path: root/drivers/net
2008-02-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (60 commits) [NIU]: Bump driver version and release date. [NIU]: Fix BMAC alternate MAC address indexing. net: fix kernel-doc warnings in header files [IPV6]: Use BUG_ON instead of if + BUG in fib6_del_route. [IPV6]: dst_entry leak in ip4ip6_err. (resend) bluetooth: do not move child device other than rfcomm bluetooth: put hci dev after del conn [NET]: Elminate spurious print_mac() calls. [BLUETOOTH] hci_sysfs.c: Kill build warning. [NET]: Remove MAC_FMT net/8021q/vlan_dev.c: Use print_mac. [XFRM]: Fix ordering issue in xfrm_dst_hash_transfer(). [BLUETOOTH] net/bluetooth/hci_core.c: Use time_* macros [IPV6]: Fix hardcoded removing of old module code [NETLABEL]: Move some initialization code into __init section. [NETLABEL]: Shrink the genl-ops registration code. [AX25] ax25_out: check skb for NULL in ax25_kick() [TCP]: Fix tcp_v4_send_synack() comment [IPV4]: fix alignment of IP-Config output Documentation: fix tcp.txt ...
2008-02-18[NIU]: Bump driver version and release date.David S. Miller
2008-02-18[NIU]: Fix BMAC alternate MAC address indexing.Matheos Worku
BMAC port alternate MAC address index needs to start at 1. Index 0 is used for the main MAC address. Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-15Merge branch 'upstream-davem' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-02-15Merge branch 'fixes' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-02-15b43legacy: Add driver load messagesStefano Brivio
This adds printk messages with basic information about the driver being loaded. This information includes a summary of the compiled-in features, which simplifies bug-reporting and debugging a lot. Also a firmware ID is printed. This is a unique identifier blob for a specific version of the firmware. This ID is attached to a specific version of the firmware blob in b43-fwcutter (see fwcutter git). This helps users to select the right firmware for their device. This also makes it possible to use automated scripts to fetch and extract the right firmware for the driver. (The script will grep the .ko for the "Firmware-ID: xxx" string.) While the driver might still support other versions of the firmware for backward compatibility, this will always print out the officially supported version, which people _should_ use. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15ipw2200: fix ucode assertion for RX queue overrunDan Williams
Restock the RX queue when there are a lot of unused frames so that the RX ring buffer doesn't overrun, causing a ucode assertion. Backport of patch "iwlwifi: fix ucode assertion for RX queue overrun". Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15iwlwifi: only check for association id when associating with APReinette Chatre
There is no association process in IBSS mode - so testing the association id is not needed. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> CC: Richard Scherping <richard@scherping.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15iwlwifi: reverting 'misc wireless annotations' patch for iwlwifiTomas Winkler
This patch revert commit blow that wrongly suppressed sparse warning in iwlwifi eeprom reading In addtion it suppresses correctly the iwlwifi eeprom register reading anomaly. commit 45883ae47a0a4700c0f4716dc75a255cccdc3a76 misc wireless annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: fix firmware load message levelStefano Brivio
The firmware version information should always get printed. Not only on a debug build. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: add firmware information to modinfoStefano Brivio
This adds the firmware ID to modinfo. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15rt2x00: Add new USB ID to rt2500usbIvo van Doorn
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43: Fix firmware load message levelMichael Buesch
The firmware version information should always get printed. Not only on a debug build. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43: Add firmware information to modinfoMichael Buesch
This adds the firmware ID to modinfo. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43: Add driver load messagesMichael Buesch
This adds printk messages with basic information about the driver being loaded. This information includes a summary of the compiled-in features, which simplifies bug-reporting and debugging a lot. Also a firmware ID is printed. This is a unique identifier blob for a specific version of the firmware. This ID is attached to a specific version of the firmware blob in b43-fwcutter (see fwcutter git). This helps users to select the right firmware for their device. This also makes it possible to use automated scripts to fetch and extract the right firmware for the driver. (the script will grep the .ko for the "Firmware-ID: xxx" string. While the driver might still support other versions of the firmware for backward compatibility, this will always print out the officially supported version, which people _should_ use. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15b43legacy: fix DMA for 30/32-bit DMA enginesStefano Brivio
This checks if the DMA address is bigger than what the controller can manage. It will reallocate the buffers in the GFP_DMA zone in that case. The patch by Michael Buesch has been ported to b43legacy. Thanks to Matti Viljanen for reporting this. Cc: Matti Viljanen <viljanen.matti@gmail.com> Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15iwlwifi: earlier rx allocationMohamed Abbas
Value of count is used to decide when to replenish rx buffers. If it is equal or above 8 we replenish the buffers. Ensure there is no starvation by initializing count to 8 - thus forcing replenish at first iteration. This is helpful when rx receives batches of buffers smaller than 8. Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15iwlwifi: Don't send host commands on rfkillGregory Greenman
This patch prevents sending host commands when rfkill is on Signed-off-by: Gregory Greenman <gregory.greenman@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15iwlwifi: do not clear GEO_CONFIGURED bit when calling _downReinette Chatre
The geos information is set up during probe and should only be removed during pci_remove, not during _down. This is a temporary fix until the setting of the status bits have been cleaned up (to explicitly match all setting with clearing of status bits). Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15rndis_wlan: enable stall workaround by link quality instead of link speedJussi Kivilinna
Enable workaround for poor link stalls by link quality instead of link speed. Using link speed caused workaround be active always on 802.11b networks which reduced performance and not even catch all stalls. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15ath5k: correct padding in tx descriptorsBruno Randolf
when setting up the tx descriptors for the hardware we must account for any padding between the header and the data we might have added previously. frame len is the length of the frame in the air (including FCS but no padding) and buffer len is the length of the buffer (including padding, but without FCS). changing the way ah_setup_tx_desc is called: now excluding the FCS, since it's easier to add that in the function where we need it. before this fix we sent trailing zero bytes after the packet (because frame len included the padding) which was not a big problem without WEP, but with WEP this resultes in a wrong WEP checksum and the packet is discarded - which is how i noticed at all ;) an easy way to run into header padding problems, btw, is to connect to a QoS (WME) enabled access point (eg. madwifi) - QoS data frames are 2 byte longer and will require padding. this patch applies on top of luis latest patch series from 04.02.2008. drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD drivers/net/wireless/ath5k/hw.c: Changes-licensed-under: ISC Signed-off-by: Bruno Randolf <bruno@thinktube.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15wavelan: mark hardware interfacing structures as packedJohn W. Linville
With assists from Russell King <rmk+kernel@arm.linux.org.uk> and Andrew Morton <akpm@linux-foundation.org>... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-15e1000e: PCIe devices do not need to unset MANC_ARP_ENADavid Graham
Users reported that ARP's were lost with e1000e. The problem is fixed by not enabling this manageability configuration bit. None of the release_manageability code is actually needed as the normal device reset during a shutdown returns everthing to the right condition automatically. Signed-off-by: David Graham <david.graham@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15igb: PCIe devices do not need to unset MANC_ARP_ENADavid Graham
Users reported that ARP's were lost with igb. The problem is fixed by not enabling this manageability configuration bit. None of the release_manageability code is actually needed as the normal device reset during a shutdown returns everthing to the right condition automatically. Signed-off-by: David Graham <david.graham@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15ixgbe: Correctly obtain protocol information on transmitAuke Kok
In reply to "RE: [Fwd: [PATCH 2.6.25] ixgbe/igb: correctly obtain protocol information on transmit]" from Andy Gospodarek: The driver was incorrectly looking at socket headers for protocol information, needed for checksumming offload. Fix this by not looking at the socket but frame headers instead. This disregards extension headers but it's unclear that linux generates those anyway. Tested by Andy Gospodarek. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15e1000e: Fix CRC stripping in hardware context bugAuke Kok
CRC stripping was only correctly enabled for packet split recieves which is used when receiving jumbo frames. Correctly enable SECRC also for normal buffer packet receives. Tested by Andy Gospodarek and Johan Andersson, see bugzilla #9940. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15gianfar iomem misannotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15mkiss: ax_bump() locking fixJarek Poplawski
According to one of OOPSes reported by Jann softirq can break while skb is prepared for netif_rx. The report isn't complete, so the real reason of the later bug could be different, but IMHO this locking break in ax_bump is unsafe and unnecessary. Reported-and-tested-by: Jann Traschewski <jann@gmx.de> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15Fix station address detection in smcChuck Ebbert
Megahertz EM1144 PCMCIA ethernet adapter needs special handling because it has two VERS_1 tuples and the station address is in the second one. Conversion to generic handling of these fields broke it. Reverting that fixes the device. https://bugzilla.redhat.com/show_bug.cgi?id=233255 Thanks go to Jon Stanley for not giving up on this one until the problem was found. Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (82 commits) [NET]: Make sure sockets implement splice_read netconsole: avoid null pointer dereference at show_local_mac() [IPV6]: Fix reversed local_df test in ip6_fragment [XFRM]: Avoid bogus BUG() when throwing new policy away. [AF_KEY]: Fix bug in spdadd [NETFILTER] nf_conntrack_proto_tcp.c: Mistyped state corrected. net: xfrm statistics depend on INET [NETFILTER]: make secmark_tg_destroy() static [INET]: Unexport inet_listen_wlock [INET]: Unexport __inet_hash_connect [NET]: Improve cache line coherency of ingress qdisc [NET]: Fix race in dev_close(). (Bug 9750) [IPSEC]: Fix bogus usage of u64 on input sequence number [RTNETLINK]: Send a single notification on device state changes. [NETLABLE]: Hide netlbl_unlabel_audit_addr6 under ifdef CONFIG_IPV6. [NETLABEL]: Don't produce unused variables when IPv6 is off. [NETLABEL]: Compilation for CONFIG_AUDIT=n case. [GENETLINK]: Relax dances with genl_lock. [NETLABEL]: Fix lookup logic of netlbl_domhsh_search_def. [IPV6]: remove unused method declaration (net/ndisc.h). ...
2008-02-15netconsole: avoid null pointer dereference at show_local_mac()Keiichi KII
This patch avoids a null pointer dereference when we read local_mac for netconsole in configfs and shows default local mac address value. A null pointer dereference occurs when we call show_local_mac() via local_mac entry in configfs before we setup the content of netpoll using netpoll_setup(). Signed-off-by: Keiichi KII <k-keiichi@bx.jp.nec.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14mlx4_core: Move table_find from fmr_alloc to fmr_enableJack Morgenstein
mlx4_table_find (for FMR MPTs) requires that ICM memory already be mapped. Before this fix, FMR allocation depended on ICM memory already being mapped for the MPT entry. If all currently mapped entries are taken, the find operation fails (even if the MPT ICM table still had more entries, which were just not mapped yet). This fix moves the mpt find operation to fmr_enable, to guarantee that any required ICM memory mapping has already occurred. Found by Oren Duer of Mellanox. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-12Merge branch 'upstream-davem' of ↵David S. Miller
2008-02-11mlx4_core: Fix build break (missing include)Olof Johansson
Commit 313abe55 ("mlx4_core: For 64-bit systems, vmap() kernel queue buffers") caused this to pop up on powerpc allyesconfig, looks like a missing include file: drivers/net/mlx4/alloc.c: In function 'mlx4_buf_alloc': drivers/net/mlx4/alloc.c:162: error: implicit declaration of function 'vmap' drivers/net/mlx4/alloc.c:162: error: 'VM_MAP' undeclared (first use in this function) drivers/net/mlx4/alloc.c:162: error: (Each undeclared identifier is reported only once drivers/net/mlx4/alloc.c:162: error: for each function it appears in.) drivers/net/mlx4/alloc.c:162: warning: assignment makes pointer from integer without a cast drivers/net/mlx4/alloc.c: In function 'mlx4_buf_free': drivers/net/mlx4/alloc.c:187: error: implicit declaration of function 'vunmap' Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-11ixgbe: remove accidentally added #ifdefAuke Kok
Let's not add these #ifdef NETIF_F_TSO's back. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11ixgbe: Disallow device reset during ethtool testAuke Kok
2008-02-11ixgbe: warn when device is in a x4 or lower width slotAuke Kok
It's easy to oversee this issue when working with this card as evrything will work OK but performance is severely limited (something like 1.5gbit on a x1 link) if the pci-express slot does not offer more bandwidth. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11e1000e: Fix logic reversal keeping link activeAuke Kok
A logic mishap caused the adapter to keep link while we can disable it due to WoL not being active, and vice versa. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11e1000: warn if this driver is used for e1000e devicesAuke Kok
We're already starting to see reports from users still using e1000 where they should be using e1000e now that this is actually possible. Just to prevent some of this thrash, add a big warning on load on these devices that people should switch to e1000e. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11replace code with FIELD_SIZEOFJulia Lawall
Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11Tsi108_eth: Add ethtool supportAlex Bounine
Add ethtool support to tsi108_eth network driver. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11Tsi108_eth: fix link recovery after disconnectAlex Bounine
Bug fix for tsi108_eth network driver. This patch fixes a problem with link recovery after connection was lost. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11Tsi108_eth: remove not needed codeAlex Bounine
Code clean-up for tsi108_eth network driver. This patch removes not needed dummy read and the corresponding comment. The PHY logic requires two reads from the status register to get current link status. This is done correctly inside mii_check_media(). Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11Tsi108_eth: fix detection of 1000Mb modeAlex Bounine
Bug fix for tsi108_eth network driver. This patch fixes a problem with detection of 1000Mb speed. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11Tsi108_eth: add missing linking to driver dataAlex Bounine
Bug fix for tsi108_eth network driver. This patch adds missing linking to driver data. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11net/phy/fixed.c: fix a use-after-freeAdrian Bunk
This patch fixes a use-after-free introduced by commit a79d8e93d300adb84cccc38ac396cfb118c238ad and spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11drivers/net/sis190: fix section mismatch warning in sis190_get_mac_addrSergio Luis
Fix following warnings: WARNING: drivers/net/sis190.o(.text+0x103): Section mismatch in reference from the function sis190_get_mac_addr() to the function .devinit.text:sis190_get_mac_addr_from_apc() WARNING: drivers/net/sis190.o(.text+0x10e): Section mismatch in reference from the function sis190_get_mac_addr() to the function .devinit.text:sis190_get_mac_addr_from_eeprom() Annotate sis190_get_mac_addr() with __devinit. Signed-off-by: Sergio Luis <sergio@uece.br> sis190.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11forcedeth: tx pause watermarksAyaz Abdulla
New chipsets introduced variant Rx FIFO sizes that need to be taken into account when setting up the tx pause watermarks. This patch introduces the new device feature flags based on a version and implements the new watermarks. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11forcedeth: tx collision fixAyaz Abdulla
This patch supports a new fix in hardware regarding tx collisions. In the cases where we are in autoneg mode and the link partner is in forced mode, we need to setup the tx deferral register differently in order to reduce collisions on the wire. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11cxgb3: Handle ARP completions that mark neighbors stale.Steve Wise
When ARP completes due to a request rather than a reply the neighbor is marked NUD_STALE instead of reachable (see arp_process()). The handler for the resulting netevent needs to check also for NUD_STALE. Failure to use the arp entry can cause RDMA connection failures. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
