Dan reported that smatch found a possible issue in ath6kl_wmi_beginscan_cmd()
where we might access sc->supp_rates beyond the end. It shouldn't happen as
ar->wiphy->bands always have just the first two bands set, but add an extra
check just to be sure.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
Add basic tracing infrastructure support to ath6kl and which can be
enabled with CONFIG_ATH6KL_TRACING.
This prepares for using the spinlock instead of krefs
which is needed in the next patch to track the refs
of combined BSSes correctly.
Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex]
Parse beacon interval from userspace to
firmware. Incase the firmware does not
supports it, just print a warning message
and continue with AP settings.
Cc: Sumathi Mandipati <sumathi@qca.qualcomm.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
dev_kfree_skb kernel API itself takes for checking for NULL
skb, so an explicit check is not required.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
As mwifiex (and mac80211 in the software case) are the
only drivers actually implementing remain-on-channel
with channel type, userspace can't be relying on it.
This is the case, as it's used only for P2P operations
right now.
Rather than adding a flag to tell userspace whether or
not it can actually rely on it, simplify all the code
by removing the ability to use different channel types.
Leave only the validation of the attribute, so that if
we extend it again later (with the needed capability
flag), it can't break userspace sending invalid data.
Rename ATH6KL_HW_FLAG_64BIT_RATES to ATH6KL_HW_64BIT_RATES.
This seemed to be necessary to add/use new hardware flags
without exceeding 80 lines. We shall be adding new hw flags
dropping the FLAG term.
There are 28 items defined in rate table array 'wmi_rate_tbl'.
The rate table index (reply->rate_index) in ath6kl_wmi_bitrate_reply_rx()
func is not checked for the valid max limit index before accessing
rate table array. There may be some incidents to get memory crashes
without safe max check. Fix this.
Found this on code review.
Signed-off-by: Raja Mani <rmani@qca.qualcomm.com>
Return value of ath6kl_get_regpair() is stored in 'regpair' in
ath6kl_wmi_regdomain_event() func and it's directly accessed
in the debug prints without checking for NULL value. There are
situation to get NULL pointer as a return value from
ath6kl_get_regpair() func. Fix this.
This patch adds support to detect fw error condition by sending
periodic message (heart beat challenge) to firmware. Upon reception
of the message, fw would send a response event to driver. When
there are no reponses from fw for about 5 cmd driver would
trigger the recovery logic assuming that fw has gone into an
error state.
Capable fw will advertise this capability through
ATH6KL_FW_CAPABILITY_HEART_BEAT_POLL bit. This feature
is disabled by default, can be enabled through a modparam
(heart_beat_poll). This modparam also confiures the polling
interval in msecs.
Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
The MSB of rate index from FW is used for sgi. But the ath6kl_wmi_get_rate
doesn't handle it. The access to wmi_rate_tbl array may be out of range
if sgi is 1. This may cause the return value of ath6kl_wmi_get_rate()
function is incorrect link rate. We add sgi adjustment to avoid such case.
kvalo: change patch title
Signed-off-by: Dengke Qiu <dqiu@qca.qualcomm.com>
This patch reflects changes in the firmware scheduled scan
implementation to behave better in cases with multiple concurrent vifs.
Major changes:
- scheduled scan filters and state are now programmed per-vif.
- decouple scheduled scan from host sleep.
To maintain graceful failure with old firmwares, a new firmware
capability bit is introduced: ATH6KL_FW_CAPABILITY_SCHED_SCAN_V2.
ath6kl simply won't advertise scheduled scan to cfg80211 if the
SCHED_SCAN_V2 is not supported.
Since firmwares from here on out won't support the previous implicit API
for scheduled scan (set WoW filters and host sleep), bump the firmware
API to protect old drivers.
Unfortunately, due to firmware RAM constraints ath6kl still cannot
expect a scan complete event at the end of a scheduled scan results
cycle, so the sched_scan_timer is retained.
Signed-off-by: Thomas Pedersen <c_tpeder@qca.qualcomm.com>
skb given to ath6kl_control_tx() is owned by ath6kl_control_tx().
Calling function should not free the skb for error cases.
This is found during code review.
kvalo: fix a checkpatch warning in ath6kl_wmi_cmd_send()
ath6kl was incorrectly assuming that IEEE80211_NUM_BANDS will always be 2
and used that also in the firmware WMI interface definitions. But after
the support for 60 GHz was added to cfg80211 IEEE80211_NUM_BANDS changed to 3
and this can cause all sort of problems, possibly even memory corruption.
I only found this during code review and didn't notice any bugs, but I'm
sure there are a few lurking somewhere.
To fix this rename unused A_NUM_BANDS to ATH6KL_NUM_BANDS, which is
always defined to be 2, and use that in WMI.
To make it possible to change the country code from user space via nl80211
add handler for reg_notifier. The feature is only enabled when built
time option CONFIG_ATH6KL_REGDOMAIN is enabled, which again depends on
CFG80211_CERTIFICATION_ONUS for certication purposes.
ATH6KL_FW_CAPABILITY_STA_P2PDEV_DUPLEX was checked in cfg80211.c which is
a bit awkward when adding more callsites to the scan functions. Refactor
the code to wmi.c so that it's transparent to the callers.
To make it easier to refactor the scan commands move
ath6kl_wmi_startscan_cmd() before the beginscan function. No functional
changes.
The ath6kl firmware can monitor a connection and report when a certain
TX failure threshold is crossed. Support this configuration and event
reporting on compatible firmwares.
The ath6kl firmware can filter scan results based on rssi. This is
useful to limit hosts wakeups on scheduled scans.
The management frame and remain-on-channel APIs will be
needed in the P2P device abstraction, so move them over
to the new wdev-based APIs. Userspace can still use both
the interface index and wdev identifier for them so it's
backward compatible, but for the P2P Device wdev it will
be able to use the wdev identifier only.
This patch adds support for dtim_period configuration in beacon.
kvalo: add a comment about ignoring the error, use vif_idx,
add \n to the warning message
Signed-off-by: Etay Luz <eluz@qca.qualcomm.com>
No need to clear requested memory after allocating new SKB
with help of ath6kl_wmi_get_new_buf(). This clear part is
already taken care in ath6kl_wmi_get_new_buf().
Tx legacy and mcs rateset can configured using iw for
2.4 and 5 bands. Add support for the same in driver.
kvalo: add an enum for the hw flags and rename the flag accordingly,
rename ath6kl_cfg80211_set_bitrate_mask() to a shorter version to make
it easier to indent
Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com>
Enable enhanced bmiss detection if the firmware supports it. This
feature is only enabled on some firmwares since it comes with a power
cost.
Also add a few missing command ids to keep the enums straight.
kvalo: fix a compiler with ath6kl_err(), add few empty lines
The currently used firmware images support 16 SSIDs in the scan
request (indexes 0..15), so update the host driver to use the same
limit to allow some more SSIDs to be scanned per request. In addition,
change the max-index to max-SSIDs to make it easier to understand the
implementation and fix couple of off-by-one checks that could limit
the maximum number of entries too strictly.
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
Send the EAPOL and management frames in the same AC_VO queue. The issue
happens when the AP supports QOS, the management frames are sent to AC_VO
queue and EAP frame goes to AC_BE queue. Even though the EAP frame is
queued before the DEAUTH management frame, as they are queued on different
h/w queues, order of delivery between these frames cannot be controlled.
This fixes the connection failure seen in P2P case.
Signed-off-by: Vivek Natarajan <nataraja@qca.qualcomm.com>
The patch "ath6kl: support fw reporting phy capabilities" gave the
firmware the ability to disable certain wiphy supported bands. Check if
this is the case in ath6kl_wmi_beginscan_cmd to avoid dereferencing a
NULL pointer.
kvalo: change the patch so that there's no code between declarations
Do not assume anyone before us includes it for us.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Currently the supported bands are just hard coded in the driver.
However, the ath6kl FW will include its 11n and band capabilites in a
WMI_READY event. Handle this and report capabilites to cfg80211
accordingly.
Found by checkpatch:
WARNING: quoted string split across lines
RSN capability field of RSN IE which is generated (which is what really
advertised in beacon/probe response) differs from the one generated in
wpa_supplicant. This inconsistency in rsn IE results in 4-way handshake
failure. To fix this, configure rsn capability used in wpa_supplicant
in firmware using a new wmi command, WMI_SET_IE_CMDID. There is a bit
(ATH6KL_FW_CAPABILITY_RSN_CAP_OVERRIDE) in fw_capabilities to advertise
this support to driver.
Signed-off-by: Subramania Sharma <sharmat@qca.qualcomm.com>
This patch disables HT in start_ap if the type of the channel on
which the AP mode is going to be operating is non-HT. HT is enabled
with default ht cap setting if the operating channel is going to be
11n.
Configure the inactivity timeout passed in start_ap() to
firmware. This capability is advertised only when fw supports
it, there is a new bit (ATH6KL_FW_CAPABILITY_INACTIVITY_TIMEOUT)
in firmware capability ie for driver to learn fw's capability.
After the fw finds out the station is inactive, it will probe
the station with null func frames. By default, the timeout is
10 secs.
This is useful during debugging to check if disconnect commands were issued by
the host.
Signed-off-by: Aarthi Thiruvengadam <athiruve@qca.qualcomm.com>
All found by checkpatch:
ath6kl/wmi.c:1036: CHECK: Logical continuations should be on the previous line
Fix the issues which checkpatch found and were easy to fix. Especially
callers of ath6kl_bmi_write() are tricky and that needs to be fixed
separately.
* In order to save the target power in WOW suspend state,
configure the best optimal values for the below parameters,
- listen interval.
- beacon miss interval.
- scan parameters.
Default values for above attributes are reverted in
wow resume operation.
* The default listen interval is set before the host issue
connect request.
* New function is added to configure beacon miss count.
kvalo: minor changes to fix open parenthesis alignment
Add the signal strength (in dBm only for now) to
frames that are received via nl80211's various
frame APIs.
Acked-by: Kalle Valo <kvalo@qca.qualcomm.com>
The ath6kl FW does not distinguish between different types of hidden
SSIDs (empty or null), so treat all cfg80211 requests for hidden ssid
the same.
As regulatory events are processed even before the wiphy is registered,
calling regulatory_hint() at early stage should be fixed.
Split the wmi event processing into the one which needs to be
vif specific and the reset. This is a step towards avoiding
the need for wiphy and a netdev registration before getting
any message from firmware.
PS buffering of unicast Action frames that are sent in a context
of a BSS. In AP mode when the recepient station goes to powersave
and PS_POLL flag is not set, we would buffer the frames. Send out
unicast mgmt bufferred frame when PS_POLL is received.
This fixes a bug in P2P GO behavior when sending a GO Discoverability
Request to a client that is in sleep mode.
kvalo: indentation fixes
Signed-off-by: Thirumalai Pachamuthu <tpachamu@qca.qualcomm.com>
Signed-off-by: Naveen Gangadharan <ngangadh@qca.qualcomm.com>
Update license header with the copyright to Qualcomm Atheros, Inc.
for the year 2011-2012.
For every WMI_SET_HOST_SLEEP_MODE_CMDID command (send from the host),
the firmware sends WMI_SET_HOST_SLEEP_MODE_CMD_PROCESSED_EVENTID as
an acknowledgement to the host.
In order to being sync with the firmware, the host has to wait for
WMI_SET_HOST_SLEEP_MODE_CMD_PROCESSED_EVENT event before going to
the suspend state. This patch ensures ath6kl_wow_suspend() waits
until it gets this event after sending set host sleep mode command.
This patch adds,
* New command WMI_SET_HOST_SLEEP_MODE_CMD_PROCESSED_EVENTID in
WMI event table.
* New WMI function ath6kl_wmi_host_sleep_mode_cmd_prcd_evt_rx()
to process the event.
* New flag HOST_SLEEP_MODE_CMD_PROCESSED in VIF flags to record
the arrival of the event.
First preference is given to the user configured WOW patterns.
If the user doesn't configure any patterns (for ex, via iw command),
the default patterns will be configured based on the current mode
(vif->nw_type) while going to WOW suspend.
Summary of changes:
* ath6kl_wow_ap() is added to configure the below default
patterns when the system enters into WOW suspend in AP mode.
+ Unicast IP, EAPOL-like and ARP packet pattern
+ ARP packet pattern
+ mDNS/SSDP/LLMNR pattern
+ DHCP broadcast pattern
* ath6kl_wow_sta() is added to configure the below default
patterns when the system enters into WOW suspend in STA mode.
+ Unicast packet pattern
* Move the user provided WOW patterns configuration code
from ath6kl_wow_suspend() to a separate function called
ath6kl_wow_usr().
* Two argument variable's ('filter' and 'mask) data type in
ath6kl_wmi_add_wow_pattern_cmd() are changed from 'u8 *' to
'const u8 *'. This is needed to make all pattern and mask
arrays to be 'static const u8' in the caller function.
* New conditional check is added to make sure user
configured pattern count is within the limit (WOW_MAX_FILTERS_PER_LIST).
We don't need it as debug calls already have a log level and compiler
should be smart enough to optimise away the code when ath6kl debug code
is not enabled. Also it makes it easier to abstract core code to
ath6kl_core.ko.
In ath6kl_dump_registers() I had to change the debug level from ANY to IRQ
as I removed the AR_DBG_LVL_CHECK() check before calling the function.
