Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
* Convert chip specific calibration data to a generic format common
for all chips
Note: We scale up power to be in 0.25dB units for all chips for
compatibility with RF5112
v2: Address Bob's and Jiri's comments
Signed-off-by: Nick Kossifidis <mickflemm@gmail.com>
Do not touch mac parameter passed to ath5k_eeprom_read_mac unless
we are sure we have correct address. I.e. when returning error, do
not change it.
While at it, use '= {}' compiler trick for memsetting mac_d.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Cc: Luis R. Rodriguez <lrodriguez@atheros.com>
Acked-by: Bob Copeland <me@bobcopeland.com>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning
of the declaration specifiers in a declaration is an obsolescent
feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
* Update reset and sync with HALs
* Clean up eeprom settings and tweaking of initvals and
put them on separate functions
* Set/Restore 32KHz ref clk operation
* Add some more documentation
TODO: Spur mitigation, tpc, half/quarter rate, compression etc
v2: Address comments from Bob and Felix and fix RSSI threshold bug
introduced on the first version of the patch
* Don't scale power values on RF5111 EEPROMs because they get out of
bounds (power is u8, so multiplying power by 50 is too much and there
is no reason to do so -we don't do it on other chips anyway-). HAL
does it as a technique to handle 0.5 dbm steps but i believe it's not
the right thing to do and certainly not the right place to do it. We
'll work this out on interpolation code for all chips (0.5 or 0.25
steps etc) in a generic way.
Signed-Off-by: Nick Kossifidis <mickflemm@gmail.com>
*Read misc2...6 values from eeprom since we want to use them (fixes
wrong power calibration info offset on RF2413+ chips)
*Initialize num_piers to 0 for RF2413 chips (note that we read 2GHz
frequency piers while reading mode sections, we have to ignore them
-usualy they are 0xff anyway but during my tests i got a 1 on b mode
with no data- and use the newer eemap.
*Add some more comments (please forgive my poor English ;-( ) and
some minor code cleanup
*Tested on 2425 and 2112 and has the same data with ath_info (i
wrote some debug code on debug.c to print everything like ath_info
but i haven't tested it yet on 5111 and it's full of > 80 col lines,
if anyone wants to play with it let me know).
Acked-by: Felix Fietkau <nbd@openwrt.org>
This patch brings the ath5k eeprom parsing code in sync with the work
done on ath_info by Nick Kossifidis and integrates the missing parts
based on the code of the Atheros Legacy HAL release.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
* No code changes...
* Split hw.c to multiple files for better maintenance and add some documentation on each file
code is going to grow soon (eeprom.c for example is going to get much stuff currently developed
on ath_info) so it's better this way.
* Rename following functions to maintain naming scheme:
ah_setup_xtx_desc -> ah_setup_mrr_tx_desc
(Because xtx doesn't say much, it's actually
a multi-rate-retry tx descriptor)
ath5k_hw_put_tx/rx_buf - > ath5k_hw_set_tx/rxdp
ath5k_hw_get_tx/rx_buf -> ath5k_hw_get_tx/rxdp
(We don't put any "buf" we set descriptor pointers on hw)
ath5k_hw_tx_start -> ath5k_hw_start_tx_dma
ath5k_hw_start_rx -> ath5k_hw_start_rx_dma
ath5k_hw_stop_pcu_recv -> ath5k_hw_stop_rx_pcu
(It's easier this way to identify them, we also
have ath5k_hw_start_rx_pcu which completes the
set)
ath5k_hw_set_intr -> ath5k_hw_set_imr
(As in get_isr we set imr here, not "intr")
* Move ath5k_hw_setup_rx_desc on ah->ah_setup_rx_desc so we can
include support for different rx descriptors in the future
* Further cleanups so that checkpatch doesn't complain
(only some > 80 col warnings for eeprom.h and reg.h as usual
due to comments)
Tested on 5211 and 5213 cards and works ok.
Changes-licensed-under: ISC
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
