path: root/drivers/net/wireless/ath5k/eeprom.c
2009-04-22atheros: put atheros wireless drivers into ath/Luis R. Rodriguez
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27ath5k: Convert chip specific calibration data to a generic formatNick Kossifidis
* Convert chip specific calibration data to a generic format common for all chips Note: We scale up power to be in 0.25dB units for all chips for compatibility with RF5112 v2: Address Bob's and Jiri's comments Signed-off-by: Nick Kossifidis <mickflemm@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16ath5k: don't change mac in eeprom_read_mac on errorJiri Slaby
Do not touch mac parameter passed to ath5k_eeprom_read_mac unless we are sure we have correct address. I.e. when returning error, do not change it. While at it, use '= {}' compiler trick for memsetting mac_d. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Nick Kossifidis <mickflemm@gmail.com> Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13ath5k: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13ath5k: Update reset codeNick Kossifidis
* Update reset and sync with HALs * Clean up eeprom settings and tweaking of initvals and put them on separate functions * Set/Restore 32KHz ref clk operation * Add some more documentation TODO: Spur mitigation, tpc, half/quarter rate, compression etc v2: Address comments from Bob and Felix and fix RSSI threshold bug introduced on the first version of the patch Signed-off-by: Nick Kossifidis <mickflemm@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29ath5k: More EEPROM code updatesNick Kossifidis
* Don't scale power values on RF5111 EEPROMs because they get out of bounds (power is u8, so multiplying power by 50 is too much and there is no reason to do so -we don't do it on other chips anyway-). HAL does it as a technique to handle 0.5 dbm steps but i believe it's not the right thing to do and certainly not the right place to do it. We 'll work this out on interpolation code for all chips (0.5 or 0.25 steps etc) in a generic way. Signed-Off-by: Nick Kossifidis <mickflemm@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29ath5k: Update EEPROM codeNick Kossifidis
*Read misc2...6 values from eeprom since we want to use them (fixes wrong power calibration info offset on RF2413+ chips) *Initialize num_piers to 0 for RF2413 chips (note that we read 2GHz frequency piers while reading mode sections, we have to ignore them -usualy they are 0xff anyway but during my tests i got a 1 on b mode with no data- and use the newer eemap. *Add some more comments (please forgive my poor English ;-( ) and some minor code cleanup *Tested on 2425 and 2112 and has the same data with ath_info (i wrote some debug code on debug.c to print everything like ath_info but i haven't tested it yet on 5111 and it's full of > 80 col lines, if anyone wants to play with it let me know). Signed-Off-by: Nick Kossifidis <mickflemm@gmail.com> Acked-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-26ath5k: Clean up eeprom parsing and add missing calibration dataFelix Fietkau
This patch brings the ath5k eeprom parsing code in sync with the work done on ath_info by Nick Kossifidis and integrates the missing parts based on the code of the Atheros Legacy HAL release. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-05ath5k: HW code cleanupNick Kossifidis
* No code changes... * Split hw.c to multiple files for better maintenance and add some documentation on each file code is going to grow soon (eeprom.c for example is going to get much stuff currently developed on ath_info) so it's better this way. * Rename following functions to maintain naming scheme: ah_setup_xtx_desc -> ah_setup_mrr_tx_desc (Because xtx doesn't say much, it's actually a multi-rate-retry tx descriptor) ath5k_hw_put_tx/rx_buf - > ath5k_hw_set_tx/rxdp ath5k_hw_get_tx/rx_buf -> ath5k_hw_get_tx/rxdp (We don't put any "buf" we set descriptor pointers on hw) ath5k_hw_tx_start -> ath5k_hw_start_tx_dma ath5k_hw_start_rx -> ath5k_hw_start_rx_dma ath5k_hw_stop_pcu_recv -> ath5k_hw_stop_rx_pcu (It's easier this way to identify them, we also have ath5k_hw_start_rx_pcu which completes the set) ath5k_hw_set_intr -> ath5k_hw_set_imr (As in get_isr we set imr here, not "intr") * Move ath5k_hw_setup_rx_desc on ah->ah_setup_rx_desc so we can include support for different rx descriptors in the future * Further cleanups so that checkpatch doesn't complain (only some > 80 col warnings for eeprom.h and reg.h as usual due to comments) Tested on 5211 and 5213 cards and works ok. Changes-licensed-under: ISC Signed-off-by: Nick Kossifidis <mickflemm@gmail.com> Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
