCf010, configuring it to use disjoint ports, but _SRS doesn't work correctly, so the device doesn't work. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-29Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IRDA]: fix printk format [NETPOLL] netconsole: fix soft lockup when removing module [NETPOLL]: tx lock deadlock fix SCTP: lock_sock_nested in sctp_sock_migrate SCTP: Fix sctp_getsockopt_get_peer_addrs SCTP: update sctp_getsockopt helpers to allow oversized buffers
2007-06-28[IRDA]: fix printk formatRandy Dunlap
Fix printk format warning: drivers/net/irda/irport.c:512: warning: format '%d' expects type 'int', but argument 5 has type 'long int' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-29gianfar: Fix typo bug introduced by move to udp_hdr()Kumar Gala
In commit 4bedb45203eab92a87b4c863fe2d0cded633427f both the udp and tcp cases where changed to use udp_hdr() instead of leaving the tcp case alone and fixing with tcp_hdr(). This ended up causing random behavior with TCP connections because of looking for tcp_hdr()->check in the wrong place. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-28Merge branch 'for_linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc * 'for_linus' of master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc: phy: Fix phy_id for Vitesse 824x PHY
2007-06-28Fix Kconfig dependency problems wrt boolean menuconfigsTrent Piepho
If one has a dependency chain (tristate)FOO depends on (bool)BAR depends on (tristate)BAZ, build problems will result. If BAZ=m, then BAR can be set y, which allows FOO=y. It's possible to have FOO=y && BAZ=m, which wouldn't be allowed if FOO depended directly on BAZ. In effect, the bool promotes the tristate from m to y. This ends up causing a problem with several menuconfigs that look like: menuconfig BAR bool depends on BAZ [tristate] if BAR config FOO tristate endif The solution used here is to add the dependencies of BAR to the if statement, so that items in the if block will gain a direct non-bool-promoted dependency on BAZ. This is how it would work if a menu was used instead of an if block. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28smsc-ircc2: skip preconfiguration for PNP devicesBjorn Helgaas
If we rely on the device resources from PNPBIOS, we also have to rely on the BIOS to configure any bridges on the way to the device. Using the PNPBIOS resources but changing the configuration of a bridge behind the back of the firmware is likely to make things inconsistent. This patch addresses part of the 2.6.22 regression: "no irda0 interface (2.6.21 was OK), smsc does not find chip" It fixes smsc-ircc2 PNP device detection on HP nx5000 laptops. Other laptops, including HP nc6000, HP nc8000, HP nw8000, and Toshiba Portege 4000, still need PNP quirks to make this work. With "smsc-ircc2.nopnp", we do the legacy device probe, including manual bridge preconfiguration, as before. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Samuel Ortiz <samuel@sortiz.org> Acked-by: "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28phy: Fix phy_id for Vitesse 824x PHYKumar Gala
The phy_id specified for the Vitesse 824x PHY would never match because it was expecting bits to be set that would be masked by the phy_id_mask. Fix the phy_id so it will match properly, and changed the mdio_bus_match to mask both the driver and devices phy_id with the mask so we dont have this issue in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-06-28[PATCH] libertas: remove private ioctlsDan Williams
Signed-off-by: Christoph Hellwig <hch@infradead.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-28[PATCH] libertas: fix WPA associations by handling ENABLE_RSN correctlyDan Williams
Don't clobber the firmware's internal state machine by setting ENABLE_RSN more than once during the 4-way handshake. Check what the ENABLE_RSN status is and only set if it should be changed. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-28[PATCH] libertas: kill wlan_scan_process_resultsDan Williams
Fold into wlan_scan_networks() and protect with debug defines. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-06-28[PATCH] libertas: style fixesDan Williams
2007-06-272.6.22: ERROR: "__ucmpdi2" [drivers/net/s2io.ko] undefined!Olaf Hering
On Tue, Jun 19, Stephen Hemminger wrote: > Olaf Hering <olaf@aepfle.de> wrote: > > What happend to __ucmpdi2 from David Woodhouse? > > google has a few hits about stuff like this on 32bit powerpc with gcc 4.1.2: > > > > ERROR: "__ucmpdi2" [drivers/net/s2io.ko] undefined! > > > > using the drivers/net/s2io* files from 2.6.21 with 2.6.22-rc5 fixes the > > compile. > > > > 25805dcf9d83098cf5492117ad2669cd14cc9b24 adds two u64 >>= 48 followed by > > a switch statement (line 2889 and 6816). > > Probably the "switch(err) {" needs a cast to a smaller type (like u8). This change removes the compiler-generated calls to __ucmpdi2. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-27cxgb3 - fix register to stop bc/mc trafficDivy Le Ray
Use the right register to stop broadcast/multicast traffic. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-27au1000_eth: Fix warnings.Ralf Baechle
Fixed by including <linux/dma-mapping.h>: CC drivers/net/au1000_eth.o drivers/net/au1000_eth.c: In function 'au1000_probe': drivers/net/au1000_eth.c:661: warning: implicit declaration of function 'dma_alloc_noncoherent' drivers/net/au1000_eth.c:802: warning: implicit declaration of function 'dma_free_noncoherent' Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-23[PPP]: Fix osize too small errors when decoding mppe.Konstantin Sharlaimov
The mppe_decompress() function required a buffer that is 1 byte too small when receiving a message of mru size. This fixes buffer allocation to prevent this from occurring. Signed-off-by: Konstantin Sharlaimov <konstantin.sharlaimov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
