path: root/drivers/net/wireless/iwlwifi/iwl-debug.c
2014-05-13iwlwifi: use dev_printk instead of dev_dbg for debug logsLiad Kaufman
When calling IWL_DEBUG_*() dev_dbg() is currently used, and this could result in the log being ignored no matter the internal loglevel, since dev_dbg() may get turned on or off based on the dynamic debug mechanism. Replace the dev_dbg() with dev_printk() since dynamic printing is pointless as we use our own debug level mechanism and there is just a single dev_dbg() call in the code. Signed-off-by: Liad Kaufman <liad.kaufman@intel.com> [rephrase commit message a bit] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2013-03-06iwlwifi: export symbols only conditionallyJohannes Berg
If all the pieces of iwlwifi are built into the kernel then there's no need for it to export its symbols to other modules, so prevent that. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-06iwlwifi: a few fixes in licenseEmmanuel Grumbach
7000.c was released as GPL only by mistake: it should be dual licensed - GPL / BSD. The file that contains the license in the kernel is COPYING and not LICENSE.GPL. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-29iwlwifi: fix debug message levelJohannes Berg
Debug messages should be printed using dev_dbg() not dev_err() which requires DEBUG to be defined. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-05iwlwifi: implement dynamic opmode loadingDon Fry
This is the next step in splitting up the driver, making the uCode API dependent pieces of it live in separate modules. Right now there's only one so it's not user-selectable, but we're actively working on more. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Don Fry <donald.h.fry@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-23iwlwifi: clean up iwl-shared.h includesJohannes Berg
That file is now holding just a few defines and the module parameters, so it shouldn't include anything. Make sure the right users include the right files instead. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2012-03-06iwlwifi: remove per-device debug levelJohannes Berg
There's no need for the per-device debug level that we expose in debugfs since the module parameter is writable in sysfs. At the same time, simplify code by changing iwl_get_debug_level(shrd) & IWL_DL_ISR) to iwl_have_debug_level(IWL_DL_ISR) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-17iwlwifi: trace debug messagesJohannes Berg
Make iwlwifi record all debug messages into tracing, even if debug_level is not enabled. Due to the lack of APIs, the debug messages are now recorded up to a max length of 100, the only one above that is the RXON which is not needed if you trace the commands as well as it only dumps the command contents. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi W Guy <wey-yi.w.guy@intel.com>
