Pull networking updates from David Miller:
1) Add BQL support to via-rhine, from Tino Reichardt.
2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers
can support hw switch offloading. From Floria Fainelli.
3) Allow 'ip address' commands to initiate multicast group join/leave,
from Madhu Challa.
4) Many ipv4 FIB lookup optimizations from Alexander Duyck.
5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel
Borkmann.
6) Remove the ugly compat support in ARP for ugly layers like ax25,
rose, etc. And use this to clean up the neigh layer, then use it to
implement MPLS support. All from Eric Biederman.
7) Support L3 forwarding offloading in switches, from Scott Feldman.
8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed
up route lookups even further. From Alexander Duyck.
9) Many improvements and bug fixes to the rhashtable implementation,
from Herbert Xu and Thomas Graf. In particular, in the case where
an rhashtable user bulk adds a large number of items into an empty
table, we expand the table much more sanely.
10) Don't make the tcp_metrics hash table per-namespace, from Eric
Biederman.
11) Extend EBPF to access SKB fields, from Alexei Starovoitov.
12) Split out new connection request sockets so that they can be
established in the main hash table. Much less false sharing since
hash lookups go direct to the request sockets instead of having to
go first to the listener then to the request socks hashed
underneath. From Eric Dumazet.
13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk.
14) Support stable privacy address generation for RFC7217 in IPV6. From
Hannes Frederic Sowa.
15) Hash network namespace into IP frag IDs, also from Hannes Frederic
Sowa.
16) Convert PTP get/set methods to use 64-bit time, from Richard
Cochran.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits)
fm10k: Bump driver version to 0.15.2
fm10k: corrected VF multicast update
fm10k: mbx_update_max_size does not drop all oversized messages
fm10k: reset head instead of calling update_max_size
fm10k: renamed mbx_tx_dropped to mbx_tx_oversized
fm10k: update xcast mode before synchronizing multicast addresses
fm10k: start service timer on probe
fm10k: fix function header comment
fm10k: comment next_vf_mbx flow
fm10k: don't handle mailbox events in iov_event path and always process mailbox
fm10k: use separate workqueue for fm10k driver
fm10k: Set PF queues to unlimited bandwidth during virtualization
fm10k: expose tx_timeout_count as an ethtool stat
fm10k: only increment tx_timeout_count in Tx hang path
fm10k: remove extraneous "Reset interface" message
fm10k: separate PF only stats so that VF does not display them
fm10k: use hw->mac.max_queues for stats
fm10k: only show actual queues, not the maximum in hardware
fm10k: allow creation of VLAN on default vid
fm10k: fix unused warnings
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"Some clean ups and small fixes, but the biggest change is the addition
of the TRACE_DEFINE_ENUM() macro that can be used by tracepoints.
Tracepoints have helper functions for the TP_printk() called
__print_symbolic() and __print_flags() that lets a numeric number be
displayed as a a human comprehensible text. What is placed in the
TP_printk() is also shown in the tracepoint format file such that user
space tools like perf and trace-cmd can parse the binary data and
express the values too. Unfortunately, the way the TRACE_EVENT()
macro works, anything placed in the TP_printk() will be shown pretty
much exactly as is. The problem arises when enums are used. That's
because unlike macros, enums will not be changed into their values by
the C pre-processor. Thus, the enum string is exported to the format
file, and this makes it useless for user space tools.
The TRACE_DEFINE_ENUM() solves this by converting the enum strings in
the TP_printk() format into their number, and that is what is shown to
user space. For example, the tracepoint tlb_flush currently has this
in its format file:
__print_symbolic(REC->reason,
{ TLB_FLUSH_ON_TASK_SWITCH, "flush on task switch" },
{ TLB_REMOTE_SHOOTDOWN, "remote shootdown" },
{ TLB_LOCAL_SHOOTDOWN, "local shootdown" },
{ TLB_LOCAL_MM_SHOOTDOWN, "local mm shootdown" })
After adding:
TRACE_DEFINE_ENUM(TLB_FLUSH_ON_TASK_SWITCH);
TRACE_DEFINE_ENUM(TLB_REMOTE_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_MM_SHOOTDOWN);
Its format file will contain this:
{ 0, "flush on task switch" },
{ 1, "remote shootdown" },
{ 2, "local shootdown" },
{ 3, "local mm shootdown" })"
* tag 'trace-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (27 commits)
tracing: Add enum_map file to show enums that have been mapped
writeback: Export enums used by tracepoint to user space
v4l: Export enums used by tracepoints to user space
SUNRPC: Export enums in tracepoints to user space
mm: tracing: Export enums in tracepoints to user space
irq/tracing: Export enums in tracepoints to user space
f2fs: Export the enums in the tracepoints to userspace
net/9p/tracing: Export enums in tracepoints to userspace
x86/tlb/trace: Export enums in used by tlb_flush tracepoint
tracing/samples: Update the trace-event-sample.h with TRACE_DEFINE_ENUM()
tracing: Allow for modules to convert their enums to values
tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values
tracing: Update trace-event-sample with TRACE_SYSTEM_VAR documentation
tracing: Give system name a pointer
brcmsmac: Move each system tracepoints to their own header
iwlwifi: Move each system tracepoints to their own header
mac80211: Move message tracepoints to their own header
tracing: Add TRACE_SYSTEM_VAR to xhci-hcd
tracing: Add TRACE_SYSTEM_VAR to kvm-s390
tracing: Add TRACE_SYSTEM_VAR to intel-sst
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
Every tracing file must have its own TRACE_SYSTEM defined.
The brcmsmac tracepoint header broke this and added in the middle
of the file:
#undef TRACE_SYSTEM
#define TRACE_SYSTEM brcmsmac
#undef TRACE_SYSTEM
#define TRACE_SYSTEM brcmsmac_tx
#undef TRACE_SYSTEM
#define TRACE_SYSTEM brcmsmac_msg
Unfortunately, this broke new code in the ftrace infrastructure.
Moving each of these TRACE_SYSTEMs into their own trace file with
just one TRACE_SYSTEM per file fixes the issue.
Link: http://lkml.kernel.org/r/5524D99C.1050902@broadcom.com
Acked-by: Arend van Spriel <arend@broadcom.com>
The iwlwifi tracepoint header broke this and added in the middle
of the file:
#undef TRACE_SYSTEM
#define TRACE_SYSTEM iwlwifi_io
#undef TRACE_SYSTEM
#define TRACE_SYSTEM iwlwifi_ucode
#undef TRACE_SYSTEM
#define TRACE_SYSTEM iwlwifi_msg
#undef TRACE_SYSTEM
#define TRACE_SYSTEM iwlwifi_data
#undef TRACE_SYSTEM
Link: http://lkml.kernel.org/r/1428479094.2809.3.camel@sipsolutions.net
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
ar9550 or later chips, the AR_GPIO_IN_OUT register only can
control GPIO[0:3]. For the extra GPIO, use standard GPIO calls
instead of WMAC internal registers.
Signed-off-by: Miaoqing Pan <miaoqing@qca.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
This patch fix a spelling typo in MODULE_DESCRIPTION in
wl1251/main.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Use bool constants as the return values instead of 1 and 0.
packet.
rtl8192cu can't connect to AP after physical reconnect.
according to dmesg, that problem's cause was DHCP timeout.
rtl_is_special_data function checks packet type for adjusting rate.
when that function is called from _rtl_rc_get_highest_rix, it can not
calculate offset correctly. so i add argument is_encn in rtl_is_special_data.
is_enc variable mean that iv header is added in skb parameter.
i test only rtl8192cu chipset. because i doesn't have other rtlwifi chipsets.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
As the driver may send multiple wmi commands with identical cmd id,
it is more robust to check seq number for timeout instead.
Signed-off-by: Fred Chou <fred.chou.nd@gmail.com>
https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-next
* some more work on LAR
* fixes for UMAC scan
* more work on debugging framework
* more work for 8000 devices
* cleanups and small bugfixes
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
The only other way to catch these would have been to monitor
the Tx deauth event, but we can send a deauth when we roam.
So it would have been tricky to make sure we capture the
connection losses only.
Define a separate trigger for the connection losses to make
it easier to catch them.
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This will allow to collect data when a time event
notifcation with a certain id and action is coming from
the firmware. This can be very useful to debug various
flows.
The current code has a lot of duplicates of printing into a buffer
(while having to make sure it's NUL-filled and -terminated) and
then passing that to the debug trigger collection.
Since that's error-prone, instead make the debug trigger collection
function take a format string and format arguments (with compiler
validity checking) and handle the buffer internally.
This makes one behavioural change -- instead of sending the whole
buffer to userspace (clearing is needed to not leak stack data) it
just passes the actual string (including NUL-terminator.)
Fix spelling error across the driver.
Modified only comments and prints.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
If ucode_loaded isn't true the function returns the 'ret' variable
without having assigned a value properly. Fix that.
Reported-by: Haim Dreyfuss <haim.dreyfuss@intel.com>
This will allow to catch failures in MLME and get the
firmware data when this happens.
Lots of updates for net-next; along with the usual flurry
of small fixes, cleanups and internal features we have:
* VHT support for TDLS and IBSS (conditional on drivers though)
* first TX performance improvements (the biggest will come later)
* many suspend/resume (race) fixes
* name_assign_type support from Tom Gundersen
The str/len arguments to iwl_fw_dbg_trigger_simple_stop() aren't used,
and for a simple trigger don't really need to be used as the trigger
code itself encodes the reason, so remove them.
Sending multiple action frames off channel, one after the other can create
a race that will result in a timeout:
1. Start sending action frame off channel.
2. Once the frame is sent or the time event is over, the flow will
eventually call ieee80211_start_next_roc to start the next roc frame &
iwl_mvm_roc_finished schedules to schedule a work to flush the queue.
3. Start sending new roc frame and write it to the queue before the
flush work has started.
4. The work is called and it flushes the new packet that was placed on the
on the queue so the packet is lost.
This causes the frame to be removed & not sent, that causes a timeout in
userspace.
Flush the work queue that flushes the roc/off channel queue before starting
to send a new frame off channel, in order to avoid a race between the new
frame that is transmitted off channel & the flushing of the queue.
Signed-off-by: Matti Gottlieb <matti.gottlieb@intel.com>
Currently the last found MCC is reconfigured only in the recovery flow.
But it should always be used when available, for the ifdown/up or
RF-Kill/CT-Kill scenarios.
While at it, fix a couple of bugs in the init-from-last-MCC flow. Return
an error value when a current MCC is not found. Pass on the regdomain to
cfg80211 only if it was changed and don't ignore the return value from
the cfg80211-setter function.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
Our testers need to know the number of scans performed while in
net-detect mode before the device wakes up. The firmware already
passes this information to the driver, so we can save it and report it
in a debugfs entry.
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
Minor cleanup and refactoring.
Signed-off-by: Eyal Shapira <eyalx.shapira@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers
Kalle Valo says:
iwlwifi:
* fix a memory leak, we leaked memory each time the module
was loaded.
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
Major changes:
ath9k:
* add Active Interference Cancellation, a method implemented in the HW
to counter WLAN RX > sensitivity degradation when BT is transmitting
at the same time. This feature is supported by cards like WB222
based on AR9462.
iwlwifi:
* Location Aware Regulatory was added by Arik
* 8000 device family work
* update to the BT Coex firmware API
brmcfmac:
* add new BCM43455 and BCM43457 SDIO device support
* add new BCM43430 SDIO device support
wil6210:
* take care of AP bridging
* fix NAPI behavior
* found approach to achieve 4*n+2 alignment of Rx frames
rt2x00:
* add new rt2800usb device DWA 130
rtlwifi:
* add USB ID for D-Link DWA-131
* add USB ID ASUS N10 WiFi dongle
mwifiex:
* throughput enhancements
When we access the triggers we need to make sure that the
data we expect was actually provided by the firmware file.
Check this when we decode the triggers from the firmware
file.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
Add new ID for ASUS N10 WiFi dongle.
Tested-by: Marek Vasut <marex@denx.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: John W. Linville <linville@tuxdriver.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
USB ID 2001:330d is used for a D-Link DWA-131.
Cc: Stable <stable@vger.kernel.org>
This will expose in /sys whether the ifname of a device is set by
userspace or generated by the kernel. The latter kind (wlanX, etc)
is not deterministic, so userspace needs to rename these devices
to names that are guaranteed to stay the same between reboots. The
former, however should never be renamed, so userspace needs to be
able to reliably tell the difference.
Similar functionality was introduced for the rtnetlink core in
commit 5517750f058e ("net: rtnetlink - make create_link take name_assign_type")
Signed-off-by: Tom Gundersen <teg@jklm.no>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: Franky (Zhenhui) Lin <frankyl@broadcom.com>
Cc: Hante Meuleman <meuleman@broadcom.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
[reformat changelog to fit 72 cols]
This patch adds recovery mechanism for SDIO RX during SKB allocation
failures.
For allocation failures during multiport aggregation, we skip and drop RX
packets.
For single port read case, we will use preallocated card->mpa_rx.buf to
complete cmd53 read.
Now we terminate SDIO operations only upon cmd53 failures.
CC: James Cameron <quozl@laptop.org>
Signed-off-by: Zhaoyang Liu <liuzy@marvell.com>
Signed-off-by: Avinash Patil <patila@marvell.com>
Cancel all pending commands including scan commands and stop CAC
during cfg80211 suspend handler.
"adapter->sleep_cfm" is always non-NULL at this point. Static checkers
complain that we already dereference it at the start of the function
when we do:
skb_put(adapter->sleep_cfm, sizeof(struct mwifiex_opt_sleep_confirm));
Acked-by: Amitkumar Karwar <akarwar@marvell.com>
SDIO reset was not happening properly on mwifiex as cancel_work_sync
in mwifiex_sdio_remove used to kill the calling work function itself.
Due to this, the interface was not getting removed and card was not
getting added again. Reset work function has been made independent
of adapter variable and cancel_work_sync has been moved to cleanup
function.
Signed-off-by: Maithili Hinge <maithili@marvell.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
replace REG_WRITE to REG_RMW and place every thing in one
RMW buffer.
it is possible to reduce time needed for this function
by rplacing REG_WRITE with REG_RMW (plus dummy 0) and putt all commands
in same buffer.
it will reduce exution time from 14ms to 2ms on ar9271
use REG_RMW in ath9k_hw_analog_shift_rmw.
It will double execution speed on usb bus.
this will reduce some overhead on usb bus.
insted of reading each register separatly
and waste 4ms on each operation, we can
use one shot read.
REG_READ generate most overhead on usb bus. It send and read micro packages
and reduce usb bandwidth. To reduce this overhead we should read in batches.
