path: root/drivers/net/wireless/rt2x00/rt2x00firmware.c
2015-11-18rt2x00: move under ralink vendor directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-01-07rt2x00: use helper to check capability/requirementFred Chou
Use rt2x00_has_cap_flag macro to check rt2x00dev->cap_flags. Signed-off-by: Fred Chou <fred.chou.nd@gmail.com> Acked-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2013-12-11rt2x00: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: linux-wireless@vger.kernel.org CC: Ivo van Doorn <IvDoorn@gmail.com> CC: Gertjan van Wingerde <gwingerde@gmail.com> CC: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-22rt2x00: Use more current logging styles, shrink object sizeJoe Perches
Reduce object space ~2% using more current logging styles. Neaten and simplify logging macros. Use wiphy_<level> where appropriate. Coalesce formats. Convert ERROR/WARNING/INFO macros to rt2x00_<level> Convert EEPROM to rt2x00_eeprom_dbg Convert PROBE_ERROR to rt2x00_probe_err Convert DEBUG to rt2x00_dbg Convert EEPROM to rt2x00_eeprom_dbg $ size drivers/net/wireless/rt2x00/built-in.o* text data bss dec hex filename 245639 71696 69584 386919 5e767 drivers/net/wireless/rt2x00/built-in.o.new 240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.nodyndbg 240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.no_rt2x00_debug 249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old 249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old.nodyndbg 244222 70096 69712 384030 5dc1e drivers/net/wireless/rt2x00/built-in.o.old.no_rt2x00_debug Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-19rt2x00: Split rt2x00dev->flagsIvo van Doorn
The number of flags defined for the rt2x00dev->flags field, has been growing over the years. Currently we are approaching the maximum number of bits which are available in the field. A secondary problem, is that one part of the field are initialized only during boot, because the driver requirements are initialized or device requirements are loaded from the EEPROM. In both cases, the flags are fixed and will not change during device operation. The other flags are the device state, and will change frequently. So far this resulted in the fact that for some flags, the atomic bit accessors are used, while for the others the non-atomic variants are used. By splitting the flags up into a "flags" and "cap_flags" we can put all flags which are fixed inside "cap_flags". This field can then be read non-atomically. In the "flags" field we keep the device state, which is going to be read atomically. This adds more room for more flags in the future, and sanitizes the field access methods. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Acked-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13rt2x00: Don't leak mem in error path of rt2x00lib_request_firmware()Jesper Juhl
We need to release_firmware() in order not to leak memory. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Acked-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16rt2x00: update fw version info in wiphy structJohn W. Linville
This makes the information available through ethtool... Signed-off-by: John W. Linville <linville@tuxdriver.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11rt2x00: Update copyright statements.Gertjan van Wingerde
As mentioned on the linux-wireless mailing list, the current copyright statements in the rt2x00 are meaningless, as the rt2x00 project is not even a formal legal entity. Therefore it is better to replace the existing copyright statements with copyright statements for the people that actually wrote the code. Note: Updated to the best of my knowledge with respect to who contributed considerable amounts of code. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09rt2x00: Validate firmware in driverIvo van Doorn
The get_firmware_crc() callback function isn't flexible enough when dealing with multiple firmware versions. It might in some cases be possible that the firmware file contains multiple CRC checksums. Create the check_firmware() callback function where the driver has complete freedom in how to validate the firmware. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29rt2x00: Update copyright year to 2009Ivo van Doorn
2008-07-14rt2x00: Reset LED assoc status after firmware updateIvo van Doorn
According to the legacy drivers the LED association status must be reset after the firmware has been uploaded to the hardware. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Move firmware checksumming to driverIvo van Doorn
rt2x00lib depended on 2 crc algorithms because rt61/rt73 use a different algorithm then rt2800. This means that even when only 1 algorithm was needed, the dependency was still present for both. By moving the checksum generation to the driver we can clean up 2 annoying flags (which indicated which checksum was required) and move the dependency to where it belongs: the driver. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Driver requiring firmware should select crc algoIvo van Doorn
The driver should select what CRC algorithm is required when performing a checksum on the firmware. rt61pci & rt73usb require crc-itu-t rt2800pci & rt2800usb require crc-ccitt Legacy 2800pci/usb driver uses crc-itu-t + bit order reversion, but that is just inefficient especially since the end result is the same as a different algorithm which is also available as library. ;) Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Update copyright noticeIvo van Doorn
2008-01-28rt2x00: Replace DRV_NAME with KBUILD_MODNAMEIvo van Doorn
DRV_NAME was always set to the KBUILD_MODNAME value, lets clean everything up by removing DRV_NAME and just use KBUILD_MODNAME directly. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[RT2x00]: add driver for Ralink wireless hardwareIvo van Doorn
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
