It should be safe to enable AP-mode now.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
RX appears to freeze while idle. Resetting rx-urbs appears to be enough to fix
this. Do reset 30 seconds after last rx.
When driver fails to acquire device semaphore lock, device usually
freezes soon afterwards. So failing to acquire lock indicates us that
not everything is going right in device/fw. So reset device when
this happens.
When doing transfers at high speed for long time, tx queue can freeze. So add
tx watchdog. TX-watchdog checks for locked tx-urbs and reset hardware when
such is detected. Merely unlinking urb was not enough, device have to be
reseted. Hw settings are restored so that any open link will stay on after
reset.
We need HW hard reset later in patchset to reset device after TX-stall.
Collect all settings that we have set to driver for later reset and
add restore function.
Device command timeouts are set up very high (1 sec) and this causes
AP beacon to lock up for long for example. Checking timeouts on device
it's easy to see that 1 sec timeout is not needed, when device fails
to response longer timeout doesn't help:
[ 473.074419] zd1211rw 1-1:1.0: print_times() Read times:
[ 473.175163] zd1211rw 1-1:1.0: print_time() 0 - 10 msec: 1506
[ 473.176429] zd1211rw 1-1:1.0: print_time() 11 - 50 msec: 0
[ 473.177955] zd1211rw 1-1:1.0: print_time() 51 - 100 msec: 0
[ 473.180703] zd1211rw 1-1:1.0: print_time() 101 - 250 msec: 0
[ 473.182101] zd1211rw 1-1:1.0: print_time() 251 - 500 msec: 0
[ 473.183221] zd1211rw 1-1:1.0: print_time() 500 - 1000 msec: 20
[ 473.184381] zd1211rw 1-1:1.0: print_time() 1000 - ... msec: 18
Also vendor driver doesn't use this long timeout. Therefore change
timeout to 50msec.
As might lower beacon update CPU usage.
Use stack for allocing small < 64 byte arrays in zd_chip.c and preallocated
buffer in zd_usb.c. This might lower CPU usage for beacon setup.
v2:
- Do not use stack buffers in zd_usb.c as they would be used for urb
transfer_buffer.
Beacon config function writes beacon to hw one write per byte. This is very
slow (usually taking more than 100ms to finish) and causes high CPU usage
when in AP-mode (kworker at ~50% on Intel Atom N270). By batching commands
together zd_mac_config_beacon() runtime can be lowered to 1/5th and lower
CPU usage to saner levels (<10% on Atom).
When doing tx/rx at high packet rate (for example simply using ping -f),
device starts to fail to respond to control messages. On non-AP modes
this only causes problems for LED updating code but when we are running
in AP-mode we are writing new beacon to HW usually every 100ms. Now if
control message fails in HW beacon setup, device lock is kept locked
and beacon data partially written. This can and usually does cause:
1. HW beacon setup fail now on, as driver cannot acquire device lock.
2. Beacon-done interrupt stop working as device has incomplete beacon.
Therefore make zd_mac_config_beacon() always try to release device lock
and add beacon watchdog to restart beaconing when stall is detected.
Also fix zd_mac_config_beacon() try acquiring device lock for max 500ms,
as what old code appeared to be trying to do using loop and msleep(1).
Add support for AP-mode beacon. Also disable beacon when interface is set
down as otherwise hw will keep flooding NEXT_BCN interrupts.
on monitor
For reasons not very clear yet to me, filter_ack leaves matching tx-packet
pending with 'ack_pending'. This causes tx-packet to be passed back to upper
layer after next packet has been transfered and tx-packets might end up
coming come out of monitor interface in wrong order vs. rx.
Because of this when enable AP-mode, hostapd monitor interface would get
packets in wrong order causing problems in WPA association.
So don't use mac->ack_pending when in AP-mode.
As bss_info_changed may sleep, we can as well set RTS_CTS register right away.
Keep mac->short_preamble for later use (hw reset).
configure_filter
Workers not needed anymore since configure_filter may sleep. Keep
mac->multicast_hash for later use (hw reset).
Signed-off-by: Jussi Kivilinna <jussi.kivilina@mbnet.fi>
Vendor driver uses CR_BNC_INTERVAL at various places, one is HW_EnableBeacon()
that combinies beacon interval with BSS-type flag and DTIM value in upper 16bit
of u32. The other one is HW_UpdateBcnInterval() that set_aw_pt_bi()
appears to be based on. HW_UpdateBcnInterval() takes interval argument as u16
and uses that for calculations, set_aw_pt_bi() uses u32 value that has flags
and dtim in upper part. This clearly seems wrong. Also HW_UpdateBcnInterval()
updates only lower 16bit part of CR_BNC_INTERVAL. So make set_aw_pt_bi() do
calculations on only lower u16 part of s->beacon_interval.
Also set 32bit beacon interval register before reading values from device,
as HW_EnableBeacon() on vendor driver does. This is required to make beacon
work on AP-mode, simply reading and then writing updated values is not enough
at least with zd1211b.
OOPS if worker is running and disconnect() is called (triggered
by unpluging device). Much harder to trigger at this stage but
later when we have AP beacon work in process_intr it happens very
easy.
When stress testing AP-mode I hit OOPS when unpluging or rmmodding
driver.
It appears that when tx-queue is disabled, tx-urbs might be left pending.
These can cause ehci to call non-existing tx_urb_complete() (after rmmod)
or uninitialized/reseted private structure (after disconnect()). Add skb
queue for submitted packets and unlink pending urbs on zd_usb_disable_tx().
Part of the problem seems to be usb->free_urb_list that isn't always
working as it should, causing machine freeze when trying to free the list
in zd_usb_disable_tx(). Caching free urbs isn't what other drivers seem
to be doing (usbnet for example) so strip free_usb_list.
Patch makes tx-urb handling saner with use of urb anchors.
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
cancel_delayed_work_sync()
cancel_rearming_delayed_work[queue]() has been superceded by
cancel_delayed_work_sync() quite some time ago. Convert all the
in-kernel users. The conversions are completely equivalent and
trivial.
Acked-by: "David S. Miller" <davem@davemloft.net>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: netdev@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: Alex Elder <aelder@sgi.com>
Cc: xfs-masters@oss.sgi.com
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: netfilter-devel@vger.kernel.org
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: linux-nfs@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Mark arrays const that are unmodified after initializations.
19291 56 4136 23483 5bbb drivers/net/wireless/zd1211rw/zd_chip.o.old
19291 56 4136 23483 5bbb drivers/net/wireless/zd1211rw/zd_chip.o.new
"These USB ID came from Palnex <http://www.planex.co.jp/>
Worked fine." says Mandriva patch for their 2.6.32 and earlier.
Web has evidence for both id's to work, so just add them upstream:
http://www.mail-archive.com/zd1211-devs@lists.sourceforge.net/msg00507.html
http://ubuntuforums.org/showthread.php?t=473046
Signed-off-by: Go Taniguchi <go@turbolinux.co.jp>
Signed-off-by: maximilian attems <max@stro.at>
This makes the information available through ethtool...
ZD_REGDOMAIN_JAPAN_ADD and ZD_REGDOMAIN_JAPAN_GW_US54GXS seem a little
verbose to me...
0x49 is used by PLANEX GW-US54GXS (2019:5303).
Signed-off-by: Kouhei Sutou <kou@clear-code.com>
drivers/net/wireless/wl12xx/wl1271.h
drivers/net/wireless/wl12xx/wl1271_cmd.h
cleanup patch.
Use new __packed annotation in drivers/net/
Signed-off-by: Walter Goldens <goldenstranger@yahoo.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits)
USB: remove unused usb_buffer_alloc and usb_buffer_free macros
usb: musb: update gfp/slab.h includes
USB: ftdi_sio: fix legacy SIO-device header
USB: kl5usb105: reimplement using generic framework
USB: kl5usb105: minor clean ups
USB: kl5usb105: fix memory leak
USB: io_ti: use kfifo to implement write buffering
USB: io_ti: remove unsused private counter
USB: ti_usb: use kfifo to implement write buffering
USB: ir-usb: fix incorrect write-buffer length
USB: aircable: fix incorrect write-buffer length
USB: safe_serial: straighten out read processing
USB: safe_serial: reimplement read using generic framework
USB: safe_serial: reimplement write using generic framework
usb-storage: always print quirks
USB: usb-storage: trivial debug improvements
USB: oti6858: use port write fifo
USB: oti6858: use kfifo to implement write buffering
USB: cypress_m8: use kfifo to implement write buffering
USB: cypress_m8: remove unused drain define
Fix up conflicts (due to usb_buffer_alloc/free renaming) in
drivers/input/tablet/acecad.c
drivers/input/tablet/kbtab.c
drivers/input/tablet/wacom_sys.c
drivers/media/video/gspca/gspca.c
sound/usb/usbaudio.c
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pedro Ribeiro <pedrib@gmail.com>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits)
bridge: ensure to unlock in error path in br_multicast_query().
drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages
sky2: Avoid rtnl_unlock without rtnl_lock
ipv6: Send netlink notification when DAD fails
drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant
ipconfig: Handle devices which take some time to come up.
mac80211: Fix memory leak in ieee80211_if_write()
mac80211: Fix (dynamic) power save entry
ipw2200: use kmalloc for large local variables
ath5k: read eeprom IQ calibration values correctly for G mode
ath5k: fix I/Q calibration (for real)
ath5k: fix TSF reset
ath5k: use fixed antenna for tx descriptors
libipw: split ieee->networks into small pieces
mac80211: Fix sta_mtx unlocking on insert STA failure path
rt2x00: remove KSEG1ADDR define from rt2x00soc.h
net: add ColdFire support to the smc91x driver
asix: fix setting mac address for AX88772
ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}.
net: Fix dev_mc_add()
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
The first chunk fixes a debugging assert to print a warning about array underflows.
The second chunk corrects a potential array underflow. I also removed an assert
in the second chunk because it can no longer happen.
Acked-by: Benoit Papillault <benoit.papillault@free.fr>
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
drivers/net/wireless/iwlwifi/iwl-core.h
Yasuhiro ABE <yadiary@gmail.com> reported success in sourceforge zd1211-dev list.
The device is a NEC Aterm WL54GU usb wireless stick.
The brand and retail product name
NEC, Aterm PA-WL54GU
The USB ID's (duh)
ID 0409:0248
The chip ID string
zd1211rw 1-1:1.0: zd1211b chip 0409:0248 v4810 high 00-1b-8b AL2230S_RF pa0 g--N-
The FCC ID
unknown
Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Signed-off-by: Yasuhiro ABE <yadiary@gmail.com>
net/mac80211/iface.c
If multicast parameter (as returned by zd_op_prepare_multicast) has
changed, no bit in changed_flags is set. To handle this situation, we do
not return if changed_flags is 0. If we do so, we will have some issue
with IPv6 which uses multicast for link layer address resolution.
Signed-off-by: Benoit Papillault <benoit.papillault@free.fr>
