This removes the remaining users of the rx status
'qual' field and the field itself.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
First, we reduce the number of hardware retries to 0 (ie 2 real retries
for each rate). Next, when we report the retries to mac80211, we always
report a retry count of 1 (it seems to be 2 in fact, but using 2 seems
to lead to wrong performance for some reason). We use a state machine to
determine the real fate of a packet based on the 802.11 ACK and what the
Zydas hardware is saying when a real retry occurs. The real retry rates
are encoded in a static array. It has been tested with both zd1211 and
zd1211b hardware. Of course, since the Zydas hardware is not reporting
retries accurately, we are just doing our best in order to get the best
performance (ie higher throughput).
Signed-off-by: Benoit PAPILLAULT <benoit.papillault@free.fr>
Over time, a whole bunch of drivers have come up
with their own scheme to delay the configure_filter
operation to a workqueue. To be able to simplify
things, allow configure_filter to sleep, and add
a new prepare_multicast callback that drivers that
need the multicast address list implement. This new
callback must be atomic, but most drivers either
don't care or just calculate a hash which can be
done atomically and then uploaded to the hardware
non-atomically.
A cursory look suggests that at76c50x-usb, ar9170,
mwl8k (which is actually very broken now), rt2x00,
wl1251, wl1271 and zd1211 should make use of this
new capability.
zd1211rw uses its own LED stuff so let rename its LED
stuff as such.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
The mac80211 workqueue exists to enable mac80211 and drivers
to queue their own work on a single threaded workqueue. mac80211
takes care to flush the workqueue during suspend but we never
really had requirements on drivers for how they should use
the workqueue in consideration for suspend.
We extend mac80211 to document how the mac80211 workqueue should
be used, how it should not be used and finally move raw access to
the workqueue to mac80211 only. Drivers and mac80211 use helpers
to queue work onto the mac80211 workqueue:
* ieee80211_queue_work()
* ieee80211_queue_delayed_work()
These helpers will now warn if mac80211 already completed its
suspend cycle and someone is trying to queue work. mac80211
flushes the mac80211 workqueue prior to suspend a few times,
but we haven't taken the care to ensure drivers won't add more
work after suspend. To help with this we add a warning when
someone tries to add work and mac80211 already completed the
suspend cycle.
Drivers should ensure they cancel any work or delayed work
in the mac80211 stop() callback.
Within mac80211, we often need to copy the rx status into
skb->cb. This is wasteful, as drivers could be building it
in there to start with. This patch changes the API so that
drivers are expected to pass the RX status in skb->cb, now
accessible as IEEE80211_SKB_RXCB(skb). It also updates all
drivers to pass the rx status in there, but only by making
them memcpy() it into place before the call to the receive
function (ieee80211_rx(_irqsafe)). Each driver can now be
optimised on its own schedule.
According to my tests, all that ZD_CS_MULTICAST does is to
disable retrying/waiting for an ACK. Reflect this by renaming
the bit to ZD_CS_NO_ACK and setting it based on
IEEE80211_TX_CTL_NO_ACK, instead of is_multicast_ether_addr.
Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com>
The config_interface method is a little strange, it contains the
BSSID and beacon updates, while bss_info_changed contains most
other BSS information for each interface. This patch removes
config_interface and rolls all the information it previously
passed to drivers into bss_info_changed.
drivers/net/igb/igb_main.c
drivers/net/qlge/qlge_main.c
drivers/net/wireless/ath9k/ath9k.h
drivers/net/wireless/ath9k/core.h
drivers/net/wireless/ath9k/hw.c
zd_op_tx() must not return an arbitrary error value since that can
leave mac80211 trying to retransmit the frame and with the extra data
pushed into the beginning of the skb on every attempt, this will end up
causing a kernel panic (skb_under_panic from skb_push call). This can
happen, e.g., when ejecting the device when associated.
Signed-off-by: Jouni Malinen <j@w1.fi>
This patch implements get_tsf() of ieee80211_ops in the zd1211rw driver.
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
All regulatory hints (core, driver, userspace and 11d) are now processed in
a workqueue.
This makes zd1211rw honour enable_beacon, as well as fixing
a memory leak: the beacon skb is leaked when configuring it
to the hardware fails.
It is rather confusing to see this in the log:
[ 695.606877] __ratelimit: 40 callbacks suppressed
[ 700.726878] __ratelimit: 40 callbacks suppressed
without ever seeing any actual message. This is because
zd1211rw doesn't compile out the net_ratelimit() call
properly if debugging is not enabled.
Giving the signal in dB isn't much more useful to userspace
than giving the signal in unspecified units. This removes
some radiotap information for zd1211 (the only driver using
this flag), but it helps a lot for getting cfg80211-based
scanning which won't support dB, and zd1211 being dB is a
little fishy anyway.
Cc: Bruno Randolf <bruno@thinktube.com>
When I review ocfs2 code, find there are 2 typos to "successfull". After
doing grep "successfull " in kernel tree, 22 typos found totally -- great
minds always think alike :)
This patch fixes all the similar typos. Thanks for Randy's ack and comments.
Signed-off-by: Coly Li <coyli@suse.de>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jeremy Kerr <jk@ozlabs.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
drivers/net/wireless/iwlwifi/iwl-core.c
drivers/net/wireless/iwlwifi/iwl-sta.c
Under my 2.6.28-rc6 sparc64, when associating to an AP through my
zd1211rw device, I was seeing kernel log messages like (not exact output):
Kernel unaligned access at TPC[10129b68] zd_mac_rx+0x144/0x32c [zd1211rw]
For the zd1211rw module, on RX, the 80211 packet will be located after
the PLCP header in the skb data buffer. The PLCP header being 5 bytes
long, the 80211 header will start unaligned from an aligned skb
buffer.
As per Documentation/unaligned-memory-access.txt, we must replace the
not unaligned() safe compare_ether_addr() with memcmp() to protect
architectures that require alignment.
Signed-off-by: Shaddy Baddah <shaddy_baddah@hotmail.com>
The code needs to be split out and cleaned up, so as a
first step remove the capability, to add it back in a
subsequent patch as a separate function. Also remove the
publically facing return value of the function and the
wiphy argument. A number of internal functions go from
being generic helpers to just being used for alpha2
setting.
So after the previous changes we were still unhappy with how
convoluted the API is and decided to make things simpler for
everybody. This completely changes the rate control API, now
taking into account 802.11n with MCS rates and more control,
most drivers don't support that though.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
This makes mac80211 notify the driver which configuration
actually changed, e.g. channel etc.
No driver changes, this is just plumbing, driver authors are
expected to act on this if they want to.
Also remove the HW CONFIG debug printk, it's incorrect, often
we configure something else.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
There's really no reason for mac80211 to be using its
own interface type defines. Use the nl80211 types and
simplify the configuration code a bit: there's no need
to translate them any more now.
This cleans up zd1211rw's own regulatory work, and makes use of
the new cfg80211 regulatory_hint().
It is obviously good for userspace to know up front which
interface modes a given piece of hardware might support (even
if adding such an interface might fail later because of
concurrency issues), so let's make cfg80211 aware of that.
For good measure, disallow adding interfaces in all other
modes so drivers don't forget to announce support for one mode
when they add it.
Signed-off-by: Stephen Blackheath <tramp.enshrine.stephen@blacksapphire.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
I forgot this in the previous patch that made it unused.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
net/netfilter/nf_conntrack_proto_tcp.c
This patch changes mac80211's beacon configuration handling
to never pass skbs to the driver directly but rather always
require the driver to use ieee80211_beacon_get(). Additionally,
it introduces "change flags" on the config_interface() call
to enable drivers to figure out what is changing. Finally, it
removes the beacon_update() driver callback in favour of
having IBSS beacon delivered by ieee80211_beacon_get() as well.
If a mesh or ad-hoc interface is brought up and later it is replaced
by managed interface, the managed interface will keep transmitting
the beacons that were configured for the former interface. This patch
fixes that behaviour.
Add some error checking to the new beacon configuration code.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
drivers/net/tg3.c
drivers/net/wireless/rt2x00/rt2x00dev.c
net/mac80211/ieee80211_i.h
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-next-2.6
drivers/net/ps3_gelic_wireless.c
drivers/net/wireless/libertas/main.c
This patch fixes a data alignment issue in the zd1211rw driver.
The IEEE80211_STYPE_QOS_DATA bit should be used as a bitwise test
to test for the presence of the 2 byte QoS control field.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This patch converts mac80211 and all drivers to have transmit
information and status in skb->cb rather than allocating extra
memory for it and copying all the data around. To make it fit,
a union is used where only data that is necessary for all steps
is kept outside of the union.
A number of fixes were done by Ivo, as well as the rt2x00 part
of this patch.
This patch modifies struct ieee80211_tx_control to give band
info and the rate index (instead of rate pointers) to drivers.
This mostly serves to reduce the TX control structure size to
make it fit into skb->cb so that the fragmentation code can
put it there and we can think about passing it to drivers that
way in the future.
The rt2x00 driver update was done by Ivo, thanks.
trying to clean up the signal/noise code. the previous code in mac80211 had
confusing names for the related variables, did not have much definition of
what units of signal and noise were provided and used implicit mechanisms from
the wireless extensions.
this patch introduces hardware capability flags to let the hardware specify
clearly if it can provide signal and noise level values and which units it can
provide. this also anticipates possible new units like RCPI in the future.
for signal:
IEEE80211_HW_SIGNAL_UNSPEC - unspecified, unknown, hw specific
IEEE80211_HW_SIGNAL_DB - dB difference to unspecified reference point
IEEE80211_HW_SIGNAL_DBM - dBm, difference to 1mW
for noise we currently only have dBm:
IEEE80211_HW_NOISE_DBM - dBm, difference to 1mW
if IEEE80211_HW_SIGNAL_UNSPEC or IEEE80211_HW_SIGNAL_DB is used the driver has
to provide the maximum value (max_signal) it reports in order for applications
to make sense of the signal values.
i tried my best to find out for each driver what it can provide and update it
but i'm not sure (?) for some of them and used the more conservative guess in
doubt. this can be fixed easily after this patch has been merged by changing
the hardware flags of the driver.
DRIVER SIGNAL MAX NOISE QUAL
adm8211 unspec(?) 100 n/a missing
at76_usb unspec(?) (?) unused missing
ath5k dBm dBm percent rssi
b43legacy dBm dBm percent jssi(?)
b43 dBm dBm percent jssi(?)
iwl-3945 dBm dBm percent snr+more
iwl-4965 dBm dBm percent snr+more
p54 unspec 127 n/a missing
rt2x00 dBm n/a percent rssi+tx/rx frame success
rt2400 dBm n/a
rt2500pci dBm n/a
rt2500usb dBm n/a
rt61pci dBm n/a
rt73usb dBm n/a
rtl8180 unspec(?) 65 n/a (?)
rtl8187 unspec(?) 65 (?) noise(?)
zd1211 dB(?) 100 n/a percent
drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD
Signed-off-by: Bruno Randolf <br1@einfach.org>
this adds initial IBSS support for the zydas zd1211rw:
convince driver that it can do IBSS mode. add mac80211 beacon_update callback.
IBSS merge and TSF updates don't work yet, but it makes the driver usable in
ad-hoc networks.
The previously unused CR_CAM_MODE register is set to MODE_AP_WDS. This makes the
driver ack mesh (WDS) frames. It does not affect Infra functionality of the
driver.
Previously missing beaconing support has been added. This might also help
implement a currently missing ah-hoc mode.
Support for interrupts from the device have been added, but we are not handling
most of them.
Mesh interfaces are considered associated as long as the interface is up.
Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com>
We must not clear the FIF_BCN_PRBRESP_PROMISC bit in the
new_flags. The zd-driver does support sending beacons and
probe responses to the host. What the flag does is say "Send me
all beacons and probe responses". And we actually do that. We always
do that, so we ignore the case when the bit is disabled. But that is
fine. But we must not clear the flag, as that tells mac80211 that
we do not support passing beacons and probe responses to the stack.
And that's not true.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
This patch creates new cfg80211 wiphy API for channel and bitrate
registration and converts mac80211 and drivers to the new API. The
old mac80211 API is completely ripped out. All drivers (except ath5k)
are updated to the new API, in many cases I expect that optimisations
can be done.
Along with the regulatory code I've also ripped out the
IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be
unnecessary if the hardware simply gives us whatever channels it wants
to support and we then enable/disable them as required, which is pretty
much required for travelling.
Additionally, the patch adds proper "basic" rate handling for STA
mode interface, AP mode interface will have to have new API added
to allow userspace to set the basic rate set, currently it'll be
empty... However, the basic rate handling will need to be moved to
the BSS conf stuff.
I do expect there to be bugs in this, especially wrt. transmit
power handling where I'm basically clueless about how it should work.
This silences sparse when run on zd1211rw.
This patch (based on Ron Rindjunsky's) creates a framework for
a unified way to pass BSS configuration to drivers that require
the information, e.g. for implementing power save mode.
This patch introduces new ieee80211_bss_conf structure that is
passed to the driver via the new bss_info_changed() callback
when the BSS configuration changes.
This new BSS configuration infrastructure adds the following
new features:
* drivers are notified of their association AID
* drivers are notified of association status
and replaces the erp_ie_changed() callback. The patch also does
the relevant driver updates for the latter change.
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
This patch gets rid of the if_id stuff where possible in favour of
a new per-virtual-interface structure "struct ieee80211_vif". This
structure is located at the end of the per-interface structure and
contains a variable length driver-use data area.
This has two advantages:
* removes the need to look up interfaces by if_id, this is better
for working with network namespaces and performance
* allows drivers to store and retrieve per-interface data without
having to allocate own lists/hash tables
