path: root/drivers/net/wireless/hostap
2008-07-22netdev: Handle ->addr_list_lock just like ->_xmit_lock for lockdep.David S. Miller
The new address list lock needs to handle the same device layering issues that the _xmit_lock one does. This integrates work done by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move _xmit_lock and xmit_lock_owner into netdev_queue.David S. Miller
Accesses are mostly structured such that when there are multiple TX queues the code transformations will be a little bit simpler. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-3945.c net/mac80211/mlme.c
2008-07-08hostap: don't compile prism2_suspend() for hostap_pci without CONFIG_PMPavel Roskin
Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-07hostap_cs: correct poor NULL checks in suspend/resume routinesJohn W. Linville
This corrects this kernel.org bug: http://bugzilla.kernel.org/show_bug.cgi?id=9701 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wan/hdlc_fr.c drivers/net/wireless/iwlwifi/iwl-4965.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2008-06-30hostap: use radiotap headers by defaultPavel Roskin
2008-06-30hostap: add radiotap support in monitor modePavel Roskin
Provide MAC time, rate, channel, signal and noise. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30hostap: don't skip any headers in hostap_80211_header_parse()Pavel Roskin
Don't try to skip any headers in hostap_80211_header_parse(). We never use that function for interfaces affected by local->monitor_type. Both the master and the AP interface receive 802.11 frames without any additional headers. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30hostap: fix sparse warningsPavel Roskin
Rewrite AID calculation in handle_pspoll() to avoid truncating bits. Make hostap_80211_header_parse() static, don't export it. Avoid shadowing variables. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30hostap: don't report useless WDS frames by defaultPavel Roskin
DEBUG_EXTRA is reported to the kernel log by default, but DEBUG_EXTRA2 is not. Unrelated WDS frames pollute the log unnecessarily. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-16wext: Emit event stream entries correctly when compat.David S. Miller
Three major portions to this change: 1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF, and IW_EV_COMPAT_POINT_LEN helper defines. 2) Delete iw_stream_check_add_*(), they are unused. 3) Add iw_request_info argument to iwe_stream_add_*(), and use it to size the event and pointer lengths correctly depending upon whether IW_REQUEST_FLAG_COMPAT is set or not. 4) The mechanical transformations to the drivers and wireless stack bits to get the iw_request_info passed down into the routines modified in #3. Also, explicit references to IW_EV_LCP_LEN are replaced with iwe_stream_lcp_len(info). With a lot of help and bug fixes from Masakazu Mokuno. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12net: Eliminate flush_scheduled_work() calls while RTNL is held.David S. Miller
If the RTNL is held when we invoke flush_scheduled_work() we could deadlock. One such case is linkwatch, it is a work struct which tries to grab the RTNL semaphore. The most common case are net driver ->stop() methods. The simplest conversion is to instead use cancel_{delayed_}work_sync() explicitly on the various work struct the driver uses. This is an OK transformation because these work structs are doing things like resetting the chip, restarting link negotiation, and so forth. And if we're bringing down the device, we're about to turn the chip off and reset it anways. So if we cancel a pending work event, that's fine here. Some drivers were working around this deadlock by using a msleep() polling loop of some sort, and those cases are converted to instead use cancel_{delayed_}work_sync() as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20hostap_cs: add ID for Conceptronic CON11CProPavel Roskin
Reported by Santiago Garcia Mantinan <hostap@manty.net> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-15hostap: fix "registers" registration in procfsMathieu Chouquet-Stringer
The "registers" entry was incorrectly created in the procfs root instead of the device specific directory. Move "registers" registration immediately after the containing procfs directory is created. Signed-off-by: Mathieu Chouquet-Stringer <mchouque@free.fr> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08[NET]: Undo code bloat in hot paths due to print_mac().David S. Miller
If print_mac() is used inside of a pr_debug() the compiler can't see that the call is redundant so still performs it even of pr_debug() ends up being a nop. So don't use print_mac() in such cases in hot code paths, use MAC_FMT et al. instead. As noted by Joe Perches, pr_debug() could be modified to handle this better, but that is a change to an interface used by the entire kernel and thus needs to be validated carefully. This here is thus the less risky fix for 2.6.25 Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31Add another Prism2 card to hostapMarcin Juszkiewicz
Card reported by Ångström user: http://bugs.openembedded.net/show_bug.cgi?id=3236 Socket 1: product info: "Wireless LAN", "11Mbps PC Card", "Version 01.02", "" manfid: 0x0156, 0x0002 function: 6 (network) Signed-off-by: Marcin Juszkiewicz <openembedded@haerwu.biz> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31hostap_80211.h: remove duplicate prototypeMichal Piotrowski
There were two identical prototypes for hostap_80211_rx() in drivers/net/wireless/hostap/hostap_80211.h. This patch fixes kernel Bugzilla #8930. Reported by Christoph Burger-Scheidlin. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28hostap_cs: don't match revisions in presense of the MAC chip namePavel Roskin
If the third PCMCIA ID string specifies the MAC chip, the fourth ID string doesn't need to be matched. Even if it's different, it will be compatible with the driver. This ensures that other different revisions of the card will be supported. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28hostap: don't mess with mixed-endian even for internal skb queuesAl Viro
Just leave hfa384x_info_frame as-is, don't convert in place. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28hostap annotationsAl Viro
2008-01-28hostap: fix endianness with txdesc->sw_supportAl Viro
it's le32, not le16... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28introduce WEXT scan capabilitiesDan Williams
Introduce scan capabilities to WEXT so that userspace can do intelligent things with scan behavior such as handling hidden SSIDs more gracefully. If the driver reports a specific scan capability, the driver must respect the options specified in the iw_scan_req structure when handling the SIOCSIWSCAN call, unless it's mode or state does not allow it to do so, in which case it must return an error. This version switches to Dave Kilroy's suggestion of claiming unused padding space for the scan_capa field. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-16hostap: section mismatch warningRandy Dunlap
Fix section mismatch by changing variable name to match one of the whitelisted (allowable) names for pointing into init data: WARNING: vmlinux.o(.data+0xce618): Section mismatch: reference to .init.data:prism2_plx_id_table (between 'prism2_plx_drv_id' and 'dev_info') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-10hostap: fix section mismatch warningRandy Dunlap
Fix section mismatch warning: WARNING: vmlinux.o(.data+0x36fcc): Section mismatch: reference to .init.data:prism2_pci_id_table (between 'prism2_pci_drv_id' and 'prism2_pci_funcs') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14long vs. unsigned long - low-hanging fruits in driversAl Viro
deal with signedness of the stuff passed to set_bit() et.al. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[PATCH] Add Linksys card to HostAP driverMarcin Juszkiewicz
Socket 1: product info: "The Linksys Group, Inc.", "Wireless Network CF Card", "ISL37300P", "RevA" manfid: 0x0274, 0x3301 Signed-off-by: Marcin Juszkiewicz <openembedded@haerwu.biz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] hostap_cs: Add device ID for Telekom T-Sinus 111cardStefan Lippers-Hollmann
This adds the PCMCIA device ID for the Deutsche Telekom T-Sinus 111card to hostap_cs. $ /sbin/lspcmcia -v [...] Socket 0 Device 0: [hostap_cs] (bus ID: 0.0) Configuration: state: on Product Name: T-Sinus 111card 2.0.0 Identification: manf_id: 0x01bf card_id: 0x3301 function: 6 (network) prod_id(1): "T-Sinus" (0x8c389dc1) prod_id(2): "111card" (0x6a23ac17) prod_id(3): --- (---) prod_id(4): "2.0.0" (0x92b9effb) Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[HOSTAP]: set netdev type before registering AP interfaceDaniel Drake
As detailed at https://bugs.gentoo.org/159646 hostap with hostapd confuses udev by presenting 2 interfaces with the same MAC address. Also, at the time of detection, the 'type' attribute is 1, identical to other hostap interfaces. The AP interface is supposed to have type ARPHRD_IEEE80211 (801), but this is not set until after registration. Setting it before register_netdev() is called allows us to avoid this confusion. We can do this by propogating the HOSTAP_INTERFACE type through to hostap_setup_dev(). Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[PATCH] dev->priv to netdev_priv(dev), for drivers/net/wirelessYoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: mcgrof@gmail.com Cc: linux-wireless@vger.kernel.org Cc: akpm@linux-foundation.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] Use mutex instead of semaphore in the Host AP driverMatthias Kaehlcke
The Host AP driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Acked-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11PCI: remove useless pci driver methodDavid Brownell
Remove pointless and never-called enable_wake() hook from pci_driver and from documentation. Evidently this was introduced in the 2.4.6 kernel, but there's no evidence it was ever called; and it was rarely implemented. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-08[PATCH] hostap: Remove driver version numberJouni Malinen
The driver version number has not been updated since the driver was included in the main kernel tree and there is no plan on updating this in the future either. At this point, the only correct way to refer to the version is to use the kernel version. The 0.4.4 version is confusing since there are external version with higher version number even though they are not actually any newer than the in-tree version. Let's get rid of the version number in the kernel tree in order to avoid this kind of confusion. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-08[PATCH] hostap: Use list_for_each_entryMatthias Kaehlcke
Use list_for_each_entry() instead of manual iteration and substitute some list_for_each() loops with list_for_each_entry(). Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-08[PATCH] hostap: Suppress broadcast if no stations are associatedPavel Roskin
This may be useful in mesh setups when most stations act as repeaters only. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] hostap: Allocate enough tailroom for TKIPBrandon Craig Rhodes
When hostap_tx_encrypt() tries to allocate enough headroom and tailroom for ieee80211 encryption, it only makes enough room for the "mpdu" phase of the operation, but forgets about the "msdu" phase. (For TKIP, these two phases require, respectively, 4 and 8 bytes of tailroom, per the "ieee80211_crypt_tkip" structure at the bottom of net/ieee80211/ieee80211_crypt_tkip.c.) Signed-off-by: Brandon Craig Rhodes <brandon@rhodesmill.org> Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] hostap_cs: support ADLINK 345 CFMarcin Juszkiewicz
Add ADLINK 345 CF card into hostap_cs product info: "ADLINK 345 CF" manfid 0xd601, 0x0005 Signed-off-by: Marcin Juszkiewicz <openembedded@hrw.one.pl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] Update my email address from jkmaline@cc.hut.fi to j@w1.fiJouni Malinen
After 13 years of use, it looks like my email address is finally going to disappear. While this is likely to drop the amount of incoming spam greatly ;-), it may also affect more appropriate messages, so let's update my email address in various places. In addition, Host AP mailing list is subscribers-only and linux-wireless can also be used for discussing issues related to this driver which is now shown in MAINTAINERS. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] hostap: Add D-Link DWL-650 Rev. P1 product idJouni Malinen
It looks like some of the PC Card manfid/product strings were lost when Host AP driver was converted to use PCMCIA_DEVICE_* helpers. This patch adds back D-Link DWL-650 Rev. P1 using the same product ID string match as the pcmcia-cs/cardmgr configuration used before. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] hostap: use offsetof() instead of own equivalentPavel Roskin
The original macros result in gcc 4.2 warning about "cast from pointer to integer of different size" on 64-bit systems. Use of offsetof() on fields in substructures is widespread throughout the kernel code and should work whether offsetof() is defined using __compiler_offsetof() or a cast. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-25[WIRELESS]: Refactor wireless Kconfig.Johannes Berg
This patch refactors the wireless Kconfig all over and already introduces net/wireless/Kconfig with just the WEXT bit for now, the cfg80211 patch will add to that as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
