path: root/drivers/net/wireless/rtlwifi/base.c
2014-01-13Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2014-01-07mac80211: remove channel_change_timeJohannes Berg
This value is no longer used by mac80211, and practically no driver ever set it to a correct value anyway, so remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-01-03rtlwifi: use ether_addr_equal_64bitsJulia Lawall
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be used when each argument is an array within a structure that contains at least two bytes of data beyond the array. The structures involved are: ieee80211_hdr defined in include/linux/ieee80211.h and rtl_mac defined in drivers/net/wireless/rtlwifi/wifi.h This was done using Coccinelle (http://coccinelle.lip6.fr/). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-12-05rtlwifi: rtl8192c: Prevent reconnect attempts if not connectedLarry Finger
This driver has a watchdog timer that attempts to reconnect when beacon frames are not seen for 6 seconds. This patch disables that reconnect whenever the device has never been connected. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-11-11rtlwifi: Fix endian error in extracting packet typeMark Cave-Ayland
All of the rtlwifi drivers have an error in the routine that tests if the data is "special". If it is, the subsequant transmission will be at the lowest rate to enhance reliability. The 16-bit quantity is big-endian, but was being extracted in native CPU mode. One of the effects of this bug is to inhibit association under some conditions as the TX rate is too high. Based on suggestions by Joe Perches, the entire routine is rewritten. One of the local headers contained duplicates of some of the ETH_P_XXX definitions. These are deleted. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Mark Cave-Ayland <mark.cave-ayland@ilande.co.uk> Cc: Stable <stable@vger.kernel.org> [2.6.38+] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-03rtlwifi: Implement a common rtl_phy_scan_operation_backup() routineLarry Finger
Several of the drivers supported by rtlwifi individually implement the same routine that supports scans. As a first step, create this routine in driver rtlwifi. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-09-03drivers/net: Convert uses of compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: (and a little typing) $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-18rtlwifi: Fix build errors for unusual casesLarry Finger
The present build configuration for the rtlwifi family of drivers will fail under two known conditions: (1) If rtlwifi is selected without selecting any of the dependent drivers, there are errors in the build. (2) If the PCI drivers are built into the kernel and the USB drivers are modules, or vice versa, there are missing globals. The first condition is fixed by never building rtlwifi unless at least one of the device drivers is selected. The second failure is fixed by splitting the PCI and USB codes out of rtlwifi, and creating their own mini drivers. If the drivers that use them are modules, they will also be modules. Although a number of files are touched by this patch, only Makefile and Kconfig have undergone significant changes. The only modifications to the other files were to export entry points needed by the new rtl_pci and rtl_usb units, or to rename two variables that had names that were likely to cause namespace collisions. Reported-by: Fengguang Wu <fengguang.wu@intel.com> [Condition 1] Reported-by: Ben Hutchings <bhutchings@solarflare.com> [Condition 2] Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-03drivers: avoid format strings in names passed to alloc_workqueue()Kees Cook
For the workqueue creation interfaces that do not expect format strings, make sure they cannot accidently be parsed that way. Additionally, clean up calls made with a single parameter that would be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-03net: wireless: replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-10Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: drivers/net/wireless/ath/carl9170/debug.c drivers/net/wireless/ath/carl9170/main.c net/mac80211/ieee80211_i.h
2013-04-01rtlwifi: rtl8192c: rtl8192ce: rtl8192cu: rtl8192de: rtl8723ae: Add changes ↵Larry Finger
required by adding rtl81988ee This patch combines the remaining changes in the rtlwifi family to handle the addition of rtl8188ee. A number of these changes eliminate some CamelCase variable names, and other shorten common variable names so that long lines in the new driver could be shortened. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: jcheung@suse.com Cc: machen@suse.com Cc: mmarek@suse.cz Cc: zhiyuan_yang@realsil.com.cn Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-01rtlwifi: Rework rtl_lps_leave() and rtl_lps_enter() to use work queueLarry Finger
In commit a5ffbe0, some of the calls to rtl_lps_leave() were switched to be called from a work queue to avoid a scheduling while atomic bug. This patch converts the remaining calls to use the work queue. In addition, the call to rtl_lps_enter() is also switched to the work queue. None of these newly converted calls had triggered the bug (yet), but this change make all of them fit a single pattern. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: jcheung@suse.com Cc: machen@suse.com Cc: mmarek@suse.cz Cc: zhiyuan_yang@realsil.com.cn Cc: page_he@realsil.com.cn Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-01rtlwifi Modify existing bits to match vendor version 2013.02.07Larry Finger
These changes add the new variables for P2P and modify the various struct definitions for other new features. This patch updates files base.{c,h} for the changes in the newest vendor driver. This patch updates files ps.{c,h} for the changes in the newest vendor driver. This patch updates files debug.{c,h}, efuse.c, pci.{c,h}, and wifi.h for the changes in the newest vendor driver. This patch updates files core.c, ps.c, rc.c, and wifi.h for the changes in the newest vendor driver. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: jcheung@suse.com Cc: machen@suse.com Cc: mmarek@suse.cz Cc: zhiyuan_yang@realsil.com.cn Cc: page_he@realsil.com.cn Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25mac80211: Use a cfg80211_chan_def in ieee80211_hw_conf_chanKarl Beldan
Drivers that don't use chanctxes cannot perform VHT association because they still use a "backward compatibility" pair of {ieee80211_channel, nl80211_channel_type} in ieee80211_conf and ieee80211_local. Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com> [fix kernel-doc] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15Merge branch 'for-john' of ↵John W. Linville
2013-02-15mac80211: stop toggling IEEE80211_HT_CAP_SUP_WIDTH_20_40Johannes Berg
For VHT, many more bandwidth changes are possible. As a first step, stop toggling the IEEE80211_HT_CAP_SUP_WIDTH_20_40 flag in the HT capabilities and instead introduce a bandwidth field indicating the currently usable bandwidth to transmit to the station. Of course, make all drivers use it. To achieve this, make ieee80211_ht_cap_ie_to_sta_ht_cap() get the station as an argument, rather than the new capabilities, so it can set up the new bandwidth field. If the station is a VHT station and VHT bandwidth is in use, also set the bandwidth accordingly. Doing this allows us to get rid of the supports_40mhz flag as the HT capabilities now reflect the true capability instead of the current setting. While at it, also fix ieee80211_ht_cap_ie_to_sta_ht_cap() to not ignore HT cap overrides when MCS TX isn't supported (not that it really happens...) Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-04rtlwifi: Fix scheduling while atomic bugLarry Finger
Kernel commits 41affd5 and 6539306 changed the locking in rtl_lps_leave() from a spinlock to a mutex by doing the calls indirectly from a work queue to reduce the time that interrupts were disabled. This change was fine for most systems; however a scheduling while atomic bug was reported in https://bugzilla.redhat.com/show_bug.cgi?id=903881. The backtrace indicates that routine rtl_is_special(), which calls rtl_lps_leave() in three places was entered in atomic context. These direct calls are replaced by putting a request on the appropriate work queue. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-and-tested-by: Nathaniel Doherty <ntdoherty@gmail.com> Cc: Nathaniel Doherty <ntdoherty@gmail.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-11-14rtlwifi: rtl8192ce: rtl8192cu: rtl8192se: rtl81723ae: Turn on building of ↵Larry Finger
the new driver This patch completes the addition of the new driver for the Realtek RTL8723AE devices by adding the make file and by modifying Kconfig and Makefile of rtlwifi. Some variable names were shortened to ease the problem of limiting all lines to 80 characters, thus changes were made to wifi.h and rtl8192{ce,cu,sw}/hw.c. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: <chaoming_li@realsil.com.cn> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-31mac80211: move TX station pointer and restructure TXThomas Huehn
Remove the control.sta pointer from ieee80211_tx_info to free up sufficient space in the TX skb control buffer for the upcoming Transmit Power Control (TPC). Instead, the pointer is now on the stack in a new control struct that is passed as a function parameter to the drivers' tx method. Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de> Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: Felix Fietkau <nbd@openwrt.org> [reworded commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-20Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2012-07-12rtlwifi: Remove extra argument from queue setup routineLarry Finger
Remove unused argument hw from call to rtl_tid_to_ac(). Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06wireless: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force, __iomem and __user. @@ type T; T *p; @@ - (T *)p + p Neatened the mwifiex_deauthenticate_infra function which was doing odd things with array pointers and not using is_zero_ether_addr. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-10drivers/net: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-09rtlwifi: Fix oops on rate-control failureLarry Finger
When the rate-control indexing is incorrectly set up, mac80211 issues a warning and returns NULL from the call to ieee80211_get_tx_rate(). When this happens, avoid a NULL pointer dereference. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22Correcting typos in rtlwifi/base.cTristan Pourcelot
This patch correct some typos in a comment. Signed-off-by: Tristan Pourcelot <tristan.pourcelot@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30rtlwifi: Convert to asynchronous firmware loadLarry Finger
This patch addresses a kernel bugzilla report and two recent mail threads. The kernel bugzilla report is https://bugzilla.kernel.org/show_bug.cgi?id=42632, which reports a udev timeout on boot. The first mail thread, which was on LKML (http://lkml.indiana.edu/hypermail/ linux/kernel/1112.3/00965.html) was for a WARNING that occurs after a suspend/resume cycle for rtl8192cu. The scond mail thread (http://marc.info/?l=linux-wireless&m=132655490826766&w=2) concerned changes in udev that break drivers that delay while firmware is loaded on modprobe. This patch converts all rtlwifi-based drivers to use the asynchronous firmware loading mechanism. Drivers rtl8192ce, rtl8192cu and rtl8192de share a common callback routine. Driver rtl8192se needs different handling of the firmware, thus it has its own code. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-30rtlwifi: Move pr_fmt macros to a single locationLarry Finger
Although the rtlwifi family of devices contains 11 copies of the pr_fmt macro, the macro is not defined for all routines that need it. By moving the macro to wifi.h, a single copy is available for all routines. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27mac80211: make beacon filtering per virtual interfaceJohannes Berg
Due to firmware limitations, we may not be able to support beacon filtering on all virtual interfaces. To allow this in mac80211, introduce per-interface driver capability flags that the driver sets when an interface is added. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24rtlwifi: Update copyright datesLarry Finger
2012-01-24rtlwifi: Convert RT_TRACE macro to use ##__VA_ARGS__Joe Perches
Consolidate printks to avoid possible message interleaving and reduce the object size. Remove unnecessary RT_TRACE parentheses. Miscellaneous typo and grammar fixes. Add missing newlines to formats. Remove duplicate KERN_DEBUG prefixes. Coalesce formats. Align arguments. $ size drivers/net/wireless/rtlwifi/built-in.o* text data bss dec hex filename 594841 55333 129680 779854 be64e drivers/net/wireless/rtlwifi/built-in.o.new 607022 55333 138720 801075 c3933 drivers/net/wireless/rtlwifi/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-03Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/b43/dma.c drivers/net/wireless/brcm80211/brcmfmac/dhd_linux.c
2011-12-19net: fix assignment of 0/1 to bool variables.Rusty Russell
DaveM said: Please, this kind of stuff rots forever and not using bool properly drives me crazy. Joe Perches <joe@perches.com> gave me the spatch script: @@ bool b; @@ -b = 0 +b = false @@ bool b; @@ -b = 1 +b = true I merely installed coccinelle, read the documentation and took credit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19rtlwifi: Fix locking problem introduces with commit 6539306bLarry Finger
When I tested commit 6539306, I did not notice that loading an out-of-tree module turns off lockdep testing in kernel 3.2. For that reason, I missed the kernel WARNING shown below: The solution fixes the warning by partially reverting commit 6539306. [ 84.168146] ------------[ cut here ]------------ [ 84.168155] WARNING: at kernel/mutex.c:198 mutex_lock_nested+0x309/0x310() [ 84.168158] Hardware name: HP Pavilion dv2700 Notebook PC [ 84.168161] Modules linked in: nfs lockd auth_rpcgss nfs_acl sunrpc af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 mperf e xt3 jbd ide_cd_mod cdrom snd_hda_codec_conexant arc4 rtl8192ce ide_pci_generic rtl8192c_common rtlwifi snd_hda_intel mac80211 snd_hda_codec snd_pcm snd_timer amd74xx ide_core cfg80211 k8temp snd joydev soundcore hwmon battery forcedeth i2c_nforce2 sg rfkill ac serio_raw snd_page_alloc button video i2c_core ipv6 a utofs4 ext4 mbcache jbd2 crc16 sd_mod ahci ohci_hcd libahci libata scsi_mod ehci_hcd usbcore usb_common fan processor thermal [ 84.168231] Pid: 1218, comm: kworker/u:2 Not tainted 3.2.0-rc5-wl+ #155 [ 84.168234] Call Trace: [ 84.168240] [<ffffffff81048aaa>] warn_slowpath_common+0x7a/0xb0 [ 84.168245] [<ffffffff81048af5>] warn_slowpath_null+0x15/0x20 [ 84.168249] [<ffffffff813811f9>] mutex_lock_nested+0x309/0x310 [ 84.168269] [<ffffffffa00793f9>] ? rtl_ips_nic_on+0x49/0xb0 [rtlwifi] [ 84.168277] [<ffffffffa00793f9>] rtl_ips_nic_on+0x49/0xb0 [rtlwifi] [ 84.168284] [<ffffffffa007ab85>] rtl_pci_tx+0x1b5/0x560 [rtlwifi] [ 84.168291] [<ffffffffa007635a>] rtl_op_tx+0x9a/0xa0 [rtlwifi] [ 84.168359] [<ffffffffa043cf51>] __ieee80211_tx+0x181/0x2b0 [mac80211] [ 84.168375] [<ffffffffa043ef06>] ieee80211_tx+0xf6/0x120 [mac80211] [ 84.168391] [<ffffffffa043ee49>] ? ieee80211_tx+0x39/0x120 [mac80211] [ 84.168408] [<ffffffffa043f80b>] ieee80211_xmit+0xdb/0x100 [mac80211] [ 84.168425] [<ffffffffa043f730>] ? ieee80211_skb_resize.isra.26+0xb0/0xb0 [mac80211] [ 84.168441] [<ffffffffa0440b2a>] ieee80211_tx_skb_tid+0x5a/0x70 [mac80211] [ 84.168458] [<ffffffffa0443da2>] ieee80211_send_auth+0x152/0x1b0 [mac80211] [ 84.168474] [<ffffffffa042e169>] ieee80211_work_work+0x1049/0x1860 [mac80211] [ 84.168489] [<ffffffffa042d120>] ? free_work+0x20/0x20 [mac80211] [ 84.168504] [<ffffffffa042d120>] ? free_work+0x20/0x20 [mac80211] [ 84.168510] [<ffffffff81065ffc>] process_one_work+0x17c/0x530 [ 84.168514] [<ffffffff81065f92>] ? process_one_work+0x112/0x530 [ 84.168519] [<ffffffff81066994>] worker_thread+0x164/0x350 [ 84.168524] [<ffffffff8108420d>] ? trace_hardirqs_on+0xd/0x10 [ 84.168528] [<ffffffff81066830>] ? manage_workers.isra.28+0x220/0x220 [ 84.168533] [<ffffffff8106bc17>] kthread+0x87/0x90 [ 84.168539] [<ffffffff813854b4>] kernel_thread_helper+0x4/0x10 [ 84.168543] [<ffffffff81382bdd>] ? retint_restore_args+0xe/0xe [ 84.168547] [<ffffffff8106bb90>] ? __init_kthread_worker+0x70/0x70 [ 84.168552] [<ffffffff813854b0>] ? gs_change+0xb/0xb [ 84.168554] ---[ end trace f25a4fdc768c028f ]--- Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stanislaw Gruska <sgruszka@redhat.com> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-13rtlwifi: merge ips,lps spinlocks into one mutexStanislaw Gruszka
With previous patch "rtlwifi: use work for lps" we can now use mutex for protecting ps mode changing critical sections. This fixes running system with interrupts disabled for long time. Merge ips_lock and lps_lock as they seems to protect the same data structures (accessed in rtl_ps_set_rf_state() function). Reported-by: Philipp Dreimann <philipp@dreimann.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Mike McCormack <mikem@ring3k.org> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux Conflicts: drivers/net/wireless/iwlegacy/iwl-debugfs.c drivers/net/wireless/iwlegacy/iwl-rx.c drivers/net/wireless/iwlegacy/iwl-scan.c drivers/net/wireless/iwlegacy/iwl-tx.c include/net/bluetooth/bluetooth.h
2011-11-21rtlwifi: rtl8192cu: Fix endianian issuesLarry Finger
Driver rtlwifi fails on a big-endian host. These changes have been tested on a Mac PowerBook G4, which has a PPC processor. Although this patch touches some of the code that will affect endian issues on PCI hardware through drivers rtl8192ce, rtl8192se, and rtl8192de, these have not been tested due to lack of suitable hardware. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31drivers/net: Add module.h to drivers who were implicitly using itPaul Gortmaker
The device.h header was including module.h, making it present for most of these drivers. But we want to clean that up. Call out the include of module.h in the modular network drivers. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-14rtlwifi: Update to new Realtek version - Part IChaoming Li
This patch incorporate the differences between the 06/20/2011 and 08/16/2011 Realtek releases of the rtlwifi driver. The changes include: 1. Handling of IEEE80211_HW_CONNECTION_MONITOR. 2. Fix typo to get proper response to nullfunc frames. Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24rtlwifi: Install updated rate-mapping routineLarry Finger
In preparation for fixing the rate-mapping situation, place a driver-agnostic version in rtlwifi. This one contains the updated rate incormation. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-21rtlwifi: Convert printks to pr_<level>Joe Perches
Use the current logging styles. Add pr_fmt where appropriate. Remove now unnecessary prefixes from printks. Convert hard coded prefix to __func__. Add a missing "\n" to a format. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-20wireless: rtlwifi: throw away MAC_FMT and use %pM insteadAndy Shevchenko
Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-20rtlwifi: rtl8192{c,ce,cu,se}: Remove comparisons of booleans with trueMike McCormack
These are a potential source of confusion, as most C code treats all non-zero values as true. Signed-off-by: Mike McCormack <mikem@ring3k.org> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01rtlwifi: Fix warnings from gcc 4.6.0Larry Finger
gcc 4.6.0 warnings for rtlwifi: CC [M] drivers/net/wireless/rtlwifi/base.o drivers/net/wireless/rtlwifi/base.c: In function ‘rtl_tx_agg_stop’: drivers/net/wireless/rtlwifi/base.c:891:23: warning: variable ‘tid_data’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/base.c: In function ‘rtl_tx_agg_oper’: drivers/net/wireless/rtlwifi/base.c:921:23: warning: variable ‘tid_data’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/efuse.o drivers/net/wireless/rtlwifi/efuse.c: In function ‘efuse_pg_packet_write’: drivers/net/wireless/rtlwifi/efuse.c:928:24: warning: variable ‘dataempty’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/efuse.c: In function ‘efuse_get_current_size’: drivers/net/wireless/rtlwifi/efuse.c:1179:5: warning: variable ‘hoffset’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/ps.o drivers/net/wireless/rtlwifi/ps.c: In function ‘rtl_ps_set_rf_state’: drivers/net/wireless/rtlwifi/ps.c:85:19: warning: variable ‘rtstate’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/regd.o drivers/net/wireless/rtlwifi/regd.c: In function ‘_rtl_dump_channel_map’: drivers/net/wireless/rtlwifi/regd.c:310:28: warning: variable ‘ch’ set but not used [-Wunused-but-set-variable] CC [M] drivers/net/wireless/rtlwifi/usb.o drivers/net/wireless/rtlwifi/usb.c: In function ‘_rtl_usb_transmit’: drivers/net/wireless/rtlwifi/usb.c:826:21: warning: variable ‘urb_list’ set but not used [-Wunused-but-set-variable] drivers/net/wireless/rtlwifi/usb.c:825:23: warning: variable ‘skb_list’ set but not used [-Wunused-but-set-variable] Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas/if_cs.c drivers/net/wireless/rtlwifi/pci.c net/bluetooth/l2cap_sock.c
2011-04-26rtlwifi: rtl8192ce: rtl8192cu: Fix most sparse warningsLarry Finger
Fix most sparse warnings in rtlwifi, rtl8192ce and rtl8192cu drivers. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-26rtlwifi: Convert core routines for addition of rtl8192se and rtl8192deChaoming_Li
Convert core routines for addition of RTL8192SE and RTL8192DE code. Additional files are changed to allow compilation. Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-26rtlwifi: Change base routines for addition of rtl8192se and rtl8192deChaoming_Li
Change base routines for addition of RTL8192SE and RTL8192DE code. Additional files are modified to allow compilation. Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-25Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/rt2x00/rt2x00queue.c drivers/net/wireless/rt2x00/rt2x00queue.h
