[ Upstream commit a3daf3d39132b405781be8d9ede0c449b244b64e ]
In case of a common event for rx and tx queue the event should be
regarded to be spurious if no rx and no tx requests are pending.
Unfortunately the condition for testing that is wrong causing to
decide a event being spurious if no rx OR no tx requests are
pending.
Fix that plus using local variables for rx/tx pending indicators in
order to split function calls and if condition.
Fixes: 23025393dbeb3b ("xen/netback: use lateeoi irq binding")
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Paul Durrant <paul@xen.org>
Reviewed-by: Wei Liu <wl@xen.org>
commit 23025393dbeb3b8b3b60ebfa724cdae384992e27 upstream.
In order to reduce the chance for the system becoming unresponsive due
to event storms triggered by a misbehaving netfront use the lateeoi
irq binding for netback and unmask the event channel only just before
going to sleep waiting for new events.
Make sure not to issue an EOI when none is pending by introducing an
eoi_pending element to struct xenvif_queue.
When no request has been consumed set the spurious flag when sending
the EOI for an interrupt.
This is part of XSA-332.
Cc: stable@vger.kernel.org
Reported-by: Julien Grall <julien@xen.org>
xenvif_connect_data() calls module_put() in case of error. This is
wrong as there is no related module_get().
Remove the superfluous module_put().
Fixes: 279f438e36c0a7 ("xen-netback: Don't destroy the netdev until the vif is shut down")
Cc: <stable@vger.kernel.org> # 3.12
Reviewed-by: Wei Liu <wei.liu@kernel.org>
The variable err is assigned with the value -ENOMEM that is never
read and it is re-assigned a new value later on. The assignment is
redundant and can be removed.
Addresses-Coverity: ("Unused value")
Acked-by: Wei Liu <wei.liu2@citrix.com>
After the previous patch, all the callers of ndo_select_queue()
provide as a 'fallback' argument netdev_pick_tx.
The only exceptions are nested calls to ndo_select_queue(),
which pass down the 'fallback' available in the current scope
- still netdev_pick_tx.
We can drop such argument and replace fallback() invocation with
netdev_pick_tx(). This avoids an indirect call per xmit packet
in some scenarios (TCP syn, UDP unconnected, XDP generic, pktgen)
with device drivers implementing such ndo. It also clean the code
a bit.
Tested with ixgbe and CONFIG_FCOE=m
With pktgen using queue xmit:
threads vanilla patched
(kpps) (kpps)
1 2334 2428
2 4166 4278
4 7895 8100
v1 -> v2:
- rebased after helper's name change
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Occasionally, during the disconnection procedure on XenBus which
includes hash cache deinitialization there might be some packets
still in-flight on other processors. Handling of these packets includes
hashing and hash cache population that finally results in hash cache
data structure corruption.
In order to avoid this we prevent hashing of those packets if there
are no queues initialized. In that case RCU protection of queues guards
the hash cache as well.
Signed-off-by: Igor Druzhinin <igor.druzhinin@citrix.com>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
Minor conflict in net/core/rtnetlink.c, David Ahern's bug fix in 'net'
overlapped the renaming of a netlink attribute in net-next.
The method ndo_start_xmit() is defined as returning an 'netdev_tx_t',
which is a typedef for an enum type, so make sure the implementation in
this driver has returns 'netdev_tx_t' value, and change the function
return type to netdev_tx_t.
Found by coccinelle.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Checking them before the grant copy means nothing as to the validity of
the incoming request. As we shouldn't make the new data live before
having validated it, introduce a second instance of the mapping array.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
For most of these calls we can just pass NULL through to the fallback
function as the sb_dev. The only cases where we cannot are the cases where
we might be dealing with either an upper device or a driver that would
have configured things to support an sb_dev itself.
The only driver that has any significant change in this patch set should be
ixgbe as we can drop the redundant functionality that existed in both the
ndo_select_queue function and the fallback function that was passed through
to us.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
This patch makes it so that instead of passing a void pointer as the
accel_priv we instead pass a net_device pointer as sb_dev. Making this
change allows us to pass the subordinate device through to the fallback
function eventually so that we can keep the actual code in the
ndo_select_queue call as focused on possible on the exception cases.
Using a period after a newline causes bad output.
There were quite a few overlapping sets of changes here.
Daniel's bug fix for off-by-ones in the new BPF branch instructions,
along with the added allowances for "data_end > ptr + x" forms
collided with the metadata additions.
Along with those three changes came veritifer test cases, which in
their final form I tried to group together properly. If I had just
trimmed GIT's conflict tags as-is, this would have split up the
meta tests unnecessarily.
In the socketmap code, a set of preemption disabling changes
overlapped with the rename of bpf_compute_data_end() to
bpf_compute_data_pointers().
Changes were made to the mv88e6060.c driver set addr method
which got removed in net-next.
The hyperv transport socket layer had a locking change in 'net'
which overlapped with a change of socket state macro usage
in 'net-next'.
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Paul Durrant <paul.durrant@citrix.com>
Cc: xen-devel@lists.xenproject.org
Cc: netdev@vger.kernel.org
RFC791 specifies the minimum MTU to be 68, while xen-net{front|back}
drivers use a minimum value of 0.
When set MTU to 0~67 with xen_net{front|back} driver, the network
will become unreachable immediately, the guest can no longer be pinged.
xen_net{front|back} should not allow the user to set this value which causes
network problems.
Reported-by: Chen Shi <cheshi@redhat.com>
Signed-off-by: Mohammed Gamal <mgamal@redhat.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Use setup_timer function instead of initializing timer with the
function and data fields.
Signed-off-by: Allen Pais <allen.lkml@gmail.com>
The xen driver initializes struct ubuf_info fields using designated
initializers. I recently moved these fields inside a nested anonymous
struct inside an anonymous union. I had missed this use case.
This breaks compilation of xen-netback with older compilers.
>From kbuild bot with gcc-4.4.7:
drivers/net//xen-netback/interface.c: In function
'xenvif_init_queue':
>> drivers/net//xen-netback/interface.c:554: error: unknown field 'ctx' specified in initializer
>> drivers/net//xen-netback/interface.c:554: warning: missing braces around initializer
drivers/net//xen-netback/interface.c:554: warning: (near initialization for '(anonymous).<anonymous>')
>> drivers/net//xen-netback/interface.c:554: warning: initialization makes integer from pointer without a cast
>> drivers/net//xen-netback/interface.c:555: error: unknown field 'desc' specified in initializer
Add double braces around the designated initializers to match their
nested position in the struct. After this, compilation succeeds again.
Fixes: 4ab6c99d99bb ("sock: MSG_ZEROCOPY notification coalescing")
Reported-by: kbuild bot <lpk@intel.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Add a flag to indicate if a queue is rate-limited. Test the flag in
NAPI poll handler and avoid rescheduling the queue if true, otherwise
we risk locking up the host. The rescheduling will be done in the
timer callback function.
Reported-by: Jean-Louis Dupond <jean-louis@dupond.be>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Tested-by: Jean-Louis Dupond <jean-louis@dupond.be>
In some cases during XenBus disconnect event handling and subsequent
queue resource release there may be some TX handlers active on
other processors. Use RCU in order to synchronize with them.
related APIs from <linux/sched.h> to <linux/sched/task.h>
But first update usage sites with the new header dependency.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
This patch fixes an issue where the type of counters in the queue(s)
and interface are not in sync (queue counters are int, interface
counters are long), causing incorrect reporting of tx/rx values
of the vif interface and unclear counter overflows.
This patch sets both counters to the u64 type.
Signed-off-by: Mart van Santen <mart@greenhost.nl>
napi_complete_done() allows to opt-in for gro_flush_timeout,
added back in linux-3.19, commit 3b47d30396ba
("net: gro: add a per device gro flush timer")
This allows for more efficient GRO aggregation without
sacrifying latencies.
vif->lock is used to protect statistics gathering agents from using the
queue structure during cleaning.
hyperv_net:
- set min/max_mtu, per Haiyang, after rndis_filter_device_add
virtio_net:
- set min/max_mtu
- remove virtnet_change_mtu
vmxnet3:
- set min/max_mtu
xen-netback:
- min_mtu = 0, max_mtu = 65517
xen-netfront:
- min_mtu = 0, max_mtu = 65535
unisys/visor:
- clean up defines a little to not clash with network core or add
redundat definitions
CC: netdev@vger.kernel.org
CC: virtualization@lists.linux-foundation.org
CC: "K. Y. Srinivasan" <kys@microsoft.com>
CC: Haiyang Zhang <haiyangz@microsoft.com>
CC: "Michael S. Tsirkin" <mst@redhat.com>
CC: Shrikrishna Khare <skhare@vmware.com>
CC: "VMware, Inc." <pv-drivers@vmware.com>
CC: Wei Liu <wei.liu2@citrix.com>
CC: Paul Durrant <paul.durrant@citrix.com>
CC: David Kershner <david.kershner@unisys.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
In the case when a frontend only negotiates a single queue with xen-
netback it is possible for a skbuff with a s/w hash to result in a
hash extra_info segment being sent to the frontend even when no hash
algorithm has been configured. (The ndo_select_queue() entry point makes
sure the hash is not set if no algorithm is configured, but this entry
point is not called when there is only a single queue). This can result
in a frontend that is unable to handle extra_info segments being given
such a segment, causing it to crash.
This patch fixes the problem by clearing the hash in ndo_start_xmit()
instead, which is clearly guaranteed to be called irrespective of the
number of queues.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
This allows full 64K skbuffs (with 1500 mtu ethernet, composed of 45
fragments) to be handled by netback for to-guest rx.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
[re-based]
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
As far as I am aware only very old Windows network frontends make use of
this style of passing GSO packets from backend to frontend. These
frontends can easily be replaced by the freely available Xen Project
Windows PV network frontend, which uses the 'default' mechanism for
passing GSO packets, which is also used by all Linux frontends.
NOTE: Removal of this feature will not cause breakage in old Windows
frontends. They simply will no longer receive GSO packets - the
packets instead being fragmented in the backend.
Instead of open coding it use the threaded irq mechanism in
xen-netback.
A domain with a frontend that does not implement a control ring has been
seen to cause a crash during domain save. This was apparently because
the call to xenvif_deinit_hash() in xenvif_disconnect_ctrl() is made
regardless of whether a control ring was connected, and hence
xenvif_hash_init() was called.
This patch brings the call to xenvif_deinit_hash() in
xenvif_disconnect_ctrl() inside the if clause that checks whether the
control ring event channel was connected. This is sufficient to ensure
it is only called if xenvif_init_hash() was called previously.
Reported-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
My recent patch to include/xen/interface/io/netif.h defines a new extra
info type that can be used to pass hash values between backend and guest
frontend.
This patch adds code to xen-netback to pass hash values calculated for
guest receive-side packets (i.e. netback transmit side) to the frontend.
My recent patch to include/xen/interface/io/netif.h defines a new shared
ring (in addition to the rx and tx rings) for passing control messages
from a VM frontend driver to a backend driver.
A previous patch added the necessary boilerplate for mapping the control
ring from the frontend, should it be created. This patch adds
implementations for each of the defined protocol messages.
This patch adds the necessary code to xen-netback to map this new shared
ring, should it be created by a frontend, but does not add implementations
for any of the defined protocol messages. These are added in a subsequent
patch for clarity.
If a queue still has a NAPI instance added to the net device, freeing
the queues early results in a use-after-free.
The shouldn't ever happen because we disconnect and tear down all queues
before freeing the net device, but doing this makes it obviously safe.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
When xenvif_connect() fails it may leave a stale NAPI instance added to
the device. Make sure we delete it in the error path.
Xen's PV network protocol includes messages to add/remove ethernet
multicast addresses to/from a filter list in the backend. This allows
the frontend to request the backend only forward multicast packets
which are of interest thus preventing unnecessary noise on the shared
ring.
The canonical netif header in git://xenbits.xen.org/xen.git specifies
the message format (two more XEN_NETIF_EXTRA_TYPEs) so the minimal
necessary changes have been pulled into include/xen/interface/io/netif.h.
To prevent the frontend from extending the multicast filter list
arbitrarily a limit (XEN_NETBK_MCAST_MAX) has been set to 64 entries.
This limit is not specified by the protocol and so may change in future.
If the limit is reached then the next XEN_NETIF_EXTRA_TYPE_MCAST_ADD
sent by the frontend will be failed with NETIF_RSP_ERROR.
Cc: Ian Campbell <ian.campbell@citrix.com>
Waking the dealloc thread before decrementing inflight_packets is racy
because it means the thread may go to sleep before inflight_packets is
decremented. If kthread_stop() has already been called, the dealloc
thread may wait forever with nothing to wake it. Instead, wake the
thread only after decrementing inflight_packets.
With the current netback, the bandwidth limiter's parameters are only
settable during vif setup time. This patch register a watch on them, and
thus makes them runtime changeable.
When the watch fires, the timer is reset. The timer's mutex is used for
fencing the change.
Cc: Anthony Liguori <aliguori@amazon.com>
Signed-off-by: Imre Palik <imrep@amazon.de>
drivers/net/ethernet/cadence/macb.c
Overlapping changes in macb driver, mostly fixes and cleanups
in 'net' overlapping with the integration of at91_ether into
macb in 'net-next'.
Use correct pointer arithmetic to get the pointer to each stat.
Use the built-in function instead of memset.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Pull networking updates from David Miller:
1) More iov_iter conversion work from Al Viro.
[ The "crypto: switch af_alg_make_sg() to iov_iter" commit was
wrong, and this pull actually adds an extra commit on top of the
branch I'm pulling to fix that up, so that the pre-merge state is
ok. - Linus ]
2) Various optimizations to the ipv4 forwarding information base trie
lookup implementation. From Alexander Duyck.
3) Remove sock_iocb altogether, from CHristoph Hellwig.
4) Allow congestion control algorithm selection via routing metrics.
From Daniel Borkmann.
5) Make ipv4 uncached route list per-cpu, from Eric Dumazet.
6) Handle rfs hash collisions more gracefully, also from Eric Dumazet.
7) Add xmit_more support to r8169, e1000, and e1000e drivers. From
Florian Westphal.
8) Transparent Ethernet Bridging support for GRO, from Jesse Gross.
9) Add BPF packet actions to packet scheduler, from Jiri Pirko.
10) Add support for uniqu flow IDs to openvswitch, from Joe Stringer.
11) New NetCP ethernet driver, from Muralidharan Karicheri and Wingman
Kwok.
12) More sanely handle out-of-window dupacks, which can result in
serious ACK storms. From Neal Cardwell.
13) Various rhashtable bug fixes and enhancements, from Herbert Xu,
Patrick McHardy, and Thomas Graf.
14) Support xmit_more in be2net, from Sathya Perla.
15) Group Policy extensions for vxlan, from Thomas Graf.
16) Remove Checksum Offload support for vxlan, from Tom Herbert.
17) Like ipv4, support lockless transmit over ipv6 UDP sockets. From
Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1494+1 commits)
crypto: fix af_alg_make_sg() conversion to iov_iter
ipv4: Namespecify TCP PMTU mechanism
i40e: Fix for stats init function call in Rx setup
tcp: don't include Fast Open option in SYN-ACK on pure SYN-data
openvswitch: Only set TUNNEL_VXLAN_OPT if VXLAN-GBP metadata is set
ipv6: Make __ipv6_select_ident static
ipv6: Fix fragment id assignment on LE arches.
bridge: Fix inability to add non-vlan fdb entry
net: Mellanox: Delete unnecessary checks before the function call "vunmap"
cxgb4: Add support in cxgb4 to get expansion rom version via ethtool
ethtool: rename reserved1 memeber in ethtool_drvinfo for expansion ROM version
net: dsa: Remove redundant phy_attach()
IB/mlx4: Reset flow support for IB kernel ULPs
IB/mlx4: Always use the correct port for mirrored multicast attachments
net/bonding: Fix potential bad memory access during bonding events
tipc: remove tipc_snprintf
tipc: nl compat add noop and remove legacy nl framework
tipc: convert legacy nl stats show to nl compat
tipc: convert legacy nl net id get to nl compat
tipc: convert legacy nl net id set to nl compat
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen features and fixes from David Vrabel:
- Reworked handling for foreign (grant mapped) pages to simplify the
code, enable a number of additional use cases and fix a number of
long-standing bugs.
- Prefer the TSC over the Xen PV clock when dom0 (and the TSC is
stable).
- Assorted other cleanup and minor bug fixes.
* tag 'stable/for-linus-3.20-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (25 commits)
xen/manage: Fix USB interaction issues when resuming
xenbus: Add proper handling of XS_ERROR from Xenbus for transactions.
xen/gntdev: provide find_special_page VMA operation
xen/gntdev: mark userspace PTEs as special on x86 PV guests
xen-blkback: safely unmap grants in case they are still in use
xen/gntdev: safely unmap grants in case they are still in use
xen/gntdev: convert priv->lock to a mutex
xen/grant-table: add a mechanism to safely unmap pages that are in use
xen-netback: use foreign page information from the pages themselves
xen: mark grant mapped pages as foreign
xen/grant-table: add helpers for allocating pages
x86/xen: require ballooned pages for grant maps
xen: remove scratch frames for ballooned pages and m2p override
xen/grant-table: pre-populate kernel unmap ops for xen_gnttab_unmap_refs()
mm: add 'foreign' alias for the 'pinned' page flag
mm: provide a find_special_page vma operation
x86/xen: cleanup arch/x86/xen/mmu.c
x86/xen: add some __init annotations in arch/x86/xen/mmu.c
x86/xen: add some __init and static annotations in arch/x86/xen/setup.c
x86/xen: use correct types for addresses in arch/x86/xen/setup.c
this patch fixes following sparse warning:
interface.c:83:5: warning: symbol 'xenvif_poll' was not declared. Should it be static?
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
After commit e9d8b2c2968499c1f96563e6522c56958d5a1d0d (xen-netback:
disable rogue vif in kthread context), a fatal (protocol) error would
leave the guest Rx thread spinning, wasting CPU time. Commit
ecf08d2dbb96d5a4b4bcc53a39e8d29cc8fef02e (xen-netback: reintroduce
guest Rx stall detection) made this even worse by removing a
cond_resched() from this path.
Since a fatal error is non-recoverable, just allow the guest Rx thread
to exit. This requires taking additional refs to the task so the
thread exiting early is handled safely.
Reported-by: Julien Grall <julien.grall@linaro.org>
Tested-by: Julien Grall <julien.grall@linaro.org>
Add gnttab_alloc_pages() and gnttab_free_pages() to allocate/free pages
suitable to for granted maps.
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Commit bc96f648df1bbc2729abbb84513cf4f64273a1f1 (xen-netback: make
feature-rx-notify mandatory) incorrectly assumed that there were no
frontends in use that did not support this feature. But the frontend
driver in MiniOS does not and since this is used by (qemu) stubdoms,
these stopped working.
Netback sort of works as-is in this mode except:
- If there are no Rx requests and the internal Rx queue fills, only
the drain timeout will wake the thread. The default drain timeout
of 10 s would give unacceptable pauses.
- If an Rx stall was detected and the internal Rx queue is drained,
then the Rx thread would never wake.
Handle these two cases (when feature-rx-notify is disabled) by:
- Reducing the drain timeout to 30 ms.
- Disabling Rx stall detection.
Reported-by: John <jw@nuclearfallout.net>
Tested-by: John <jw@nuclearfallout.net>
Reviewed-by: Wei Liu <wei.liu2@citrix.com>
drivers/net/phy/marvell.c
Simple overlapping changes in drivers/net/phy/marvell.c
Otherwise the interrupt handler still calls napi_complete. Although it
won't schedule NAPI again as either NAPI_STATE_DISABLE or
NAPI_STATE_SCHED is set, it is just unnecessary, and it makes more
sense to do this way.
Signed-off-by: Zoltan Kiss <zoltan.kiss@linaro.org>
If a frontend not receiving packets it is useful to detect this and
turn off the carrier so packets are dropped early instead of being
queued and drained when they expire.
A to-guest queue is stalled if it doesn't have enough free slots for a
an extended period of time (default 60 s).
If at least one queue is stalled, the carrier is turned off (in the
expectation that the other queues will soon stall as well). The
carrier is only turned on once all queues are ready.
When the frontend connects, all the queues start in the stalled state
and only become ready once the frontend queues enough Rx requests.
