In "Build regressions/improvements in v3.0-rc2", Geert Uytterhoeven
reports a number of warnings that occur for parisc builds of rtlwifi
and dependents.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Add some error handling if the allocation fails.
1) Avoid global adapter pointer usage
a) in sdio.c by moving some code from mwifiex_cleanup_module() to
mwifiex_sdio_remove().
b) in main.c by passing an extra parameter to few functions.
2) Add new variable "user_rmmod" to identify if mwifiex_sdio_remove()
callback function is called in card removal or rmmod context. These
code changes are adapted from Libertas driver.
3) Remove unnecessary NULL pointer check for "func" pointer in
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Use less indentions and remove uneeded irq-save flags.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Messages like that
iwl4965 0000:03:00.0: Start IWL Event Log Dump: display last 20 entries
iwl4965 0000:03:00.0: EVT_LOGT:1821445332:0x00000000:1352
iwl4965 0000:03:00.0: EVT_LOGT:1821445332:0x00000001:1353
iwl4965 0000:03:00.0: EVT_LOGT:1821445336:0x0000000c:0357
iwl4965 0000:03:00.0: EVT_LOGT:1821445533:0x00000107:0106
iwl4965 0000:03:00.0: EVT_LOGT:1821445534:0x00000000:0302
iwl4965 0000:03:00.0: EVT_LOGT:1821445574:0x000000d4:0321
iwl4965 0000:03:00.0: EVT_LOGT:1821445575:0x00000000:1350
iwl4965 0000:03:00.0: EVT_LOGT:1821445576:0x00000000:1351
iwl4965 0000:03:00.0: EVT_LOGT:1821445576:0x00000000:1352
iwl4965 0000:03:00.0: EVT_LOGT:1821445577:0x00000001:1353
iwl4965 0000:03:00.0: EVT_LOGT:1821445581:0x0000000d:0357
iwl4965 0000:03:00.0: EVT_LOGT:1821446327:0x00000107:0106
iwl4965 0000:03:00.0: EVT_LOGT:1821446328:0x00000000:0302
iwl4965 0000:03:00.0: EVT_LOGT:1821446368:0x000000d4:0321
iwl4965 0000:03:00.0: EVT_LOGT:1821446369:0x00000000:1350
iwl4965 0000:03:00.0: EVT_LOGT:1821446370:0x00000000:1351
iwl4965 0000:03:00.0: EVT_LOGT:1821446370:0x00000000:1352
iwl4965 0000:03:00.0: EVT_LOGT:1821446371:0x00000001:1353
iwl4965 0000:03:00.0: EVT_LOGT:1821446375:0x0000000e:0357
iwl4965 0000:03:00.0: EVT_LOGT:1821446383:0x00000000:0125
are completely useless for me. Remove bunch of code that generate them.
We do not reset radio anymore, hence don't need that code too.
Recover from statistics code was added during 6xxx devices development,
I don't think is needed on old devices. Also it is suspicious to cause
random, unreproducible microcode errors and hangs. So remove it.
At http://dev.laptop.org/ticket/10748 we are seeing a case of the
libertas firmware randomly stopping responding to commands after
resume. Careful monitoring of communications indicates a firmware or
hardware bug, which has been reported to Marvell.
Work around this issue by adding a reset_card method; this is
automatically called when command timeouts are detected and provides an
instant recovery to this situation.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Signed-off-by: Mike McCormack <mikem@ring3k.org>
Once we realize a bad packet was received, don't
waste time unmapping it, freeing it, then allocation
a new skb and mapping it, just resubmit the existing
skb.
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
We use priv->mutex to avoid race conditions between chswitch_done()
and mac_channel_switch(), when marking channel switch in
progress. But chswitch_done() can be called in atomic context
from rx_csa() or with mutex already taken from commit_rxon().
To fix remove mutex from chswitch_done() and use atomic bitops
for marking channel switch pending.
Cc: stable@kernel.org # 2.6.39+
During channge channel, tx power will not send to uCode, the tx power command
should send after scan complete. but should also can send after RXON command.
Stable fix identified by Stanislaw Gruszka <sgruszka@redhat.com>.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Cc: stable@kernel.org [2.6.38+]
Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
Padding per MSDU will affect the length of next packet and hence
the exact length of next packet is uncertain here.
Also, aggregation of transmission buffer, while downloading the
data to the card, wont gain much on the AMSDU packets as the AMSDU
packets utilizes the transmission buffer space to the maximum
(adapter->tx_buf_size).
All MSDUs, except the last one in an AMSDU, should end up at 4
bytes boundary. There is need to check if enough skb_tailroom
space exists before padding the skb.
Also re-arranging code for better readablity.
The check of skb list empty before calling skb_peek and skb_dequeue is
redundant. These functions returns NULL if the list is empty.
Instead of counting the number of packets in txq
for particular RA list before AMSDU creation,
maintain a counter which will keep track of the
same.
This will reduce some MIPS while generating AMSDU
traffic as we only have to check the counter instead
of traversing through skb list.
the code always returns ret regardless, so if(ret) check is unecessary.
Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Adding new event that close RX BA session in case of periodic BT activity
limiting WLAN activity.
Signed-off-by: Shahar Levi <shahar_levi@ti.com>
In the case we fail to allocate a new skb, the old skb should
be resubmitted unmodified.
Fixes bug introduced in a9e12869758430424804.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Should pass along packet if there's no CRC and no hardware error.
Setting tx power can be deferred during scan or changing channel.
If after that correct tx power settings will not be sent to device,
we can observe transmission problems and timeouts. Force to send
tx power settings also after partial rxon change, to assure device
always be configured with up-to-date settings.
Resolves:
https://bugzilla.kernel.org/show_bug.cgi?id=36492
Avoid queue and run autowakeup_work when device is not present anymore.
That prevent rmmod and device remove crash introduced by:
commit 1c0bcf89d85cc97a0d9ce4cd909351a81fa4fdde
Author: Ivo van Doorn <ivdoorn@gmail.com>
Date: Sat Apr 30 17:18:18 2011 +0200
rt2x00: Add autowake support for USB hardware
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
This patch fixes 802.11n stability and performance regression we have
since 2.6.35. It boost performance on my 5GHz N-only network from about
5MB/s to 8MB/s. Similar percentage boost can be observed on 2.4 GHz.
These are test results of 5x downloading of approximately 700MB iso
image:
vanilla: 5.27 5.22 4.94 4.47 5.31 ; avr 5.0420 std 0.35110
patched: 8.07 7.95 8.06 7.99 7.96 ; avr 8.0060 std 0.055946
This was achieved with NetworkManager configured to do not perform
periodical scans, by configuring constant BSSID. With periodical scans,
after some time, performance downgrade to unpatched driver level, like
in example below:
patched: 7.40 7.61 4.28 4.37 4.80 avr 5.6920 std 1.6683
However patch still make better here, since similar test on unpatched
driver make link disconnects with below messages after some time:
wlan1: authenticate with 00:23:69:35:d1:3f (try 1)
wlan1: authenticate with 00:23:69:35:d1:3f (try 2)
wlan1: authenticate with 00:23:69:35:d1:3f (try 3)
wlan1: authentication with 00:23:69:35:d1:3f timed out
On 2.6.35 kernel patch helps against connection hangs with messages:
iwlagn 0000:20:00.0: queue 10 stuck 3 time. Fw reload.
iwlagn 0000:20:00.0: On demand firmware reload
iwlagn 0000:20:00.0: Stopping AGG while state not ON or starting
Cc: stable@kernel.org # 2.6.35+
No need to go though multiple levels of indirect call to send RXON command.
Call it directly
After driver split, no need to use function "ops" for post_scan.
Both tx power and power save are being done after scan complete, move into
post_scan function
For some timing reason, 1000 device having problem to kick-in to aggregation
without sending rxon assoc command. This is a W/A until find the real reason
When change smps mode due to bt coex, save it
lq_sta has other null checks in this function.
assuming they are correct, this additional null check
should be added too.
Incorporating suggestion from Gustavo Padovan.
propogate the return value from iwl4965_get_tx_atten_grp instead
of implicitly returning -EINVAL in the error case.
Cleanup the code to return -EINVAL instead of -1
return; at the end of the function is unecessary.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
It does nothing useful yet, so it is matched as BROKEN.
For now this is just an option for b43, in future we may want to make
b43 support SSB or BCMA (note: or, not xor).
Luckily the only flag we use when calling core reset is GMODE one.
Thanks to that we can just switch to single bool and make function calls
bus generic.
Tested on my BCM4312 (LP-PHY) and early tested with BCM43224.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Make sure all updates to a descriptor are flushed to memory
before assigning ownship to hardware.
Ownership of an rx buffer should only be given to the hardware
after all other changes are written, otherwise there's
a potential race.
Now power state transitions are not called from an
interrupt context, there's no need to block interrupts.
This code appears to block interrupts for too long,
causing my trackpad to lose sync occasionally.
This removes the need to use IRQ safe spinlocks in many places.
