With a recent change now it is possible to detect the strapping
option on SD8997, which allows to pick up a correct firmware
for either SDIO-SDIO or SDIO-UART.
This commit enables SDIO-UART firmware on SD8997.
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Signed-off-by: Kalle Valo <kvalo@kernel.org>
Link: https://lore.kernel.org/r/20220422090313.125857-3-andrejs.cainikovs@toradex.com
Upstream-Status: Backport [562354ab9f0aa4fcd8f2184506dcb9c18a792182]
Some WiFi/Bluetooth modules might have different host connection
options, allowing to either use SDIO for both WiFi and Bluetooth,
or SDIO for WiFi and UART for Bluetooth. It is possible to detect
whether a module has SDIO-SDIO or SDIO-UART connection by reading
its host strap register.
This change introduces a way to automatically select appropriate
firmware depending of the connection method, and removes a need
of symlinking or overwriting the original firmware file with a
required one.
Host strap register used in this commit comes from the NXP driver [1]
hosted at Code Aurora.
[1] https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/net/wireless/nxp/mxm_wifiex/wlan_src/mlinux/moal_sdio_mmc.c?h=rel_imx_5.4.70_2.3.2&id=688b67b2c7220b01521ffe560da7eee33042c7bd#n1274
Reviewed-by: Alvin Šipraga <alsi@bang-olufsen.dk>
Link: https://lore.kernel.org/r/20220422090313.125857-2-andrejs.cainikovs@toradex.com
Upstream-Status: Backport [255ca28a659d3cfb069f73c7644853ed93aecdb0]
[ Upstream commit 6fb3a5868b2117611f41e421e10e6a8c2a13039a ]
Fix:
drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c: In function ‘brcmf_sdio_drivestrengthinit’:
drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c:3798:2: error: case label does not reduce to an integer constant
case SDIOD_DRVSTR_KEY(BRCM_CC_43143_CHIP_ID, 17):
drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c:3809:2: error: case label does not reduce to an integer constant
case SDIOD_DRVSTR_KEY(BRCM_CC_43362_CHIP_ID, 13):
See https://lore.kernel.org/r/YkwQ6%2BtIH8GQpuct@zn.tnic for the gory
details as to why it triggers with older gccs only.
Cc: Arend van Spriel <aspriel@gmail.com>
Cc: Franky Lin <franky.lin@broadcom.com>
Cc: Hante Meuleman <hante.meuleman@broadcom.com>
Cc: Kalle Valo <kvalo@kernel.org>
Cc: Jakub Kicinski <kuba@kernel.org>
Cc: brcm80211-dev-list.pdl@broadcom.com
Cc: netdev@vger.kernel.org
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Link: https://lore.kernel.org/r/Ykx0iRlvtBnKqtbG@zn.tnic
[ Upstream commit dbc2b1764734857d68425468ffa8486e97ab89df ]
Fix:
drivers/net/wireless/mediatek/mt76/mt76x2/pci.c: In function ‘mt76x2e_probe’:
././include/linux/compiler_types.h:352:38: error: call to ‘__compiletime_assert_946’ \
declared with attribute error: FIELD_PREP: mask is not constant
_compiletime_assert(condition, msg, __compiletime_assert_, __COUNTER__)
Cc: Felix Fietkau <nbd@nbd.name>
Cc: Lorenzo Bianconi <lorenzo.bianconi83@gmail.com>
Cc: Ryder Lee <ryder.lee@mediatek.com>
Cc: Shayne Chen <shayne.chen@mediatek.com>
Cc: Sean Wang <sean.wang@mediatek.com>
Cc: linux-wireless@vger.kernel.org
Link: https://lore.kernel.org/r/20220405151517.29753-9-bp@alien8.de
commit 5a6b06f5927c940fa44026695779c30b7536474c upstream.
The ieee80211_tx_info_clear_status() helper also clears the rate counts and
the driver-private part of struct ieee80211_tx_info, so using it breaks
quite a few other things. So back out of using it, and instead define a
ath-internal helper that only clears the area between the
status_driver_data and the rates info. Combined with moving the
ath_frame_info struct to status_driver_data, this avoids clearing anything
we shouldn't be, and so we can keep the existing code for handling the rate
information.
While fixing this I also noticed that the setting of
tx_info->status.rates[tx_rateindex].count on hardware underrun errors was
always immediately overridden by the normal setting of the same fields, so
rearrange the code so that the underrun detection actually takes effect.
The new helper could be generalised to a 'memset_between()' helper, but
leave it as a driver-internal helper for now since this needs to go to
stable.
Cc: stable@vger.kernel.org
Reported-by: Peter Seiderer <ps.report@gmx.net>
Fixes: 037250f0a45c ("ath9k: Properly clear TX status area before reporting to mac80211")
Signed-off-by: Toke Høiland-Jørgensen <toke@redhat.com>
Reviewed-by: Peter Seiderer <ps.report@gmx.net>
Tested-by: Peter Seiderer <ps.report@gmx.net>
Link: https://lore.kernel.org/r/20220404204800.2681133-1-toke@toke.dk
commit 037250f0a45cf9ecf5b52d4b9ff8eadeb609c800 upstream.
The ath9k driver was not properly clearing the status area in the
ieee80211_tx_info struct before reporting TX status to mac80211. Instead,
it was manually filling in fields, which meant that fields introduced later
were left as-is.
Conveniently, mac80211 actually provides a helper to zero out the status
area, so use that to make sure we zero everything.
The last commit touching the driver function writing the status information
seems to have actually been fixing an issue that was also caused by the
area being uninitialised; but it only added clearing of a single field
instead of the whole struct. That is now redundant, though, so revert that
commit and use it as a convenient Fixes tag.
Fixes: cc591d77aba1 ("ath9k: Make sure to zero status.tx_time before reporting TX status")
Reported-by: Bagas Sanjaya <bagasdotme@gmail.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Toke Høiland-Jørgensen <toke@toke.dk>
Tested-by: Bagas Sanjaya <bagasdotme@gmail.com>
Link: https://lore.kernel.org/r/20220330164409.16645-1-toke@toke.dk
[ Upstream commit 10cb21f4ff3f9cb36d1e1c39bf80426f02f4986a ]
This reverts commit 743b9065fe6348a5f8f5ce04869ce2d701e5e1bc.
The original commit breaks the 256 bitmap in blockack frames in AP
mode. After reverting the commit the feature works again in both AP and
mesh modes
Tested-on: IPQ8074 hw2.0 PCI WLAN.HK.2.6.0.1-00786-QCAHKSWPL_SILICONZ-1
Fixes: 743b9065fe63 ("ath11k: mesh: add support for 256 bitmap in blockack frames in 11ax")
Signed-off-by: Anilkumar Kolli <quic_akolli@quicinc.com>
Link: https://lore.kernel.org/r/1648701477-16367-1-git-send-email-quic_akolli@quicinc.com
[ Upstream commit 123bc712b1de0805f9d683687e17b1ec2aba0b68 ]
mt7921s driver may receive frames with fragment buffers. If there is a
CTS packet received in monitor mode, the payload is 10 bytes only and
need 6 bytes header padding after RXD buffer. However, only RXD in the
first linear buffer, if we pull buffer size RXD-size+6 bytes with
skb_pull(), that would trigger "BUG_ON(skb->len < skb->data_len)" in
__skb_pull().
To avoid the nonlinear buffer issue, enlarge the RXD size from 128 to
256 to make sure all MCU operation in linear buffer.
[ 52.007562] kernel BUG at include/linux/skbuff.h:2313!
[ 52.007578] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 52.007987] pc : skb_pull+0x48/0x4c
[ 52.008015] lr : mt7921_queue_rx_skb+0x494/0x890 [mt7921_common]
[ 52.008361] Call trace:
[ 52.008377] skb_pull+0x48/0x4c
[ 52.008400] mt76s_net_worker+0x134/0x1b0 [mt76_sdio 35339a92c6eb7d4bbcc806a1d22f56365565135c]
[ 52.008431] __mt76_worker_fn+0xe8/0x170 [mt76 ef716597d11a77150bc07e3fdd68eeb0f9b56917]
[ 52.008449] kthread+0x148/0x3ac
[ 52.008466] ret_from_fork+0x10/0x30
Signed-off-by: Lorenzo Bianconi <lorenzo@kernel.org>
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Signed-off-by: Deren Wu <deren.wu@mediatek.com>
Signed-off-by: Felix Fietkau <nbd@nbd.name>
[ Upstream commit 9273ffcc9a11942bd586bb42584337ef3962b692 ]
Smatch reports the following:
drivers/net/wireless/mediatek/mt76/mt7615/mac.c:1865
mt7615_mac_adjust_sensitivity() warn: assigning (-110) to unsigned
variable 'def_th'
mt7615_mac_adjust_sensitivity() warn: assigning (-98) to unsigned
variable 'def_th'
Reported-by: Abaci Robot <abaci@linux.alibaba.com>
Signed-off-by: Yang Li <yang.lee@linux.alibaba.com>
[ Upstream commit 28225a6ef80ebf46c46e5fbd5b1ee231a0b2b5b7 ]
Before, the hardware would be allowed to transmit injected 802.11 MPDUs
as A-MSDU. This resulted in corrupted frames being transmitted. Now,
injected MPDUs are transmitted as-is, without A-MSDU.
The fix was verified with frame injection on MT7915 hardware, both with
and without the injected frame being encrypted.
If the hardware cannot do A-MSDU aggregation on MPDUs, this problem
would also be present in the TX path where mac80211 does the 802.11
encapsulation. However, I have not observed any such problem when
disabling IEEE80211_HW_SUPPORTS_TX_ENCAP_OFFLOAD to force that mode.
Therefore this fix is isolated to injected frames only.
The same A-MSDU logic is also present in the mt7921 driver, so it is
likely that this fix should be applied there too. I do not have access
to mt7921 hardware so I have not been able to test that.
Signed-off-by: Johan Almbladh <johan.almbladh@anyfinetworks.com>
[ Upstream commit e04135c07755d001b5cde61048c69a7cc84bb94b ]
During disassociation we're decreasing the phy's ref count.
If the ref count becomes 0, we're configuring the phy ctxt
to the default channel (the lowest channel which the device
can operate on). Currently we're not checking whether the
the default channel is enabled or not. Fix it by configuring
the phy ctxt to the lowest channel which is enabled.
Signed-off-by: Miri Korenblit <miriam.rachel.korenblit@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Link: https://lore.kernel.org/r/iwlwifi.20220210181930.03f281b6a6bc.I5b63d43ec41996d599e6f37ec3f32e878b3e405e@changeid
[ Upstream commit d8d4dd26b9e0469baf5017f0544d852fd4e3fb6d ]
Currently, fragmented EBS was set for a channel only if the 'hb_type'
was set to fragmented or balanced scan. However, 'hb_type' is set only
in case of CDB, and thus fragmented EBS is never set for a channel for
non-CDB devices. Fix it.
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
Link: https://lore.kernel.org/r/iwlwifi.20220204122220.a6165ac9b9d5.I654eafa62fd647030ae6d4f07f32c96c3171decb@changeid
[ Upstream commit 577298ec55dfc8b9aece54520f0258c3f93a6573 ]
Even if it is only a false-positive since skip_buf0/skip_buf1 are only
used in mt76_dma_tx_cleanup_idx routine, initialize skip_unmap in
mt76_dma_rx_fill in order to fix the following UBSAN report:
[ 13.924906] UBSAN: invalid-load in linux-5.15.0/drivers/net/wireless/mediatek/mt76/dma.c:162:13
[ 13.924909] load of value 225 is not a valid value for type '_Bool'
[ 13.924912] CPU: 9 PID: 672 Comm: systemd-udevd Not tainted 5.15.0-18-generic #18-Ubuntu
[ 13.924914] Hardware name: LENOVO 21A0000CMX/21A0000CMX, BIOS R1MET43W (1.13 ) 11/05/2021
[ 13.924915] Call Trace:
[ 13.924917] <TASK>
[ 13.924920] show_stack+0x52/0x58
[ 13.924925] dump_stack_lvl+0x4a/0x5f
[ 13.924931] dump_stack+0x10/0x12
[ 13.924932] ubsan_epilogue+0x9/0x45
[ 13.924934] __ubsan_handle_load_invalid_value.cold+0x44/0x49
[ 13.924935] ? __iommu_dma_map+0x84/0xf0
[ 13.924939] mt76_dma_add_buf.constprop.0.cold+0x23/0x85 [mt76]
[ 13.924949] mt76_dma_rx_fill.isra.0+0x102/0x1f0 [mt76]
[ 13.924954] mt76_dma_init+0xc9/0x150 [mt76]
[ 13.924959] ? mt7921_dma_enable+0x110/0x110 [mt7921e]
[ 13.924966] mt7921_dma_init+0x1e3/0x260 [mt7921e]
[ 13.924970] mt7921_register_device+0x29d/0x510 [mt7921e]
[ 13.924975] mt7921_pci_probe.part.0+0x17f/0x1b0 [mt7921e]
[ 13.924980] mt7921_pci_probe+0x43/0x60 [mt7921e]
[ 13.924984] local_pci_probe+0x4b/0x90
[ 13.924987] pci_device_probe+0x115/0x1f0
[ 13.924989] really_probe+0x21e/0x420
[ 13.924992] __driver_probe_device+0x115/0x190
[ 13.924994] driver_probe_device+0x23/0xc0
[ 13.924996] __driver_attach+0xbd/0x1d0
[ 13.924998] ? __device_attach_driver+0x110/0x110
[ 13.924999] bus_for_each_dev+0x7e/0xc0
[ 13.925001] driver_attach+0x1e/0x20
[ 13.925003] bus_add_driver+0x135/0x200
[ 13.925005] driver_register+0x95/0xf0
[ 13.925008] ? 0xffffffffc0766000
[ 13.925010] __pci_register_driver+0x68/0x70
[ 13.925011] mt7921_pci_driver_init+0x23/0x1000 [mt7921e]
[ 13.925015] do_one_initcall+0x48/0x1d0
[ 13.925019] ? kmem_cache_alloc_trace+0x19e/0x2e0
[ 13.925022] do_init_module+0x62/0x280
[ 13.925025] load_module+0xac9/0xbb0
[ 13.925027] __do_sys_finit_module+0xbf/0x120
[ 13.925029] __x64_sys_finit_module+0x18/0x20
[ 13.925030] do_syscall_64+0x5c/0xc0
[ 13.925033] ? do_syscall_64+0x69/0xc0
[ 13.925034] ? sysvec_reschedule_ipi+0x78/0xe0
[ 13.925036] ? asm_sysvec_reschedule_ipi+0xa/0x20
[ 13.925039] entry_SYSCALL_64_after_hwframe+0x44/0xae
[ 13.925040] RIP: 0033:0x7fbf2b90f94d
[ 13.925045] RSP: 002b:00007ffe2ec7e5d8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 13.925047] RAX: ffffffffffffffda RBX: 000056106b0634e0 RCX: 00007fbf2b90f94d
[ 13.925048] RDX: 0000000000000000 RSI: 00007fbf2baa3441 RDI: 0000000000000013
[ 13.925049] RBP: 0000000000020000 R08: 0000000000000000 R09: 0000000000000002
[ 13.925050] R10: 0000000000000013 R11: 0000000000000246 R12: 00007fbf2baa3441
[ 13.925051] R13: 000056106b062620 R14: 000056106b0610c0 R15: 000056106b0640d0
[ 13.925053] </TASK>
[ Upstream commit 827e7799c61b978fbc2cc9dac66cb62401b2b3f0 ]
If the nic fails to start, it is possible that the
reset_work has already been scheduled. Ensure the
work item is canceled so we do not have use-after-free
crash in case cleanup is called before the work item
is executed.
This fixes crash on my x86_64 apu2 when mt7921k radio
fails to work. Radio still fails, but OS does not
crash.
Signed-off-by: Ben Greear <greearb@candelatech.com>
[ Upstream commit 3df6d74aedfdca919cca475d15dfdbc8b05c9e5d ]
If amss.bin was missing ath11k would crash during 'rmmod ath11k_pci'. The
reason for that was that we were using mhi_async_power_up() which does not
check any errors. But mhi_sync_power_up() on the other hand does check for
errors so let's use that to fix the crash.
I was not able to find a reason why an async version was used.
ath11k_mhi_start() (which enables state ATH11K_MHI_POWER_ON) is called from
ath11k_hif_power_up(), which can sleep. So sync version should be safe to use
here.
[ 145.569731] general protection fault, probably for non-canonical address 0xdffffc0000000000: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN PTI
[ 145.569789] KASAN: null-ptr-deref in range [0x0000000000000000-0x0000000000000007]
[ 145.569843] CPU: 2 PID: 1628 Comm: rmmod Kdump: loaded Tainted: G W 5.16.0-wt-ath+ #567
[ 145.569898] Hardware name: Intel(R) Client Systems NUC8i7HVK/NUC8i7HVB, BIOS HNKBLi70.86A.0067.2021.0528.1339 05/28/2021
[ 145.569956] RIP: 0010:ath11k_hal_srng_access_begin+0xb5/0x2b0 [ath11k]
[ 145.570028] Code: df 48 89 fa 48 c1 ea 03 80 3c 02 00 0f 85 ec 01 00 00 48 8b ab a8 00 00 00 48 b8 00 00 00 00 00 fc ff df 48 89 ea 48 c1 ea 03 <0f> b6 14 02 48 89 e8 83 e0 07 83 c0 03 45 85 ed 75 48 38 d0 7c 08
[ 145.570089] RSP: 0018:ffffc900025d7ac0 EFLAGS: 00010246
[ 145.570144] RAX: dffffc0000000000 RBX: ffff88814fca2dd8 RCX: 1ffffffff50cb455
[ 145.570196] RDX: 0000000000000000 RSI: ffff88814fca2dd8 RDI: ffff88814fca2e80
[ 145.570252] RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffffa8659497
[ 145.570329] R10: fffffbfff50cb292 R11: 0000000000000001 R12: ffff88814fca0000
[ 145.570410] R13: 0000000000000000 R14: ffff88814fca2798 R15: ffff88814fca2dd8
[ 145.570465] FS: 00007fa399988540(0000) GS:ffff888233e00000(0000) knlGS:0000000000000000
[ 145.570519] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 145.570571] CR2: 00007fa399b51421 CR3: 0000000137898002 CR4: 00000000003706e0
[ 145.570623] Call Trace:
[ 145.570675] <TASK>
[ 145.570727] ? ath11k_ce_tx_process_cb+0x34b/0x860 [ath11k]
[ 145.570797] ath11k_ce_tx_process_cb+0x356/0x860 [ath11k]
[ 145.570864] ? tasklet_init+0x150/0x150
[ 145.570919] ? ath11k_ce_alloc_pipes+0x280/0x280 [ath11k]
[ 145.570986] ? tasklet_clear_sched+0x42/0xe0
[ 145.571042] ? tasklet_kill+0xe9/0x1b0
[ 145.571095] ? tasklet_clear_sched+0xe0/0xe0
[ 145.571148] ? irq_has_action+0x120/0x120
[ 145.571202] ath11k_ce_cleanup_pipes+0x45a/0x580 [ath11k]
[ 145.571270] ? ath11k_pci_stop+0x10e/0x170 [ath11k_pci]
[ 145.571345] ath11k_core_stop+0x8a/0xc0 [ath11k]
[ 145.571434] ath11k_core_deinit+0x9e/0x150 [ath11k]
[ 145.571499] ath11k_pci_remove+0xd2/0x260 [ath11k_pci]
[ 145.571553] pci_device_remove+0x9a/0x1c0
[ 145.571605] __device_release_driver+0x332/0x660
[ 145.571659] driver_detach+0x1e7/0x2c0
[ 145.571712] bus_remove_driver+0xe2/0x2d0
[ 145.571772] pci_unregister_driver+0x21/0x250
[ 145.571826] __do_sys_delete_module+0x30a/0x4b0
[ 145.571879] ? free_module+0xac0/0xac0
[ 145.571933] ? lockdep_hardirqs_on_prepare.part.0+0x18c/0x370
[ 145.571986] ? syscall_enter_from_user_mode+0x1d/0x50
[ 145.572039] ? lockdep_hardirqs_on+0x79/0x100
[ 145.572097] do_syscall_64+0x3b/0x90
[ 145.572153] entry_SYSCALL_64_after_hwframe+0x44/0xae
Tested-on: WCN6855 hw2.0 PCI WLAN.HSP.1.1-03003-QCAHSPSWPL_V1_V2_SILICONZ_LITE-2
Signed-off-by: Kalle Valo <quic_kvalo@quicinc.com>
Link: https://lore.kernel.org/r/20220127090117.2024-2-kvalo@kernel.org
[ Upstream commit b4f4c56459a5c744f7f066b9fc2b54ea995030c5 ]
Mario reported that the kernel was crashing on suspend if ath11k was not able
to find a board file:
[ 473.693286] PM: Suspending system (s2idle)
[ 473.693291] printk: Suspending console(s) (use no_console_suspend to debug)
[ 474.407787] BUG: unable to handle page fault for address: 0000000000002070
[ 474.407791] #PF: supervisor read access in kernel mode
[ 474.407794] #PF: error_code(0x0000) - not-present page
[ 474.407798] PGD 0 P4D 0
[ 474.407801] Oops: 0000 [#1] PREEMPT SMP NOPTI
[ 474.407805] CPU: 2 PID: 2350 Comm: kworker/u32:14 Tainted: G W 5.16.0 #248
[ 474.407868] Call Trace:
[ 474.407870] <TASK>
[ 474.407874] ? _raw_spin_lock_irqsave+0x2a/0x60
[ 474.407882] ? lock_timer_base+0x72/0xa0
[ 474.407889] ? _raw_spin_unlock_irqrestore+0x29/0x3d
[ 474.407892] ? try_to_del_timer_sync+0x54/0x80
[ 474.407896] ath11k_dp_rx_pktlog_stop+0x49/0xc0 [ath11k]
[ 474.407912] ath11k_core_suspend+0x34/0x130 [ath11k]
[ 474.407923] ath11k_pci_pm_suspend+0x1b/0x50 [ath11k_pci]
[ 474.407928] pci_pm_suspend+0x7e/0x170
[ 474.407935] ? pci_pm_freeze+0xc0/0xc0
[ 474.407939] dpm_run_callback+0x4e/0x150
[ 474.407947] __device_suspend+0x148/0x4c0
[ 474.407951] async_suspend+0x20/0x90
dmesg-efi-164255130401001:
Oops#1 Part1
[ 474.407955] async_run_entry_fn+0x33/0x120
[ 474.407959] process_one_work+0x220/0x3f0
[ 474.407966] worker_thread+0x4a/0x3d0
[ 474.407971] kthread+0x17a/0x1a0
[ 474.407975] ? process_one_work+0x3f0/0x3f0
[ 474.407979] ? set_kthread_struct+0x40/0x40
[ 474.407983] ret_from_fork+0x22/0x30
[ 474.407991] </TASK>
The issue here is that board file loading happens after ath11k_pci_probe()
succesfully returns (ath11k initialisation happends asynchronously) and the
suspend handler is still enabled, of course failing as ath11k is not properly
initialised. Fix this by checking ATH11K_FLAG_QMI_FAIL during both suspend and
resume.
Reported-by: Mario Limonciello <mario.limonciello@amd.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=215504
Link: https://lore.kernel.org/r/20220127090117.2024-1-kvalo@kernel.org
[ Upstream commit 22b59cb965f79ee1accf83172441c9ca0ecb632a ]
Call netif_napi_del() from ath11k_ahb_free_ext_irq() to fix
the following kernel panic when unload/load ath11k modules
for few iterations.
[ 971.201365] Unable to handle kernel paging request at virtual address 6d97a208
[ 971.204227] pgd = 594c2919
[ 971.211478] [6d97a208] *pgd=00000000
[ 971.214120] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 971.412024] CPU: 2 PID: 4435 Comm: insmod Not tainted 5.4.89 #0
[ 971.434256] Hardware name: Generic DT based system
[ 971.440165] PC is at napi_by_id+0x10/0x40
[ 971.445019] LR is at netif_napi_add+0x160/0x1dc
[ 971.743127] (napi_by_id) from [<807d89a0>] (netif_napi_add+0x160/0x1dc)
[ 971.751295] (netif_napi_add) from [<7f1209ac>] (ath11k_ahb_config_irq+0xf8/0x414 [ath11k_ahb])
[ 971.759164] (ath11k_ahb_config_irq [ath11k_ahb]) from [<7f12135c>] (ath11k_ahb_probe+0x40c/0x51c [ath11k_ahb])
[ 971.768567] (ath11k_ahb_probe [ath11k_ahb]) from [<80666864>] (platform_drv_probe+0x48/0x94)
[ 971.779670] (platform_drv_probe) from [<80664718>] (really_probe+0x1c8/0x450)
[ 971.789389] (really_probe) from [<80664cc4>] (driver_probe_device+0x15c/0x1b8)
[ 971.797547] (driver_probe_device) from [<80664f60>] (device_driver_attach+0x44/0x60)
[ 971.805795] (device_driver_attach) from [<806650a0>] (__driver_attach+0x124/0x140)
[ 971.814822] (__driver_attach) from [<80662adc>] (bus_for_each_dev+0x58/0xa4)
[ 971.823328] (bus_for_each_dev) from [<80663a2c>] (bus_add_driver+0xf0/0x1e8)
[ 971.831662] (bus_add_driver) from [<806658a4>] (driver_register+0xa8/0xf0)
[ 971.839822] (driver_register) from [<8030269c>] (do_one_initcall+0x78/0x1ac)
[ 971.847638] (do_one_initcall) from [<80392524>] (do_init_module+0x54/0x200)
[ 971.855968] (do_init_module) from [<803945b0>] (load_module+0x1e30/0x1ffc)
[ 971.864126] (load_module) from [<803948b0>] (sys_init_module+0x134/0x17c)
[ 971.871852] (sys_init_module) from [<80301000>] (ret_fast_syscall+0x0/0x50)
Tested-on: IPQ8074 hw2.0 AHB WLAN.HK.2.6.0.1-00760-QCAHKSWPL_SILICONZ-1
Signed-off-by: Venkateswara Naralasetty <quic_vnaralas@quicinc.com>
Link: https://lore.kernel.org/r/1642583973-21599-1-git-send-email-quic_vnaralas@quicinc.com
[ Upstream commit 564d4eceb97eaf381dd6ef6470b06377bb50c95a ]
The bug was found during fuzzing. Stacktrace locates it in
ath5k_eeprom_convert_pcal_info_5111.
When none of the curve is selected in the loop, idx can go
up to AR5K_EEPROM_N_PD_CURVES. The line makes pd out of bound.
pd = &chinfo[pier].pd_curves[idx];
There are many OOB writes using pd later in the code. So I
added a sanity check for idx. Checks for other loops involving
AR5K_EEPROM_N_PD_CURVES are not needed as the loop index is not
used outside the loops.
The patch is NOT tested with real device.
The following is the fuzzing report
BUG: KASAN: slab-out-of-bounds in ath5k_eeprom_read_pcal_info_5111+0x126a/0x1390 [ath5k]
Write of size 1 at addr ffff8880174a4d60 by task modprobe/214
CPU: 0 PID: 214 Comm: modprobe Not tainted 5.6.0 #1
Call Trace:
dump_stack+0x76/0xa0
print_address_description.constprop.0+0x16/0x200
? ath5k_eeprom_read_pcal_info_5111+0x126a/0x1390 [ath5k]
__kasan_report.cold+0x37/0x7c
kasan_report+0xe/0x20
? apic_timer_interrupt+0xa/0x20
? ath5k_eeprom_init_11a_pcal_freq+0xbc0/0xbc0 [ath5k]
? ath5k_pci_eeprom_read+0x228/0x3c0 [ath5k]
ath5k_eeprom_init+0x2513/0x6290 [ath5k]
? usleep_range+0xb8/0x100
? ath5k_eeprom_read_pcal_info_2413+0x2f20/0x2f20 [ath5k]
ath5k_hw_init+0xb60/0x1970 [ath5k]
ath5k_init_ah+0x6fe/0x2530 [ath5k]
? kasprintf+0xa6/0xe0
? ath5k_stop+0x140/0x140 [ath5k]
? _dev_notice+0xf6/0xf6
ath5k_pci_probe.cold+0x29a/0x3d6 [ath5k]
? ath5k_pci_eeprom_read+0x3c0/0x3c0 [ath5k]
? mutex_lock+0x89/0xd0
local_pci_probe+0xd3/0x160
pci_device_probe+0x23f/0x3e0
? pci_device_remove+0x280/0x280
really_probe+0x209/0x5d0
Reported-by: Brendan Dolan-Gavitt <brendandg@nyu.edu>
Signed-off-by: Zekun Shen <bruceshenzk@gmail.com>
Link: https://lore.kernel.org/r/YckvDdj3mtCkDRIt@a-10-27-26-18.dynapool.vpn.nyu.edu
[ Upstream commit 849ee6ac9dd3efd0a57cbc98b9a9d6ae87374aff ]
Fix mt7921_queues_acq implementation according to the vendor sdk.
Fixes: 474a9f21e2e20 ("mt76: mt7921: add debugfs support")
[ Upstream commit 9747a78d5f758a5284751a10aee13c30d02bd5f1 ]
The device_node pointer is returned by of_parse_phandle() with refcount
incremented. We should use of_node_put() on it when done.
This function only calls of_node_put() in the regular path.
And it will cause refcount leak in error path.
Fixes: 727fec790ead ("ath10k: Setup the msa resources before qmi init")
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
Reviewed-by: Jeff Johnson <quic_jjohnson@quicinc.com>
Link: https://lore.kernel.org/r/20220308070238.19295-1-linmq006@gmail.com
[ Upstream commit 583d18336abdfb1b355270289ff8f6a2608ba905 ]
Return -ENODEV instead of success on this error path.
Fixes: dd36a507c806 ("iwlwifi: mvm: look for the first supported channel when add/remove phy ctxt")
Link: https://lore.kernel.org/r/20210816183930.GA2068@kili
[ Upstream commit c305c94bdc18e45b5ad1db54da4269f8cbfdff6b ]
Currently the error -EIO is being assinged to variable ret when
the READY_BIT is not set but the function iwlagn_mac_start returns
0 rather than ret. Fix this by returning ret instead of 0.
Addresses-Coverity: ("Unused value")
Fixes: 7335613ae27a ("iwlwifi: move all mac80211 related functions to one place")
Link: https://lore.kernel.org/r/20210907104658.14706-1-colin.king@canonical.com
[ Upstream commit ce014c9861544bb4e789323d0d8956a5ad262e25 ]
Due to preg protection we cannot write to this register
while FW is running (when FW in Halt it is ok).
since we have some cases that we need to dump this
region while FW is running remove this writing from DRV.
FW will do this writing.
Signed-off-by: Rotem Saado <rotem.saado@intel.com>
Fixes: 89639e06d0f3 ("iwlwifi: yoyo: support for new DBGI_SRAM region")
Link: https://lore.kernel.org/r/iwlwifi.20220129105618.209f3078bc74.I463530bd2f40daedb39f6d9df987bb7cee209033@changeid
[ Upstream commit 59e1221f470c2e5d2f2d4c95153edd577a7071c5 ]
Since commit a05829a7222e ("cfg80211: avoid holding the RTNL when
calling the driver") we're not only holding the RTNL when going
in and out of suspend, but also the wiphy->mtx. Add that to the
D3 test debugfs in iwlwifi since it's required for various calls
to mac80211.
Fixes: a05829a7222e ("cfg80211: avoid holding the RTNL when calling the driver")
Link: https://lore.kernel.org/r/iwlwifi.20220129105618.fcec0204e162.Ib73bf787ab4d83581de20eb89b1f8dbfcaaad0e3@changeid
[ Upstream commit 8a265d1a619c16400406c9d598411850ee104aed ]
We may not have all the interfaces added to the driver when we get the
THERMAL_DUAL_CHAIN_REQUEST notification from the FW, so instead of
iterating all vifs to update SMPS, iterate only the ones that are
already assigned. The interfaces that were not assigned yet, will be
updated accordingly when we start using them.
Fixes: 2a7ce54ccc23 ("iwlwifi: mvm: honour firmware SMPS requests")
Link: https://lore.kernel.org/r/iwlwifi.20220129105618.9416aade2ba0.I0b71142f89e3f158aa058a1dfb2517c8c1fa3726@changeid
[ Upstream commit 30d17c12b0895e15ce22ebc1f52a4ff02df6dbc6 ]
The recent fix for NULL sta in iwl_mvm_get_tx_rate() still has a call
of iwl_mvm_sta_from_mac80211() that may be called with NULL sta.
Although this practically only points to the address and the actual
access doesn't happen due to the conditional evaluation at a later
point, it looks a bit flaky.
This patch drops the temporary variable above and evaluates
iwm_mvm_sta_from_mac80211() directly for avoiding confusions.
Fixes: d599f714b73e ("iwlwifi: mvm: don't crash on invalid rate w/o STA")
Link: https://lore.kernel.org/r/20220121114024.10454-1-tiwai@suse.de
[ Upstream commit 6a6f457ed5fdf6777536c20644a9e42128a50ec2 ]
Check sta_rates pointer value in mt7615_sta_rate_tbl_update routine
since minstrel_ht_update_rates can fail allocating rates array.
Fixes: 04b8e65922f63 ("mt76: add mac80211 driver for MT7615 PCIe-based chipsets")
[ Upstream commit fc8e2c707ce11c8ec2e992885b0d53a5e04031ac ]
Check sta_rates pointer value in mt7603_sta_rate_tbl_update routine
Fixes: c8846e1015022 ("mt76: add driver for MT7603E and MT7628/7688")
[ Upstream commit 42ce8d3b623162f3248db50a38359f294e6b06fd ]
Fix a possible race in mt7615_pm_power_save_work() if rx/tx napi
schedules ps_work and we are currently accessing device register
on a different cpu.
Fixes: db928f1ab9789 ("mt76: mt7663: rely on mt76_connac_pm_ref/mt76_connac_pm_unref in tx/rx napi")
[ Upstream commit 591cdccebdd4d02eb46d400dea911136400cc567 ]
Fix a possible race in mt7921_pm_power_save_work() if rx/tx napi
on a different cpu.
Fixes: 1d8efc741df8 ("mt76: mt7921: introduce Runtime PM support")
[ Upstream commit abdb8bc94be4cf68aa71c9a8ee0bad9b3e6f52d3 ]
Similar to mt7915_mcu_wtbl_generic_tlv, rely on vif->bss_conf.aid for
aid in sta mode and not on sta->aid.
Fixes: e57b7901469fc ("mt76: add mac80211 driver for MT7915 PCIe-based chipsets")
[ Upstream commit a56b1b0f145ef2d6bb9312dedf3ab8558ef50a5b ]
mac80211 provides aid in vif->bss_conf.aid for sta mode and not in
sta->aid. Fix mt7915_mcu_wtbl_generic_tlv routine using proper value for
aid in sta mode.
[ Upstream commit 74c337ec0905d99111fc63a15f2e0784b9ed5503 ]
Similar to mt7915 driver, fix tag len error for sta_rec_wtbl, which
causes fw parsing error for the tags placed behind it.
Fixes: d0e274af2f2e4 ("mt76: mt76_connac: create mcu library")
[ Upstream commit 7e4760713391ee46dc913194b33ae234389a174e ]
As the possible failure of the ioremap(), the 'local->sram' and other
two could be NULL.
Therefore it should be better to check it in order to avoid the later
dev_dbg.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Jiasheng Jiang <jiasheng@iscas.ac.cn>
Link: https://lore.kernel.org/r/20211230022926.1846757-1-jiasheng@iscas.ac.cn
[ Upstream commit d1e0df1c57bd30871dd1c855742a7c346dbca853 ]
Syzbot reported 2 KMSAN bugs in ath9k. All of them are caused by missing
field initialization.
In htc_connect_service() svc_meta_len and pad are not initialized. Based
on code it looks like in current skb there is no service data, so simply
initialize svc_meta_len to 0.
htc_issue_send() does not initialize htc_frame_hdr::control array. Based
on firmware code, it will initialize it by itself, so simply zero whole
array to make KMSAN happy
Fail logs:
BUG: KMSAN: kernel-usb-infoleak in usb_submit_urb+0x6c1/0x2aa0 drivers/usb/core/urb.c:430
hif_usb_send_regout drivers/net/wireless/ath/ath9k/hif_usb.c:127 [inline]
hif_usb_send+0x5f0/0x16f0 drivers/net/wireless/ath/ath9k/hif_usb.c:479
htc_issue_send drivers/net/wireless/ath/ath9k/htc_hst.c:34 [inline]
htc_connect_service+0x143e/0x1960 drivers/net/wireless/ath/ath9k/htc_hst.c:275
Uninit was created at:
slab_post_alloc_hook mm/slab.h:524 [inline]
slab_alloc_node mm/slub.c:3251 [inline]
__kmalloc_node_track_caller+0xe0c/0x1510 mm/slub.c:4974
kmalloc_reserve net/core/skbuff.c:354 [inline]
__alloc_skb+0x545/0xf90 net/core/skbuff.c:426
alloc_skb include/linux/skbuff.h:1126 [inline]
htc_connect_service+0x1029/0x1960 drivers/net/wireless/ath/ath9k/htc_hst.c:258
Bytes 4-7 of 18 are uninitialized
Memory access of size 18 starts at ffff888027377e00
Bytes 16-17 of 18 are uninitialized
Fixes: fb9987d0f748 ("ath9k_htc: Support for AR9271 chipset.")
Reported-by: syzbot+f83a1df1ed4f67e8d8ad@syzkaller.appspotmail.com
Signed-off-by: Pavel Skripkin <paskripkin@gmail.com>
Link: https://lore.kernel.org/r/20220115122733.11160-1-paskripkin@gmail.com
[ Upstream commit e3fb3d4418fce5484dfe7995fcd94c18b10a431a ]
In function ath10k_wow_convert_8023_to_80211(), it will do memcpy for
the new->pattern, and currently the new->pattern and new->mask is same
with the old, then the memcpy of new->pattern will also overwrite the
old->pattern, because the header format of new->pattern is 802.11,
its length is larger than the old->pattern which is 802.3. Then the
operation of "Copy frame body" will copy a mistake value because the
body memory has been overwrite when memcpy the new->pattern.
Assign another empty value to new_pattern to avoid the overwrite issue.
Tested-on: QCA6174 hw3.2 SDIO WLAN.RMH.4.4.1-00049
Fixes: fa3440fa2fa1 ("ath10k: convert wow pattern from 802.3 to 802.11")
Signed-off-by: Wen Gong <quic_wgong@quicinc.com>
Link: https://lore.kernel.org/r/20211222031347.25463-1-quic_wgong@quicinc.com
commit b50255c83b914defd61a57fbc81d452334b63f4c upstream.
The driver was enabling IRQs before the message processing was
initialized. This could cause IRQs to come in too early and crash the
driver. Instead, move the IRQ enable and hostready to a bus preinit
function, at which point everything is properly initialized.
Fixes: 9e37f045d5e7 ("brcmfmac: Adding PCIe bus layer support.")
Reviewed-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Hector Martin <marcan@marcan.st>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Link: https://lore.kernel.org/r/20220131160713.245637-7-marcan@marcan.st
commit 9466987f246758eb7e9071ae58005253f631271e upstream.
The alignment check was wrong (e.g. & 4 instead of & 3), and the logic
was also inefficient if the length was not a multiple of 4, since it
would needlessly fall back to copying the entire buffer bytewise.
We already have a perfectly good memcpy_toio function, so just call that
instead of rolling our own copy logic here. brcmf_pcie_init_ringbuffers
was already using it anyway.
Link: https://lore.kernel.org/r/20220131160713.245637-6-marcan@marcan.st
commit 6d766d8cb505ec1fae63da8faef4fc5712c3d794 upstream.
Move one of the declarations from sdio.c to pcie.c, since it makes no
sense in the former (SDIO support is optional), and add missing ones.
Fixes: 75729e110e68 ("brcmfmac: expose firmware config files through modinfo")
Link: https://lore.kernel.org/r/20220131160713.245637-5-marcan@marcan.st
commit 5e90f0f3ead014867dade7a22f93958119f5efab upstream.
This avoids leaking memory if brcmf_chip_get_raminfo fails. Note that
the CLM blob is released in the device remove path.
Fixes: 82f93cf46d60 ("brcmfmac: get chip's default RAM info during PCIe setup")
Link: https://lore.kernel.org/r/20220131160713.245637-2-marcan@marcan.st
commit d19d8e3ba256f81ea4a27209dbbd1f0a00ef1903 upstream.
If boardrev is missing from the NVRAM we add a default one, but this
might need more space in the output buffer than was allocated. Ensure
we have enough padding for this in the buffer.
Fixes: 46f2b38a91b0 ("brcmfmac: insert default boardrev in nvram data if missing")
Link: https://lore.kernel.org/r/20220131160713.245637-3-marcan@marcan.st
commit 02a95374b5eebdbd3b6413fd7ddec151d2ea75a1 upstream.
Currently tx_params is being re-assigned with a new value and the
previous setting IEEE80211_HT_MCS_TX_RX_DIFF is being overwritten.
The assignment operator is incorrect, the original intent was to
bit-wise or the value in. Fix this by replacing the = operator
with |= instead.
Kudos to Christian Lamparter for suggesting the correct fix.
Fixes: fe8ee9ad80b2 ("carl9170: mac80211 glue and command interface")
Signed-off-by: Colin Ian King <colin.i.king@gmail.com>
Cc: <Stable@vger.kernel.org>
Acked-by: Christian Lamparter <chunkeey@gmail.com>
Link: https://lore.kernel.org/r/20220125004406.344422-1-colin.i.king@gmail.com
commit 98d504a82cc75840bec8e3c6ae0e4f411921962b upstream.
The spread of capability between the three WiFi silicon parts wcn36xx
supports is:
wcn3620 - 802.11 a/b/g
wcn3660 - 802.11 a/b/g/n
wcn3680 - 802.11 a/b/g/n/ac
We currently treat wcn3660 as wcn3620 thus limiting it to 2GHz channels.
Fix this regression by ensuring we differentiate between all three parts.
Fixes: 8490987bdb9a ("wcn36xx: Hook and identify RF_IRIS_WCN3680")
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Reviewed-by: Loic Poulain <loic.poulain@linaro.org>
Link: https://lore.kernel.org/r/20220125004046.4058284-1-bryan.odonoghue@linaro.org
commit 1ec7ed5163c70a0d040150d2279f932c7e7c143f upstream.
This reverts commit 2dc016599cfa9672a147528ca26d70c3654a5423.
Users are reporting regressions in regulatory domain detection and
channel availability.
The problem this was trying to resolve was fixed in firmware anyway:
QCA6174 hw3.0: sdio-4.4.1: add firmware.bin_WLAN.RMH.4.4.1-00042
https://github.com/kvalo/ath10k-firmware/commit/4d382787f0efa77dba40394e0bc604f8eff82552
Link: https://bbs.archlinux.org/viewtopic.php?id=254535
Link: http://lists.infradead.org/pipermail/ath10k/2020-April/014871.html
Link: http://lists.infradead.org/pipermail/ath10k/2020-May/015152.html
Link: https://lore.kernel.org/all/1c160dfb-6ccc-b4d6-76f6-4364e0adb6dd@reox.at/
Fixes: 2dc016599cfa ("ath: add support for special 0x0 regulatory domain")
Cc: Wen Gong <wgong@codeaurora.org>
Signed-off-by: Brian Norris <briannorris@chromium.org>
Link: https://lore.kernel.org/r/20200527165718.129307-1-briannorris@chromium.org
[ Upstream commit 1db5fcbba2631277b78d7f8aff99c9607d29f6d8 ]
Some APs misbehave when TWT is used and cause our firmware to crash.
We don't know a reasonable way to detect and work around this problem
in the FW yet. To prevent these crashes, disable TWT in the driver by
stopping to advertise TWT support.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=215523
Signed-off-by: Golan Ben Ami <golan.ben.ami@intel.com>
[reworded the commit message]
Link: https://lore.kernel.org/r/20220301072926.153969-1-luca@coelho.fi
commit 5a6248c0a22352f09ea041665d3bd3e18f6f872c upstream.
When "debugfs=off" is used on the kernel command line, iwiwifi's
mvm module uses an invalid/unchecked debugfs_dir pointer and causes
a BUG:
BUG: kernel NULL pointer dereference, address: 000000000000004f
PGD 0 P4D 0
CPU: 1 PID: 503 Comm: modprobe Tainted: G W 5.17.0-rc5 #7
Hardware name: Dell Inc. Inspiron 15 5510/076F7Y, BIOS 2.4.1 11/05/2021
RIP: 0010:iwl_mvm_dbgfs_register+0x692/0x700 [iwlmvm]
Code: 69 a0 be 80 01 00 00 48 c7 c7 50 73 6a a0 e8 95 cf ee e0 48 8b 83 b0 1e 00 00 48 c7 c2 54 73 6a a0 be 64 00 00 00 48 8d 7d 8c <48> 8b 48 50 e8 15 22 07 e1 48 8b 43 28 48 8d 55 8c 48 c7 c7 5f 73
RSP: 0018:ffffc90000a0ba68 EFLAGS: 00010246
RAX: ffffffffffffffff RBX: ffff88817d6e3328 RCX: ffff88817d6e3328
RDX: ffffffffa06a7354 RSI: 0000000000000064 RDI: ffffc90000a0ba6c
RBP: ffffc90000a0bae0 R08: ffffffff824e4880 R09: ffffffffa069d620
R10: ffffc90000a0ba00 R11: ffffffffffffffff R12: 0000000000000000
R13: ffffc90000a0bb28 R14: ffff88817d6e3328 R15: ffff88817d6e3320
FS: 00007f64dd92d740(0000) GS:ffff88847f640000(0000) knlGS:0000000000000000
CR2: 000000000000004f CR3: 000000016fc79001 CR4: 0000000000770ee0
PKRU: 55555554
Call Trace:
<TASK>
? iwl_mvm_mac_setup_register+0xbdc/0xda0 [iwlmvm]
iwl_mvm_start_post_nvm+0x71/0x100 [iwlmvm]
iwl_op_mode_mvm_start+0xab8/0xb30 [iwlmvm]
_iwl_op_mode_start+0x6f/0xd0 [iwlwifi]
iwl_opmode_register+0x6a/0xe0 [iwlwifi]
? 0xffffffffa0231000
iwl_mvm_init+0x35/0x1000 [iwlmvm]
do_one_initcall+0x5a/0x1b0
? kmem_cache_alloc+0x1e5/0x2f0
? do_init_module+0x1e/0x220
do_init_module+0x48/0x220
load_module+0x2602/0x2bc0
? __kernel_read+0x145/0x2e0
? kernel_read_file+0x229/0x290
__do_sys_finit_module+0xc5/0x130
? __do_sys_finit_module+0xc5/0x130
__x64_sys_finit_module+0x13/0x20
do_syscall_64+0x38/0x90
RIP: 0033:0x7f64dda564dd
Code: 5b 41 5c c3 66 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 1b 29 0f 00 f7 d8 64 89 01 48
RSP: 002b:00007ffdba393f88 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f64dda564dd
RDX: 0000000000000000 RSI: 00005575399e2ab2 RDI: 0000000000000001
RBP: 000055753a91c5e0 R08: 0000000000000000 R09: 0000000000000002
R10: 0000000000000001 R11: 0000000000000246 R12: 00005575399e2ab2
R13: 000055753a91ceb0 R14: 0000000000000000 R15: 000055753a923018
</TASK>
Modules linked in: btintel(+) btmtk bluetooth vfat snd_hda_codec_hdmi fat snd_hda_codec_realtek snd_hda_codec_generic iwlmvm(+) snd_sof_pci_intel_tgl mac80211 snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence soundwire_bus snd_sof_intel_hda snd_sof_pci snd_sof snd_sof_xtensa_dsp snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core btrfs snd_compress snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec raid6_pq iwlwifi snd_hda_core snd_pcm snd_timer snd soundcore cfg80211 intel_ish_ipc(+) thunderbolt rfkill intel_ishtp ucsi_acpi wmi i2c_hid_acpi i2c_hid evdev
---[ end trace 0000000000000000 ]---
Check the debugfs_dir pointer for an error before using it.
Fixes: 8c082a99edb9 ("iwlwifi: mvm: simplify iwl_mvm_dbgfs_register")
Cc: Luca Coelho <luciano.coelho@intel.com>
Cc: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Cc: stable <stable@vger.kernel.org>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://lore.kernel.org/r/20220223030630.23241-1-rdunlap@infradead.org
[change to make both conditional]
[ Upstream commit cacfddf82baf1470e5741edeecb187260868f195 ]
In mac80211_hwsim, the probe_req frame is created and sent while
scanning. It is sent with ieee80211_tx_info which is not initialized.
Uninitialized ieee80211_tx_info can cause problems when using
mac80211_hwsim with wmediumd. wmediumd checks the tx_rates field of
ieee80211_tx_info and doesn't relay probe_req frame to other clients
even if it is a broadcasting message.
Call ieee80211_tx_prepare_skb() to initialize ieee80211_tx_info for
the probe_req that is created by hw_scan_work in mac80211_hwsim.
Signed-off-by: JaeMan Park <jaeman@google.com>
Link: https://lore.kernel.org/r/20220113060235.546107-1-jaeman@google.com
[fix memory leak]
[ Upstream commit 42a79960ffa50bfe9e0bf5d6280be89bf563a5dd ]
Add IEEE80211_TX_STAT_NOACK_TRANSMITTED to tx_status flags to have proper
statistics for non-acked frames.
Signed-off-by: Benjamin Beichler <benjamin.beichler@uni-rostock.de>
Link: https://lore.kernel.org/r/20220111221327.1499881-1-benjamin.beichler@uni-rostock.de
commit 665408f4c3a5c83e712871daa062721624b2b79e upstream.
The call to brcm_alt_fw_path in brcmf_fw_get_firmwares is not protected
by a check to the validity of the fwctx->req->board_type pointer. This
results in a crash in strlcat when, for example, the WLAN chip is found
in a USB dongle.
Prevent the crash by adding the necessary check.
See: https://github.com/raspberrypi/linux/issues/4833
Fixes: 5ff013914c62 ("brcmfmac: firmware: Allow per-board firmware binaries")
Signed-off-by: Phil Elwell <phil@raspberrypi.com>
Link: https://lore.kernel.org/r/20220118154514.3245524-1-phil@raspberrypi.com
commit 5f06f6bf8d816578c390a2b8a485d40adcca4749 upstream.
SAR GEO offsets are not supported on 3160 devices. The code was
refactored and caused us to start sending the command anyway, which
causes a FW assertion failure. Fix that only considering this feature
supported on FW API with major version is 17 if the device is not
3160.
Additionally, fix the caller of iwl_mvm_sar_geo_init() so that it
checks for the return value, which it was ignoring.
Reported-by: Len Brown <lenb@kernel.org>
Fixes: 78a19d5285d9 ("iwlwifi: mvm: Read the PPAG and SAR tables at INIT stage")
Link: https://lore.kernel.org/r/iwlwifi.20220128144623.96f683a89b42.I14e2985bfd7ddd8a8d83eb1869b800c0e7f30db4@changeid
