path: root/drivers/net/wireless/mwifiex/ioctl.h
2015-11-18mwifiex: move under marvell vendor directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-06-08mwifiex: parse power constraint IE from TailAvinash Patil
This patch adds support to parse power constraint IEs from Tail buffer. This power constraint is then set to FW during bss_config download. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Cathy Luo <cluo@marvell.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-05-26mwifiex: add prints debug ctrl supportZhaoyang Liu
This patch adds support for debugging print control in mwifiex driver. The debug level can be controlled via either by modules load parameter debug_mask or by writing to debug_mask in debugfs file. Signed-off-by: Zhaoyang Liu <liuzy@marvell.com> Signed-off-by: Cathy Luo <cluo@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-05-26mwifiex: add support for FW memory read/write operationsChin-ran Lo
This patch adds support for FW memory read/write operations via debugfs. This is useful during debugging FW issues. Examples: For reading FW memory location: echo r 0x01ac > /sys/kernel/debug/mwifiex/mlan0/memrw cat /sys/kernel/debug/mwifiex/mlan0/memrw For writing FW memory location: echo w 0x01ac 0x55aa > /sys/kernel/debug/mwifiex/mlan0/memrw Signed-off-by: Chin-ran Lo <crlo@marvell.com> Signed-off-by: Cathy Luo <cluo@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-01-06mwifiex: add bcn_rcv_cnt and bcn_miss_cnt in getlog debugfsXinming Hu
This patch add receive beacon count and miss beacon count statistics in debugfs getlog item. Signed-off-by: Xinming Hu <huxm@marvell.com> Signed-off-by: Cathy Luo <cluo@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-01-06mwifiex: report tdls peers in debugfsXinming Hu
This patch add provision to show TDLS peer table in debugfs file. Signed-off-by: Xinming Hu <huxm@marvell.com> Signed-off-by: Cathy Luo <cluo@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2014-06-25mwifiex: update Copyright to 2014Xinming Hu
This patch updates mwifiex Copyright to 2014. Signed-off-by: Xinming Hu <huxm@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-04-22mwifiex: increase the number of nodes in command poolAmitkumar Karwar
Command nodes are increased from 20 to 50. Now we can always scan 1 channel per scan command to avoid traffic delay/loss in connected state. We will get rid of *CHANNEL_PER_SCAN_CMD macros used due to command node constraints. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-03-14mwifiex: add AMSDU inside AMPDU supportAmitkumar Karwar
Currently AMPDU aggregation is preferred over AMSDU. AMSDU aggregation is performed only if AMPDU streams in firmware are full. This patch adds simultaneous AMSDU and AMPDU aggregation support. This mechanism helps to improve throughput. AMSDU is enabled only for 8897 chipsets which supports 4K transmit buffer. User can disable AMSDU using 'disable_tx_amsdu' module parameter. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-28mwifiex: replace num_cmd_timeout with is_cmd_timedoutAmitkumar Karwar
Command timeout happens when firmware goes into bad state. There is no chance that next command will be successful after this. Hence we will maintain a flag instead of count. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-12mwifiex: add key material v2 supportAvinash Patil
This patch adds key material V2 support to mwifiex. Newer FW supports this feature and FW KEY API version is used to determine which command structure needs to be used. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-12mwifiex: add cfg80211 tdls_oper handler supportAvinash Patil
This patch adds cfg80211 handler tdls_oper handler support to mwifiex. Upon enable link, driver sets status as TDLS status as setup complete and also sets AMSDU size, AMPDU params for direct link. Upon disable link, driver issues command to FW to delete this link in FW. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-12mwifiex: add tdls_mgmt handler supportAvinash Patil
This patch adds support for TDLS management frames transmit handler. mwifiex driver supports TDLS with external support, i.e. expects user space application to form TDLS frames. Same is advertised to cfg80211 during registration. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-12mwifiex: remove unsupported code in 11acBing Zhao
bit12 in fw_cap_info is for testing only. Remove all related code. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-08-09mwifiex: add packet coalesce supportAmitkumar Karwar
Coalesce filters are configured in firmware based on settings received from cfg80211. Packet type which is required by firmware is determined based on provided patterns in a rule: Unicast: if pattern '01' with offset 0 is found Multicast: if pattern '33:33' or '01:00:5e' with offset 0 is found Broadcast: if pattern 'ff:ff:ff:ff' with offset 0 is found Some example coalesce configuration files: 1) Coalesce Rx data packets from 192.168.0.88 mac address of our device is 00:50:43:21:53:7A Source IP address offset comes out as 52 after following calculations: 32 bytes of HW 802.11 header + 8 bytes LLC + 12 bytes in IPV4 header till source IP address Destination mac is at offset 6 in HW header. delay=100 condition=1 patterns=01,6+00:50:43:22,10+53:7A,52+c0:a8:00:58 2) Coalesce all broadcast and multicast packets(Multiple packet types are not allowed in a single rule. Hence created separate rules) delay=400 condition=1 patterns=33:33 delay=400 condition=1 patterns=ff:ff:ff:ff Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-08-09mwifiex: rename mef macrosAmitkumar Karwar
Their names were generic. We need to define similar macros for coalesce feature. Hence they are renamed here. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25mwifiex: add support to configure VHT for AP modeYogesh Ashok Powar
Currently, default VHT configuration from the firmware is used for the VHT operations. Adding vhtcfg command to configure the firmware based on input received from cfg. Enable VHT for AP mode only when cfg80211_ap_settings has a VHT IE i.e., when ieee80211ac is set to 1 in the hostapd.conf. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-06mwifiex: add WOWLAN supportAmitkumar Karwar
Currently 'magic-packet' and 'patterns' options in 'iw wowlan' command are supported. Appropriate packet filters for wowlan are configured in firmware based on provided patterns and/or magic-packet option. For examples, wake-on ARP request for 192.168.0.100: iw phy0 wowlan enable patterns ff:ff:ff:ff:ff:ff 20+08:06 46+c0:a8:00:64 wake-on RX packets sent from IP address 192.168.0.88: iw phy0 wowlan enable patterns 34+c0:a8:00:58 wake-on RX packets with TCP destination port 80 iw phy0 wowlan enable patterns 44+50 wake-on MagicPacket: iw phy0 wowlan enable magic-packet wake-on MagicPacket or patterns: iw phy0 wowlan enable magic-packet patterns 12+00:11:22:33:44:55 18+00:50:43:21 wake-on IPv4 multicast packets: iw phy0 wowlan enable patterns 01:00:5e wake-on IPv6 multicast packets: iw phy0 wowlan enable patterns 33:33 disable all wowlan options iw phy0 wowlan disable Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-18mwifiex: add 802.11AC supportYogesh Ashok Powar
For STA mode, collect VHT realated IEs from the Beacons or Probe Responses and append similar VHT related IEs to association requests. For AP mode, get VHT related capability information and share it with cfg80211 at the time of wiphy register. This information is further used by cfg80211 and hostapd to start an AP with 802.11AC support. Currently only 8897 supports 802.11AC. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Frank Huang <frankh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-01mwifiex: remove max_tx_buf_sizeBing Zhao
max_tx_buf_size is not used any more after reconfiguration of tx buffer size has been removed. Also add missing curr_tx_buf_size update while dumping debug info via debugfs. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-07mwifiex: parse WMM IEs from hostapd for mwifiex APAvinash Patil
This patch adds support for parsing WMM IEs from hostapd and setting them to FW via sys configure command. Patch also sets wiphy flag to advertise AP uAPSD support. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-09-28mwifiex: add inactivity deauth support for apKevin Gan
The firmware has support for this feature, so we offload it to firmware. In start_ap, driver passes the inactivity timeout value to firmware via TLVs and firmware will report STA_DEAUTH event to driver when inactivity timer is fired. Signed-off-by: Kevin Gan <ganhy@marvell.com> Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-09-07mwifiex: parse rate info for APAvinash Patil
This patch adds support for parsing rates from cfg80211_ap_settings of start_ap handler. This in turn adds support for 11a and 11b phy configurations. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-06mwifiex: pass key_params pointer in mwifiex_set_encodeYing Luo
'cipher' and 'seq' coming from cfg80211 add_key handler will be parsed in mwifiex_set_encode() to handle AES_CMAC cipher suite. Signed-off-by: Ying Luo <luoy@marvell.com> Signed-off-by: Stone Piao <piaoyun@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-06mwifiex: rename wapi_rxpn to pnYing Luo
This array was used for wapi_rxpn only. Now it will be used for AES_CMAC as well. So make a generic name for it. Signed-off-by: Ying Luo <luoy@marvell.com> Signed-off-by: Stone Piao <piaoyun@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-17mwifiex: remove unnecessary code in data rate configurationAmitkumar Karwar
1) Remove unnecessary wrapper functions. 2) Currently we don't have command to set Tx data rate, so mwifiex_rate_ioctl_set_rate_value() function and related code can be removed. 3) "ds_rate" filled by mwifiex_ret_tx_rate_cfg() is never used. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-09mwifiex: add set_antenna handler supportAmitkumar Karwar
This enables user to set mode of Tx/Rx path using "iw set antenna" command. For non MIMO chips, the command will be used for selecting specific antenna or configuring antenna diversity mode. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-20mwifiex: support for WEP in AP modeAvinash Patil
This patch adds support for WEP open/shared encryption in AP mode. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-20mwifiex: set HT capability based on cfg80211_ap_settingsAvinash Patil
Parse HT IE from cfg80211 and set HT capabilities accordingly to FW. If HT IE is missing, 11n would be disabled in FW. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16mwifiex: add custom IE frameworkAvinash Patil
1. support for setting custom IE from application hostapd etc. Custom IE addition using auto-indexing and Custom IE deletion using static indices (which are allocated during IE addition and stored in driver) are supported. 2. Separate file for handling IE related execution. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16mwifiex: add WPA2 support for APAvinash Patil
1. Support for parsing security related parameters from cfg80211_ap_settings in start_ap cfg80211 handler 2. Conversion of these security information into FW understandle TLVs and setting into FW thru sys_config command 3. key management is done on host. This ensures that FW forwards EAPOL key packets to host instead of processing on its own. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16mwifiex: add cfg80211 start_ap and stop_ap handlersAvinash Patil
1. add start AP and stop AP handlers 2. support for parsing ssid, beacon period, DTIM period from beacon_parameters structure and setting it to FW. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16mwifiex: common set_wiphy_params cfg80211 handler for AP and STA interfaceAvinash Patil
Add support for setting fragmentation threshold, RTS threshold and retry limit. Since wiphy parameters are properties of physical device, appropriate function to set phy parameters is invoked depending upon bss_type(STA or AP) for each virtual interface. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16mwifiex: add AP command sys_config and set channelAvinash Patil
1. support for AP sys_config command and added parsing of channel information. 2. support for setting AP channel from cfg80211 set_channel handler Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-12mwifiex: add support for WPS2.0Avinash Patil
This patches enables setting association request and probe request IE for station interface. WPS exchange between WPS2.0 AP and mwifiex STA Enrollee/External Registrar completes successfully. Tested with wpa_supplicant 1.0 and 2.0 devel. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-12mwifiex: display correct country information in debugfs "info"Amitkumar Karwar
Use "priv->country_code" string to display country information in debugfs command "info" instead of "adapter->region_code". "adapter->region_code" contains default region code got from FW while initialization, whereas "priv->country_code" is updated in reg_notifier handler whenever there is a change in regulatory domain. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-09mwifiex: add set_cqm_rssi_config handler supportAmitkumar Karwar
In this handler LOW_RSSI and HIGH_RSSI events are subscribed to FW using provided threshold value so that FW will monitor connection quality and trigger any of these events. Driver will notify cfg80211 about connection quality based on inputs from FW and provided hysteresis. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-09mwifiex: remove redundant signal handling codeAmitkumar Karwar
1) The wrapper function mwifiex_get_signal_info() is unnecessary. 2) As noise and signal vaules in private structure already get modified, we don't need to explicitly pass "struct mwifiex_ds_get_signal" to get it filled. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05mwifiex: remove unnecessary struct mwifiex_802_11_ssidAmitkumar Karwar
Use struct cfg80211_ssid available in include/net/cfg80211.h instead of having similar definition in driver. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-21mwifiex: use IEEE80211_HT_PARAM_CHA_SEC_* macrosAmitkumar Karwar
Replace driver specific macros with the corresponding IEEE80211_HT_PARAM_CHA_SEC_* macros defined in ieee80211.h. Also, rename 'adapter->chan_offset' to 'adapter->sec_chan_offset' for consistency. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-21mwifiex: remove redundant band config codeAmitkumar Karwar
struct mwifiex_ds_band_cfg and mwifiex_set_radio_band_cfg() routine are unnecessary. It can be done with simple equivalant code. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08mwifiex: remove redundant variable scan_table_idxBing Zhao
mwifiex_get_bss_info() routine updates variable 'info->scan_table_idx' but it is never used. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08mwifiex: remove wireless.h inclusion and fix resulting bugsBing Zhao
replace IW_MAX_AP & IW_CUSTOM_MAX with local definitions and remove usage of struct iw_statistics. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08mwifiex: add wext includeJohannes Berg
In trying to remove the wext includes from mac80211 and cfg80211 I found that mwifiex currently uses them. This is wrong, it shouldn't, but to not break it completely include wext there. Please remove this and fix all the resulting bugs. Cc: Bing Zhao <bzhao@marvell.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-21mwifiex: disable auto deep sleep before unloading the driverAmitkumar Karwar
Since the auto deep sleep mode has been enabled at driver init time we should disable it at driver unloading to shutdown the function gracefully. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11mwifiex: cleanup ioctl.hBing Zhao
Some structures and macros in ioctl.h are redundant or no longer used. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-19mwifiex: remove some macro definitionsAmitkumar Karwar
use corresponding macros defined in include/linux/ieee80211.h Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-07mwifiex: remove redundant encryption_mode mappingYogesh Ashok Powar
remove MWIFIEX_ENCRYPTION_MODE_ and use WLAN_CIPHER_SUITE_ macros directly Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-04mwifiex: remove unused radio_on variable and macrosMarc Yang
The radio_on variable is defined but never used. Signed-off-by: Marc Yang <yangyang@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-04mwifiex: remove MWIFIEX_AUTH_MODE_ macrosMarc Yang
replace them with NL80211_AUTHTYPE_ macros Signed-off-by: Marc Yang <yangyang@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
