path: root/drivers/net/zorro8390.c
2006-03-25[PATCH] amiga: fix driver_register() return handling, remove zorro_module_init()Bjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. zorro_module_init() used the device count to automatically unregister and unload drivers that found no devices. That might have worked at one time, but has been broken for some time because zorro_register_driver() returned either a negative error or a positive count (never zero). So it could only unregister on failure, when it's not needed anyway. This functionality could be resurrected in individual drivers by counting devices in their .probe() methods. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
