commit 9e80ad37f6788ed52b89a3cfcd593e0aa69b216d upstream.
ath10k_mac_vif_chan() always returns an error for the given vif
during system-wide resume which reliably triggers two WARN_ON()s
in ath10k_bss_info_changed() and they are not particularly
useful in that code path, so drop them.
Tested: QCA6174 hw3.2 PCI with WLAN.RM.2.0-00180-QCARMSWPZ-1
Tested: QCA6174 hw3.2 SDIO with WLAN.RMH.4.4.1-00007-QCARMSWP-1
Fixes: cd93b83ad927 ("ath10k: support for multicast rate control")
Fixes: f279294e9ee2 ("ath10k: add support for configuring management packet rate")
Cc: stable@vger.kernel.org
Reviewed-by: Brian Norris <briannorris@chromium.org>
Tested-by: Brian Norris <briannorris@chromium.org>
Tested-by: Claire Chang <tientzu@chromium.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 1863008369ae0407508033b4b00f98b985adeb15 ]
WCN3990 supports shadow registers write operation support
for copy engine for regular operation in powersave mode.
Since WCN3990 is a 64-bit target, the shadow register
implementation needs to be done in the copy engine handlers
for 64-bit target. Currently the shadow register implementation
is present in the 32-bit target handlers of copy engine.
Fix the shadow register copy engine write operation
implementation for 64-bit target(WCN3990).
Tested HW: WCN3990
Tested FW: WLAN.HL.2.0-01188-QCAHLSWMTPLZ-1
Fixes: b7ba83f7c414 ("ath10k: add support for shadow register for WNC3990")
Signed-off-by: Rakesh Pillai <pillair@codeaurora.org>
[ Upstream commit 2bd345cd2bfc0bd44528896313c0b45f087bdf67 ]
Commit 2ea9f12cefe4 ("ath10k: add new cipher suite support") added a new
n_cipher_suites HW param with a fallback value and a warning log. Commit
03a72288c546 ("ath10k: wmi: add hw params entry for wcn3990") later
added WCN3990 HW entries, but it missed the n_cipher_suites.
Rather than seeing this warning every boot
ath10k_snoc 18800000.wifi: invalid hw_params.n_cipher_suites 0
let's provide the appropriate value.
Cc: Rakesh Pillai <pillair@qti.qualcomm.com>
Cc: Govind Singh <govinds@qti.qualcomm.com>
Signed-off-by: Brian Norris <briannorris@chromium.org>
[ Upstream commit 2d3b55853b123c177037cf534c5aaa2650310094 ]
There was a race condition in SMP that an ath10k_peer was created but its
member sta was null. Following are procedures of ath10k_peer creation and
member sta access in peer statistics path.
1. Peer creation:
ath10k_peer_create()
=>ath10k_wmi_peer_create()
=>ath10k_wait_for_peer_created()
# another kernel path, RX from firmware
ath10k_htt_t2h_msg_handler()
=>ath10k_peer_map_event()
=>wake_up()
# ar->peer_map[id] = peer //add peer to map
#wake up original path from waiting
# peer->sta = sta //sta assignment
2. RX path of statistics
=>ath10k_update_per_peer_tx_stats()
=>ath10k_htt_fetch_peer_stats()
# peer->sta //sta accessing
Any access of peer->sta after peer was added to peer_map but before sta was
assigned could cause a null pointer issue. And because these two steps are
asynchronous, no proper lock can protect them. So both peer and sta need to
be checked before access.
Tested: QCA9984 with firmware ver 10.4-3.9.0.1-00005
Signed-off-by: Zhi Chen <zhichen@codeaurora.org>
[ Upstream commit a9911937e7d332761e8c4fcbc7ba0426bdc3956f ]
When running in AP mode, ath10k sometimes suffers from TX credit
starvation. The issue is hard to reproduce and shows up once in a
few days, but has been repeatedly seen with QCA9882 and a large
range of firmwares, including 10.2.4.70.67.
Once the module is in this state, TX credits are never replenished,
which results in "SWBA overrun" errors, as no beacons can be sent.
Even worse, WMI commands run in a timeout while holding the conf
mutex for three seconds each, making any further operations slow
and the whole system unresponsive.
The firmware/driver never recovers from that state automatically,
and triggering TX flush or warm restarts won't work over WMI. So
issue a hardware restart if a WMI command times out due to missing
TX credits. This implies a connectivity outage of about 1.4s in AP
mode, but brings back the interface and the whole system to a usable
state. WMI command timeouts have not been seen in absent of this
specific issue, so taking such drastic actions seems legitimate.
Signed-off-by: Martin Willi <martin@strongswan.org>
[ Upstream commit 058a7eab9d9ee12f57282eb0b606668dada70d7a ]
The tx_status for management frames is being filled
incorrectly in the flags of skb_cb. This incorrect
flag setting causes the upper layers to consider that
the particular frame was not transmitted properly,
leading to improper behavior.
Set the IEEE80211_TX_STAT_ACK flag in the info flags
of skb_cb, to indicate the successful transmission of
the management frame.
Tested HW: WCN3990
Fixes: dc405152bb64d4ae01c9ac669de25b2d1fb6fc2d
The QCA4019 hw1.0 firmware 10.4-3.2.1-00050 and 10.4-3.5.3-00053 (and most
likely all other) seem to ignore the WMI_CHAN_FLAG_DFS flag during the
scan. This results in transmission (probe requests) on channels which are
not "available" for transmissions.
Since the firmware is closed source and nothing can be done from our side
to fix the problem in it, the driver has to work around this problem. The
WMI_CHAN_FLAG_PASSIVE seems to be interpreted by the firmware to not
scan actively on a channel unless an AP was detected on it. Simple probe
requests will then be transmitted by the STA on the channel.
ath10k must therefore also use this flag when it queues a radar channel for
scanning. This should reduce the chance of an active scan when the channel
might be "unusable" for transmissions.
Fixes: e8a50f8ba44b ("ath10k: introduce DFS implementation")
Signed-off-by: Sven Eckelmann <sven.eckelmann@openmesh.com>
These were recently introduced and found by checkpatch:
drivers/net/wireless/ath/ath10k/mac.c:6118: Alignment should match open parenthesis
drivers/net/wireless/ath/ath10k/mac.c:6121: Alignment should match open parenthesis
drivers/net/wireless/ath/ath10k/mac.c:6124: Alignment should match open parenthesis
Debugfs support to do hardware warm reset with WMI command
WMI_PDEV_PARAM_PDEV_RESET for 10.4 and 10.2.4(if wmi
service is enabled in the firmware for backward compatibility).
This change is purely for debugging purpose when hardware hangs/mutes.
This hardware reset won't affect the connectivity but there will be small
pause in data traffic. Here we are doing BB/MAC level reset and hence
whenever the BB/MAC watchdog is triggered, it does a hardware_chip_reset.
So the target will be in the active state.
Below command used to warm reset the hardware.
echo 1 > /sys/kernel/debug/ieee80211/phyX/ath10k/warm_hw_reset
Tested in QCA988X with firmware ver 10.2.4.70.45
Tested in QCA4019 with firmware ver 10.4-3.2.1.1-00011
Signed-off-by: Maharaja Kennadyrajan <mkenna@codeaurora.org>
This is only code refactoring as all call sites of
ath10k_htt_tx_alloc_msdu_id() take the same lock it can be moved into the
id_get function and the assertion dropped.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Pointers dev and noa are being assigned but are never used hence they
are redundant and can be removed.
Cleans up clang warnings:
warning: variable 'dev' set but not used [-Wunused-but-set-variable]
warning: variable 'noa' set but not used [-Wunused-but-set-variable]
WCN3990 transmits management frames via WMI
with reference. Currently, with the management
tx completion not being handled, these frames are
not getting freed even after the transmission status
is returned by the firmware.
The transmitted management frames should be freed
when the firmware sends the over-the-air tx status of
the corresponding management frames.
Handle the wmi mgmt tx completion event and free
the corresponding management frame.
Tested HW: WCN3990
The tx completion of multiple mgmt frames can be bundled
in a single event and sent by the firmware to host, if this
capability is not disabled explicitly by the host. If the host
cannot handle the bundled mgmt tx completion, this capability
support needs to be disabled in the wmi init cmd, sent to the firmware.
Add the host capability indication flag in the wmi ready command,
to let firmware know the features supported by the host driver.
This field is ignored if it is not supported by firmware.
Set the host capability indication flag(i.e. host_capab) to zero,
for disabling the support of bundle mgmt tx completion. This will
indicate the firmware to send completion event for every mgmt tx
completion, instead of bundling them together and sending in a single
event.
Tested HW: WCN3990
Signed-off-by: Surabhi Vishnoi <svishnoi@codeaurora.org>
Issues a wmi command to firmware when multicast rate change is received with the
new BSS_CHANGED_MCAST_RATE flag. Also fixes the incorrect fixed_rate setting
for CCK rates which got introduced with addition of ath10k_rates_rev2 enum.
Tested on QCA9984 with firmware ver 10.4-3.6-00104
Signed-off-by: Pradeep Kumar Chitrapu <pradeepc@codeaurora.org>
Fixes a recently added checkpatch warning:
wmi-tlv.c:2703: open brace '{' following function definitions go on the next line
ath.git patches for 4.19. Major changes:
wcn36xx
* fix WEP in client mode
wil6210
* add support for Talyn-MB (Talyn ver 2.0) device
* add support for enhanced DMA firmware feature
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
wireless-drivers-next patches for 4.19
The first set of patches for 4.19. Only smaller features and bug
fixes, not really anything major. Also included are changes to
include/linux/bitfield.h, we agreed with Johannes that it makes sense
to apply them via wireless-drivers-next.
Major changes:
ath10k
* support channel 173
* fix spectral scan for QCA9984 and QCA9888 chipsets
ath6kl
* add support for Dell Wireless 1537
ti wlcore
* add support for runtime PM
* enable runtime PM autosuspend support
qtnfmac
* support changing MAC address
* enable source MAC address randomization support
libertas
* fix suspend and resume for SDIO cards
mt76
* add software DFS radar pattern detector for mt76x2 based devices
Without this, packets larger than 1500 will silently be dropped.
Easily reproduced by sending a ping packet with a size larger
than 1500.
Co-Developed-by: Niklas Cassel <niklas.cassel@linaro.org>
Signed-off-by: Alagu Sankar <alagusankar@silex-india.com>
Signed-off-by: Niklas Cassel <niklas.cassel@linaro.org>
Without this, when receiving a packet that has this flag set
from firmware, we will read invalid trailer data from the packet,
which will be shown as various errors, e.g. "sdio mbox lookahead
is zero" or "invalid rx packet" or "payload length x exceeds max
htc length".
All packets in a bundle should use the same endpoint id as the
first lookahead.
This matches how things are done is ath6kl, however,
this patch can theoretically handle several bundles
in ath10k_sdio_mbox_rx_process_packets().
Without this patch we get lots of errors about invalid endpoint id:
ath10k_sdio mmc2:0001:1: invalid endpoint in look-ahead: 224
ath10k_sdio mmc2:0001:1: failed to get pending recv messages: -12
ath10k_sdio mmc2:0001:1: failed to process pending SDIO interrupts: -12
In our environment we are occasionally seeing the following stack trace
in ath10k:
Unable to handle kernel paging request at virtual address 0000a800
pgd = c0204000
[0000a800] *pgd=00000000
Internal error: Oops: 17 [#1] SMP ARM
Modules linked in: dwc3 dwc3_of_simple phy_qcom_dwc3 nf_nat xt_connmark
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.31 #2
Hardware name: Generic DT based system
task: c09f4f40 task.stack: c09ee000
PC is at kfree_skb_list+0x1c/0x2c
LR is at skb_release_data+0x6c/0x108
pc : [<c065dcc4>] lr : [<c065da5c>] psr: 200f0113
sp : c09efb68 ip : c09efb80 fp : c09efb7c
r10: 00000000 r9 : 00000000 r8 : 043fddd1
r7 : bf15d160 r6 : 00000000 r5 : d4ca2f00 r4 : ca7c6480
r3 : 000000a0 r2 : 01000000 r1 : c0a57470 r0 : 0000a800
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 10c5787d Table: 56e6006a DAC: 00000051
Process swapper/0 (pid: 0, stack limit = 0xc09ee210)
Stack: (0xc09efb68 to 0xc09f0000)
fb60: ca7c6480 d4ca2f00 c09efb9c c09efb80 c065da5c c065dcb4
fb80: d4ca2f00 00000000 dcbf8400 bf15d160 c09efbb4 c09efba0 c065db28 c065d9fc
fba0: d4ca2f00 00000000 c09efbcc c09efbb8 c065db48 c065db04 d4ca2f00 00000000
fbc0: c09efbe4 c09efbd0 c065ddd0 c065db38 d4ca2f00 00000000 c09efc64 c09efbe8
fbe0: bf09bd00 c065dd10 00000003 7fffffff c09efc24 dcbfc9c0 01200000 00000000
fc00: 00000000 00000000 ddb7e440 c09e9440 c09efc48 1d195000 c09efc7c c09efc28
fc20: c027bb68 c028aa00 ddb7e4f8 bf13231c ddb7e454 0004091f bf154571 d4ca2f00
fc40: dcbf8d00 ca7c5df6 bf154538 01200000 00000000 bf154538 c09efd1c c09efc68
fc60: bf132458 bf09bbbc ca7c5dec 00000041 bf154538 bf154539 000007bf bf154545
fc80: bf154538 bf154538 bf154538 bf154538 bf154538 00000000 00000000 000016c1
fca0: 00000001 c09efcb0 01200000 00000000 00000000 00000000 00000000 00000001
fcc0: bf154539 00000041 00000000 00000007 00000000 000000d0 ffffffff 3160ffff
fce0: 9ad93e97 3e973160 7bf09ad9 0004091f d4ca2f00 c09efdb0 dcbf94e8 00000000
fd00: dcbf8d00 01200000 00000000 dcbf8d00 c09efd44 c09efd20 bf132544 bf132130
fd20: dcbf8d00 00000000 d4ca2f00 c09efdb0 00000001 d4ca2f00 c09efdec c09efd48
fd40: bf133630 bf1324d0 ca7c5cc0 000007c0 c09efd88 c09efd70 c0764230 c02277d8
fd60: 200f0113 ffffffff dcbf94c8 bf000000 dcbf93b0 dcbf8d00 00000040 dcbf945c
fd80: dcbf94e8 00000000 c09efdcc 00000000 c09efd90 c09efd90 00000000 00000024
fda0: dcbf8d00 00000000 00000005 dcbf8d00 c09efdb0 c09efdb0 00000000 00000040
fdc0: c09efdec dcbf8d00 dcbfc9c0 c09ed140 00000040 00000000 00000100 00000040
fde0: c09efe14 c09efdf0 bf1739b4 bf132840 dcbfc9c0 ddb82140 c09ed140 1d195000
fe00: 00000001 00000100 c09efe64 c09efe18 c067136c bf173958 ddb7fac8 c09f0d00
fe20: 001df678 0000012c c09efe28 c09efe28 c09efe30 c09efe30 c0a7fb28 ffffe000
fe40: c09f008c 00000003 00000008 c0a598c0 00000100 c09f0080 c09efeb4 c09efe68
fe60: c02096e0 c0671278 c0494584 00000080 dd5c3300 c09f0d00 00000004 001df677
fe80: 0000000a 00200100 dd5c3300 00000000 00000000 c09eaa70 00000060 dd410800
fea0: c09ee000 00000000 c09efecc c09efeb8 c0227944 c02094c4 00000000 00000000
fec0: c09efef4 c09efed0 c0268b64 c02278ac de802000 c09f1b1c c09eff20 c0a16cc0
fee0: de803000 c09ee000 c09eff1c c09efef8 c020947c c0268ae0 c02103dc 600f0013
ff00: ffffffff c09eff54 ffffe000 c09ee000 c09eff7c c09eff20 c021448c c0209424
ff20: 00000001 00000000 00000000 c021ddc0 00000000 00000000 c09f1024 00000001
ff40: ffffe000 c09f1078 00000000 c09eff7c c09eff80 c09eff70 c02103ec c02103dc
ff60: 600f0013 ffffffff 00000051 00000000 c09eff8c c09eff80 c0763cc4 c02103bc
ff80: c09effa4 c09eff90 c025f0e4 c0763c98 c0a59040 c09f1000 c09effb4 c09effa8
ffa0: c075efe0 c025efd4 c09efff4 c09effb8 c097dcac c075ef7c ffffffff ffffffff
ffc0: 00000000 c097d6c4 00000000 c09c1a28 c0a59294 c09f101c c09c1a24 c09f61c0
ffe0: 4220406a 512f04d0 00000000 c09efff8 4220807c c097d95c 00000000 00000000
[<c065dcc4>] (kfree_skb_list) from [<c065da5c>] (skb_release_data+0x6c/0x108)
[<c065da5c>] (skb_release_data) from [<c065db28>] (skb_release_all+0x30/0x34)
[<c065db28>] (skb_release_all) from [<c065db48>] (__kfree_skb+0x1c/0x9c)
[<c065db48>] (__kfree_skb) from [<c065ddd0>] (consume_skb+0xcc/0xd8)
[<c065ddd0>] (consume_skb) from [<bf09bd00>] (ieee80211_rx_napi+0x150/0x82c [mac80211])
[<bf09bd00>] (ieee80211_rx_napi [mac80211]) from [<bf132458>] (ath10k_htt_t2h_msg_handler+0x15e8/0x19c4 [ath10k_core])
[<bf132458>] (ath10k_htt_t2h_msg_handler [ath10k_core]) from [<bf132544>] (ath10k_htt_t2h_msg_handler+0x16d4/0x19c4 [ath10k_core])
[<bf132544>] (ath10k_htt_t2h_msg_handler [ath10k_core]) from [<bf133630>] (ath10k_htt_txrx_compl_task+0xdfc/0x12cc [ath10k_core])
[<bf133630>] (ath10k_htt_txrx_compl_task [ath10k_core]) from [<bf1739b4>] (ath10k_pci_napi_poll+0x68/0xf4 [ath10k_pci])
[<bf1739b4>] (ath10k_pci_napi_poll [ath10k_pci]) from [<c067136c>] (net_rx_action+0x100/0x33c)
[<c067136c>] (net_rx_action) from [<c02096e0>] (__do_softirq+0x228/0x31c)
[<c02096e0>] (__do_softirq) from [<c0227944>] (irq_exit+0xa4/0x114)
The trace points to a corrupt skb inside kfree_skb(), seemingly because
one of the shared skb queues is getting corrupted. Most of the skb queues
ath10k uses are local to a single call stack, but three are shared among
multiple codepaths:
- rx_msdus_q,
- rx_in_ord_compl_q, and
- tx_fetch_ind_q
Of the three, the first two are manipulated using the unlocked skb_queue
functions without any additional lock protecting them. Use the locked
variants of skb_queue_* functions to protect these manipulations.
Signed-off-by: Bob Copeland <bobcopeland@fb.com>
The hardcoded values used in ath10k_mac_tx_push_pending and
ath10k_mac_op_wake_tx_queue set an upper limit of how many packets that
can be consumed from the TX queue.
HTC_HOST_MAX_MSG_PER_TX_BUNDLE is a proper name for this constant, as
the value effectively limits the number of messages that can be consumed
in one step. Thus, the value is an upper limit of the number of messages
that can be added to a TX message bundle.
Signed-off-by: Erik Stromdahl <erik.stromdahl@gmail.com>
This define is only used for RX bundling so it is more descriptive if
RX is added to the define-name.
Although the TID mask is 0xf, the modulus operation does still not
produce identical results as the bitwise and operator. If the TID is 15, the
modulus operation will "convert" it to 0, whereas the bitwise and will keep it
as 15.
This was found during code review.
While debugging driver crashes related to a buggy firmware
crashing under load, I noticed that ath10k_htt_rx_ring_free
could be called without being under lock. I'm not sure if this
is the root cause of the crash or not, but it seems prudent to
protect it.
Originally tested on 4.16+ kernel with ath10k-ct 10.4 firmware
running on 9984 NIC.
Signed-off-by: Ben Greear <greearb@candelatech.com>
When running iperf on ath10k SDIO, TX can stop working:
iperf -c 192.168.1.1 -i 1 -t 20 -w 10K
[ 3] 0.0- 1.0 sec 2.00 MBytes 16.8 Mbits/sec
[ 3] 1.0- 2.0 sec 3.12 MBytes 26.2 Mbits/sec
[ 3] 2.0- 3.0 sec 3.25 MBytes 27.3 Mbits/sec
[ 3] 3.0- 4.0 sec 655 KBytes 5.36 Mbits/sec
[ 3] 4.0- 5.0 sec 0.00 Bytes 0.00 bits/sec
[ 3] 5.0- 6.0 sec 0.00 Bytes 0.00 bits/sec
[ 3] 6.0- 7.0 sec 0.00 Bytes 0.00 bits/sec
[ 3] 7.0- 8.0 sec 0.00 Bytes 0.00 bits/sec
[ 3] 8.0- 9.0 sec 0.00 Bytes 0.00 bits/sec
[ 3] 9.0-10.0 sec 0.00 Bytes 0.00 bits/sec
[ 3] 0.0-10.3 sec 9.01 MBytes 7.32 Mbits/sec
There are frames in the ieee80211_txq and there are frames that have
been removed from from this queue, but haven't yet been sent on the wire
(num_pending_tx).
When num_pending_tx reaches max_num_pending_tx, we will stop the queues
by calling ieee80211_stop_queues().
As frames that have previously been sent for transmission
(num_pending_tx) are completed, we will decrease num_pending_tx and wake
the queues by calling ieee80211_wake_queue(). ieee80211_wake_queue()
does not call wake_tx_queue, so we might still have frames in the
queue at this point.
While the queues were stopped, the socket buffer might have filled up,
and in order for user space to write more, we need to free the frames
in the queue, since they are accounted to the socket. In order to free
them, we first need to transmit them.
This problem cannot be reproduced on low-latency devices, e.g. pci,
since they call ath10k_mac_tx_push_pending() from
ath10k_htt_txrx_compl_task(). ath10k_htt_txrx_compl_task() is not called
on high-latency devices.
Fix the problem by calling ath10k_mac_tx_push_pending(), after
processing rx packets, just like for low-latency devices, also in the
SDIO case. Since we are calling ath10k_mac_tx_push_pending() directly,
we also need to export it.
The 5ghz channel parameters of TLV target wasn't passed to host, it caused
host can only use lower channels from 36 to 64.
Length of WMI scan message was not calculated correctly. The allocated
buffer was smaller than what we expected. So WMI message corrupted
skb_info, which is at the end of skb->data. This fix takes TLV header
into account even if the element is zero-length.
Crash log:
[49.629986] Unhandled kernel unaligned access[#1]:
[49.634932] CPU: 0 PID: 1176 Comm: logd Not tainted 4.4.60 #180
[49.641040] task: 83051460 ti: 8329c000 task.ti: 8329c000
[49.646608] $ 0 : 00000000 00000001 80984a80 00000000
[49.652038] $ 4 : 45259e89 8046d484 8046df30 8024ba70
[49.657468] $ 8 : 00000000 804cc4c0 00000001 20306320
[49.662898] $12 : 33322037 000110f2 00000000 31203930
[49.668327] $16 : 82792b40 80984a80 00000001 804207fc
[49.673757] $20 : 00000000 0000012c 00000040 80470000
[49.679186] $24 : 00000000 8024af7c
[49.684617] $28 : 8329c000 8329db88 00000001 802c58d0
[49.690046] Hi : 00000000
[49.693022] Lo : 453c0000
[49.696013] epc : 800efae4 put_page+0x0/0x58
[49.700615] ra : 802c58d0 skb_release_data+0x148/0x1d4
[49.706184] Status: 1000fc03 KERNEL EXL IE
[49.710531] Cause : 00800010 (ExcCode 04)
[49.714669] BadVA : 45259e89
[49.717644] PrId : 00019374 (MIPS 24Kc)
In the case of Station connects to AP with narrower bandwidth at beginning.
And later the AP changes the bandwidth to winder bandwidth, the AP will
beacon with wider bandwidth IE, eg VHT20->VHT40->VHT80 or VHT40->VHT80.
Since the supported BANDWIDTH will be limited by the PHYMODE, so while
Station receives the bandwidth change request, it will also need to
reconfigure the PHYMODE setting to firmware instead of just configuring
the BANDWIDTH info, otherwise it'll trigger a firmware crash with
non-support bandwidth.
The issue was observed in WLAN.RM.4.4.1-00051-QCARMSWP-1, QCA6174 with
below scenario:
AP xxx changed bandwidth, new config is 5200 MHz, width 2 (5190/0 MHz)
disconnect from AP xxx for new auth to yyy
RX ReassocResp from xxx (capab=0x1111 status=0 aid=102)
associated
AP xxx changed bandwidth, new config is 5200 MHz, width 3 (5210/0 MHz)
firmware register dump:
[00]: 0x05030000 0x000015B3 0x00987291 0x00955B31
[04]: 0x00987291 0x00060730 0x00000004 0x00000001
[08]: 0x004089F0 0x00955A00 0x000A0B00 0x00400000
[12]: 0x00000009 0x00000000 0x00952CD0 0x00952CE6
[16]: 0x00952CC4 0x0098E25F 0x00000000 0x0091080D
[20]: 0x40987291 0x0040E7A8 0x00000000 0x0041EE3C
[24]: 0x809ABF05 0x0040E808 0x00000000 0xC0987291
[28]: 0x809A650C 0x0040E948 0x0041FE40 0x004345C4
[32]: 0x809A5C63 0x0040E988 0x0040E9AC 0x0042D1A8
[36]: 0x8091D252 0x0040E9A8 0x00000002 0x00000001
[40]: 0x809FDA9D 0x0040EA58 0x0043D554 0x0042D554
[44]: 0x809F8B22 0x0040EA78 0x0043D554 0x00000001
[48]: 0x80911210 0x0040EAC8 0x00000010 0x004041D0
[52]: 0x80911154 0x0040EB28 0x00400000 0x00000000
[56]: 0x8091122D 0x0040EB48 0x00000000 0x00400600
Reported-by: Rouven Czerwinski <rouven@czerwinskis.de>
Tested-by: Timur Kristóf <timur.kristof@gmail.com>
Signed-off-by: Ryan Hsu <ryanhsu@codeaurora.org>
The BIT macro uses unsigned long which some architectures handle as 32 bit
and therefore might cause macro's shift to overflow when used on a value
equals or larger than 32 (NL80211_STA_INFO_RX_DURATION and afterwards).
Since 'filled' member in station_info changed to u64, BIT_ULL macro
should be used with all NL80211_STA_INFO_* attribute types instead of BIT
to prevent future possible bugs when one will use BIT macro for higher
attributes by mistake.
This commit cleans up all usages of BIT macro with the above field
in wireless-drivers by changing it to BIT_ULL instead. In addition, there are
some places which don't use BIT nor BIT_ULL macros so align those as well.
Signed-off-by: Omer Efrat <omer.efrat@tandemg.com>
ath10k
ath6kl
Return type of resource init method is not assigned.
Handle resource init failures for graceful exit.
Signed-off-by: Govind Singh <govinds@codeaurora.org>
In non-bmi target ex. WCN3990, data calibration
is handled via QMI.
Skip data calibration in debug routine to enable ath10k
debugfs for non bmi targets.
Do not mix spaces and tabs in Kconfig.
Sort these alphabetically, with local includes in a separate section.
We started using a common CE_ATTR_FLAGS definition, so drop this one.
It's easier to violate abstractions and introduce bugs when snoc.h is
including pci.h. Let's not do that.
I'm not extremely familiar with this driver yet, but several of the
shared PCI/SNOC bits seem to be related to the Copy Engine, so move them
to ce.h.
We're 'ath10k_snoc', not 'ath10k_pci'. This probably means we're
accessing junk data in ath10k_snoc_rx_replenish_retry(), unless
'ath10k_snoc' and 'ath10k_pci' happen to have very similar struct
layouts.
Noticed by inspection.
Fixes: d915105231ca ("ath10k: add hif rx methods for wcn3990")
ath10k_snoc_init()/ath10k_snoc_exit() don't add much value;
module_platform_driver() can remove the boilerplate.
The comments are telling you what the enum could tell you instead.
Use dma_zalloc_coherent instead of dma_alloc_coherent
followed by memset 0.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
sizeof(struct ce_desc) should be a copy-paste mistake
just use sizeof(struct ce_desc_64) to avoid mem leak
Fixes the following sparse warnings:
drivers/net/wireless/ath/ath10k/snoc.c:823:5: warning:
symbol 'ath10k_snoc_get_ce_id_from_irq' was not declared. Should it be static?
drivers/net/wireless/ath/ath10k/snoc.c:871:6: warning:
symbol 'ath10k_snoc_init_napi' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
The spectral scan has been always broken on QCA9984 and QCA9888.
Introduce a hardware parameter 'spectral_bin_offset' to resolve this issue for
QCA9984 and QCA9888 chipsets. For other chipsets, the hardware parameter
'spectral_bin_offset' is zero so that existing behaviour is retained as it is.
In QCA9984 and QCA9888 chipsets, hardware param value 'spectral_bin_discard'
is 12 bytes. This 12 bytes is derived as the sum of segment index (4 bytes),
extra bins before the actual data (4 bytes) and extra bins after the actual
data (4 bytes). Always discarding (12 bytes) happens at end of the samples and
incorrect samples got dumped, so that user can find incorrect arrangement
samples in spectral scan dump.
To fix this issue, we have to discard first 8 bytes and last 4 bytes in every
samples, so totally 12 bytes are discarded. In every sample we need to consider
the offset while taking the actual spectral data. For QCA9984, QCA9888 the
offset is 8 bytes (segment index + extra bins before actual data).
Hardware tested: QCA9984 and QCA9888
Firmware tested: 10.4-3.5.3-00053
Signed-off-by: Karthikeyan Periyasamy <periyasa@codeaurora.org>
The India regulatory domain allows CH 173, so add that to the
available channel list. I verified basic connectivity between
a 9880 and 9984 NIC.
Currently tpc_stats is allocated and is leaked on the return
path if num_tx_chain is greater than WMI_TPC_TX_N_CHAIN. Avoid
this leak by performing the check on num_tx_chain before the
allocation of tpc_stats.
Detected by CoverityScan, CID#1469422 ("Resource Leak")
Fixes: 4b190675ad06 ("ath10k: fix kernel panic while reading tpc_stats")
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Notice that in this particular case, I replaced "pass through" with
a proper "fall through" comment, which is what GCC is expecting
to find.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
In the 10.4-3.6 firmware branch there's a new DFS Host confirmation
feature which is advertised using WMI_SERVICE_HOST_DFS_CHECK_SUPPORT flag.
This new features enables the ath10k host to send information to the
firmware on the specifications of detected radar type. This allows the
firmware to validate if the host's radar pattern detector unit is
operational and check if the radar information shared by host matches
the radar pulses sent as phy error events from firmware. If the check
fails the firmware won't allow use of DFS channels on AP mode when using
FCC regulatory region.
Hence this patch is mandatory when using a firmware from 10.4-3.6 branch.
Else, DFS channels on FCC regions cannot be used.
Supported Chipsets : QCA9984/QCA9888/QCA4019
Firmware Version : 10.4-3.6-00104
Signed-off-by: Sriram R <srirrama@codeaurora.org>
