path: root/drivers/net/wireless/rtlwifi/usb.c
2015-10-14rtlwifi: rtl818x: Move drivers into new realtek directoryLarry Finger
Now that a new mac80211-based driver for Realtek devices has been submitted, it is time to reorganize the directories. Rather than having directories rtlwifi and rtl818x be in drivers/net/wireless/, they will now be in drivers/net/wireless/realtek/. This change simplifies the directory structure, but does not result in any configuration changes that are visable to the user. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-04-28rtlwifi: rtl8192cu: Fix kernel deadlockLarry Finger
The USB mini-driver in rtlwifi, which is used by rtl8192cu, issues a call to usb_control_msg() with a timeout value of 0. In some instances where the interface is shutting down, this infinite wait results in a CPU deadlock. A one second timeout fixes this problem without affecting any normal operations. This bug is reported at https://bugzilla.novell.com/show_bug.cgi?id=927786. Reported-by: Bernhard Wiedemann <bwiedemann@suse.com> Tested-by: Bernhard Wiedemann <bwiedemann@suse.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Cc: Bernhard Wiedemann <bwiedemann@suse.com> Cc: Takashi Iwai<tiwai@suse.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-02-27rtlwifi: Modify some USB de-initialize code.Taehee Yoo
Delete SET_USB_STOP macro and rtl_usb_deinit because those are called twice in USB de-initialize routine. Add some de-initialize workqueue function in USB disconnect routine. Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2014-10-23rtl8192cu: Call ieee80211_register_hw from rtl_usb_probeKarsten Wiese
In a previous patch the call to ieee80211_register_hw was moved from the load firmware callback to the rtl_pci_probe only. rt8192cu also uses this callback. Currently it doesnt create a wlan%d device. Fill in the call to ieee80211_register_hw in rtl_usb_probe. Signed-off-by: Karsten Wiese <fzuuzf@googlemail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-09-30rtlwifi: rtl8188ee: rtl8723ae: rtl8821ae: Initialize some variablesLarry Finger
In a number of places, kmalloc or valloc were used to acquire memory. To ensure that these locations are correctly initialized, the calls were changed to kzalloc and vzalloc. The change fixes a problem that was causing HT operations to be cancelled. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-03-06rtlwifi: rtl8192ce: rtl8192cu: rtl8192de: rtl8192se: rtl8723ae: rtl8723be: ↵Larry Finger
rtl8188eu: Modify for new API The addition of a driver for the RTL8821AE requires a new API for the fill_tx_desc() and set_desc() callback routines. This commit makes the appropriate modifications in all the other drivers. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-03-04rtlwifi: Prepare existing drivers for new driverLarry Finger
A driver for the RTL8723BE will soon be added. This patch adds the necessary parts to the common headers, and modifies the existing drivers for those changes. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-12-05rtlwifi: Update beacon statistics for USB driverLarry Finger
The USB drivers were not updating the beacon statistics, which led to false beacon loss indications. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-12-05rtlwifi: Increase the RX queue length for USB driversLarry Finger
The current number of RX buffers queued is 32, which is too small under heavy load. That number is doubled. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-12-05rtlwifi: Remove unused calls to rtl_is_special_data()Larry Finger
When routine rtl_is_special_data() is called with false as its last argument, and the returned value is not tested, the call is essentially an extended no-op. Accordingly, these calls may be removed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Mark Cave-Ayland <mark.cave-ayland@ilande.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-03rtlwifi: Fix smatch warnings in usb.cLarry Finger
Smatch displays the following: CHECK drivers/net/wireless/rtlwifi/usb.c drivers/net/wireless/rtlwifi/usb.c:458 _rtl_usb_rx_process_agg() warn: assigning (-98) to unsigned variable 'stats.noise' drivers/net/wireless/rtlwifi/usb.c:503 _rtl_usb_rx_process_noagg() warn: assigning (-98) to unsigned variable 'stats.noise' drivers/net/wireless/rtlwifi/usb.c:596 _rtl_rx_get_padding() info: ignoring unreachable code. drivers/net/wireless/rtlwifi/usb.c:596 _rtl_rx_get_padding() info: ignoring unreachable code. The variable 'stats.noise' is not used, thus the initializers are removed. The unreachable code info is fixed by including the appropriate section inside #ifdef .. #endif constructions. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-18rtlwifi: Fix build errors for unusual casesLarry Finger
The present build configuration for the rtlwifi family of drivers will fail under two known conditions: (1) If rtlwifi is selected without selecting any of the dependent drivers, there are errors in the build. (2) If the PCI drivers are built into the kernel and the USB drivers are modules, or vice versa, there are missing globals. The first condition is fixed by never building rtlwifi unless at least one of the device drivers is selected. The second failure is fixed by splitting the PCI and USB codes out of rtlwifi, and creating their own mini drivers. If the drivers that use them are modules, they will also be modules. Although a number of files are touched by this patch, only Makefile and Kconfig have undergone significant changes. The only modifications to the other files were to export entry points needed by the new rtl_pci and rtl_usb units, or to rename two variables that had names that were likely to cause namespace collisions. Reported-by: Fengguang Wu <fengguang.wu@intel.com> [Condition 1] Reported-by: Ben Hutchings <bhutchings@solarflare.com> [Condition 2] Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-17rtlwifi: Initialize power-setting callback for USB devicesLarry Finger
Commit a269913c5 entitled "rtlwifi: Rework rtl_lps_leave() and rtl_lps_enter() to use work queue" has two bugs for USB drivers. Firstly, the work queue in question was not initialized. Secondly, the callback routine used by this queue is contained within the file used for PCI devices. As a result, it is not available for architectures without PCI hardware. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Richard Genoud <richard.genoud@gmail.com> Tested-by: Richard Genoud <richard.genoud@gmail.com> Cc: Richard Genoud <richard.genoud@gmail.com> Cc: Stable <stable@vger.kernel.org> [3.10] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12rtlwifi: rtl8192cu: Fix problem in connecting to WEP or WPA(1) networksLarry Finger
Driver rtl8192cu can connect to WPA2 networks, but fails for any other encryption method. The cause is a failure to set the rate control data blocks. These changes fix https://bugzilla.redhat.com/show_bug.cgi?id=952793 and https://bugzilla.redhat.com/show_bug.cgi?id=761525. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-26rtlwifi: rtl8192cu: Fix false loss of AP indicationLarry Finger
A major change in the rtlwifi family recently added code to detect when there is loss of AP signals. One critical statement needed for the USB driver was missed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: net/mac80211/sta_info.c net/wireless/core.h
2013-03-25rtlwifi: usb: add NET_IP_ALIGN padding to RX skb when neededJussi Kivilinna
Add proper alignment at first packet copy, to avoid extra copies made later in networking stack. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25rtlwifi: usb: defer rx processing to taskletJussi Kivilinna
Move processing of received packets to tasklet from hard-irq context. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25rtlwifi: usb: remove extra skb copy on RX pathJussi Kivilinna
RX path has extra copying of packets, that can be avoided. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25rtlwifi: usb: use usb_alloc_coherent for RX buffersJussi Kivilinna
Use dedicated DMA coherent buffers for RX urbs, to avoid allocation of large skbuffs in hard-irq context and improve performance. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-18rtlwifi: usb: add missing freeing of skbuffJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-11wireless:rtlwifi: replaced kmalloc+memcpy with kmemdupAndrei Epure
Signed-off-by: Andrei Epure <epure.andrei@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-18rtlwifi: usb: allocate URB control message setup_packet and data buffer ↵Jussi Kivilinna
separately rtlwifi allocates both setup_packet and data buffer of control message urb, using shared kmalloc in _usbctrl_vendorreq_async_write. Structure used for allocating is: struct { u8 data[254]; struct usb_ctrlrequest dr; }; Because 'struct usb_ctrlrequest' is __packed, setup packet is unaligned and DMA mapping of both 'data' and 'dr' confuses ARM/sunxi, leading to memory corruptions and freezes. Patch changes setup packet to be allocated separately. [v2]: - Use WARN_ON_ONCE instead of WARN_ON Cc: <stable@vger.kernel.org> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-14Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/dvm/tx.c
2013-02-08rtlwifi: rtl8192cu: Fix NULL dereference BUG when using new_idLarry Finger
When the new_id entry in /sysfs is used for a foreign USB device, rtlwifi BUGS with a NULL pointer dereference because the per-driver configuration data is not available. The probe function has been restructured as suggested by Ben Hutchings <bhutchings@solarflare.com>. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-01rtlwifi: Fix warnings in usb.cLarry Finger
Building this driver with "make W=1" results in the following 2 warnings: drivers/net/wireless/rtlwifi/usb.c:829:21: warning: variable ‘urb_list’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/usb.c:828:23: warning: variable ‘skb_list’ set but not used [-Wunused-but-set-variable] Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-28rtlwifi: Fix the usage of the wrong variable in usb.cLarry Finger
In routine _rtl_rx_pre_process(), skb_dequeue() is called to get an skb; however, the wrong variable name is used in subsequent calls. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-02rtlwifi: Don't leak on error in _rtl_usb_receive()Jesper Juhl
We fail to release 'urb' if '_rtl_prep_rx_urb()' fails in _rtl_usb_receive(). This patch should take care of the leak. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-02rtlwifi: fix incorrect use of usb_alloc_coherent with usb_control_msgJussi Kivilinna
Incorrect use of usb_alloc_coherent memory as input buffer to usb_control_msg can cause problems in arch DMA code, for example kernel BUG at 'arch/arm/include/asm/dma-mapping.h:321' on ARM (linux-3.4). Change _usb_writeN_sync use kmalloc'd buffer instead. Cc: stable@vger.kernel.org Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06rtlwifi: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-10-24rtlwifi: pass rx setup error code to callerChristian Lamparter
If _rtl_usb_receive fails, the device is probably not ready. Hence the error code should be passed to the caller, so it can react accordingly and notify the user. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-09-07rtlwifi: rtl8192c: rtl8192ce: rtl8192cu: rtl8192se: Remove sparse warningsLarry Finger
The rtlwifi family of drivers has the following sparse errors: CHECK drivers/net/wireless/rtlwifi/usb.c drivers/net/wireless/rtlwifi/usb.c:122:17: warning: cast to restricted __le32 CHECK drivers/net/wireless/rtlwifi/rtl8192c/dm_common.c drivers/net/wireless/rtlwifi/rtl8192c/dm_common.c:1157:13: warning: context imbalance in 'rtl92c_dm_refresh_rate_adaptive_mask' - different lock contexts for basic block CHECK drivers/net/wireless/rtlwifi/rtl8192ce/hw.c drivers/net/wireless/rtlwifi/rtl8192ce/hw.c:1909:30: warning: cast to restricted __le32 CHECK drivers/net/wireless/rtlwifi/rtl8192ce/sw.c drivers/net/wireless/rtlwifi/rtl8192ce/sw.c:345:1: warning: symbol 'rtl92ce_pci_ids' was not declared. Should it be static? CHECK drivers/net/wireless/rtlwifi/rtl8192cu/trx.c drivers/net/wireless/rtlwifi/rtl8192cu/trx.c:494:9: warning: cast from restricted __le16 CHECK drivers/net/wireless/rtlwifi/rtl8192se/fw.c drivers/net/wireless/rtlwifi/rtl8192se/fw.c:490:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:490:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:494:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:494:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:499:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:499:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:510:25: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:510:25: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:607:9: warning: cast to restricted __le16 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:607:9: warning: cast to restricted __le16 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:650:9: warning: cast to restricted __le16 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:650:9: warning: cast to restricted __le16 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:652:9: warning: cast to restricted __le16 drivers/net/wireless/rtlwifi/rtl8192se/fw.c:652:9: warning: cast to restricted __le16 CHECK drivers/net/wireless/rtlwifi/rtl8192se/trx.c drivers/net/wireless/rtlwifi/rtl8192se/trx.c:758:9: warning: cast from restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/trx.c:788:17: warning: cast from restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/trx.c:804:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/trx.c:804:17: warning: cast to restricted __le32 drivers/net/wireless/rtlwifi/rtl8192se/trx.c:807:17: warning: cast from restricted __le32 Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-31mac80211: move TX station pointer and restructure TXThomas Huehn
Remove the control.sta pointer from ieee80211_tx_info to free up sufficient space in the TX skb control buffer for the upcoming Transmit Power Control (TPC). Instead, the pointer is now on the stack in a new control struct that is passed as a function parameter to the drivers' tx method. Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de> Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: Felix Fietkau <nbd@openwrt.org> [reworded commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-12rtlwifi: rtl8192cu: Change buffer allocation for synchronous readsLarry Finger
In commit a7959c1, the USB part of rtlwifi was switched to convert _usb_read_sync() to using a preallocated buffer rather than one that has been acquired using kmalloc. Although this routine is named as though it were synchronous, there seem to be simultaneous users, and the selection of the index to the data buffer is not multi-user safe. This situation is addressed by adding a new spinlock. The routine cannot sleep, thus a mutex is not allowed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-14rtlwifi: fix for race condition when firmware is cachedLarry Finger
In commit b0302ab, the rtlwifi family of drivers was converted to use asynchronous firmware loading. Unfortumately, the implementation was racy, and the ieee80211 routines could be started before rtl_init_core() was called to setup the data. This patch fixes the bug noted in https://bugzilla.kernel.org/show_bug.cgi?id=43187. Reported-by: Joshua Roys <Joshua.Roys@gtri.gatech.edu> Tested-by: Neptune Ning <frostyplanet@gmail.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> [3.3] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-11rtlwifi: Preallocate USB read buffers and eliminate kalloc in read routineLarry Finger
The current version of rtlwifi for USB operations uses kmalloc to acquire a 32-bit buffer for each read of the device. When _usb_read_sync() is called with the rcu_lock held, the result is a "sleeping function called from invalid context" BUG. This is reported for two cases in https://bugzilla.kernel.org/show_bug.cgi?id=42775. The first case has the lock originating from within rtlwifi and could be fixed by rearranging the locking; however, the second originates from within mac80211. The kmalloc() call is removed from _usb_read_sync() by creating a ring buffer pointer in the private area and allocating the buffer data in the probe routine. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> [This version good for 3.3+ - different patch for 3.2 - 2.6.39] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05rtlwifi: Remove extraneous value returnLarry Finger
In usb.c, routine _rtl_usb_init_sw() always returns 0, and rtl_usb_probe() never checks the returned value. Thus we can change _rtl_usb_init_sw() to a void routine. In addition, remove the underscore at the beginning of the name of the routine. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05rtlwifi: Detect misread of end-point countLarry Finger
In the unlikely event of a misread of the USB end point count, the driver generates a divide fault. To prevent this, add a check of the value returned by _rtl_usb_init(). In addition, add some logging to indicate why the condition occurred. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30rtlwifi: Convert to asynchronous firmware loadLarry Finger
This patch addresses a kernel bugzilla report and two recent mail threads. The kernel bugzilla report is https://bugzilla.kernel.org/show_bug.cgi?id=42632, which reports a udev timeout on boot. The first mail thread, which was on LKML (http://lkml.indiana.edu/hypermail/ linux/kernel/1112.3/00965.html) was for a WARNING that occurs after a suspend/resume cycle for rtl8192cu. The scond mail thread (http://marc.info/?l=linux-wireless&m=132655490826766&w=2) concerned changes in udev that break drivers that delay while firmware is loaded on modprobe. This patch converts all rtlwifi-based drivers to use the asynchronous firmware loading mechanism. Drivers rtl8192ce, rtl8192cu and rtl8192de share a common callback routine. Driver rtl8192se needs different handling of the firmware, thus it has its own code. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30rtlwifi: Move pr_fmt macros to a single locationLarry Finger
Although the rtlwifi family of devices contains 11 copies of the pr_fmt macro, the macro is not defined for all routines that need it. By moving the macro to wifi.h, a single copy is available for all routines. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24rtlwifi: Update copyright datesLarry Finger
2012-01-24rtlwifi: rtl8192c_common: rtl8192de: Check for allocation failuresLarry Finger
In https://bugzilla.redhat.com/show_bug.cgi?id=771656, a kernel bug was triggered due to a failed skb allocation that was not checked. This event lead to an audit of all memory allocations in the complete rtlwifi family of drivers. This patch fixes the rest. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24rtlwifi: Convert RT_ASSERT macro to use ##__VA_ARGS__Joe Perches
Consolidate printks to avoid possible message interleaving and reduce the object size. Remove unnecessary RT_ASSERT parentheses. Align arguments. Coalesce formats. Remove unnecessary __func__ use as the macro uses it. $ size drivers/net/wireless/rtlwifi/built-in.o* text data bss dec hex filename 588901 55333 127216 771450 bc57a drivers/net/wireless/rtlwifi/built-in.o.new 590002 55333 127560 772895 bcb1f drivers/net/wireless/rtlwifi/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24rtlwifi: Convert RT_TRACE macro to use ##__VA_ARGS__Joe Perches
Consolidate printks to avoid possible message interleaving and reduce the object size. Remove unnecessary RT_TRACE parentheses. Miscellaneous typo and grammar fixes. Add missing newlines to formats. Remove duplicate KERN_DEBUG prefixes. Coalesce formats. Align arguments. $ size drivers/net/wireless/rtlwifi/built-in.o* text data bss dec hex filename 594841 55333 129680 779854 be64e drivers/net/wireless/rtlwifi/built-in.o.new 607022 55333 138720 801075 c3933 drivers/net/wireless/rtlwifi/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24rtlwifi: Neaten RT_ASSERT, RT_TRACE, RTPRINT, RT_PRINT_DATA macrosJoe Perches
Make the macros a bit more readable. Use do {...} while (0) without terminating semicolons. Add missing terminating semicolon to a few uses. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22rtlwifi: squash warning in _usb_read_syncJohn W. Linville
drivers/net/wireless/rtlwifi/usb.c: In function ‘_usb_read_sync’: drivers/net/wireless/rtlwifi/usb.c:102:6: warning: ‘status’ may be used uninitialized in this function drivers/net/wireless/rtlwifi/usb.c:102:6: note: ‘status’ was declared here My compiler is dumb, but better to eliminate the warning than to have anyone waste time evaluating this again... Signed-off-by: John W. Linville <linville@tuxdriver.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
2011-11-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux Conflicts: drivers/net/wireless/iwlegacy/iwl-debugfs.c drivers/net/wireless/iwlegacy/iwl-rx.c drivers/net/wireless/iwlegacy/iwl-scan.c drivers/net/wireless/iwlegacy/iwl-tx.c include/net/bluetooth/bluetooth.h
2011-11-21rtlwifi: rtl8192cu: Fix endianian issuesLarry Finger
Driver rtlwifi fails on a big-endian host. These changes have been tested on a Mac PowerBook G4, which has a PPC processor. Although this patch touches some of the code that will affect endian issues on PCI hardware through drivers rtl8192ce, rtl8192se, and rtl8192de, these have not been tested due to lack of suitable hardware. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21rtlwifi: rtl8192cu: Change firmware upload to use block writesLarry Finger
Driver rtl8192cu writes the firmware with 32-bit asynchronous writes. This design is OK for USB 2.0 adapters, but the current implementation of xhcu-hcd has a limited ring size, which is exceeded. By converting to synchronous block writes, this error is avoided. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21rtlwifi: rtl8192cu: Allow retries for USB I/OGeorge
The USB driver does not retry reads - allow 10 tries. Signed-off-by: George <george0505@realtek.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
