path: root/drivers/net/wireless/libertas
2013-03-01Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-02-27libertas: fix crash for SD8688Bing Zhao
For SD8688, FUNC_INIT command is queued before fw_ready flag is set. This causes the following crash as lbs_thread blocks any command if fw_ready is not set. [ 209.338953] [<c0502248>] (__schedule+0x610/0x764) from [<bf20ae24>] (__lbs_cmd+0xb8/0x130 [libertas]) [ 209.348340] [<bf20ae24>] (__lbs_cmd+0xb8/0x130 [libertas]) from [<bf222474>] (if_sdio_finish_power_on+0xec/0x1b0 [libertas_sdio]) [ 209.360136] [<bf222474>] (if_sdio_finish_power_on+0xec/0x1b0 [libertas_sdio]) from [<bf2226c4>] (if_sdio_power_on+0x18c/0x20c [libertas_sdio]) [ 209.373052] [<bf2226c4>] (if_sdio_power_on+0x18c/0x20c [libertas_sdio]) from [<bf222944>] (if_sdio_probe+0x200/0x31c [libertas_sdio]) [ 209.385316] [<bf222944>] (if_sdio_probe+0x200/0x31c [libertas_sdio]) from [<bf01d820>] (sdio_bus_probe+0x94/0xfc [mmc_core]) [ 209.396748] [<bf01d820>] (sdio_bus_probe+0x94/0xfc [mmc_core]) from [<c02e729c>] (driver_probe_device+0x12c/0x348) [ 209.407214] [<c02e729c>] (driver_probe_device+0x12c/0x348) from [<c02e7530>] (__driver_attach+0x78/0x9c) [ 209.416798] [<c02e7530>] (__driver_attach+0x78/0x9c) from [<c02e5658>] (bus_for_each_dev+0x50/0x88) [ 209.425946] [<c02e5658>] (bus_for_each_dev+0x50/0x88) from [<c02e6810>] (bus_add_driver+0x108/0x268) [ 209.435180] [<c02e6810>] (bus_add_driver+0x108/0x268) from [<c02e782c>] (driver_register+0xa4/0x134) [ 209.444426] [<c02e782c>] (driver_register+0xa4/0x134) from [<bf22601c>] (if_sdio_init_module+0x1c/0x3c [libertas_sdio]) [ 209.455339] [<bf22601c>] (if_sdio_init_module+0x1c/0x3c [libertas_sdio]) from [<c00085b8>] (do_one_initcall+0x98/0x174) [ 209.466236] [<c00085b8>] (do_one_initcall+0x98/0x174) from [<c0076504>] (load_module+0x1c5c/0x1f80) [ 209.475390] [<c0076504>] (load_module+0x1c5c/0x1f80) from [<c007692c>] (sys_init_module+0x104/0x128) [ 209.484632] [<c007692c>] (sys_init_module+0x104/0x128) from [<c0008c40>] (ret_fast_syscall+0x0/0x38) Fix it by setting fw_ready flag prior to queuing FUNC_INIT command. Cc: <stable@vger.kernel.org> # 3.5+ Reported-by: Lubomir Rintel <lkundrak@v3.sk> Tested-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-18Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/dvm/tx.c drivers/net/wireless/ti/wlcore/sdio.c drivers/net/wireless/ti/wlcore/spi.c
2013-02-11cfg80211: pass wiphy to cfg80211_ref_bss/put_bssJohannes Berg
This prepares for using the spinlock instead of krefs which is needed in the next patch to track the refs of combined BSSes correctly. Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-04wireless: Remove unnecessary alloc/OOM messages, alloc cleanupsJoe Perches
alloc failures already get standardized OOM messages and a dump_stack. Convert kzalloc's with multiplies to kcalloc. Convert kmalloc's with multiplies to kmalloc_array. Remove now unused variables. Remove unnecessary memset after kzalloc->kcalloc. Whitespace cleanups for these changes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14wireless: make the reg_notifier() voidLuis R. Rodriguez
The reg_notifier()'s return value need not be checked as it is only supposed to do post regulatory work and that should never fail. Any behaviour to regulatory that needs to be considered before cfg80211 does work to a driver should be specified by using the already existing flags, the reg_notifier() just does post processing should it find it needs to. Also make lbs_reg_notifier static. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> [move lbs_reg_notifier to not break compile] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-12-06libertas: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Dan Williams <dcbw@redhat.com> Cc: libertas-dev@lists.infradead.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: drivers/net/wireless/mwifiex/sta_ioctl.c net/mac80211/scan.c
2012-11-30cfg80211: fix BSS struct IE access racesJohannes Berg
When a BSS struct is updated, the IEs are currently overwritten or freed. This can lead to races if some other CPU is accessing the BSS struct and using the IEs concurrently. Fix this by always allocating the IEs in a new struct that holds the data and length and protecting access to this new struct with RCU. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26Merge branch 'for-john' of ↵John W. Linville
2012-11-26cfg80211: pass a channel definition structJohannes Berg
Instead of passing a channel pointer and channel type to all functions and driver methods, pass a new channel definition struct. Right now, this struct contains just the control channel and channel type, but for VHT this will change. Also, add a small inline cfg80211_get_chandef_type() so that drivers don't need to use the _type field of the new structure all the time, which will change. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-14add Marvell 88W8688 support to libertas_sdioHarro Haan
This chip is for example used in the GuruPlug. This patch avoids the following error: libertas_sdio: failed to load firmware libertas_sdio: probe of mmc0:0001:1 failed with error -5 The fix is based on code in: drivers/net/wireless/libertas_uap/uap_sdio_mmc.c This file can for example be found on the following links: http://www.xilka.com/sheeva/2.6/2.6.36/2.6.36.2/source/0002-Driver-for-Marvell-Libertas-8688-SDIO-micro-AP-suppo-2.6.35.patch http://www.downloadsnewit.co.uk/kernel-v3.0.7/ I followed the following wiki to setup a working WiFi client mode connection on the GuruPlug: http://wiki.debian.org/libertas Signed-off-by: Harro Haan <hrhaan@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-10-18wireless: drivers: make use of WLAN_EID_VENDOR_SPECIFICArend van Spriel
The include file linux/ieee80211.h contains three definitions for the same thing in enum ieee80211_eid due to historic changes: /* Information Element IDs */ enum ieee80211_eid { : WLAN_EID_WPA = 221, WLAN_EID_GENERIC = 221, WLAN_EID_VENDOR_SPECIFIC = 221, : }; The standard refers to this as "vendor specific" element so the other two definitions are better not used. This patch changes the wireless drivers to use one definition, ie. WLAN_EID_VENDOR_SPECIFIC. Cc: Jouni Malinen <j@w1.fi> Cc: Dan Williams <dcbw@redhat.com> Cc: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Kalle Valo <kvalo@qca.qualcomm.com> [ath6kl] Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex] Acked-by: Stanislav Yakovlev <stas.yakovlev@gmail.com> [ipw2x00] Signed-off-by: Arend van Spriel <arend@broadcom.com> [change libipw as well] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-09-14Merge branch 'master' of ↵John W. Linville
2012-09-11libertas: set mac control synchronously during initDaniel Drake
CMD_MAC_CONTROL is currently sent async to the firmware, and is sent from the lbs_setup_firmware() path during device init. This means that device init can complete with commands pending, and the if_sdio driver will sometimes power down the device (after init) with this command still pending. This was causing an occasional spurious command timeout after init, leading to a device reset. Fix this by making CMD_MAC_CONTROL synchronous when called from the lbs_setup_firmware() path. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-09-05libertas sdio: fix suspend when interface is downDaniel Drake
When the interface is down, the hardware is powered off. However, the suspend handler currently tries to send host sleep commands (when wakeup params are set) in this configuration, causing a system hang when going into suspend (the commands will never complete). Avoid this by detecting this situation and simply returning from the suspend handler without doing anything special. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Missed rcu_assign_pointer() in mac80211 scanning, from Johannes Berg. 2) Allow devices to limit the number of segments that an individual TCP TSO packet can use at a time, to deal with device and/or driver specific limitations. From Ben Hutchings. 3) Fix unexpected hard IPSEC expiration after setting the date. From Fan Du. 4) Memory leak fix in bxn2x driver, from Jesper Juhl. 5) Fix two memory leaks in libertas driver, from Daniel Drake. 6) Fix deref of out-of-range array index in packet scheduler generic actions layer. From Hiroaki SHIMODA. 7) Fix TX flow control errors in mlx4 driver, from Yevgeny Petrilin. 8) Fix CRIS eth_v10.c driver build, from Randy Dunlap. 9) Fix wrong SKB freeing in LLC protocol layer, from Sorin Dumitru. 10) The IP output path checks neigh lookup errors incorrectly, it needs to use IS_ERR(). From Vasiliy Kulikov. 11) An estimator leak leads to deref of freed memory in timer handler, fix from Hiroaki SHIMODA. 12) TCP early demux in ipv6 needs to use DST cookies in order to validate the RX route properly. Fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits) net: ipv6: fix TCP early demux net: Use PTR_RET rather than if(IS_ERR(.. [1] net_sched: act: Delete estimator in error path. ip: fix error handling in ip_finish_output2() llc: free the right skb ixp4xx_eth: fix ptp_ixp46x build failure drivers/atm/iphase.c: fix error return code tcp_output: fix sparse warning for tcp_wfree drivers/net/phy/mdio-mux-gpio.c: drop devm_kfree of devm_kzalloc'd data batman-adv: select an internet gateway if none was chosen mISDN: Bugfix for layer2 fixed TEI mode igb: don't break user visible strings over multiple lines in igb_ethtool.c igb: correct hardware type (i210/i211) check in igb_loopback_test() igb: Fix for failure to init on some 82576 devices. cris: fix eth_v10.c build error cdc-ncm: tag Ericsson WWAN devices (eg F5521gw) with FLAG_WWAN isdnloop: fix and simplify isdnloop_init() hyperv: Move wait completion msg code into rndis_filter_halt_device() net/mlx4_core: Remove port type restrictions net/mlx4_en: Fixing TX queue stop/wake flow ...
2012-08-02libertas: fix two memory leaksDaniel Drake
The if_sdio_card structure was never being freed, and neither was the command structure used for association. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-02libertas: don't reset card on error when it is being removedDaniel Drake
On an OLPC XO-1.5 we have seen the following situation: - the system starts going into suspend - no wake params are set, so the mmc layer removes the card - during remove, we send a command to the card - that command fails, causing if_sdio's reset method to try and remove the mmc card in attempt to reset it - the mmc layer is not happy about being asked to remove a card that it is already removing, and the kernel crashes While the MMC layer could possibly be taught to behave better here, it also seems sensible for libertas not to try and reset a card if we're in the process of removing it anyway. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-31drivers: OLPC: update various drivers to include olpc-ec.hAndres Salomon
Switch over to using olpc-ec.h in multiple steps, so as not to break builds. This covers every driver that calls olpc_ec_cmd(). Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Paul Fox <pgf@laptop.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2012-07-20Merge branch 'master' of ↵John W. Linville
2012-07-19libertas: firmware.c: remove duplicated includeDuan Jiong
Signed-off-by: Duan Jiong <djduanjiong@gmail.com>
2012-07-17libertas USB: don't set surpriseremoved flagDaniel Drake
We found a deadlock in the handling of command failures/reset conditions. For example: 1. Two commands are in the queue. 2. The first command is sent, but causes a timeout, which kicks off an asynchronous device reset 3. The second command is queued (but not yet sent to the hardware) 4. The device reset kicks in, causing the if_usb disconnect handler to set the "surprise removed" flag to be set as the device disappears from the bus. This causes lbs_thread to stop processing things ("adapter removed; waiting to die"), not processing any further commands, leaving the second queued command "in the air", causing a deadlock. Fix this by removing the surpriseremoved flag setting in if_usb. I can't see any reason why this needs to be done so early. lbs_remove_card will set this flag at an appropriate time - i.e. after all pending commands have been completed or cancelled, avoiding this deadlock. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-17libertas: handle command failure immediatelyDaniel Drake
Fail commands immediately when the request cannot be sent to the hardware. This solves the following deadlock: 1. Two commands are in the queue. 2. The first command is sent, but causes a timeout, which kicks off an asynchronous device reset 3. The second command is submitted to the device, and fails. The failure is noted but the existing code waits for the timeout handler to take care of the failure. 4. The device reset kicks in, causing the device "surprise removed" flag to be set as the device disappears from the bus. 5. lbs_thread notes this and enters "adapter removed; waiting to die" mode, without processing any further command timeouts. While adjusting lbs thread logic to handle this situation may be one way to fix this, it seems more practical to simplify handling of host_to_card failure so that the commands are failed immediately without waiting for more compliated timeout logic to kick in. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-17libertas: Update 11d info only when interface is activeDaniel Drake
reg_notifier can be called before the interface is up. Handle this correctly by storing the requested country code, then apply the relevant configuration when the interface is brought up. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-12Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: drivers/net/wireless/iwmc3200wifi/cfg80211.c drivers/net/wireless/mwifiex/cfg80211.c
2012-07-12Merge branch 'master' of ↵John W. Linville
2012-07-12nl80211: move scan API to wdevJohannes Berg
The new P2P Device will have to be able to scan for P2P search, so move scanning to use struct wireless_dev instead of struct net_device. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-09net/wireless: remove macro defined twice with same valueOskar Schirmer
In the list of commands CMD_802_11_EEPROM_ACCESS had been defined twice, unnecessarily, luckily with same value. Remove one occurence. Signed-off-by: Oskar Schirmer <oskar@scara.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-12Merge branch 'master' of ↵John W. Linville
2012-06-06cfg80211: clarify set_channel APIsJohannes Berg
Now that we've removed all uses of the set_channel API except for the monitor channel and in libertas, clarify this. Split the libertas mesh use into a new libertas_set_mesh_channel() operation, just to keep backward compatibility, and rename the normal set_channel() to set_monitor_channel(). Also describe the desired set_monitor_channel() semantics more clearly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06wireless: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force, __iomem and __user. @@ type T; T *p; @@ - (T *)p + p Neatened the mwifiex_deauthenticate_infra function which was doing odd things with array pointers and not using is_zero_ether_addr. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-22Merge tag 'usb-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB 3.5-rc1 changes from Greg Kroah-Hartman: "Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window. It's touches a lot of different parts of the kernel, all USB drivers, due to some API cleanups (getting rid of the ancient err() macro) and some changes that are needed for USB 3.0 power management updates. There are also lots of new drivers, pimarily gadget, but others as well. We deleted a staging driver, which was nice, and finally dropped the obsolete usbfs code, which will make Al happy to never have to touch that again. There were some build errors in the tree that linux-next found a few days ago, but those were fixed by the most recent changes (all were due to us not building with CONFIG_PM disabled.) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits) xhci: Fix DIV_ROUND_UP compile error. xhci: Fix compile with CONFIG_USB_SUSPEND=n USB: Fix core compile with CONFIG_USB_SUSPEND=n brcm80211: Fix compile error for .disable_hub_initiated_lpm. Revert "USB: EHCI: work around bug in the Philips ISP1562 controller" MAINTAINERS: Add myself as maintainer to the USB PHY Layer USB: EHCI: fix command register configuration lost problem USB: Remove races in devio.c USB: ehci-platform: remove update_device USB: Disable hub-initiated LPM for comms devices. xhci: Add Intel U1/U2 timeout policy. xhci: Add infrastructure for host-specific LPM policies. USB: Add macros for interrupt endpoint types. xhci: Reserve one command for USB3 LPM disable. xhci: Some Evaluate Context commands must succeed. USB: Disable USB 3.0 LPM in critical sections. USB: Add support to enable/disable USB3 link states. USB: Allow drivers to disable hub-initiated LPM. USB: Calculate USB 3.0 exit latencies for LPM. USB: Refactor code to set LPM support flag. ... Conflicts: arch/arm/mach-exynos/mach-nuri.c arch/arm/mach-exynos/mach-universal_c210.c drivers/net/wireless/ath/ath6kl/usb.c
2012-05-18USB: Disable hub-initiated LPM for comms devices.Sarah Sharp
Hub-initiated LPM is not good for USB communications devices. Comms devices should be able to tell when their link can go into a lower power state, because they know when an incoming transmission is finished. Ideally, these devices would slam their links into a lower power state, using the device-initiated LPM, after finishing the last packet of their data transfer. If we enable the idle timeouts for the parent hubs to enable hub-initiated LPM, we will get a lot of useless LPM packets on the bus as the devices reject LPM transitions when they're in the middle of receiving data. Worse, some devices might blindly accept the hub-initiated LPM and power down their radios while they're in the middle of receiving a transmission. The Intel Windows folks are disabling hub-initiated LPM for all USB communications devices under a xHCI USB 3.0 host. In order to keep the Linux behavior as close as possible to Windows, we need to do the same in Linux. Set the disable_hub_initiated_lpm flag for for all USB communications drivers. I know there aren't currently any USB 3.0 devices that implement these class specifications, but we should be ready if they do. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Jan Dumon <j.dumon@option.com> Cc: Petko Manolov <petkan@users.sourceforge.net> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Kalle Valo <kvalo@qca.qualcomm.com> Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com> Cc: Jouni Malinen <jouni@qca.qualcomm.com> Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: Brett Rudley <brudley@broadcom.com> Cc: Roland Vossen <rvossen@broadcom.com> Cc: Arend van Spriel <arend@broadcom.com> Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com> Cc: Kan Yan <kanyan@broadcom.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Herton Ronaldo Krzesinski <herton@canonical.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Cc: Daniel Drake <dsd@gentoo.org> Cc: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2012-05-08libertas: include sched.h on firmware.cLuis R. Rodriguez
Do not assume we have our subsystem including this for us, at least for older kernels this is not true. Lets just be explicit about this requirement for the usage of wake_up(). Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-26Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-testmode.c
2012-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Fix merge between commit 3adadc08cc1e ("net ax25: Reorder ax25_exit to remove races") and commit 0ca7a4c87d27 ("net ax25: Simplify and cleanup the ax25 sysctl handling") The former moved around the sysctl register/unregister calls, the later simply removed them. With help from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-23libertas: add missing includeFelix Fietkau
Without it, I get compile errors due to missing TASK_NORMAL, TASK_UNINTERRUPTIBLE and schedule. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-23libertas CS: convert to asynchronous firmware loadingDaniel Drake
Signed-off-by: Daniel Drake <dsd@laptop.org> Tested-by: Dan Williams <dcbw@redhat.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-17libertas USB: convert to asynchronous firmware loadingDaniel Drake
2012-04-17libertas SDIO: convert to asynchronous firmware loadingDaniel Drake
2012-04-17libertas: add asynchronous firmware loading capabilityDaniel Drake
As described at http://article.gmane.org/gmane.linux.kernel.wireless.general/86084 libertas is taking a long time to load because it loads firmware during module loading. Add a new API for interface drivers to load their firmware asynchronously. The same semantics of the firmware table are followed like before. Interface drivers will be converted in follow-up patches, then we can remove the old, synchronous firmware loading function. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-17libertas: harden-up exit pathsDaniel Drake
These simple sanity check avoids extra complexity in error paths when moving to asynchronous firmware loading (which means the device may fail to init some time after its creation). Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-17libertas: Firmware loading simplificationsDaniel Drake
Remove the ability to pass module parameters with firmware filenames for USB and SDIO interfaces. Remove the ability to pass custom "user" filenames to lbs_get_firmware(). Remove the ability to reprogram internal device memory with a different firmware from the USB driver (we don't know of any users), and simplify the OLPC firmware loading quirk to simply placing the OLPC firmware at the top of the list (we don't know of any users other than OLPC). Move lbs_get_firmware() into its own file. These simplifications should have no real-life effect but make the upcoming transition to asynchronous firmware loading considerably less painful. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-17drivers/net/wireless/libertas/if_usb.c: add missing debugging codeJulia Lawall
Add a corresponding leave call on error failure. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-13libertas: fix signedness bug in lbs_auth_to_authtype()Amitkumar Karwar
Return type for lbs_auth_to_authtype() is changed from "u8" to "int" to return negative error code correctly. Also an error check is added in connect handler for invalid auth type. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-12wireless, libertas: remove redundant NULL tests before calling ↵Jesper Juhl
release_firmware() release_firmware() tests for, and deals gracefully with, NULL pointers. Remove redundant explicit tests before calling the function. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/ath/ath9k/hw.c
2012-03-15libertas: remove dump_survey implementationDaniel Drake
libertas provides a dump_survey implementation based on reading of a RSSI value. However, this RSSI value is calculated based on the last received beacon from the associated AP - it is not a good way of surveying a channel in general, and even causes an error if the card is not associated to a network. As this is not appropriate as a survey, remove it. This fixes an issue where something in userspace is repeatedly calling site-survey during boot, resulting in many repeated errors as the RSSI value cannot be read before associating. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
