This removes the "FWxx" ID strings from the b43 and b43legacy
drivers. They were once used to match a specific driver revision
to a set of firmware files. However, this is hardly useful today.
Additionally, the IDs are not updated and maintained properly, so
they might mislead users.
Signed-off-by: Michael Buesch <m@bues.ch>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Pavel Roskin <proski@gnu.org>
Devices supported by b43legacy don't support 64-bit DMA.
linux/wireless.h and net/iw_handler.h headers are
for wireless extensions only, so mac80211 drivers
shouldn't be including them.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Semicolons are not necessary after switch/while/for/if braces
so remove them.
gcc 4.6.0 warnings for b43legacy:
CC [M] drivers/net/wireless/b43legacy/main.o
drivers/net/wireless/b43legacy/main.c: In function ‘b43legacy_request_firmware’:
drivers/net/wireless/b43legacy/main.c:1567:6: warning: variable ‘tmshigh’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/b43legacy/main.c: In function ‘b43legacy_op_dev_config’:
drivers/net/wireless/b43legacy/main.c:2637:6: warning: variable ‘antenna_rx’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/b43legacy/main.c: In function ‘b43legacy_op_bss_info_changed’:
drivers/net/wireless/b43legacy/main.c:2778:24: warning: variable ‘phy’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/b43legacy/xmit.c: In function ‘generate_txhdr_fw3’:
drivers/net/wireless/b43legacy/xmit.c:324:7: warning: variable ‘rts_rate_ofdm’ set but not used [-Wunused-but-set-variable]
CC [M] drivers/net/wireless/b43legacy/dma.o
drivers/net/wireless/b43legacy/dma.c: In function ‘free_all_descbuffers’:
drivers/net/wireless/b43legacy/dma.c:820:36: warning: variable ‘desc’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/b43legacy/dma.c: In function ‘b43legacy_dma_tx’:
drivers/net/wireless/b43legacy/dma.c:1377:28: warning: variable ‘info’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/b43legacy/dma.c:1374:24: warning: variable ‘hdr’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/b43legacy/dma.c: In function ‘b43legacy_dma_handle_txstatus’:
drivers/net/wireless/b43legacy/dma.c:1438:36: warning: variable ‘desc’ set but not used [-Wunused-but-set-variable]
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
Remove the code to detect inactive 802.11 cores, as that function is now done
in ssb.
We were performing it on wrong core, it was outdated and is already
implemented in ssb.
The return value of the tx operation is commonly
misused by drivers, leading to errors. All drivers
will drop frames if they fail to TX the frame, and
they must also properly manage the queues (if they
didn't, mac80211 would already warn).
Removing the ability for drivers to return a BUSY
value also allows significant cleanups of the TX
TX handling code in mac80211.
Note that this also fixes a bug in ath9k_htc, the
old "return -1" there was wrong.
Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k]
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00]
Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi]
Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx]
The flag isn't very descriptive -- the intention
is that the driver provides a TSF timestamp at
the beginning of the MPDU -- make that clearer
by renaming the flag to RX_FLAG_MACTIME_MPDU.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Using %pV reduces the number of printk calls and
eliminates any possible message interleaving from
other printk calls.
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
The default llseek operation is changing from
default_llseek to no_llseek, so all code relying on
the current behaviour needs to make that explicit.
The wireless driver infrastructure and some of the drivers
make use of generated debugfs files, so they cannot
be converted by our script that automatically determines
the right operation.
All these files use debugfs and they typically rely
on simple_read_from_buffer, so the best llseek operation
here is generic_file_llseek.
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
This makes the information available through ethtool...
drivers/net/wireless/wl12xx/wl1271.h
drivers/net/wireless/wl12xx/wl1271_cmd.h
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Stefano Brivio <stefano.brivio@polimi.it>
Cc: John W. Linville <linville@tuxdriver.com>
Acked-by: Michael Buesch <mb@bu3sch.de>
cleanup patch.
Use new __packed annotation in drivers/net/
drivers/net/wireless/libertas_tf/cmd.c
drivers/net/wireless/libertas_tf/main.c
Also remove associated IEEE80211_HW_NOISE_DBM from ieee80211_hw_flags.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/net/wireless/rt2x00/rt2800pci.c
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
get_tx_stats() will be removed from mac80211.
Compile-tested only.
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
If b43 or b43legacy are deauthenticated or disconnected, there is a
possibility that a reconnection is tried with the queues stopped in
mac80211. To prevent this, start the queues before setting
STAT_INITIALIZED.
In b43, a similar change has been in place (twice) in the
wireless_core_init() routine. Remove the duplicate and add similar
code to b43legacy.
Cc: Stable <stable@kernel.org> [2.6.32]
In f41f3f373dd72344c65d801d6381fe83ef3a2c54 the B43 driver was ported
to use the cfg80211 API for rfkill and consequently the config option
was dropped (RFKILL is now unconditionally enabled).
However in the Kernel Info the feature is still checked and reported
missing. This patch just removes the conditional and the relevant code
blocks while still reporting that feature unconditionally would be
another option (it's always there).
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
Enhance module information with the names of the firmware files
that could be used by this driver. This helps tools like Jockey to
correctly detect and/or install the firmware files relevant to
this driver.
All its members (vif, mac_addr, type) are now available
in the vif struct directly, so we can pass that instead
of the conf struct. I generated this patch (except the
mac80211 and header file changes) with this semantic
patch:
identifier conf, fn, hw;
type tp;
tp fn(struct ieee80211_hw *hw,
-struct ieee80211_if_init_conf *conf)
+struct ieee80211_vif *vif)
-conf->type
+vif->type
-conf->mac_addr
+vif->addr
-conf->vif
+vif
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
For PPC architecture with PHY Revision < 3, a read of the register
B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43legacy_status()
returns a value of 2 (B43legacy_STAT_STARTED); however, one finds that
the driver is unable to associate after resuming from hibernation unless
this routine returns 1. To satisfy both conditions, the routine is rewritten
to return TRUE whenever b43legacy_status() returns a value < 2.
This patch fixes the second problem listed in the postings for Red Hat
Bugzilla #538523.
Cc: Stable <stable@vger.org>
drivers/net/sfc/sfe4001.c
drivers/net/wireless/libertas/cmd.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/rtl8187se/Kconfig
drivers/staging/rtl8192e/Kconfig
This patch was generated by
git grep -E -i -l '[Aa]quire' | xargs -r perl -p -i -e 's/([Aa])quire/$1cquire/'
and the cumsumed was found by checking the diff for aquire.
With the deprecation of the qual member of ieee80211_rx_status, that
calculation and an associated constant can be removed.
This patch is adapted from the submission by Michael Buesch <mb@bu3sch.de>
for a bounce-buffer copying problem with b43.
