Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
The current method of identifying MAC hangs is
convoluted and also, the signatures are wrong and
don't apply to all the chips in the AR9003 family.
Fix this by cleaning up the code and checking for
the correct hang signatures.
This is required for adding separate hang check
routines for AR9002 and AR9003.
HW hang checks have to be done on a per-chip basis.
The Buffalo device WZR-HP-G450H uses the index 3 for TX gain,
which is set to the high_power table currently. Later variants
of the router use the same index, but instead refer to the
low_ob_db gain table. This is not handled in the driver since
there is no way to distinguish board revisions and the high_power
table is used (incorrectly) for the newer variants.
By default, devices based on AR9300 using the TX gain index 3 have
to use the high_power table. To make sure that WZR-HP-G450H is not
broken when the high_power table is updated, use a separate array
based on information obtained from the platform data.
The current situation where only the original variant of WZR-HP-G450H
works properly stays unchanged.
Certain baseband registers require different values
to be programmed when operating in a DFS channel to
ensure that radar detection works correctly. This
is required for AR9300, AR9340 and AR9580.
This is missing for AR9300, AR9580 and AR9340.
The initvals for AR9462 v2.1 are very similar to v2.0.
Identify duplicate arrays and reuse the values from v2.0
to reduce module size.
CUS227, which is an AR9340 based card used in Qualcomm's
Allplay platforms requires a custom TX gain array, based
on the index 7. Add suport for this.
Cc: Michael Larson <mlarson@qce.qualcomm.com>
Cc: Stephen Collmeyer <scollmey@qce.qualcomm.com>
This HW config option is always set to true and is not needed.
Currently, the PLL is turned off for AR9485 when
switching to a low power state, but AR9485 has an issue
where the card will become unresponsive if left idle
for a long time without any traffic. To fix this,
force the PLL to always be on using a different initval
array, ar9485_1_1_pll_on_cdr_on_clkreq_disable_L1.
This is done for most of the AR9485 based cards
like HB125, WB225 etc. but certain models require the
feature to be turned off. Identify such cards and use
default values for them.
This is missing for AR9565.
The PCIE Workaround register (AR_WA/0x4004) is used to handle
various hardware quirks. For AR9002 chips, AR_WA_D3_L1_DISABLE
is used to prevent the HW from automatically entering L1 state
when D3 is enforced.
AR_WA_D3_L1_DISABLE has to be enabled for a few AR9280 based
cards, mark them based on their PCI subdevice/subvendor IDs
and enforce it in ar9002_hw_configpcipowersave().
If the L1 entrance latency is not calibrated properly
in the EEPROM in WB222 boards, there could be problems
in connectivity. Check and correct the calibrated value
if it doesn't match the optimal value for WB222, 4us.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/ath/ath9k/main.c
drivers/net/wireless/iwlwifi/dvm/tx.c
ar900*_init_mode_regs needs to be called before RF banks are allocated,
otherwise the storage size of RF banks isn't known. This patch fixes
a memory overrun that can show up as a crash on unloading the module.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Improves stability on affected devices and also fixes the Tx IQ calibration
related regression on some AR9340 devices such as the TP-Link TL-WDR4300.
Populate iniModesRxGain with the correct initvals
array for AR9485 v1.1
Cc: stable@vger.kernel.org
2484 Mhz (Japan) usage requires filter coefficients to
be programmed in the CCK TX FIR registers. This is required
for AR9331, AR9485 and AR9462. Fix this and also remove
a few useless macros and a duplicate variable.
This reduced the power consumption to half in full and network sleep.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Cc: Paul Stewart <pstew@chromium.org>
The row/column sizes can be derived from the array argument within the macro
itself, which is less error prone. In a few cases the supplied column size
was actually wrong.
Use the EEPROM information to choose the right tx gain table
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
The MAX_TXPWR table for BTCOEX is not needed for AR9462.
Programming these values to the HW results in undesirable
behavior - for example, large number of delimiter/data
underruns are seen in AES-CCMP mode. Also, registers like
AR_PCU_MISC_MODE2 return 0xdeadbeef after the BTCOEX_MAX
power table is programmed to the HW, and frames being transmitted
end up being looped back to the RX engine, an example being beacon
frames in IBSS mode.
Remove this table for now - this fixes CCMP performance and general
IBSS usage.
use iniModesFastClock for 5 ghz fast clock specific settings, and
iniAdditional for clock/chip specific initval overrides
v1.0 chips are not available in the market.
Renamed to be in sync with Marketing term and to avoid
confusion with other chip names.
The AR946/8x chips are 2x2 Dual band with BT support. In order
to avoid misleading with other chips and to be in sync with
marketing team's term, AR9480 is renamed as AR9462.
This patch adds support for AR946/8x chipets.
Signed-off-by: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Split tx/rx gain table initval hanlding part so readability
is better and easy to manage the code.
Here are the AR9580 1.0 initvals checksums using the
Atheros initvals-tools [1]. This is useful for when
we udate the initvals again with other values. It ensures
that we match the same initvals used internally. The
tool is documented on the wiki [2].
$ ./initvals -f ar9580-1p0
0x00000000e912711f ar9580_1p0_modes_fast_clock
0x000000004a488fc7 ar9580_1p0_radio_postamble
0x00000000f3888b02 ar9580_1p0_baseband_core
0x0000000003f783bb ar9580_1p0_mac_postamble
0x0000000094be244a ar9580_1p0_low_ob_db_tx_gain_table
0x0000000094be244a ar9580_1p0_high_power_tx_gain_table
0x0000000090be244a ar9580_1p0_lowest_ob_db_tx_gain_table
0x00000000ed9eaac6 ar9580_1p0_baseband_core_txfir_coeff_japan_2484
0x00000000c4d66d1b ar9580_1p0_mac_core
0x00000000e8e9043a ar9580_1p0_mixed_ob_db_tx_gain_table
0x000000003521a300 ar9580_1p0_wo_xlna_rx_gain_table
0x00000000301fc841 ar9580_1p0_soc_postamble
0x00000000a9a06b3a ar9580_1p0_high_ob_db_tx_gain_table
0x00000000a15ccf1b ar9580_1p0_soc_preamble
0x0000000029495000 ar9580_1p0_rx_gain_table
0x0000000037ac0ee8 ar9580_1p0_radio_core
0x00000000603a1b80 ar9580_1p0_baseband_postamble
0x000000003d8b4396 ar9580_1p0_pcie_phy_clkreq_enable_L1
0x00000000398b4396 ar9580_1p0_pcie_phy_clkreq_disable_L1
0x00000000397b4396 ar9580_1p0_pcie_phy_pll_on_clkreq
[1] git://git.kernel.org/pub/scm/linux/kernel/git/mcgrof/initvals-tool.git
[2] http://wireless.kernel.org/en/users/Drivers/ath9k_hw/initvals-tool
Cc: David Quan <dquan@qca.qualcomm.com>
Cc: Kathy Giori <kgiori@qca.qualcomm.com>
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Tested-by: Florian Fainelli <florian@openwrt.org>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Move common checks into wrapper function. Since ASPM can be only enabled
on PCIe devices ->is_pciexpress check is unneeded.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
We always call ->config_pci_powersave() with both restore and power_off
arguments equal to 0 or both equal to 1, so merge them into one
argument.
We receive many bug reports about system hang during suspend/resume
when ath9k driver is in use. Adrian Chadd remarked that this problem
happens on systems that have ASPM disabled.
To do not hit the bug, skip doing ->config_pci_powersave magic if PCIe
downstream port device, which ath9k device is connected to, has ASPM
disabled.
Bug was introduced by:
commit 53bc7aa08b48e5cd745f986731cc7dc24eef2a9f
Author: Vivek Natarajan <vnatarajan@atheros.com>
Date: Mon Apr 5 14:48:04 2010 +0530
ath9k: Add support for newer AR9285 chipsets.
Patch should address:
https://bugzilla.kernel.org/show_bug.cgi?id=37462
https://bugzilla.kernel.org/show_bug.cgi?id=37082
https://bugzilla.redhat.com/show_bug.cgi?id=697157
however I did not receive confirmation about that, except from Camilo
Mesias, whose system stops hang regularly with this patch (but still
hangs from time to time, but this is probably some other bug).
Tested-by: Camilo Mesias <camilo@mesias.co.uk>
Cc: stable@kernel.org # 2.6.35+
The Times They Are a-Changin'.
Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com>
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
